查看: 1188|回复: 1
灌铜问题 急求大神帮忙
发表于 2013-1-11 21:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本人Layout之后分割好地和电源层,灌铜时出现这些错误:
- w+ q- j% r$ ^! x4 K! e  H  O( N% g5 f: ?9 C: _/ R- ]
1 @: k3 }& L; u6 I) l: H5 T* e
THERMAL RELIEF ERRORS REPORT -- FPGA2.pcb -- Fri Jan 11 21:44:01 20137 _2 q: F$ A+ o
3 A# t0 u( v/ V# H( s) f* l9 s  G' `. `- [% _$ u+ O+ L+ ~
       Drilled pads with                    Nondrilled pads with
( v( Y8 q7 T7 A$ L9 j/ p3 Y1 mless than 50% thermal extensions      less than 50% thermal extensions
: T3 K$ i1 q, [  X3 m
0 O: ]3 z! q# D$ p5 @) I' Y- m" k# {Report of Thermal Spokes Generator.4 Q) h4 j) b' i! N! U  ~9 w8 p. K6 m, i% k
) L6 K7 A1 R  ?- e) O
On GND3:  w1 z8 ?' R# j0 F! [
        (2506, 775) # = 07 v1 z; r7 T7 b4 D
        (807, 454) # = 0
  c5 u0 @; B' Y1 z! O1 @* a2 H        (3125, 750) # = 0: s* H+ i3 J. w$ V8 F
        (418, 189) # = 0+ F% F' W) M; o5 [+ a3 \
        (2199, 749) # = 0
  q1 F/ c# u9 f% G+ B        (1178, 648) # = 0
4 E! D$ s' L4 F. L. o7 e5 Y$ O  `: T        (1295, 800) # = 0
* s1 O# ^/ r. z        (1256, 839) # = 07 X6 P0 R2 G9 m/ Z" u
        (1763, 878) # = 0$ t4 z1 b6 E9 D# y, ]
        (1646, 878) # = 02 E+ ?8 l. e! F
        (1295, 878) # = 0! w  v0 P) q7 C6 ?) C& d
        (1295, 917) # = 0, ~9 |7 ?+ I$ e5 C* G
        (1256, 956) # = 08 p: G6 ~9 d2 j9 L
        (1685, 1034) # = 0
$ r! A  Q* T, R' F* ^  W# P* Z4 @; ~        (1295, 1034) # = 0
& l1 k2 L/ Q# T$ y9 W        (1646, 1073) # = 0
3 k2 \/ S) k! H, @2 g" P9 _        (1295, 1151) # = 0: w: n4 W0 b* r. m' F
        (1490, 1231) # = 0/ s% S9 h$ r7 H+ j8 q1 e9 B* D( V
0 K5 R( @8 t' BTotal Drilled pads:   18               Total Nondrilled pads:    0; G* q# ?6 Y1 U) a" b" J2 x2 m
0 g1 l) N8 b: N- Q  P
Report of Violating Thermal Spokes Remover.& K3 v+ R; D" F  R5 ~" l, i' w# D
" C  x3 J0 _# ^/ p$ c+ J% ^On GND3:% h+ R% i6 z6 A
        (1373, 1151) # = 0
% M; Q' }# Q, m" [3 p0 {        (1490, 1151) # = 03 L! m$ e/ [; _) ~  s0 q7 S
        (1529, 1151) # = 08 e6 F$ w7 M- n# n, C8 ~
        (1568, 1151) # = 0+ B+ [6 `/ V' K4 [
        (1373, 1307) # = 0
2 {7 G" n( r/ C' x
: E2 T2 k- p8 YOn Power:
7 v. x* _6 J0 L- ]1 Y        (2086, 1220) # = 0
' l  n0 o" R: O  [% ]8 _; T) u        (2334, 760) # = 0
' R7 q* v; K8 v7 G- g  X        (1178, 683) # = 0
/ L/ C/ J9 K* {# ]        (1139, 683) # = 0% }. {9 {2 G# n9 y
        (1728, 882) # = 0
' V! q2 I2 @0 s7 }" {* m2 E        (1143, 761) # = 17 D  O$ o7 y3 R& |" a
        (1218, 1181) # = 0
/ N% X% @( q6 M; v/ o' E
9 |$ _: d, m) TTotal Drilled pads:   12               Total Nondrilled pads:    0" w) b  M7 q" \
不知道 这是什么问题,如何解决?
发表于 2013-1-12 11:08 | 只看该作者
GND不完整
GMT+8, 2025-7-30 22:10 , Processed in 0.125000 second(s), 23 queries , Gzip On.
