查看: 182|回复: 1
ZCC5160 Synchronous Step-Down 60V 3A V2.0
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-11-10 16:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    ( @% p" m+ f' M: f9 i( z
    ) ~) @0 D  R+ J6 U+ X# j9 EFeatures
    2 E$ {  u8 K! p" x
    9 S9 v7 D2 s& K0 M8 Y0 v7 B# X& N' t20-μA Quiescent current in regulation
    2 a' ~, R4 K! @  w
    / R# R7 B9 x! E: ~Input voltage range: 4V-60V
    ; o) L) R0 P/ K7 u& {; t
    ' g: E* `7 `( Q, A; FOutput voltage range: 1V-VIN1 K& g: T8 Z# k/ }3 K
    ( m+ f, Z: c* L( }
    Integrated upper and lower power MOSFET
    - G' c- T. L2 gmaximum current: 5A6 z- ^% }0 ]- a% L7 ~
    9 x5 R8 b8 q' e6 z0 b
    Adjustable frequency range: 200KHz~2MHz
    ! l- m( h$ b8 z4 k& w, F/ C9 z' h2 y5 n) |1 Y. X& A+ U
    Automatic switching of CCM/DCM/PFM mode1 @# O* A( S, }  ]: n# Z, E
    ( B" X) X8 K, AAdjustable soft-start time and Output voltage
    0 f/ m1 h- h) v$ Q( J8 s  n0 {tracking capability* y/ a6 Q, N$ p" A' O% a) X
    # L' T% y7 n6 \2 i$ @
    Automatically switched bypass linear power
    ' c% b/ H/ q- T3 ssupply; l, G/ G; p+ `: A
    $ H0 @9 q) f2 c! W2 @7 o
    Provides ultra-low input and output dropout5 f; p# X* F4 w& K- V
    voltage close to 100% duty cycle) l7 u  i- w7 q* W7 y
    0 ^2 q6 O: h9 x
    Internal Compensation
    * X. s- j6 X7 b1 b6 P
    , t# c3 J& O" d: l/ q1 DPower-good flag4 z4 l& n# u: [& h) ]3 b' E* @8 }
    1 W( `! a. q" m
    Dynamic Frequency Stretch Technology
    $ m" p; w4 \% m* R% {* Y
    5 B, ~+ J  _* q4 gSupport large capacitive load start-up
    0 B, f9 S2 V3 e- q! I
    # ^6 Q9 G! R- E/ i$ p2 Y% YProtection function: UVLO/OCP/SCP/OTP/OVP
    : |  L) Z, F. F- i% z. H9 @
    6 l4 a5 E4 c; xOperating junction temperature range: -40℃ to4 y5 l# S; E9 ~
    +125℃! I& l  e: m! ~% Q" T- u& i1 k. k
    1 w% D) B  ^* d3 _+ \2 IAll pins have ±2000V (HBM) ESD protection
    : s) d4 C. W4 F4 S/ H
    / Q) D9 P9 L% j7 ]+ EETSSOP 16-Pin Exposed Pad Package' v& u$ D4 K0 f2 b! @
    Applications- W/ V3 }* f- c  n' f! g
    ' p# [2 S" L, R8 A
    Industrial power supply
    : M3 k7 {1 W7 h7 j) i; V8 [
    3 e8 ?9 |8 c0 f# M& M2 c: |7 t/ k( pWide voltage input range power supply
    3 p% s% e1 q) y6 g+ j2 ^
    , |0 a; X2 O3 i  D) m1 c& v6 LLow ripple low noise power supply! a5 b% c+ Y' B/ \5 N
    ! B$ m& V9 Q+ C: R4 x' OAutomotive electronic power supply" q+ x9 O! a- x" e, s
    Figure. 1 Typical Application Circuit5 p; _; i0 ?1 F% b8 n3 ?# t' J
    Description; d$ f+ b" Q( n5 U1 o9 l
    ZCC5160 is a step-down DC/DC regulator with an
    ( I  \* U: R4 r, ]; {internal switch, featuring SKIP control mode, which5 ^' n+ B, v6 x+ M5 C
    combines low quiescent current with high switching% E! K) S' e( }% m4 l5 f
    frequency to achieve high-efficiency regulation over a9 k: ?  s1 l0 ^# J
    wide range of load currents. SKIP mode uses a short: S2 Q1 \6 l& ]+ a
    "burst" cycle to switch the inductor current through
    ( s" g1 ?- t/ g0 Qthe internal power MOSFET, followed by a sleep" c  g& x6 t% v
    cycle in which the power switch is turned off and the
    ( T0 f) U: r% l9 Y; eload current is provided by the output capacitor. At
    % x3 y% l; b5 z2 D9 s+ z$ Qlight loads, burst cycles are a small fraction of the: ]# f# \7 h' d, M7 M! Z3 p& T
    total cycle time, minimizing average supply current9 Q0 _% t+ [& M5 }
    and greatly improving efficiency at light loads.
    5 q5 K3 V% L* h/ [ZCC5160 has a wide input voltage range of 4V-60V,$ ^. ?7 b  q9 {% i! l" R
    thus minimizing the need for external surge
    " S6 O" b7 N! r+ Usuppression components. Making it the best choice: a; x% _6 \: v
    for wide input power range industrial and high cell% [% Q% m. E+ H+ s" L2 n
    count battery pack applications. ZCC5160 is ideal for
    ) k  ?* [7 v- ]use in the 48V automotive power bus range.
    , o1 J  a+ W$ w5 I" ?ZCC5160 features low-value 100mΩ high-side and# z- B1 ]3 ^8 i, O9 [, J* m. E) ^
    80mΩ low-side MOSFET that provide at least 3A' s' ~! g  X' _' I" }; n
    output current capability with excellent load and line
    + ^2 Y; b3 M1 j+ stransient response.3 A  N" U6 u  O, O+ p; a% e/ a
    Additional features include: soft-start, thermal3 a+ ^8 `' w9 E3 V& }/ _
    shutdown, UVLO undervoltage lockout, gate driver
    + i$ L; p5 u+ Vundervoltage lockout, maximum duty cycle limit timer,. y% R7 p* W1 V8 p0 w
    and current limit shutdown timer. It also integrates* V* X9 `+ I0 k/ Z. S9 g
    output short-circuit protection, providing HICCUP* f' U5 d8 w+ H8 }& x( @
    mode when the FB voltage is low to avoid; R$ y* Y  f( S( F8 F3 D
    overheating during short-circuit.3 h! N7 d7 `( j0 [# S' E* d- s
    6 D& K# d; G8 [! ^
    发表于 2022-11-10 17:18 | 只看该作者
    车规级60V 3A同步降压芯片-ZCC5160
    GMT+8, 2025-7-21 00:23 , Processed in 0.109375 second(s), 24 queries , Gzip On.
