- l' Y1 K, k3 S8 \ \" J
VREF is not a high current supply, but it is important to keep it as quiet as possible with minimal inductance. The minimum nominal trace width for VREF is 20 mils. Necking down VREF to accommodate BGA escape and localized via congestion is acceptable, but care should be taken to keep VREF 20 mils wide as much as possible. VREF is a DC net and as such, trace delay is not critical, however, overall trace length should be kept to a minimum.
