查看: 394|回复: 4
Synthesiable High Performance SDRAM Contoller
发表于 2016-6-12 10:59 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
Synthesiable High PeRFormance SDRAM Contoller
. v1 n: Z' G; G& f! w; d. G' ^( |# _6 m7 E) X8 m4 C0 D
9 q- j  ^% B3 U; t+ b9 p4 F) kSynchronous DRAMs are available in speed grades above 100 MHz using LVTTL I/Os. The% J; A$ H! O6 H6 K$ ?1 J  y
Virtex? series of FPGAs and the Spartan?-II family of FPGAs have many features, such as- q7 D6 Q& y! c- B6 S4 W+ A1 O6 o
SelectI/O? resource and the Clock Delay Lock Loop, that make it easy to interface to high
2 H  j, V# X# B, ~0 k! dspeed Synchronous DRAMs. This application note describes the design and implementation of
% `) _! G$ N/ f5 K; k& w0 aa synthesizable, parameterizable, flexible, auto-placed-and-routed synchronous DRAM
' y, h2 r9 y) dcontroller in the Virtex FPGA family. The design can also be implemented with a Spartan-II
4 B# K5 w! Y" @; M! t) sdevice. A 32-bit wide data interface version can run up to 125 MHz when automatically placed: N" E, f( \( F5 L( R* ?8 S# y
and routed in a Virtex -6 speed grade device. Hand placed versions of the design can run even
7 e( S2 Z# a7 G! K5 H/ B0 Mfaster.
UL5Vy8Tu.pdf
103.42 KB, 下载次数: 1, 下载积分: 威望 -5
发表于 2016-9-7 14:11 | 只看该作者
学习中,谢谢分享) }$ n$ i. v/ K$ z* H( ^
发表于 2016-9-7 14:09 | 只看该作者
谢谢分享,必须赞一个~3 Y1 G( G. C7 d& O
发表于 2016-9-7 14:04 | 只看该作者
学习中,谢谢分享. y2 A5 v5 n9 K
发表于 2016-6-13 15:22 | 只看该作者
确实不错,推荐下载& q. F: y( W% w9 {! Y
GMT+8, 2025-11-24 00:23 , Processed in 0.140625 second(s), 27 queries , Gzip On.
