查看: 3615|回复: 5
ORCAD CAPTURE输出网表导入PADS LAYOUT的问题
发表于 2008-8-20 10:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用的PCB软件是pads2007,用orcad CAPTURE CIS 10.5导出asc格式的网络表(如下图),出现如下问题,是什么原因呢?Unspecified or unsupported version of ASCII file是什么意思呢?怎样解决??我是新手,望讲解的详细一点
- F' y( r$ ]) N+ E" rReading file --  C:\Documents and Settings\Administrator\桌面\PERIPHERY.asc
7 Z9 B( J' u* X*Unspecified or unsupported version of ASCII file( c6 g/ O3 n+ X$ Z, o5 Q, {& n
*PADS-PCB*& J& c5 X; _6 ^$ i  ]% _/ t
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CONN/GPC0
( `% }7 t& X, J! `+ o/ f*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CONN/GPA16) b  ]. o8 D; q. C1 n% l
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CONN/GPA13
4 u$ M( A4 {( K. F) P# l*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CONN/GPA15* a2 y* y, t4 T9 E( e8 ^
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CONN/GPA12
. L9 {* i8 e, a& m, V+ t$ V# o*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CONN/GPC6+ F' `/ u; A3 G+ A; C# o; r: p
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CONN/GPC7- h; {2 _' B# b7 g, ^5 V* I
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CONN/GPC5
2 @6 [3 m: G  a: K4 q' l1 dWarning: deleting signal CONN/GPC09 q+ {' Z9 ~3 Q7 @6 b. [1 W
Warning: deleting signal CONN/GPA16, w$ B! z: D; d" c
Warning: deleting signal CONN/GPA13, H* X8 Q) J1 d5 \7 B- G5 j7 l
Warning: deleting signal CONN/GPA15
; I& M6 G6 Q, f% SWarning: deleting signal CONN/GPA12: ^2 s' q9 w9 Q* j
Warning: deleting signal CONN/GPC65 x& s, j) r9 ]. P" J  y
Warning: deleting signal CONN/GPC72 m5 e* v' M/ U* M2 J( Q
Warning: deleting signal CONN/GPC51 w* M9 o# J+ T/ _9 q/ r1 e
**INPUT WARNINGS FOUND**
发表于 2008-8-20 16:33 | 只看该作者
我也遇到这些问题了,丢失了不少的飞线,要是解决了,顺便告诉我一下
 楼主| 发表于 2008-8-20 17:48 | 只看该作者
Unspecified or unsupported version of ASCII file这句话代表什么?应该怎样解决??
    2021-8-25 15:10
    发表于 2008-9-8 10:40 | 只看该作者
    意思是说你的网络标号只有一个,当然有错了,两线要连接至少也要两个一样的网络标号.好好检查一下原图中网络,是不是只有一个.若上面的改好了,下面的也不会有这样的提示了
    ! O' ?1 g2 r$ h; _$ N- `, ~4 }! @9 n
    [ 本帖最后由 fee110 于 2008-9-8 10:41 编辑 ]
    发表于 2011-11-11 13:36 | 只看该作者
    !PADS-POWERPCB-V2005.0-BASIC! DESIGN DATABASE ASCII FILE 1.0
    % J3 W+ C: J) W: E& a" z2 F  q6 l) S*PADS2000*6 d# d1 O8 e1 w4 D
    *PART** S4 p4 V5 L" r
    发表于 2011-11-16 17:25 | 只看该作者
    顶一顶
    GMT+8, 2025-7-18 21:54 , Processed in 0.140625 second(s), 27 queries , Gzip On.
