Fixed in PADS 9.5 Update 1$ y. r0 ^" s9 l6 u3 r- H4 B: c
DxDesigner
0 |& D* `$ e& [- Z DR 941866 - Customer observes that when fonts are exported to hpgl file the text is not , T2 n+ h2 k. U y1 N- H9 S
WYSIWYG
1 d0 \) g9 l( P$ ?' o5 B8 ~, x DR 941870 - HPGL data exported from a DxDesigner sheet is not the correct size
& s; `' v7 ]0 i9 O& s DR 941875 - Mapped fonts don't zoom properly
I8 B* _2 P) {* W U$ h DR 941879 - The translator simultaneously migrates schematic symbols locally in the
( {; o. Z& q" ]% L. vdesign and into the Central Library
3 B: D3 Y, z+ w {! m DR 941881 - Text origin is not changed when Scout is run
7 |) I$ \& S3 A- \5 w/ f DR 941882 - Need to increment the DxD application version string' S" L G1 J8 a, t( P
DR 941883 - Symbol_Swap Groups data is incorrect in created PDB+ q9 C9 e( L5 P( O3 Z* ` C
DR 941884 - Translated design is losing global net name when pins are on top of one 1 Y! c Z& s6 g
another, Q5 g% N; {! [+ _7 o
DR 941885 - Schematic instances have pin number duplication; Packager failed
7 M3 z; S8 ], l7 `# M1 h! @6 tHyperLynx Analog
2 v' B5 W0 g) ?5 b DR 941871 - Update Simulation Model does not support symbol version properly
# I5 Q" y3 r% o1 \9 y: x- O DR 941873 - Ability to associate a local model to several components at a time1 y7 {# q8 |9 Y0 X
iCDB6 l/ g. p% A: h G+ I6 Z3 S
DR 926341 - Error while creating new project using RSCM server
: E& J$ L2 W2 _9 W# I, r DR 926705 - Scout removes nets and components in PADS 9.5: s! _4 x! Y& m
PADS Layout2 j) F9 m. X- H1 Y+ L4 J2 Z9 n
DR 924209 - Changing ref des font on Chinese install of PADS 9.5 results in a crash% r& q( X" _0 G3 g( A+ G
ODB++9 ?2 @, j% t6 C: r
DR 916783 - ODB++ export is combining different sized slots.
& j' D3 C% U# ^/ g DR 922608 - ODB++ output is combining slotted drill sizes with regular, circular drill
! {0 |) g+ K0 K$ Csizes in the drill chart
' w5 ]- L+ _# \1 `7 P0 H$ ^/ O DR 916779 - ODB++ export isn't creating the 'THRU/PRTL' column in the drill tablePADS 9.5 Update 1 Release Notes 34 p/ \/ j7 `: O8 @; {
May 2013
; n0 v' g* Y$ ?4 T2 O o/ i7 c DR 916785 - ODB++ export puts a drill marker (symbol) at the center of a slot but
* i6 J7 c$ D. X2 O8 {Gerber places 2 markers, one at each end.
3 v8 _, F* j9 L, i9 ~ DR 918290 - ODB++ shows trace passing through annular ring pad creating short
# n* R1 V! ?# H3 S M DR 932145 - vSure Main Application has stopped working when component on the % p) [2 _6 A% S& s
bottom side has 151 or more pins associated with copper |
