查看: 3125|回复: 1
AD 10 PCB能转 PADS 9.3吗?
发表于 2013-2-25 11:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在论坛里下了AD的PCB文件,有的能转到pads PCB中,只是有一些错误,但有的根本就转不了,在网上找了个资料说是要用PADS转换软件,在开始里面找转换软件,我的是WIN7的,里面根本就没有转换软件,请知道的大师们不吝赐教。
 楼主| 发表于 2013-2-25 11:54 | 只看该作者
导过去记事本提示问题如下:! H- x5 b1 B- d5 v- t
PADS Layout Translator (Version 9.0) 02/25/13 11:53:43
5 A, B4 t/ |* qCopyright (c) 2009 Mentor Graphics Corp. - All rights reserved$ G7 n) Q* f9 q$ V
1 q% I6 D' j1 N* ?  n; K------------------------------------------------------------
" M, C# I" K3 v5 J8 h4 \Input file: D:\TDDOWNLOAD\pcb2.PCBDOC, n4 r* W1 U. x( q+ s) Q
File size: 10748 Kb
# b+ B+ n% u+ j$ w1 [3 hFile type: Protel PCB Binary Design, `, \# |; Z$ i2 @' p; ^/ ?. L1 j
File version: 6.0
5 i6 M8 o3 A/ u( `2 m6 t) j7 SOutput file: .\pcb2_pads.pcb
: }+ s. ~+ J) w2 C. K; f. l0 Z$ F3 W5 t5 a# L$ G
[W] Cannot find the Protel configuration file 'C:\Users\ASUS\AppData\Roaming\Altium\advpcb.ini'. Using Protel Classic Colors for layers.
7 \% P6 h* i8 v# s  }( R) D1 p, N[W] Cannot load the current color map from the PADS Layout configuration file. Using default colors.
+ [. [: S4 `+ p[W] Ignored DXP rule scope whose functions, properties, or operators are not supported: Inpoly& ~: q1 E+ S# P  O$ a7 a) L' I) `- z
[I] Protel rule type is not supported in PADS Layout. Rule type ignored: Testpoint of kind FabricationTestpoint
- r+ |9 @; v$ V1 m* l# a[I] Protel rule type is not supported in PADS Layout. Rule type ignored: Fanout_Small of kind FanoutControl( ~4 p- x  _: \$ F+ p
[I] Protel rule type is not supported in PADS Layout. Rule type ignored: Fanout_SOIC of kind FanoutControl: U* U5 k8 ?. J3 T+ y5 g
[I] Protel rule type is not supported in PADS Layout. Rule type ignored: Fanout_LCC of kind FanoutControl  u0 I$ B6 V' r- V7 j' o2 E, ^
[I] Protel rule type is not supported in PADS Layout. Rule type ignored: Fanout_BGA of kind FanoutControl4 v# {( b) i5 K: q8 }2 f' e
[I] Protel rule type is not supported in PADS Layout. Rule type ignored: Power Plane Connect Style - pads with no thermal of kind PlaneConnect
5 c5 ?- v/ W: G' P& O4 K[I] Protel rule type is not supported in PADS Layout. Rule type ignored: Power Plane Connect Style for CN12-1 of kind PlaneConnect
' @! ~  U4 N5 G! X[I] Protel rule type is not supported in PADS Layout. Rule type ignored: Power Plane Connect Style for CN2-1 of kind PlaneConnect( W( n) @) i; g$ R" y) X3 H/ t
[I] Protel rule type is not supported in PADS Layout. Rule type ignored: Power Plane Connect Style for CN2-2 of kind PlaneConnect* O; J+ j& p+ N, w# ^
[I] Protel rule type is not supported in PADS Layout. Rule type ignored: Power Plane Connect Style for CN31-1 of kind PlaneConnect8 |( f# [2 S/ [; t  m* n8 k' j
[W] Ignored DXP rule scope whose functions, properties, or operators are not supported: Name
! l& ?$ `) {, g7 O. |" @[W] Ignored DXP rule scope whose expressions are illegal or not supported: Name='CN31-1'
5 l/ u4 H/ ^# t; c3 ~[W] Ignored DXP rule scope whose expressions are illegal or not supported: Name='CN31-2'
# ^1 h8 W1 V3 v/ p$ h& [$ {[W] Ignored DXP rule scope whose expressions are illegal or not supported: Name='CN31-3'. k- G9 Y$ L8 F7 D1 I* Z
[I] Protel rule type is not supported in PADS Layout. Rule type ignored: Power Plane Connect Style for CN6-1 of kind PlaneConnect
  [# A& s* B+ }9 _4 @[I] Protel rule type is not supported in PADS Layout. Rule type ignored: Power Plane Connect Style - pads with no thermal_35 of kind PlaneConnect: z( {0 a; q1 e" _: t6 F1 r
[I] Protel rule type is not supported in PADS Layout. Rule type ignored: Power Plane Connect Style for JP3-1 of kind PlaneConnect9 q3 e9 e$ ^" s9 P& L: w
[I] Protel rule type is not supported in PADS Layout. Rule type ignored: Power Plane Connect Style for JP4-1 of kind PlaneConnect
6 R5 V2 G4 f4 f; I[W] Ignored DXP rule scope whose functions, properties, or operators are not supported: InDifferentialPair
3 Z: w6 T8 h: `+ ~' B- n- `7 C0 {[W] Ignored DXP rule scope whose expressions are illegal or not supported: 'InDifferentialPair ('DPTX_L3')' of rule DiffPair_MatchedLengths_4
) A, T( @" u4 c$ S% D. k& r[W] Ignored DXP rule scope whose expressions are illegal or not supported: 'InDifferentialPair ('DPTX_L2')' of rule DiffPair_MatchedLengths_3
+ D% h* v) |, l- x1 E[W] Ignored DXP rule scope whose expressions are illegal or not supported: 'InDifferentialPair ('DPTX_L1')' of rule DiffPair_MatchedLengths_2% |$ |# I" K5 m& J
[W] Ignored DXP rule scope whose expressions are illegal or not supported: 'InDifferentialPair ('DPTX_L0')' of rule DiffPair_MatchedLengths_1
, Z+ ~$ Q+ B) r( D5 t/ z0 L4 x" T[W] Ignored DXP rule scope whose expressions are illegal or not supported: 'InDifferentialPair ('DPTXAU')' of rule DiffPair_MatchedLengths0 `1 Q6 M& S$ j3 t5 B( B3 p+ {3 B
[W] PADS Layout can not handle individual settings (Remove dead copper) for polygon planes at (-137.01, -185.802) on VCC4 y, _$ E8 U* p+ a6 K' l( k
[W] PADS Layout can not handle individual settings (Remove dead copper) for polygon planes at (-2078.05, -1225.3) on VCC. l7 I! P" E6 }  [2 t' `
[W] PADS Layout can not handle individual settings (Remove dead copper) for polygon planes at (-3153.13, -229.077) on VCC
' I7 h0 ^# O1 ]: R3 @[W] PADS Layout can not handle individual settings (Remove dead copper) for polygon planes at (3553.31, 1281.5) on VCC4 l2 q- A- e3 L+ M- Z( K
[W] PADS Layout can not handle individual settings (Remove dead copper) for polygon planes at (740.85, 512.732) on VCC
: X0 F8 g- I- @; C9 f[W] PADS Layout can not handle individual settings (Remove dead copper) for polygon planes at (1416.26, -225) on VCC+ X" t, |5 Q8 [4 A$ H+ _
[W] PADS Layout can not handle individual settings (Remove dead copper) for polygon planes at (-2495.91, -117.992) on VCC/ K+ e) A- H1 U# W
[W] PADS Layout can not handle individual settings (Remove dead copper) for polygon planes at (-1902.56, 906.725) on VCC5 B0 t) U* U6 o- U# z3 B3 i: D9 E
[W] PADS Layout can not handle individual settings (Remove dead copper) for polygon planes at (5221.67, 1679.43) on GND6 [  b3 O1 [7 L! I
[E] Polygon contours are not expandable. Polygons are translated as 2D lines at (5221.67, 1679.43) on GND
' @& n" N1 E2 Y6 C[W] PADS Layout can not handle individual settings (Remove dead copper) for polygon planes at (5306.1, 1796.96) on Top0 J$ r# r: H0 N$ C. u
[W] PADS Layout can not handle individual settings (Remove dead copper) for polygon planes at (-4399.45, 1699.86) on Bottom
- |. D/ D; b7 z) ~5 f$ g[I] Renamed pattern name to uppercase letters: PCBComponent_1 renamed PCBCOMPONENT_13 A; c& t: ]/ [: ^8 S
[W] Renamed symbols with the same pattern: PCBCOMPONENT_1 renamed PCBCOMPONENT_1/2; P! D/ ?0 f. v
[W] Renamed symbols with the same pattern: PCBCOMPONENT_1 renamed PCBCOMPONENT_1/3
  S5 V8 @/ Q( M/ Y8 `' ][W] Renamed components with duplicate names: C7 renamed C7/2/ \( s  A) o: g2 d4 k
[W] Renamed symbols with the same pattern: 0603C renamed 0603C/2! Q6 r. a/ s3 r: n2 K
[W] Renamed components with duplicate names: C8 renamed C8/22 Y3 A+ ^1 @8 A+ @) P
[I] Renamed device name to uppercase letters: 1000uF/16V renamed 1000UF/16V9 M& E  Z- \4 j8 B- o/ H# j
[W] Renamed components with duplicate names: U6 renamed U6/2
2 x- n! P% N8 s$ e[W] Renamed incorrect device name: TOROID IRON_1 renamed TOROID_IRON_1
7 |4 F" x) ?3 G7 X" V[W] Renamed symbols with the same pattern: 0603C renamed 0603C/3, x8 Z! E, j" g: }
[I] Renamed device name to uppercase letters: CAP NP_Dup2 renamed CAP NP_DUP2
6 G5 m6 a1 d1 J4 W$ E[W] Renamed incorrect device name: CAP NP_DUP2 renamed CAP_NP_DUP2
+ y& y" r: I9 S8 T% l9 e) v- `[W] Renamed components with duplicate names: C34 renamed C34/27 w  K8 C' f- }' b" _
[W] Renamed components with duplicate names: C33 renamed C33/2% [4 j& s/ Y0 v
[W] Renamed symbols with the same pattern: 0603C renamed 0603C/4
3 G) ]: [1 d; |! U8 @, v( h8 N[W] Renamed symbols with the same device name: CAP_NP_DUP2 renamed CAP_NP_DUP2/2
4 ^5 K! e! F. N5 Y& ][W] Renamed components with duplicate names: C29 renamed C29/2+ L" e/ G' ^1 P6 j0 W9 k
[W] Renamed components with duplicate names: C28 renamed C28/2$ c" V4 Y0 f! q* T7 B' w
[W] Renamed symbols with the same pattern: 0603C renamed 0603C/5
* o( l. h: s% m% l: C- y8 s/ H[W] Renamed symbols with the same device name: CAP_NP_DUP2 renamed CAP_NP_DUP2/3
9 _/ q3 y  V! B! g; C0 [) I[W] Renamed components with duplicate names: C27 renamed C27/2( s8 f: A9 p9 H4 x2 b
[W] Renamed symbols with the same pattern: R0603 renamed R0603/2( E/ q/ q) [: Y& ]' O
[W] Renamed components with duplicate names: R80 renamed R80/2
) N- M* [( W0 a$ o[W] Renamed components with duplicate names: R79 renamed R79/23 A1 v) n. t$ U2 u% m7 I
[W] Renamed components with duplicate names: R78 renamed R78/2
) ?* {% p( r6 u  d[W] Renamed components with duplicate names: L2 renamed L2/2
, ?, {3 |0 S/ i; T7 ~% b4 T8 q2 f[W] Renamed components with duplicate names: C125 renamed C125/2( T' D  n5 Y( B" G5 M/ U
[W] Renamed components with duplicate names: C124 renamed C124/2
- r( E# E% E( [3 G/ O4 L[W] Renamed components with duplicate names: C123 renamed C123/2
% C. P* c. p8 g, F( ~+ `/ p: z[W] Renamed components with duplicate names: C122 renamed C122/2
4 w; I& q2 b3 S: w0 R: ]" }, Q1 U9 [[W] Renamed incorrect device name: 50V稳压管 renamed 50VYSBDDM
- p. L  q& U+ v& e[W] Renamed symbols with the same pattern: EC8X12 renamed EC8X12/2
/ x! s3 Y3 b0 _1 h3 O1 S[W] Renamed symbols with the same device name: 1000UF/16V renamed 1000UF/16V/2
. m$ [9 W. D1 }6 w[W] Renamed components with duplicate names: C104 renamed C104/2
) t; D% ^; q* Z* f[W] Renamed components with duplicate names: C127 renamed C127/26 p/ M6 G( ], W
[W] Renamed components with duplicate names: C128 renamed C128/2/ o4 e. I" U# o* D- p7 e. e1 @% |9 t& }
[W] Renamed components with duplicate names: C129 renamed C129/2; R' e: [) Q7 h9 j; X3 ]
[W] Renamed components with duplicate names: C130 renamed C130/2
0 @; F" Y( u2 ~) ?[W] Renamed components with duplicate names: C132 renamed C132/2% d$ V7 r! t* i- x8 J
[W] Renamed components with duplicate names: C133 renamed C133/2
1 Q9 X% A. i( h" s, t  M! {[W] Renamed components with duplicate names: C204 renamed C204/2& H% u1 u, Y0 }7 }* O3 t
[W] Renamed components with duplicate names: C35 renamed C35/2
$ t1 A9 O* A; b& ^9 S' s" o[W] Renamed symbols with the same pattern: SOT23 renamed SOT23/21 o5 p) A4 V, \# M0 z
[W] Renamed symbols with the same device name: SOT23 renamed SOT23/2
0 [- c: \# Z% ?: }[W] Renamed components with duplicate names: D1 renamed D1/2  z0 w0 c1 ]6 Q* e" c. J
[W] Renamed symbols with the same pattern: SOT663 renamed SOT663/2
. @9 N3 S. K' z( ~$ l& \: n[W] Renamed symbols with the same device name: SOT663 renamed SOT663/2
7 ^6 i: m. b- u0 a( y/ Q[W] Renamed components with duplicate names: D2 renamed D2/2
+ x+ W9 B* {: ?0 n[W] Renamed components with duplicate names: D4 renamed D4/2$ H7 E0 ^) J5 i1 ?
[W] Renamed components with duplicate names: Q1 renamed Q1/28 q  H: g0 s4 r1 D0 @, [
[W] Renamed components with duplicate names: R10 renamed R10/2
, J8 c% j* S- L+ m* Q[W] Renamed components with duplicate names: R11 renamed R11/2
: d( k9 [8 u# v$ N* n[W] Renamed components with duplicate names: R20 renamed R20/2
; s/ ]. q4 J" D0 }& ^[W] Renamed components with duplicate names: R21 renamed R21/28 w* }* }8 G; i; ^$ R6 K+ g& M
[W] Renamed components with duplicate names: R23 renamed R23/2+ `( y; x* k, N( `+ R1 s& S4 M' w. H
[W] Renamed components with duplicate names: R5 renamed R5/2" j# m- `7 U0 U1 Q! k
[W] Renamed components with duplicate names: R6 renamed R6/2
' t4 I3 B6 x( B4 o, D% S9 X[W] Renamed components with duplicate names: R77 renamed R77/2  k: t9 m, m' a& {' ^
[W] Renamed components with duplicate names: R9 renamed R9/2  B( d. L* _8 W& h
[W] Renamed symbols with the same pattern: TP renamed TP/2+ A, D7 D' m9 ~3 O' u7 ^. f7 W( k
[W] Renamed symbols with the same device name: TP renamed TP/2
1 n1 O" H% I- S( O4 Y2 Q" ~7 h; z[W] Renamed symbols with the same pattern: SO-8 renamed SO-8/2
( [0 M$ f" n* ]# ]+ d2 ?[W] Renamed symbols with the same device name: SO-8 renamed SO-8/2/ [9 V9 w$ H0 g% Q' I
[W] Renamed symbols with the same pattern: SO-8 renamed SO-8/37 j0 G; ~# j; l
[W] Renamed symbols with the same device name: SO-8 renamed SO-8/3
& Z) H5 e" ]( s& ^1 U& x[W] Renamed symbols with the same pattern: SO-8 renamed SO-8/4- Z$ b, c1 j. X
[W] Renamed symbols with the same device name: SO-8 renamed SO-8/4. c5 C5 {4 H+ U( F( y
[W] Renamed symbols with the same pattern: DFN-8 renamed DFN-8/2
; I5 [$ E3 q+ A  S' V! {5 ^[W] Renamed symbols with the same device name: DFN-8 renamed DFN-8/2
7 h) c9 |4 m8 W- ?- a[W] Renamed symbols with the same pattern: NATIONAL\SOT23-6 renamed NATIONAL\SOT23-6/28 ^+ ]3 c( T; \! N4 l
[W] Renamed symbols with the same device name: NATIONAL\SOT23-6 renamed NATIONAL\SOT23-6/2
  M) H& _# X! k* U6 o; G4 d[W] Renamed components with duplicate names: U7 renamed U7/2
8 A, F- ^2 g+ i, d+ ]: b[W] Renamed components with duplicate names: U8 renamed U8/2
# b: ^) R$ C1 G1 ?/ l[W] Renamed symbols with the same pattern: 0603C renamed 0603C/6
5 F" ^8 Y( Q! t5 f1 }- _( M[W] Renamed components with duplicate names: C222 renamed C222/22 C. }* S) }+ v. x) ^1 [, B7 ?
[W] Renamed components with duplicate names: C223 renamed C223/21 K' f' K# b7 _" W* P0 J
[W] Renamed components with duplicate names: C225 renamed C225/2
6 x8 C4 b, I- ]2 q! N# c[W] Renamed symbols with the same pattern: 0603R renamed 0603R/20 f2 F- L6 W5 b5 u
[W] Renamed components with duplicate names: R221 renamed R221/2" q- U$ g/ e. X+ S/ W) o4 x3 a0 Q
[W] Renamed components with duplicate names: C177 renamed C177/2
5 m. b1 [, U2 ?/ v; i. B/ q" `[W] Renamed incorrect device name: 220U,16V renamed 220U_16V
  S* T0 j% |0 y7 U7 N, |[F] Encountered an improper argument.
7 a/ L: o* K# ^2 q) e' u3 _* Z
GMT+8, 2025-8-1 15:11 , Processed in 0.109375 second(s), 24 queries , Gzip On.
