谢谢阿科GL ,但是用PROTEL99导入ASC文件后会出现一连串的错误信息& U' f: {3 \: j, n' l
0 B' f* `) p s0 n1 [2 e0 [Protel Design System: PADS PowerPCB To Protel 99 SE Translator Report
% a8 j5 k: o1 P$ \7 f$ cPCB ASCII File : 211
0 h% c/ f- K7 U) nDate : 5-Nov-2011
: S4 ^8 w5 h0 `; x& w- k% ?$ c$ }Time : 08:04:25# |8 P8 g& L# {7 r" \3 r
1 d& n" y; A# o3 N
0 v2 `! [( c; \, Z! @3 u0 W- T. s5 `
Load Errors : 767
, n/ a" Q5 _3 B6 ~" iError loading label visibility attribute from line: 1077
2 O' C+ P7 g" P6 k) jExpected number in line: 1078 at position 0 and found this: **CRLF**2 z2 z; V+ Y9 u x# ?3 P9 y ?
Expected number in line: 1078 at position 0 and found this: **CRLF**5 Q! \2 F0 k% R; h2 A$ i4 ?, i4 r
Expected number in line: 1078 at position 0 and found this: **CRLF**+ R! S/ F2 v! k3 c$ y4 R, y
Expected integer in line: 1078 at position 0
' P+ V$ A$ _( s+ J& o3 A) uExpected number in line: 1078 at position 0 and found this: **CRLF**
" z, b! H. N7 HExpected number in line: 1078 at position 0 and found this: **CRLF**9 X2 o$ u' |( N+ l' x& a
Error loading label mirrored attribute from line: 1078) e. D5 t. Y1 S7 Q$ [: K1 K
Error loading label text justification attributes from line: 1078
0 U7 |3 ]% R5 ^" kError loading label right-reading attribute from line: 1078
' j3 p: N4 j& Y+ J% |( h4 x3 OExpected number in line: 1079 at position 0 and found this: Part5 I' Q; i& }, z( R. Z
Expected number in line: 1080 at position 0 and found this: **CRLF**1 ?( B5 E: [! Q3 C: P3 }
* ?+ Z3 R0 |( p9 V' O5 lExpected number in line: 1080 at position 0 and found this: **CRLF**
& h2 Q; V3 l/ p7 o/ yInvalid pin data discarded.
: T/ O, Z- Z; V/ h'PAD' expected in line: 1081
A- u5 b' W7 ~' I% [Expected integer in line: 1081 at position 0- s+ Y7 h% N+ @& F: C
Expected integer in line: 1082 at position 0
3 ]' M5 K- E7 ^" _4 X5 `Bad pad stack data in line: 1082.5 ?5 D4 Z7 l# ?% L$ u" Y
Can't load pad stack.; V0 m0 i7 G6 ]1 A+ r0 X7 Y* J3 m
Error Loading Footprint :0402- G: `4 ]" p2 ?9 }9 E6 ]: L
Expected number in line: 1083 at position 0 and found this: **CRLF**
/ F2 ^5 {9 J9 U7 z+ `" q9 @Expected integer in line: 1083 at position 0
7 r- H' N. h- W: `6 lExpected integer in line: 1083 at position 0
; t+ D' {) D& {1 m d1 MExpected integer in line: 1083 at position 0
* d; M5 k+ v2 I$ IError Loading Footprint AD/ ~3 d. b% o1 H- T0 h
Expected number in line: 1083 at position 10 and found this: S/ C2 L, M" Z3 E2 _7 I/ P
Expected number in line: 1084 at position 0 and found this: **CRLF**
$ B N. ^" O8 S% ?' ?- HExpected integer in line: 1084 at position 06 N$ k: ?7 [4 _+ H+ F
Expected integer in line: 1084 at position 06 t* S0 _9 F* U3 J
) I d+ v" O s6 b+ wError Loading Footprint :-2
" T/ _& P+ F5 nExpected number in line: 1084 at position 7 and found this: R
6 Y9 ]2 ?' u! f. lExpected number in line: 1085 at position 0 and found this: **CRLF**6 }- W! g$ @5 A
Expected integer in line: 1085 at position 0$ @7 q8 a4 N* ^; W! g6 O. C
Expected integer in line: 1085 at position 0! ^4 k! v d; ^$ R* V% i8 c0 e
* P3 U8 I: V- L/ ^1 o8 i5 x) S% wError Loading Footprint :-1
8 v, P d8 I9 l- \Expected number in line: 1085 at position 7 and found this: R8 G1 M E* Z6 A1 g
Expected number in line: 1086 at position 0 and found this: **CRLF**
9 y/ D `% o5 U! GExpected integer in line: 1086 at position 05 ~7 F: `/ y# n: \% d: T
- M: m) v6 F# k4 m" y' Y# a+ MExpected integer in line: 1086 at position 0
( {( e" G6 v$ C; U. HError Loading Footprint :03 B2 J9 E3 l3 N
Expected number in line: 1086 at position 10 and found this: S
. T; ^8 R% r* }, G# lExpected number in line: 1087 at position 0 and found this: **CRLF**
" ?- |0 [. q. q' _, I$ T' PExpected integer in line: 1087 at position 0
# |9 u( a' ~1 K0 Z% rExpected integer in line: 1087 at position 0
0 |1 F" l2 Q# ~: ]& p: n- {8 O! cExpected integer in line: 1087 at position 0$ F" V1 ]+ E) T* P. `, i, v
Error Loading Footprint :214 w, ^5 V# ~; z9 Q
Expected number in line: 1087 at position 10 and found this: S u; V4 e+ b* x
Expected number in line: 1088 at position 0 and found this: **CRLF**6 H* z( C4 j5 y' y( \3 E' o2 @
Expected integer in line: 1088 at position 0
# L- B5 Y0 h! w0 O' @ OExpected integer in line: 1088 at position 0
4 b0 H3 B1 W" y7 A7 w% aExpected integer in line: 1088 at position 0
6 x3 i1 T v" D" O0 SError Loading Footprint :23
% K8 l, g2 r' D4 B% {8 c* KError loading label visibility attribute from line: 1101
& g1 h8 K5 G5 a+ j$ w! J: dExpected number in line: 1101 at position 5 and found this: Type
1 M" }7 `7 N+ X& ^9 i& y; lExpected number in line: 1102 at position 0 and found this: **CRLF*** K& J! L* k8 B7 J5 r9 b2 F
Expected number in line: 1102 at position 0 and found this: **CRLF**7 n4 J; W1 g$ z. f; I `' D
Expected integer in line: 1102 at position 0
1 i; h; k+ {% @% T3 |9 m) |Expected number in line: 1102 at position 0 and found this: **CRLF**
) C z: ^# q# ^1 {. }, X0 d. G# pExpected number in line: 1102 at position 0 and found this: **CRLF**
" L! T7 c; h* @/ P' tError loading label mirrored attribute from line: 1102
c* ~9 l: _& B8 ~" L9 BError loading label text justification attributes from line: 1102
2 l, z; T* z7 e& I nError loading label right-reading attribute from line: 1102) y& Y$ e; c' m9 r- y' ?
Expected number in line: 1103 at position 0 and found this: Ref.Des.
! Z8 z, W9 U! H6 n) q8 H! ?8 PExpected number in line: 1104 at position 0 and found this: **CRLF**5 g( e; w$ B1 ^2 M
Expected number in line: 1104 at position 0 and found this: **CRLF**0 P- b) X5 d' h j; c J
Expected number in line: 1104 at position 0 and found this: **CRLF**1 y% j+ J3 q' b# h/ |
Invalid pin data discarded.# K+ K& H/ G* P# E! U
'PAD' expected in line: 1105
9 C5 U+ F1 u1 |+ T2 {Expected integer in line: 1105 at position 0( M6 c" m M" C2 k4 z8 h& K* v9 F Z
Expected integer in line: 1106 at position 0- N! g- m5 g) O# w3 r4 s6 L
Bad pad stack data in line: 1106.& Y2 Q& O7 z! k8 N6 w) C0 D/ \
Can't load pad stack.- M- O/ F0 K; A9 V2 `4 e. j$ ~
Error Loading Footprint :08054 F. b# e+ ?) U; _$ b
Expected number in line: 1107 at position 0 and found this: **CRLF**& \+ m B6 n( x+ s4 I4 V5 k2 X- g9 b. |, p
Expected integer in line: 1107 at position 0
0 k7 D, {9 V$ f; F8 C3 YExpected integer in line: 1107 at position 0
* H+ r9 C$ k$ Z# z9 S* dExpected integer in line: 1107 at position 0
% O1 b% ~" `* n0 z* _6 a+ F9 \8 PError Loading Footprint AD
( V0 }) b2 ]. l) RExpected number in line: 1107 at position 11 and found this: RF& I( B- i# j. @( l$ T4 c# P
Expected number in line: 1108 at position 0 and found this: **CRLF**
/ w1 y& C4 q" ^& j+ L- z( q8 t2 VExpected integer in line: 1108 at position 0
6 {7 _6 m3 }% A2 \Expected integer in line: 1108 at position 0
6 w( h: [, Q' q/ PExpected integer in line: 1108 at position 0
' s( j7 K7 l7 k* n7 @Error Loading Footprint :-21 v; ~# v3 G( F7 L' b
Expected number in line: 1108 at position 7 and found this: R( O& q ]3 A: u' n
Expected number in line: 1109 at position 0 and found this: **CRLF**& }* ~$ `) G! W( @: u* n- w8 W( @2 O
Expected integer in line: 1109 at position 0) f3 ]& T; |4 X5 Q0 j( e) s/ {
# {( K: m3 X0 T# X- \9 t! QExpected integer in line: 1109 at position 0' d0 s/ y, l9 d2 }& u" a- L
Error Loading Footprint :-11 G% j" z0 y9 n' b
Expected number in line: 1109 at position 7 and found this: R
3 Q5 Q+ n" P9 P% I$ p* _Expected number in line: 1110 at position 0 and found this: **CRLF**4 z) B& U- D, S# p, _0 C7 t
Expected integer in line: 1110 at position 08 V p3 s$ v' M& Z# O# k; i# T5 |
. b! j9 u# J% ^" s0 |Expected integer in line: 1110 at position 0
$ F6 ^/ J C9 G7 Q- t# @' d RError Loading Footprint :0
. C+ g! X6 S4 ]8 pError loading label visibility attribute from line: 11220 g5 D7 |) N' y
Expected number in line: 1123 at position 0 and found this: **CRLF**
9 {$ L% }# y5 M4 u" B4 ~$ qExpected number in line: 1123 at position 0 and found this: **CRLF**
+ n$ t1 [; ^ p* B q! ZExpected number in line: 1123 at position 0 and found this: **CRLF**
& g% `( R1 e1 y2 S/ p* r& TExpected integer in line: 1123 at position 0* a# V& C/ F, [" q: ^6 v4 \
- R6 s3 e1 B1 U9 e# u2 H7 yExpected number in line: 1123 at position 0 and found this: **CRLF**+ v D9 d% I7 a% E. E
Error loading label mirrored attribute from line: 1123
& h V( N% H- ]Error loading label text justification attributes from line: 1123# Q1 W+ h& R6 c' G1 i
Error loading label right-reading attribute from line: 1123/ P( m [4 a, X, a* t4 f8 N
Expected number in line: 1124 at position 0 and found this: Part
8 g% P' w/ o& n* nExpected number in line: 1125 at position 0 and found this: **CRLF**
) @/ r3 K0 Q3 @% {. c0 I' fExpected number in line: 1125 at position 0 and found this: **CRLF**1 K$ B5 `. Q2 r2 M9 R" p
Expected number in line: 1125 at position 0 and found this: **CRLF**% w; C( {3 `6 ?
! d5 i0 H6 o1 [, ]'PAD' expected in line: 1132
: z. I7 {! W Y. U2 d3 aExpected integer in line: 1132 at position 0+ t! `; z( I4 {: Z* @0 U( F
Expected integer in line: 1133 at position 0
! B: q) Q, v5 n' L5 N3 R2 H: bBad pad stack data in line: 1133.! k( [- X3 W* u# @3 J
, Q: }8 |* H0 oError Loading Footprint :SO8, c9 b, F2 X: H9 t8 J% ^
Expected number in line: 1138 at position 0 and found this: **CRLF**
" B9 E$ {. o: w! m' K4 NExpected integer in line: 1138 at position 01 s% h5 } I) l7 o
. }8 W! z2 A# R& s' E/ B6 ?Expected integer in line: 1138 at position 06 g- ^* u% a- ?/ ~& p$ W( J
5 S* W5 _+ }! A' D0 O5 z( ~Expected number in line: 1138 at position 10 and found this: RF
" K! p6 t7 T6 k/ t! t: i( L: MExpected number in line: 1139 at position 0 and found this: **CRLF**
0 \' Q; y2 A1 \6 U6 A: d4 F& fExpected integer in line: 1139 at position 0: }7 s B9 ]) @
! B" J/ Q5 I* H& K/ J: b8 Y+ fExpected integer in line: 1139 at position 07 v5 z5 K2 b" V8 A. \& j) _
9 o) G0 q; r+ z. sExpected number in line: 1139 at position 7 and found this: R* |0 b) @0 o/ L% U* W4 \* Y
Expected number in line: 1140 at position 0 and found this: **CRLF**
/ a8 d, d2 }$ i+ ^Expected integer in line: 1140 at position 0
H+ d; r* B- D8 I" bExpected integer in line: 1140 at position 0
! r6 p5 l5 ?- u& s: O' PExpected integer in line: 1140 at position 04 C3 b1 |9 H$ k) N. e
, w) v$ Y% Z$ k. v! T4 a s9 CExpected number in line: 1140 at position 7 and found this: R
$ B' w2 f1 s7 b' \( `- e9 SExpected number in line: 1141 at position 0 and found this: **CRLF** V5 z) Z* [4 p y
Expected integer in line: 1141 at position 0
" D# Y8 j/ T8 g9 d) P* F& x. CExpected integer in line: 1141 at position 0
8 P& {& t: D. K4 XExpected integer in line: 1141 at position 0
1 ~, D' i' M+ R4 ]6 U, [! `+ B7 OError Loading Footprint :04 B. d( N2 j- S2 }9 @ r
Error loading label visibility attribute from line: 1162
1 V. b& S: A/ `( b* \) n8 zExpected number in line: 1163 at position 0 and found this: **CRLF**6 S7 X, b; X5 X& |
" m6 a3 ~. m, W$ M% p$ ^* RExpected number in line: 1163 at position 0 and found this: **CRLF**, W; q1 n# p* t4 j
Expected integer in line: 1163 at position 0
, H) D! a. \: i- y( \Expected number in line: 1163 at position 0 and found this: **CRLF**
$ \7 Z0 X. c- T0 lExpected number in line: 1163 at position 0 and found this: **CRLF**
8 p; I+ j; U$ V! lError loading label mirrored attribute from line: 1163% `+ j% J! h/ ^' d0 Y
Error loading label text justification attributes from line: 1163
+ ~& A' d: v) q' a$ JError loading label right-reading attribute from line: 11634 f! D! a4 l( n, L/ a* g
Expected number in line: 1164 at position 0 and found this: Comment
9 x- J2 u' w0 L& }Expected number in line: 1165 at position 0 and found this: **CRLF**
7 u. X* O' N& HExpected number in line: 1165 at position 0 and found this: **CRLF**
w& ?! v. e# t0 yExpected number in line: 1165 at position 0 and found this: **CRLF**. t. B( M! o' [! J$ f8 Y- E
0 Y( q2 M3 ^: L5 |7 \7 s'PAD' expected in line: 1166
% t* [4 I2 ~, h. \2 V" i% SExpected integer in line: 1166 at position 0. H* L) K5 O4 j, z
Expected integer in line: 1167 at position 0$ s! O. z& ^# W( ^
Bad pad stack data in line: 1167.
" O# @# L% E- x- ACan't load pad stack.
& ^3 \* ]! A( lError Loading Footprint ED06030 Z0 o! u% d) [4 J' x. P8 b
Expected number in line: 1168 at position 0 and found this: **CRLF**, [, S, H$ w3 m8 ^- I
Expected integer in line: 1168 at position 04 Z5 R" E! v! X+ G7 h
- {: b! W- ], z4 G# O& R& XExpected integer in line: 1168 at position 0
% {2 c0 E' M2 k" T9 B% W7 n5 PError Loading Footprint :PAD
, C2 F# A6 N1 W9 r& }' fExpected number in line: 1168 at position 11 and found this: RF h, L& F& J4 N3 w
Expected number in line: 1169 at position 0 and found this: **CRLF**
+ p2 M" X/ ?( w+ `) _Expected integer in line: 1169 at position 0
* X$ }6 I9 g+ l0 OExpected integer in line: 1169 at position 0
3 \3 |$ X" x5 k, [6 FExpected integer in line: 1169 at position 0) W0 [& W+ C( v# {8 U* M
Error Loading Footprint :-2- i0 }5 w# N$ O4 T7 [, Q/ b
Expected number in line: 1169 at position 7 and found this: R
8 \! `. U& v1 p& dExpected number in line: 1170 at position 0 and found this: **CRLF**) D! f' T: n$ v0 h4 B% U" H3 V
Expected integer in line: 1170 at position 0
# ?/ t) i2 @9 t" V' xExpected integer in line: 1170 at position 01 V- f+ A; }0 L, J' F
4 |# H" O& ~+ J$ I; @Error Loading Footprint :-14 U- m# ~& Y% e% t) ^$ \
Expected number in line: 1170 at position 7 and found this: R; ^1 s. a5 K1 W5 s
Expected number in line: 1171 at position 0 and found this: **CRLF**9 a( ^- K7 V4 L: ^0 K* B4 b+ t4 ^
Expected integer in line: 1171 at position 0
" N. b" o. P2 k cExpected integer in line: 1171 at position 0
8 J2 z/ e2 P: g3 o% }& G4 zExpected integer in line: 1171 at position 0
5 e" g. ]; f: t: c8 a: L0 iError Loading Footprint :0
! M" g( h7 Y( ~0 {: ~+ d7 |Error loading label visibility attribute from line: 1228/ Z# Y9 L* z5 S4 t9 {/ [, d
Expected number in line: 1229 at position 0 and found this: **CRLF**
9 s" h# ]' Z s9 zExpected number in line: 1229 at position 0 and found this: **CRLF**4 c/ C: o: k% J% Q9 C4 Q; W* o- N
Expected number in line: 1229 at position 0 and found this: **CRLF**% |# k6 A7 o8 a9 {4 Q, G
Expected integer in line: 1229 at position 0
. v$ B7 W, X2 r4 U6 {( _2 u$ wExpected number in line: 1229 at position 0 and found this: **CRLF**/ G$ n5 n7 Z' }/ L C6 a" t
Expected number in line: 1229 at position 0 and found this: **CRLF**7 D8 ]! u+ W* S! x- h" m) R3 t) }; y( T
Error loading label mirrored attribute from line: 1229
' r) ^3 k! Z( e, }3 P* r3 y5 B6 |* ?Error loading label text justification attributes from line: 1229
# W6 h+ {. t+ H; mError loading label right-reading attribute from line: 12292 W9 a! `8 J8 m7 I, e ^4 ]
Expected number in line: 1231 at position 0 and found this: **CRLF**; r: T0 z) \6 _0 L
# L {' H" I, T. d, J3 h$ yExpected number in line: 1231 at position 0 and found this: **CRLF**
" n' D, Z9 I8 tExpected integer in line: 1231 at position 165 S$ X5 y# x, [9 @$ Q5 j |( r
Expected integer in line: 1232 at position 65. k8 y7 ~: `" R1 @+ a& {6 a1 E" }
Expected number in line: 1234 at position 0 and found this: VALUE% v, D3 i/ \! o8 d$ b1 X* [* I% k
Expected number in line: 1235 at position 0 and found this: **CRLF**# V. T2 C% f+ k. z `4 y6 b' h
+ H; D; H6 \1 HExpected integer in line: 1236 at position 08 k3 H2 D6 H1 G
Error loading label visibility attribute from line: 1238- P( g: A( V4 k+ A1 @
Expected number in line: 1239 at position 0 and found this: **CRLF**$ \1 \) ?8 M; h7 b1 ~5 D
Expected number in line: 1239 at position 0 and found this: **CRLF**- B Y6 o6 R% V1 a# {1 r
1 e8 l! X* }/ P- U6 D+ J. G% pExpected integer in line: 1239 at position 0" C0 l1 {5 v$ s1 D7 n, k
0 {* i9 p1 N2 kExpected number in line: 1239 at position 0 and found this: **CRLF**
9 D5 u" v/ N5 Q" z# iError loading label mirrored attribute from line: 1239
& l! A# a9 T/ hError loading label text justification attributes from line: 1239
4 }3 p, C4 l" i$ L* jError loading label right-reading attribute from line: 12392 S' j$ g Z. o( h
Expected number in line: 1241 at position 0 and found this: C117 s, F4 O# u& c1 S
Expected number in line: 1242 at position 0 and found this: **CRLF**/ M, `% _1 ]7 Y9 l' C6 Z
Expected number in line: 1242 at position 0 and found this: **CRLF**2 v7 T8 R+ ^: y
Expected integer in line: 1242 at position 30! N. _7 a, N, t. L4 k5 _. J1 i
Expected number in line: 1244 at position 0 and found this: VALUE
& w3 z/ ~0 a/ Y, {- x+ Z% WExpected number in line: 1245 at position 0 and found this: **CRLF**+ l2 S5 N' m, n) g
Expected number in line: 1245 at position 0 and found this: **CRLF**0 x: c& d5 w; T1 e! o2 f) x: s
Expected integer in line: 1245 at position 5/ |3 B9 r ]% A" y6 j& N' b/ [
Error loading label visibility attribute from line: 1248/ |$ A2 D2 |. I8 ?5 f1 R
Expected number in line: 1249 at position 0 and found this: **CRLF**
; j0 J, e& v1 b4 eExpected number in line: 1249 at position 0 and found this: **CRLF**
; z: q# g: B) R D2 `Expected number in line: 1249 at position 0 and found this: **CRLF**
( i. h, w# E& F. A: e' eExpected integer in line: 1249 at position 05 n6 f \- v# f( S
Expected number in line: 1249 at position 0 and found this: **CRLF**- b1 m" ~5 L% y% k
) X+ p+ p# U6 ?- w$ NError loading label mirrored attribute from line: 1249
# q/ e, n8 d+ r# ?' x0 uError loading label text justification attributes from line: 1249
* q$ a4 H0 B$ D0 MError loading label right-reading attribute from line: 12491 ~% [+ [2 f8 \: |9 \! v. G: [# u
Expected number in line: 1251 at position 0 and found this: **CRLF**3 x2 F L: E& B* _9 M6 z# \+ Q
' j) H0 W' L, B! ?. A& `Expected number in line: 1251 at position 0 and found this: **CRLF**
. S8 M) h, J. NExpected integer in line: 1251 at position 46
" J0 b* q( N. Z1 |Expected integer in line: 1252 at position 65. {) X" q3 ? o% e: k7 r+ W. V
Expected number in line: 1254 at position 0 and found this: VALUE, t, r& S6 K; ]" |" Q5 \
Expected number in line: 1255 at position 0 and found this: **CRLF**
. w4 o9 Q0 |- u2 |- XExpected number in line: 1255 at position 0 and found this: **CRLF**4 z: V! i5 u7 n6 c( e2 ]
Expected integer in line: 1255 at position 5% g5 h3 N8 A: K% R; R% P
Error loading label visibility attribute from line: 1258- `7 t7 O' q5 a, g9 S) B
Expected number in line: 1259 at position 0 and found this: **CRLF**
) R4 P( M2 f' o: X) [Expected number in line: 1259 at position 0 and found this: **CRLF**
" o0 `0 E4 c9 C/ o ~1 `Expected number in line: 1259 at position 0 and found this: **CRLF**
" b* ~5 Z2 e7 M: M. o$ T1 W. S$ xExpected integer in line: 1259 at position 0/ [7 x1 ~+ g6 q6 P8 O
' f9 F. \. ~# X$ l' l, ~( hExpected number in line: 1259 at position 0 and found this: **CRLF**( I6 z1 l1 q+ E6 _9 k% G
Error loading label mirrored attribute from line: 1259
, `" j+ h0 P0 E6 g. g/ i; i+ y. eError loading label text justification attributes from line: 1259
0 o2 _* m5 u' m" S+ |6 @0 yError loading label right-reading attribute from line: 1259$ L7 [" a* T3 u# U
Expected number in line: 1261 at position 0 and found this: **CRLF**
^' j7 u0 M5 ]Expected number in line: 1261 at position 0 and found this: **CRLF**
( g. X, f! @) x1 r# Y; y2 \Expected number in line: 1261 at position 0 and found this: **CRLF** E- a* ^* F. \0 Q. y
Expected integer in line: 1261 at position 46
% c+ `3 p* ~# @6 w/ W8 I! HExpected integer in line: 1262 at position 65
' c/ C: g0 w: A3 ]6 xExpected number in line: 1264 at position 0 and found this: VALUE
' d7 O: G- o/ I" x' o& M YExpected number in line: 1265 at position 0 and found this: **CRLF**
/ c0 k2 _/ I, ~Expected number in line: 1265 at position 0 and found this: **CRLF**
" w; ?% i) b: P" M; rExpected integer in line: 1265 at position 52 Z6 q* i; X! D6 q6 |7 @* u8 |
Error loading label visibility attribute from line: 1268# e( N+ r. y$ v0 F3 R* x) f" F
Expected number in line: 1269 at position 0 and found this: **CRLF** Z. P# p0 h' ~8 a/ H3 G- R1 V5 \
Expected number in line: 1269 at position 0 and found this: **CRLF**0 H1 e& J4 M: x9 I* q
: c ~8 S" U6 i+ w5 MExpected integer in line: 1269 at position 05 R& M" G' X& P; c. X; x1 ~
Expected number in line: 1269 at position 0 and found this: **CRLF**1 c: R0 P: { v# v+ \
Expected number in line: 1269 at position 0 and found this: **CRLF*** ]6 {) t8 i: A' j. G' K
Error loading label mirrored attribute from line: 1269 K, S. I1 g* W2 H4 L; g8 r$ \
Error loading label text justification attributes from line: 1269
. o4 R; a6 S& F( D: _. U1 _- uError loading label right-reading attribute from line: 1269
& [( K! U+ j; W2 i, ]Expected number in line: 1271 at position 0 and found this: **CRLF**
8 c6 c) L' f4 _Expected number in line: 1271 at position 0 and found this: **CRLF**0 U( [/ v4 V" Y; G! t8 \ n
Expected number in line: 1271 at position 0 and found this: **CRLF**( _6 Z7 H% Y/ B/ w( `5 a5 r
Expected integer in line: 1271 at position 47
& {5 E- y% A- l/ j/ _ \, x, hExpected integer in line: 1272 at position 65
* I2 C, l9 c' q+ S9 W" ZExpected number in line: 1274 at position 0 and found this: VALUE. j8 ^9 @$ `5 l# d. v! J' Y$ @
Expected number in line: 1275 at position 0 and found this: **CRLF**
! ]+ R3 k! ^+ O# H. ^4 vExpected number in line: 1275 at position 0 and found this: **CRLF**
3 f/ ]7 c; V. j( oExpected integer in line: 1275 at position 5* ?; q+ J3 s1 s0 o/ Y" l* c* u
Error loading label visibility attribute from line: 12784 ` e" W2 N9 a" m1 h! U
Expected number in line: 1279 at position 0 and found this: **CRLF**- _1 q% ?7 P+ w3 n
% o, @5 z4 f3 z8 {. m6 j' YExpected number in line: 1279 at position 0 and found this: **CRLF**
, |4 v- z8 X0 f, ~7 ~Expected integer in line: 1279 at position 0
! k5 Y" ~! e4 vExpected number in line: 1279 at position 0 and found this: **CRLF**
p/ v# K8 [; sExpected number in line: 1279 at position 0 and found this: **CRLF**! c5 \. q+ ^( H7 W, Q
Error loading label mirrored attribute from line: 1279
/ c( c4 E6 J" C, ~8 nError loading label text justification attributes from line: 1279
& k2 G* i$ R- M+ u/ F9 bError loading label right-reading attribute from line: 1279& M1 h9 x, W0 u" Y
Expected number in line: 1281 at position 0 and found this: **CRLF**
2 r5 Z0 l# a; E/ k- u' C' s: xExpected number in line: 1281 at position 0 and found this: **CRLF** l1 i# T7 Y6 _9 {
Expected number in line: 1281 at position 0 and found this: **CRLF**' ?+ ^$ S; y) E- }" l1 W7 S( _
Expected integer in line: 1281 at position 47" b" E- f; W2 E
Expected integer in line: 1282 at position 65
/ L2 u- {6 [ i; Z3 q7 |. S7 {7 NExpected number in line: 1284 at position 0 and found this: VALUE
; z/ {* b+ \ K2 dExpected number in line: 1285 at position 0 and found this: **CRLF**) v5 m; M* y, g4 D- b3 W
Expected number in line: 1285 at position 0 and found this: **CRLF**$ c R/ ~2 T" ]
Expected integer in line: 1285 at position 5( d# r4 r9 X: d9 H
Error loading label visibility attribute from line: 12881 c8 e9 M3 `% D& e7 X7 |3 }. D
Expected number in line: 1289 at position 0 and found this: **CRLF**+ v6 f% X% }6 [% \
Expected number in line: 1289 at position 0 and found this: **CRLF**2 E- B4 P) `0 r0 g7 a: Y* {) D! H/ m
Expected number in line: 1289 at position 0 and found this: **CRLF** h% g8 o# U1 ^+ c: y/ \1 \5 f) l
Expected integer in line: 1289 at position 0) O7 k/ m* Q' h& [# d* U& O
0 i2 _( n ^/ ]Expected number in line: 1289 at position 0 and found this: **CRLF**
% U0 l2 k7 Z7 `, i8 c, PError loading label mirrored attribute from line: 12897 f0 \3 }1 a; b# ]' {1 b* [
Error loading label text justification attributes from line: 12896 a6 W: p! ]1 `+ {) f
Error loading label right-reading attribute from line: 1289
: U7 W5 S: g9 g0 N2 RExpected number in line: 1291 at position 0 and found this: **CRLF**
! ~% t3 ~" x! d( r) E9 _Expected number in line: 1291 at position 0 and found this: **CRLF**) _6 e* i2 |" b6 c& U) s$ Q9 F0 d
- _6 i6 g r+ U. F! qExpected integer in line: 1291 at position 47
3 N }5 Q8 L, G PExpected integer in line: 1292 at position 659 S& }- @0 j! |& n5 U' }( U
Expected number in line: 1294 at position 0 and found this: VALUE
7 v7 |8 `/ `# Y/ {" u( g" h }Expected number in line: 1295 at position 0 and found this: **CRLF**" m$ n, V4 j& U# L, a y+ V; Z
Expected number in line: 1295 at position 0 and found this: **CRLF**. H9 n8 p; \4 i7 t
Expected integer in line: 1295 at position 5
- g% I9 s" z2 J+ L& W" {Error loading label visibility attribute from line: 1298 e2 l E1 R. X; M5 \4 V
Expected number in line: 1299 at position 0 and found this: **CRLF**% z# h, f8 m$ e/ j9 K9 T P q8 p
Expected number in line: 1299 at position 0 and found this: **CRLF**% n/ n$ c5 d; l2 N; q
Expected number in line: 1299 at position 0 and found this: **CRLF**; i* V; B+ }" m7 L0 \9 _
Expected integer in line: 1299 at position 0
2 A9 P% }* \8 U3 b4 }Expected number in line: 1299 at position 0 and found this: **CRLF**
7 V) H1 d9 y$ L/ N% @. dExpected number in line: 1299 at position 0 and found this: **CRLF**
& a: C& F) o; aError loading label mirrored attribute from line: 1299& P1 a, `4 ]1 q H
Error loading label text justification attributes from line: 1299$ o5 j- k1 D5 R x( F: ~
Error loading label right-reading attribute from line: 1299
4 V5 n6 O, F5 i" h, `Expected number in line: 1301 at position 0 and found this: **CRLF**' _: u7 d& h: I2 p
1 u, ]2 D/ F' s$ a6 AExpected number in line: 1301 at position 0 and found this: **CRLF**
* j) Y2 j! J, @$ a' lExpected integer in line: 1301 at position 47
Z% M: e% B) O6 rExpected integer in line: 1302 at position 65
6 a" Y2 b" Y0 b. j: l, dExpected number in line: 1304 at position 0 and found this: VALUE
4 c5 c; r( l% b; Q2 e0 P7 U8 OExpected number in line: 1305 at position 0 and found this: **CRLF**
* b1 f1 E. i5 i' sExpected number in line: 1305 at position 0 and found this: **CRLF**) Q# ?2 e3 E( \+ k E0 D" E
Expected integer in line: 1305 at position 5& w+ }8 U& L+ }8 t+ d# P% n
Error loading label visibility attribute from line: 1308/ ]1 ~( x2 }1 w* U9 [- Q' K
Expected number in line: 1309 at position 0 and found this: **CRLF**) F/ Z# T' \( F% b4 B/ ?+ V
Expected number in line: 1309 at position 0 and found this: **CRLF**1 ?; _; o: o" |1 c
$ H9 F ]& B& |& y4 RExpected integer in line: 1309 at position 0
6 c$ A3 U( s& }" {Expected number in line: 1309 at position 0 and found this: **CRLF**
9 v2 X5 f, C% B: w& PExpected number in line: 1309 at position 0 and found this: **CRLF*** Z& X+ W& M7 y( j6 F: z0 r
Error loading label mirrored attribute from line: 1309
, b; b/ k7 x3 R0 ~+ |- [Error loading label text justification attributes from line: 13099 ^7 A* Y8 e$ O
Error loading label right-reading attribute from line: 1309
5 q; C5 \3 Q/ e' F S# W; nExpected number in line: 1311 at position 0 and found this: **CRLF**
1 A4 \* a7 f! g6 I5 y+ kExpected number in line: 1311 at position 0 and found this: **CRLF**
" L7 C8 S. Q) u: j, ]; yExpected number in line: 1311 at position 0 and found this: **CRLF**
- v7 J# \3 J) J: yExpected integer in line: 1311 at position 45( V0 U# H P$ A& P" j+ L# U6 ?
Expected integer in line: 1312 at position 65
6 [% q; O; N/ jExpected number in line: 1314 at position 0 and found this: VALUE3 M; o" }: H5 x2 T
Expected number in line: 1315 at position 0 and found this: **CRLF**
9 \. y! P! K {6 |& E: wExpected number in line: 1315 at position 0 and found this: **CRLF**
+ m7 ~. w/ `9 f% j( T4 j: U4 CExpected integer in line: 1315 at position 5% w5 i2 l$ |) B" w7 w% C, y
Error loading label visibility attribute from line: 13189 C6 I' B3 { F6 N1 W/ [
Expected number in line: 1319 at position 0 and found this: **CRLF**
6 o: T3 q& U' ~; eExpected number in line: 1319 at position 0 and found this: **CRLF**" l' e4 W9 p! B1 B8 A6 J/ b
: C: O2 |: q$ L+ rExpected integer in line: 1319 at position 0
! o, y6 w9 r/ U% |Expected number in line: 1319 at position 0 and found this: **CRLF**) O7 B* u% |! {# |! h% `
Expected number in line: 1319 at position 0 and found this: **CRLF**- o4 A! w; Y/ a% D4 q
Error loading label mirrored attribute from line: 1319* h6 `& O9 {& g* L2 F
Error loading label text justification attributes from line: 1319
" N; p6 I0 i( J. N" SError loading label right-reading attribute from line: 1319! a3 \6 Q y9 N' S' m( V- h% H- O3 A: `
Expected number in line: 1321 at position 0 and found this: **CRLF**8 C1 T! B# j) n: j1 p' k
0 P% I; Q1 f1 a0 b; l U: GExpected number in line: 1321 at position 0 and found this: **CRLF**
, e- _1 @7 I5 n0 pExpected integer in line: 1321 at position 47$ o6 r) D. T5 m7 U7 O
Expected integer in line: 1322 at position 653 E, I& d V8 z' O% V
Expected number in line: 1324 at position 0 and found this: VALUE
+ ^/ |6 q8 c+ O5 S/ A- ]Expected number in line: 1325 at position 0 and found this: **CRLF**
8 o) ^; o4 O9 p/ F! Y lExpected number in line: 1325 at position 0 and found this: **CRLF**
* l2 r9 ^" \) F7 `4 [! B3 Y7 qExpected integer in line: 1325 at position 5
, _0 [: \5 \6 Y* o2 \* f& b: UError loading label visibility attribute from line: 1328
3 H" ^: n+ e6 d' o& b, r+ h# w( R0 lExpected number in line: 1329 at position 0 and found this: **CRLF**# w2 H. Y0 X' }; @5 q
Expected number in line: 1329 at position 0 and found this: **CRLF**0 {0 m0 {2 x9 p' w1 ]
Expected number in line: 1329 at position 0 and found this: **CRLF**6 x" n+ C0 }" e8 L% D
Expected integer in line: 1329 at position 0
$ o. S; S3 D+ ^+ Y4 G6 K9 GExpected number in line: 1329 at position 0 and found this: **CRLF**6 h! Y' N8 c% V. M8 T; n
Expected number in line: 1329 at position 0 and found this: **CRLF** w/ ], O7 ~ F' @0 n
Error loading label mirrored attribute from line: 1329
0 I6 Z2 m! E( M& VError loading label text justification attributes from line: 13296 r; m# O6 \# a; Q8 l7 G
Error loading label right-reading attribute from line: 1329. Y9 W" T: z" u7 K9 b) I+ i
Expected number in line: 1331 at position 0 and found this: **CRLF**' \& A3 M/ R' Q- b1 F% S& {, D
3 c4 f+ E: I! D. j/ @Expected number in line: 1331 at position 0 and found this: **CRLF*** H V! _8 e- i2 f5 Z( x
Expected integer in line: 1331 at position 458 v4 U3 F5 I0 ~* f
Expected integer in line: 1332 at position 65
6 }5 r. u0 i0 l7 r( i3 `* {, ^Expected number in line: 1334 at position 0 and found this: VALUE( k, H7 t9 L0 p: h) R1 J, F, m
Expected number in line: 1335 at position 0 and found this: **CRLF**( C3 R: Z( e& L. J9 Q+ |$ t
Expected number in line: 1335 at position 0 and found this: **CRLF**8 B2 y7 s; F# b# j3 h: Z
Expected integer in line: 1335 at position 5- ?+ c+ T0 R! S, }5 M, \( s4 |
Error loading label visibility attribute from line: 1338& t: Y8 ?3 a* _* g& P
Expected number in line: 1339 at position 0 and found this: **CRLF**7 G& I" a9 q/ A5 B
Expected number in line: 1339 at position 0 and found this: **CRLF**1 C4 x# \5 c! K$ @1 j
Expected number in line: 1339 at position 0 and found this: **CRLF**" M; d5 ^5 m9 A0 r
Expected integer in line: 1339 at position 0
% {6 E0 s- o4 g5 q4 {4 A; bExpected number in line: 1339 at position 0 and found this: **CRLF**
2 u4 e8 O$ J4 L( D+ P! dExpected number in line: 1339 at position 0 and found this: **CRLF**( B# w8 i) V6 X! _
Error loading label mirrored attribute from line: 1339% @2 G% }7 K* j# y
Error loading label text justification attributes from line: 1339' J% `5 u+ B l) B2 q& V
Error loading label right-reading attribute from line: 1339- P# N* z+ A- m! X6 l
Expected number in line: 1341 at position 0 and found this: **CRLF**+ A4 x" J: Q/ ~" p0 Y
2 w' c4 E9 y9 o1 [8 e# d3 b: IExpected number in line: 1341 at position 0 and found this: **CRLF**
( ^! w! t' S9 W3 P! S0 QExpected integer in line: 1341 at position 47
0 r( _$ y3 V8 T: g) |$ c! hExpected integer in line: 1342 at position 656 |( G% j3 l# i$ I2 l" X
Expected number in line: 1344 at position 0 and found this: VALUE
% x8 \5 g3 Q6 a! T, qExpected number in line: 1345 at position 0 and found this: **CRLF**: U8 _) z. y% |2 j* k/ o1 s, p
Expected number in line: 1345 at position 0 and found this: **CRLF** n; |! q& ]# m! O& ]( [
Expected integer in line: 1345 at position 5
7 R5 i# d( Y! x9 PError loading label visibility attribute from line: 1348* H, C& z- i# s2 \! I) {
Expected number in line: 1349 at position 0 and found this: **CRLF**
& k8 F( t( S# lExpected number in line: 1349 at position 0 and found this: **CRLF**
0 \! V) p$ K' Z5 Z$ IExpected number in line: 1349 at position 0 and found this: **CRLF**) g2 G* }1 ^' m. J3 i
Expected integer in line: 1349 at position 0
4 U' S6 n' Y2 e3 b6 Y* nExpected number in line: 1349 at position 0 and found this: **CRLF**7 E y7 C. |4 q% p, B$ U7 B/ v8 E
" t; C; s9 p" P( O) k) W+ a5 RError loading label mirrored attribute from line: 1349% t$ q6 S' `& M+ |. p
Error loading label text justification attributes from line: 1349$ Q4 w$ y n9 j+ I+ v! _$ r( W
Error loading label right-reading attribute from line: 13490 L0 Q0 M! G9 C1 u
Expected number in line: 1351 at position 0 and found this: **CRLF**7 U4 }. x- F* p- |
, N% S( ?2 n6 X; M/ eExpected number in line: 1351 at position 0 and found this: **CRLF**; L) w U: I6 d% C
Expected integer in line: 1351 at position 47
# Y7 [+ ^3 m {$ PExpected integer in line: 1352 at position 653 W2 o; v2 ^4 ]1 Q
Expected number in line: 1354 at position 0 and found this: VALUE
8 d6 q3 b" B) w* J& @. PExpected number in line: 1355 at position 0 and found this: **CRLF**
* N/ C- c0 g/ h4 ?Expected number in line: 1355 at position 0 and found this: **CRLF**
6 d% K4 S7 X) c; m: a9 M! e2 r. o& E5 oExpected integer in line: 1355 at position 5
3 V6 i( f, u" r+ @+ T! m9 T! LError loading label visibility attribute from line: 1358
: j+ q% Y) T' `, t1 OExpected number in line: 1359 at position 0 and found this: **CRLF**9 q! D2 y+ N( R- ~2 N! u9 [
) U: H9 J5 P0 D) O% uExpected number in line: 1359 at position 0 and found this: **CRLF**1 b1 w2 D$ E' [
Expected integer in line: 1359 at position 0/ G# y X- U, Z' I+ z) K
Expected number in line: 1359 at position 0 and found this: **CRLF**/ _) I! }9 k% M- a* w* J
Expected number in line: 1359 at position 0 and found this: **CRLF**7 T; @, b* f! X, O/ W( r
Error loading label mirrored attribute from line: 1359# S/ @4 w- _9 L: D# p# L9 e8 w
Error loading label text justification attributes from line: 1359+ b2 u" c* j) S! W) M" Y
Error loading label right-reading attribute from line: 1359: \9 I4 M7 w* w( v
Expected number in line: 1361 at position 0 and found this: **CRLF**
# G3 A+ C7 T. d- z$ x8 r; E/ A/ PExpected number in line: 1361 at position 0 and found this: **CRLF**( M2 w2 z- |9 p C, Q, \9 y' [
, X; u m- y. J3 `" AExpected integer in line: 1361 at position 47
; h1 C. }$ K$ r# q8 c9 @) O% LExpected integer in line: 1362 at position 65( e/ Z( y6 M" b6 [, u: {+ l
Expected number in line: 1364 at position 0 and found this: VALUE0 D; D, G9 c9 A# c8 {+ X" o8 U3 D' C
Expected number in line: 1365 at position 0 and found this: **CRLF**$ F r9 m: o+ R {
- T! U# ^$ W3 l- {" A" DExpected integer in line: 1365 at position 5
$ g' Y. z' `& ^+ c: LError loading label visibility attribute from line: 1368
2 \( _- p' n& ?2 [9 DExpected number in line: 1369 at position 0 and found this: **CRLF**, j. R% U1 a- `! ~ o
Expected number in line: 1369 at position 0 and found this: **CRLF**) V) r* k9 |. b. B) L' c
Expected number in line: 1369 at position 0 and found this: **CRLF**+ N- N7 ~! t4 u y) g0 `" f
Expected integer in line: 1369 at position 0
8 E Y; V0 v2 WExpected number in line: 1369 at position 0 and found this: **CRLF**+ g$ @( Y% o6 Z/ G5 O3 l, N0 v
Expected number in line: 1369 at position 0 and found this: **CRLF**7 R. r$ w. V; E, ]% ]; ~ C
Error loading label mirrored attribute from line: 1369
) V# _- ^0 O$ G9 [$ r2 |Error loading label text justification attributes from line: 1369 d9 t; I7 `7 U
Error loading label right-reading attribute from line: 1369: s/ d9 j4 P' ]+ b
Expected number in line: 1371 at position 0 and found this: **CRLF**, m2 k, v" s4 U( @/ B& `
$ {( _) p) u1 r) G6 V) AExpected number in line: 1371 at position 0 and found this: **CRLF**
2 a4 o, s1 L6 U5 I6 V' w+ mExpected integer in line: 1371 at position 47! [% K1 W/ j3 L9 I8 ~
Expected integer in line: 1372 at position 65
: T- [ d- O% |0 F9 bExpected number in line: 1374 at position 0 and found this: VALUE( b. U% z7 i& _( u7 r7 r+ [# t
Expected number in line: 1375 at position 0 and found this: **CRLF**
8 P8 y$ P, a# }Expected number in line: 1375 at position 0 and found this: **CRLF**- q. C w7 C! c3 S! A
Expected integer in line: 1375 at position 5) C( I6 k/ X/ C: t& b7 C; T* _
Error loading label visibility attribute from line: 1378
' E1 S X/ L# o" i" DExpected number in line: 1379 at position 0 and found this: **CRLF**8 l, u; k- g6 Z
Expected number in line: 1379 at position 0 and found this: **CRLF**! d+ x& A. D: [! Q
Expected number in line: 1379 at position 0 and found this: **CRLF**8 Y- C+ o5 V2 Q6 c
Expected integer in line: 1379 at position 0
5 e ?; H# B( e3 { XExpected number in line: 1379 at position 0 and found this: **CRLF**
8 j( W& Z/ s* E' @- {6 g" `Expected number in line: 1379 at position 0 and found this: **CRLF**& O7 U9 e- i; J0 i, G* g9 V
Error loading label mirrored attribute from line: 13794 E* R# G2 x( L4 y' a3 j
Error loading label text justification attributes from line: 1379
1 n+ C% u) @: o L0 H% Y. m0 v1 CError loading label right-reading attribute from line: 1379
0 D' Y4 I8 i6 }( D7 nExpected number in line: 1381 at position 0 and found this: **CRLF**2 H" z0 G4 R( m, |3 ]0 p3 E
Expected number in line: 1381 at position 0 and found this: **CRLF**' ?9 i* Q, W+ G1 K# ] U
Expected number in line: 1381 at position 0 and found this: **CRLF**- E: B) [" H- Z# u# @% ^ c" z
Expected integer in line: 1381 at position 47- ?& [$ h+ X0 R4 E. Z- k, j
Expected integer in line: 1382 at position 65
: ?* e/ }/ J9 j) O, f: |! M9 Y7 MExpected number in line: 1384 at position 0 and found this: VALUE5 d. }2 k5 a2 d+ u
Expected number in line: 1385 at position 0 and found this: **CRLF**
; y" M& v: d( B* |' R% AExpected number in line: 1385 at position 0 and found this: **CRLF**
/ {# t1 I0 [: e) W! R2 TExpected integer in line: 1385 at position 5
3 P/ G" J. g9 N/ i8 I2 oError loading label visibility attribute from line: 1388" d& E) z3 m' m5 M
Expected number in line: 1389 at position 0 and found this: **CRLF**, m* R b0 I; O1 C
Expected number in line: 1389 at position 0 and found this: **CRLF**1 V; A0 z# I* g% ^2 I; ~6 e+ \
$ v: B7 ~- k; g8 Y" BExpected integer in line: 1389 at position 0$ X' O- e, q' V2 y* Q/ S: }, P; G
- V, S7 a6 A- i! |8 @* ?: [+ I( tExpected number in line: 1389 at position 0 and found this: **CRLF**
{. F- }1 L. Q5 W4 c% T$ G' zError loading label mirrored attribute from line: 1389
6 R/ H" } `) `: f. R+ w$ ]+ s4 GError loading label text justification attributes from line: 13896 j: m3 f k R1 D8 J
Error loading label right-reading attribute from line: 1389
: Y5 B8 ]+ P) i1 IExpected number in line: 1391 at position 0 and found this: **CRLF**( t7 V" u( E; h$ Y
2 c1 F I, u/ i# a1 uExpected number in line: 1391 at position 0 and found this: **CRLF**
7 Z0 R' H/ g' ]* f7 C* N6 s- }# PExpected integer in line: 1391 at position 44: j7 l9 x% s+ f* K2 D
Expected integer in line: 1392 at position 65/ F( I, x' i C: H/ r1 i3 Y6 \
Expected number in line: 1394 at position 0 and found this: VALUE
( y9 K$ A) u4 e- dExpected number in line: 1395 at position 0 and found this: **CRLF**; Y' `: d0 d# h! \ I5 t
" E+ f/ z/ T% g: {, E$ {Expected integer in line: 1395 at position 55 ]2 w1 i( [. A# c
Error loading label visibility attribute from line: 13981 \- Z5 k v( C2 G8 x& k
Expected number in line: 1399 at position 0 and found this: **CRLF**- q' _& k" R/ T. q
Expected number in line: 1399 at position 0 and found this: **CRLF**1 q3 y+ B0 {$ B5 Q1 \- V% R: ?0 R. Y Q
Expected number in line: 1399 at position 0 and found this: **CRLF**& e2 q: T; {2 o2 P% ?# @5 H+ ?
Expected integer in line: 1399 at position 0
" C" `/ Y# E/ O) J9 i0 FExpected number in line: 1399 at position 0 and found this: **CRLF**' |" _! b9 }$ b: |/ Y( ^( s
* B( d* M$ }) k" C! SError loading label mirrored attribute from line: 13996 V/ T$ `( e- K: v o- N1 |1 p
Error loading label text justification attributes from line: 1399' M# j0 n0 @. `6 Y) p
Error loading label right-reading attribute from line: 1399
+ d/ O0 A% n! F |! AExpected number in line: 1401 at position 0 and found this: **CRLF**
3 i7 O$ q7 ^* l7 q, UExpected number in line: 1401 at position 0 and found this: **CRLF**
* P; H4 Q' q9 q) c$ YExpected number in line: 1401 at position 0 and found this: **CRLF**
# _ g+ W! G' N, g( o# k( zExpected integer in line: 1401 at position 46
: q0 w, k! Q/ Y/ YExpected integer in line: 1402 at position 658 L$ _9 }: g7 n: a3 X4 T! {, T
Expected number in line: 1404 at position 0 and found this: VALUE
. Z* n. R6 v6 P. J' L& vExpected number in line: 1405 at position 0 and found this: **CRLF**$ F. f# r# y, [ O! \' y, A/ O
$ K% h, N3 J. @$ @. JExpected integer in line: 1405 at position 5( q$ O6 H) v8 [' N; c
Error loading label visibility attribute from line: 1408
7 `1 ?0 v$ v. h8 S2 F* |Expected number in line: 1409 at position 0 and found this: **CRLF**0 I8 F0 U; h' S0 q* s% ?
Expected number in line: 1409 at position 0 and found this: **CRLF**5 u# R7 p$ j: g* {% |# ~0 n
Expected number in line: 1409 at position 0 and found this: **CRLF**5 @8 m+ l2 \: P
Expected integer in line: 1409 at position 0
1 k+ B% f [# C( ]2 y( XExpected number in line: 1409 at position 0 and found this: **CRLF**
R9 l, W/ I- e2 ^/ u& IExpected number in line: 1409 at position 0 and found this: **CRLF**
5 X# B9 U5 R$ N$ @Error loading label mirrored attribute from line: 1409" P9 T9 n; r; B& ^3 T' v) Y. A
Error loading label text justification attributes from line: 1409
& V# T% C3 n7 U4 v! PError loading label right-reading attribute from line: 1409
, a- H9 `8 g( p* g# lExpected number in line: 1411 at position 0 and found this: **CRLF**
1 L% ?/ d' W0 o3 E2 x+ O" MExpected number in line: 1411 at position 0 and found this: **CRLF**
# ]! m% ?$ C) v1 t% z* qExpected number in line: 1411 at position 0 and found this: **CRLF**
y5 T: X" d$ n0 g0 z3 F2 `3 |0 kExpected integer in line: 1411 at position 46+ ^9 `7 r; g q; Y5 P( q
Expected integer in line: 1412 at position 65; R, ?% I7 q Z2 `/ [0 D$ {, J
Expected number in line: 1414 at position 0 and found this: VALUE
9 Z4 _& E. \. p j9 m/ g YExpected number in line: 1415 at position 0 and found this: **CRLF**
" s, J! |% C/ pExpected number in line: 1415 at position 0 and found this: **CRLF**
' J. l" F6 U5 L) }/ [' w9 {" MExpected integer in line: 1415 at position 5+ g5 q2 q1 {7 }/ j# \. i
Error loading label visibility attribute from line: 1418
6 }. M! v3 J9 j# b9 |Expected number in line: 1419 at position 0 and found this: **CRLF**; k( R& _- G; O% g$ G! k
Expected number in line: 1419 at position 0 and found this: **CRLF**9 C' _! k S3 U0 e( Z/ U
Expected number in line: 1419 at position 0 and found this: **CRLF**6 y( t& F4 _, P6 F% T* |4 s7 l3 Q
Expected integer in line: 1419 at position 0# X* F8 q6 I1 r; o( A7 [& T
- F0 m" y- N" y1 Z4 kExpected number in line: 1419 at position 0 and found this: **CRLF**5 N& S9 O8 F; Y2 h9 V3 Z( J
Error loading label mirrored attribute from line: 1419
% t! ^$ q! `4 z$ r7 [3 D0 xError loading label text justification attributes from line: 1419
0 w0 b) y7 |- v2 q% s. g5 GError loading label right-reading attribute from line: 1419
9 C0 B0 s* E% A1 _) }Expected number in line: 1421 at position 0 and found this: **CRLF**( R _ B; i8 b/ h. ~3 b
: `/ C3 Q/ D. F2 i) q: ]+ dExpected number in line: 1421 at position 0 and found this: **CRLF**
* X3 L0 M% R; g9 x8 V [Expected integer in line: 1421 at position 46+ L, S" S# t& J! @; _; ~" p; X
Expected integer in line: 1422 at position 65
& Y% g1 G" l7 e# h+ V, DExpected number in line: 1424 at position 0 and found this: VALUE
5 H" [3 o) d. d6 x8 ^' q1 ]" ~Expected number in line: 1425 at position 0 and found this: **CRLF**, U# Q1 C: A) B
7 D* y: {8 s( |9 i9 N: f' Z: lExpected integer in line: 1425 at position 5
) y. ?' k% R8 hError loading label visibility attribute from line: 14281 o) v* M* i. n: G T
Expected number in line: 1429 at position 0 and found this: **CRLF**
2 i; J! ~3 q. w, _2 v g1 EExpected number in line: 1429 at position 0 and found this: **CRLF**3 g! h4 f1 V" r; k* ]( Z
Expected number in line: 1429 at position 0 and found this: **CRLF**7 T/ J- r1 k9 w: Y. H
Expected integer in line: 1429 at position 0' V( k2 K+ w y/ e V
Expected number in line: 1429 at position 0 and found this: **CRLF**/ r) Y' N/ o1 l5 J
0 u6 G# X0 P2 R: \: W W2 KError loading label mirrored attribute from line: 1429$ N- e1 a1 c- L9 s
Error loading label text justification attributes from line: 1429
. ]: v3 z5 j: `1 I$ N1 N- eError loading label right-reading attribute from line: 1429
7 @$ y( k9 g K2 gExpected number in line: 1431 at position 0 and found this: **CRLF**
5 A6 {' s/ h5 A3 ]( h' EExpected number in line: 1431 at position 0 and found this: **CRLF**% S A6 {. X0 {$ k: Q* R+ P
3 U( D, H2 j+ RExpected integer in line: 1431 at position 44
, y; [/ z( Q1 r- O5 b- X CExpected integer in line: 1432 at position 65/ U+ u2 ^ v/ {1 j) C" E m
Expected number in line: 1434 at position 0 and found this: VALUE3 B/ s; a% m& l
Expected number in line: 1435 at position 0 and found this: **CRLF**
( Y; T; R1 P! \- M, eExpected number in line: 1435 at position 0 and found this: **CRLF**2 E7 D$ N+ r; u* ?: S3 m
Expected integer in line: 1435 at position 5# h1 Q/ L$ I4 j# t$ P* A
Expected number in line: 1441 at position 0 and found this: C19; L3 g- L6 G- H1 U* g# V0 e
Expected number in line: 1442 at position 0 and found this: **CRLF**& X3 s+ E' U" J0 q/ A
Expected number in line: 1442 at position 0 and found this: **CRLF**% V7 ^) W( U5 J) a% j( s. c F: L. L
Expected integer in line: 1442 at position 32# [) `2 V7 K# l8 v4 n
Expected number in line: 1444 at position 0 and found this: VALUE! {7 Z: c; m2 ^) |) d4 T4 a
Expected number in line: 1445 at position 0 and found this: **CRLF**
% R- H% ?2 a! L: O4 x5 U4 ?Expected number in line: 1445 at position 0 and found this: **CRLF**. S7 Y' {9 m- ]9 M
Expected integer in line: 1446 at position 0
6 s0 T- E- E# Y) OExpected number in line: 1451 at position 0 and found this: C20
3 \8 q1 m% u: L% ^, z3 H1 ?/ lExpected number in line: 1452 at position 0 and found this: **CRLF**( h& V' b6 ]/ C% R) O# C
3 v5 P$ H' S$ pExpected integer in line: 1452 at position 32
: r4 V# I4 \& x8 d5 ZExpected number in line: 1454 at position 0 and found this: VALUE
# v9 m# l, \7 NExpected number in line: 1455 at position 0 and found this: **CRLF**
, P4 I/ g$ s1 h/ eExpected number in line: 1455 at position 0 and found this: **CRLF**8 s3 J. j: @6 l2 Y9 f, y) X* a
Expected integer in line: 1456 at position 0
7 i8 i/ X' v; Y/ R0 ]2 W8 [Expected number in line: 1461 at position 0 and found this: C23
& O' t8 `) Z& P1 eExpected number in line: 1462 at position 0 and found this: **CRLF**
# t( s- c4 \, ^$ L7 b: u6 I; f. wExpected number in line: 1462 at position 0 and found this: **CRLF**
$ c' \9 A j. @# X2 k9 ?1 q9 AExpected integer in line: 1462 at position 32# v7 E. P% Q/ K4 a3 A1 i- Q, d
Expected number in line: 1464 at position 0 and found this: VALUE
6 z* j+ A+ b8 DExpected number in line: 1465 at position 0 and found this: **CRLF**( e# H6 r1 V1 H2 {) ~
: y9 a; }7 w$ J0 U: y4 ?Expected integer in line: 1466 at position 0' o3 | a" b4 x y( Y+ U5 _/ q, V
Expected number in line: 1471 at position 0 and found this: C25
- e+ ^3 A3 R2 C& T$ PExpected number in line: 1472 at position 0 and found this: **CRLF**7 }1 R; W3 T0 a
; u h3 n5 Z" }, V5 G- {/ e& @Expected integer in line: 1472 at position 32( R3 }5 n$ Q) e( d6 O( T# ?
Expected number in line: 1474 at position 0 and found this: VALUE1 t3 H. a% Q( b+ ~
Expected number in line: 1475 at position 0 and found this: **CRLF**
]8 ^# @/ l* P$ O5 }2 P7 ~2 VExpected number in line: 1475 at position 0 and found this: **CRLF**
" R; `; j7 z% q$ o" _& X5 C, d0 TExpected integer in line: 1476 at position 0
$ R9 k$ ?% T( D4 p! G3 `3 ~0 |& CExpected number in line: 1481 at position 0 and found this: C28
, E4 y2 s6 Y: v4 F: J( F" V3 rExpected number in line: 1482 at position 0 and found this: **CRLF**
/ v! T7 P9 _! t b8 M* m+ WExpected number in line: 1482 at position 0 and found this: **CRLF**5 `* e* Q m# a! ]
Expected integer in line: 1482 at position 32
# g% _5 m: j( U# A8 L: \7 p- kExpected number in line: 1484 at position 0 and found this: VALUE+ A1 r4 i% J1 T+ ^& e1 A
Expected number in line: 1485 at position 0 and found this: **CRLF**
" i ]+ D! N0 Z4 d n/ z, [& K8 a: HExpected number in line: 1485 at position 0 and found this: **CRLF**6 [/ \3 c3 |7 Q# [, O, C$ x
Expected integer in line: 1486 at position 0( {! P2 H2 y. [: j
Expected number in line: 1491 at position 0 and found this: C36& s: u8 L& f q; ]+ S
Expected number in line: 1492 at position 0 and found this: **CRLF**
/ h: a6 q2 V+ o4 bExpected number in line: 1492 at position 0 and found this: **CRLF**
3 {+ z8 O3 v: h8 _ nExpected integer in line: 1492 at position 32$ H/ q' L; A3 h) X
Expected number in line: 1494 at position 0 and found this: VALUE' f0 ?- }1 O2 t) u$ ]* z& ~
Expected number in line: 1495 at position 0 and found this: **CRLF**
1 e E( M. l& B6 @Expected number in line: 1495 at position 0 and found this: **CRLF**0 d, c/ H) z8 L" T8 W
Expected integer in line: 1496 at position 0+ j- e5 ?# ^7 z- x/ J
Expected number in line: 1501 at position 0 and found this: C40# P3 X, D/ _, L) w
Expected number in line: 1502 at position 0 and found this: **CRLF**
& M( Q. u C! k7 @0 Q2 DExpected number in line: 1502 at position 0 and found this: **CRLF**
6 M& I& g2 f# @6 `3 K3 O! L7 s2 mExpected integer in line: 1502 at position 324 m7 p' k% d! v9 Y/ r
Expected number in line: 1504 at position 0 and found this: VALUE
5 d$ }; T6 ?, qExpected number in line: 1505 at position 0 and found this: **CRLF**0 p5 F, u% `8 Q. F! H7 j c Z+ g
: v2 @/ \2 C+ v6 v" f1 ?# @Expected integer in line: 1506 at position 0 Y8 e& ~* _8 G0 A5 q# W6 b* M' x
Expected number in line: 1511 at position 0 and found this: C433 f' O% |3 m3 I C1 m' o
Expected number in line: 1512 at position 0 and found this: **CRLF**4 i8 ~5 g6 }9 O" z
8 Z. U! E0 \5 C) p! z9 T& FExpected integer in line: 1512 at position 32
- B, k3 R. X8 ^$ G5 S4 I% s* Y" yExpected number in line: 1514 at position 0 and found this: VALUE
+ L) ~- D d& T' N* ]& ?Expected number in line: 1515 at position 0 and found this: **CRLF**1 J% g/ f$ T0 l$ U$ h: ^; `8 V
2 g& E! S3 x; ~6 f+ g/ i% HExpected integer in line: 1516 at position 0
- ?+ \3 L% W" S3 X* E. U0 H1 VExpected number in line: 1521 at position 0 and found this: C7
3 o) r6 M- h- H9 GExpected number in line: 1522 at position 0 and found this: **CRLF**6 u8 g2 O, k9 U C3 ~% k$ M1 p
Expected number in line: 1522 at position 0 and found this: **CRLF**: M% H# s8 E6 E$ ]6 I: s: a' [
Expected integer in line: 1522 at position 32
; P1 W+ x; A3 B0 w. QExpected number in line: 1524 at position 0 and found this: VALUE
3 R* G7 I7 ~- p- kExpected number in line: 1525 at position 0 and found this: **CRLF**. Q4 k- z$ i# `2 m" W8 r
Expected number in line: 1525 at position 0 and found this: **CRLF**: ~- z" q0 C' U; P2 K7 ]1 d
Expected integer in line: 1526 at position 0
; Z1 ?6 R' `6 V- LExpected number in line: 1531 at position 0 and found this: R12: N) J3 u! x$ r3 v8 O! O! I
Expected number in line: 1532 at position 0 and found this: **CRLF**. R4 n p! H: o/ f# \9 A' N" J
" q( L+ d2 B+ p2 D- i6 ?' F0 @Expected integer in line: 1532 at position 326 p2 J% g3 N: k3 L# v! A( x
Expected number in line: 1534 at position 0 and found this: VALUE6 Y4 c7 [. M W: \: {( P1 l- _
Expected number in line: 1535 at position 0 and found this: **CRLF**; T$ W7 P+ o5 {' w( V
Expected number in line: 1535 at position 0 and found this: **CRLF**; N: t) ]" K9 }' }
Expected integer in line: 1536 at position 0" I2 d9 s4 @: Q2 f5 j9 K5 C
Expected number in line: 1541 at position 0 and found this: R22/ g( H" g3 W$ q! c
Expected number in line: 1542 at position 0 and found this: **CRLF**0 |/ n$ {0 Z& J2 y
Expected number in line: 1542 at position 0 and found this: **CRLF**" R% h9 t# ~+ d& U. F
Expected integer in line: 1542 at position 32, ]) `3 g$ Y0 _, R( Q3 `
Expected number in line: 1544 at position 0 and found this: VALUE
9 ^. f l* O7 |5 {- ^- Y; F6 PExpected number in line: 1545 at position 0 and found this: **CRLF**. Z+ [9 |: k& s9 T8 w# j
Expected number in line: 1545 at position 0 and found this: **CRLF**& O+ F% Z6 f" }! `" K
Expected integer in line: 1546 at position 0* G m- ~% |; b( K2 V# {" A/ h" m
Expected number in line: 1551 at position 0 and found this: R28
* H4 X/ J ]( [+ I1 C( RExpected number in line: 1552 at position 0 and found this: **CRLF**
J2 v; Z- l5 BExpected number in line: 1552 at position 0 and found this: **CRLF**
( L X# N s) x- K/ \Expected integer in line: 1552 at position 32
9 \4 {* d, Z1 |5 O; oExpected number in line: 1554 at position 0 and found this: VALUE
+ Y+ G! N" q8 k9 X& VExpected number in line: 1555 at position 0 and found this: **CRLF**. _4 Y J* M9 d! e
8 @& a& X4 \: w0 {; c7 a; R. eExpected integer in line: 1556 at position 0
- J9 g0 L2 I) a1 RExpected number in line: 1561 at position 0 and found this: R31
% H$ Q$ H% K) p9 QExpected number in line: 1562 at position 0 and found this: **CRLF**% h1 a& h: Q5 E1 c
# e9 D: S! I4 z( ^! eExpected integer in line: 1562 at position 32* u9 f- ]+ ?, d3 ]; j! n
Expected number in line: 1564 at position 0 and found this: VALUE, s7 L4 y/ R& f8 D# @/ C, N- X3 K4 W
Expected number in line: 1565 at position 0 and found this: **CRLF**
3 t7 f6 R- f6 s3 H+ ZExpected number in line: 1565 at position 0 and found this: **CRLF*** J( k) h3 Q4 ^( ^; E, R: P* v
Expected integer in line: 1566 at position 02 C" Y6 L# A# `8 f5 {8 x8 q
Error loading label visibility attribute from line: 1568- P- [8 M- T+ L6 M2 e) W |( S
Expected number in line: 1569 at position 0 and found this: **CRLF**
' a" v8 t# D0 fExpected number in line: 1569 at position 0 and found this: **CRLF**
- i! t& L7 B6 \7 eExpected number in line: 1569 at position 0 and found this: **CRLF**
8 c) Z6 Q' c/ W7 @$ wExpected integer in line: 1569 at position 0' e' }) M7 k, V/ J/ {
Expected number in line: 1569 at position 0 and found this: **CRLF**0 X+ \0 v& \6 e0 C
Expected number in line: 1569 at position 0 and found this: **CRLF**" [6 Q v4 C' n1 H0 f
Error loading label mirrored attribute from line: 1569
8 D' q1 Q B) o5 r0 V' jError loading label text justification attributes from line: 1569' K! v- Y* r/ y# }6 t3 H5 B) [6 z
Error loading label right-reading attribute from line: 15698 B( Y1 I5 Z4 e
Expected number in line: 1571 at position 0 and found this: R26
* z) X- N' e, F4 U; M5 a$ I( V5 RExpected number in line: 1572 at position 0 and found this: **CRLF**% T- ]6 W7 w8 n, q
Expected number in line: 1572 at position 0 and found this: **CRLF**& }+ a" l) O0 l- O% w
Expected integer in line: 1572 at position 320 D5 \- K, `% h5 E
Expected number in line: 1574 at position 0 and found this: VALUE
' J, G1 E1 {% o8 yExpected number in line: 1575 at position 0 and found this: **CRLF**. K# n% ^! A4 `5 K% J% R
Expected number in line: 1575 at position 0 and found this: **CRLF**7 q9 \4 _' X; O4 a
Expected integer in line: 1576 at position 0+ X U) |& A+ B+ e% Q+ ^0 o
Error loading label visibility attribute from line: 15784 Z" r& L" w; w; T- k
Expected number in line: 1578 at position 5 and found this: Type" ^) ^, [: |" d- R# m( B7 r& t6 y
Expected number in line: 1579 at position 0 and found this: **CRLF**
: j6 h: a+ }0 r( M7 R0 r' _0 p8 C) GExpected number in line: 1579 at position 0 and found this: **CRLF**
0 p' R- X, _, D1 F$ QExpected integer in line: 1579 at position 0
0 P" K) r0 X% `/ _7 N$ A( R C5 lExpected number in line: 1579 at position 0 and found this: **CRLF**, ~) f/ c2 s7 |+ y1 K3 B3 I
Expected number in line: 1579 at position 0 and found this: **CRLF**" Q0 h% ^8 o0 L
Error loading label mirrored attribute from line: 15797 U; |" e Q3 i
Error loading label text justification attributes from line: 1579
' P* j% x8 M N1 x* b4 a3 S1 l3 MError loading label right-reading attribute from line: 1579+ u! y! S5 r/ a, {; f9 L/ s. d0 T& [
Expected number in line: 1581 at position 0 and found this: R0 A' S) B4 H+ ]0 g' o) K
Expected number in line: 1582 at position 0 and found this: **CRLF**1 v0 _! t* B3 i1 }9 X5 q
Expected number in line: 1582 at position 0 and found this: **CRLF**) L6 u ~6 K3 ^4 x* v
Expected integer in line: 1582 at position 324 k& ?: v% ] @
Expected number in line: 1584 at position 0 and found this: **CRLF**
( x e7 u5 Y! b2 Q H- e% `) P% HExpected number in line: 1584 at position 0 and found this: **CRLF**; |5 r9 C5 x3 Q/ M
# r' H' e( _) Q5 D0 nExpected integer in line: 1584 at position 32
4 o0 ~% \6 Z: H6 e( fExpected number in line: 1587 at position 0 and found this: **CRLF**
: z9 I" _% q o% ~2 _0 \7 zExpected number in line: 1587 at position 0 and found this: **CRLF**
+ Q: ?3 R4 @6 s m s$ R, B# JExpected number in line: 1587 at position 0 and found this: **CRLF** b& N% l, B3 \2 }5 s9 g# F
Expected integer in line: 1588 at position 0
9 c! K2 K6 w$ Y! W" W: XErrors encountered while processing of *PART* section.( z {1 \: d- I/ X* @% T
Expected number in line: 2249 at position 0 and found this: R19.2' I% z! i0 d1 C6 E
Expected number in line: 2250 at position 0 and found this: **CRLF**0 s5 v% L5 a, j
Error in line: 2250& o6 Q. {5 ?$ h
Error loading connection list for connection from pin: J2.2 to pin: C31.10 L9 V; G0 q) c; t- X( K# A% _
Expected number in line: 2367 at position 0 and found this: C43.1) a5 ?2 X" g4 I
Expected number in line: 2368 at position 0 and found this: **CRLF**
( K; W0 ^7 |3 Z/ x/ i) IError in line: 23680 o+ Q7 i; M! t5 ^/ h+ p/ I) _1 b
Error loading connection list for connection from pin: R30.1 to pin: R28.1" X6 g2 R$ W8 _ F
Expected number in line: 2657 at position 0 and found this: J1.11, v# Q, O d8 A* h
Expected number in line: 2658 at position 0 and found this: **CRLF**9 k4 v4 \5 c9 y
Error in line: 2658
+ d; e5 P9 i0 z) o1 Q F2 f! SError loading connection list for connection from pin: J2.3 to pin: J1.10- F9 L# H4 A0 }$ n& {) o
Error, expected keyword: 'MIN_LENGTH' in line: 14180
* k+ ]6 X1 z9 y2 hError, expected keyword: 'MAX_LENGTH' in line: 141812 R2 t! T7 G4 Z+ f/ t4 c
Error, expected keyword: 'GAP' in line: 14182* p0 M2 e0 X$ b) ?+ @3 O& O
Error loading differential pair rule: D1
# e! I8 c8 D, e* gError, expected keyword: 'MIN_LENGTH' in line: 14188
/ s0 ], R$ T9 Q3 U: b+ V4 t) kError, expected keyword: 'MAX_LENGTH' in line: 141899 q F6 l3 `9 b) W" m
Error, expected keyword: 'GAP' in line: 141906 p' q4 J' h( _1 [% h
Error loading differential pair rule: D2
9 v: `, c' X; i' [Error, expected keyword: 'MIN_LENGTH' in line: 14196
/ i4 V8 F( r" k6 u* `3 kError, expected keyword: 'MAX_LENGTH' in line: 14197; |( x$ \, L1 L+ I* f; F
Error, expected keyword: 'GAP' in line: 14198
$ Y/ p1 e1 ]3 T" mError loading differential pair rule: D3" ]4 x5 ?. @7 Q D
Error, expected keyword: 'MIN_LENGTH' in line: 142041 ]. d* i# e+ A% p0 ^4 ]% @- s
Error, expected keyword: 'MAX_LENGTH' in line: 14205/ x: q* A( Y4 [1 E$ H% k/ O* i
Error, expected keyword: 'GAP' in line: 14206" U8 v( e* j5 W0 g
Error loading differential pair rule: D4* y% d, {9 C, ]) @; m! a/ m
Error, expected keyword: 'MIN_LENGTH' in line: 142128 H8 M, I+ I' Q5 l9 `5 l+ w5 e) t
Error, expected keyword: 'MAX_LENGTH' in line: 14213
0 p- s" |4 S3 k% Y% OError, expected keyword: 'GAP' in line: 14214/ ?6 i2 q6 B" ]: i* l
Error loading differential pair rule: D5
1 w# c$ k- W* x. \Error, expected keyword: 'MIN_LENGTH' in line: 14220
4 {8 u: i2 F8 B( \5 C" K" qError, expected keyword: 'MAX_LENGTH' in line: 142219 l4 a3 w9 L# c6 {+ V
Error, expected keyword: 'GAP' in line: 14222
. q- Y/ E) X" g7 r2 F6 u) VError loading differential pair rule: D6
' d' C% @0 ]+ f
# ~, c0 y, y. j5 OImport Errors : 26
0 Z }4 ]% Y# jFootprint not found for component: C12, of parttype: 0402+ w, T* ?+ c/ D. A) }
Component can't be imported.9 T" ]' m7 e8 v+ i
Footprint not found for component: C2, of parttype: 04029 z8 `+ A4 s$ Q. Y* X, l& Z0 B
) J1 e: S" @: V: C# EFootprint not found for component: C21, of parttype: 0402
8 L x$ e+ t: E5 r! {0 OComponent can't be imported.( |/ n! S. U. C E& [
Footprint not found for component: C24, of parttype: 0402+ b( w/ H. w7 r/ W! ^& _
Component can't be imported.5 ~5 j, Z* m; x s2 V$ Y3 d9 A f
Footprint not found for component: C26, of parttype: 0402) z1 l' i3 k& W9 R8 i/ G
, Z$ n# X- O$ ~Footprint not found for component: C29, of parttype: 0402
9 z) L( P( [+ }9 B5 mComponent can't be imported.! b! f3 }# r+ b/ t( b
Footprint not found for component: C37, of parttype: 0402# E) r* c5 A8 r$ l# x9 m+ e
7 R% |' V/ W1 i) [( Y' _% j! PFootprint not found for component: C42, of parttype: 0402
" o8 O2 @7 q) h) R4 yComponent can't be imported.
" x* y8 k; k" u! o% D0 l/ N* wFootprint not found for component: C5, of parttype: 0402
% [, e" W$ }: Z, O" i) H; e3 D3 ^+ TComponent can't be imported.: |; k1 G0 Z: C, K( }& k
Footprint not found for component: C9, of parttype: 0402
7 M& F$ O/ }5 n2 n# e3 |1 GComponent can't be imported.
0 ?2 g9 G( Y. S9 c) w/ f: nFootprint not found for component: R14, of parttype: 04027 e9 ^( i, w0 k& Q z6 t+ {
Component can't be imported.9 N# X- ~. l% d7 d
Footprint not found for component: R27, of parttype: 0402
* b* }3 n2 p% u9 \3 yComponent can't be imported.4 R* @5 f) J! W1 a4 Z
Footprint not found for component: R30, of parttype: 04027 j2 J& _2 Q' r" f$ r( [2 {* {
4 ?/ `6 C. r+ U- @# c
& O7 U4 }. g9 B8 ^' G6 xLoad Warnings : 86
' y. u- y& O6 w, |The smallest available values for diameter and hole size will be taken for via: JMPVIA_AAAAA/ R" D, o9 W) k$ K0 S- f
Via padstack is unsupported.9 I1 B$ Q. k& h+ f
The smallest available values for diameter and hole size will be taken for via: STANDARDVIA5 u5 t/ ?* C' L. V
$ K7 h% m( r! j5 M& ]: G$ ]6 E4 TThe smallest available values for diameter and hole size will be taken for via: STDPROVIA R9 X1 g6 d1 T0 C& e/ h3 u6 Q; Q( K
1 h+ E" G5 k5 W% aError in line: 1077.4 m' o- A) a: j4 L2 F, {; O
Nothing to load, empty line!
) z; ?7 g) M7 \$ Q4 oError in line: 1101., r6 R- Y& H5 Z3 b5 H
. c! M; x5 b0 q1 aError in line: 1122.- c6 }5 N4 A. M- T! L3 |" u5 ^, a
Nothing to load, empty line!+ {2 R9 r3 h) e1 Y
Error in line: 1162.
5 Y1 Z2 c- f# X% y6 n3 W% DNothing to load, empty line!$ ~8 V# l7 w$ D! y C
Error in line: 1228.2 F3 A/ k8 ]" H: M/ G" X, ?
Nothing to load, empty line!- V1 D* w8 z! ~4 _. ]* N
Error in line: 1238., M5 v4 F7 x- r
Nothing to load, empty line!4 ?* [# k% J. ?8 N
Error in line: 1248. J. p$ j1 Z& M$ T: K2 M5 _
2 o& c& E- }# J* gError in line: 1258.5 m" J" m+ R, H5 @; p9 {
/ O6 f: P/ T% W; t& A2 O* k1 T, R& fError in line: 1268.
- R" E7 L# u$ G1 h5 n. HNothing to load, empty line!
9 J: _& Z( @7 f# ~Error in line: 1278./ P; n3 j. R+ i; Z
Nothing to load, empty line!6 N& ?7 C1 M* X/ ^4 A7 w' U3 d
Error in line: 1288.
: B3 X; @2 F: } s8 [7 b" xNothing to load, empty line!, V$ F+ [- K: W j
Error in line: 1298.
& J3 J+ t/ R5 `, h. n6 L+ xNothing to load, empty line!
( D1 v3 i1 x8 ~0 P% p1 | u* R4 wError in line: 1308.
8 h- }9 u, u1 d8 q. p6 oNothing to load, empty line!
h2 W3 A, j- ?Error in line: 1318.4 K# t4 |" s# k) h; l4 w
Nothing to load, empty line!3 }) R$ m) V" R3 g& d
Error in line: 1328.0 F2 G% `2 V6 w/ e* H1 S
Nothing to load, empty line!& Q& M9 k( t- c0 h( e
Error in line: 1338.
; ` M5 R% ]! D4 K! b3 RNothing to load, empty line!
0 G. R: }5 J! F; ?# z3 s# j5 R" NError in line: 1348.
- Z( J+ n% ~( C. p9 }Nothing to load, empty line!3 z+ v2 W& |( G9 b
Error in line: 1358.3 l; i3 ?& K: Y! l5 g1 b
Nothing to load, empty line!& U1 o1 s# o! a& n
Error in line: 1368.
. V! B$ d' L/ X1 p+ b( j" y& fNothing to load, empty line!
6 t8 g/ B+ {) l2 VError in line: 1378.
- L+ Y5 a! b% ~8 @) tNothing to load, empty line!! F/ Y, B! u* i3 I
Error in line: 1388.
9 M: U9 L# N" I2 a0 V) gNothing to load, empty line!
5 p' o/ E( U: |9 JError in line: 1398.
& ^& W/ `6 s( l& i: ?: U3 [6 h. \Nothing to load, empty line!
" c5 y w5 q, }" f6 dError in line: 1408. \1 m' l4 I( E- }2 w% i
6 p$ W/ x& q1 j' Q/ f/ j* YError in line: 1418.! u5 r: u, E" O( i6 Q6 c- {, h: p {
Nothing to load, empty line!0 Z0 a; f0 N* [$ B# F; J# s( v3 Y
Error in line: 1428.2 c2 J8 T/ {1 C) ]+ V
Nothing to load, empty line!) _* o, s9 ^0 K
Error in line: 1440.) S3 s8 g% t- t& {6 z
Nothing to load, empty line!' q! w/ {8 Z0 q, \) D. S( _
Error in line: 1450.4 s8 u& X+ i e3 T' d7 F& q b
+ d1 i& d% x0 |3 c: }Error in line: 1460." T8 d: H( Z3 ^' S9 A; Y" R
Nothing to load, empty line!. N9 F5 \* z$ }1 `& `# B0 G
Error in line: 1470.8 B" S: r" f; G; G& o3 I
Nothing to load, empty line!( ]% ? o& I8 j ]7 F7 i3 O
Error in line: 1480.; Y" g3 ^$ p y; M- k
Nothing to load, empty line!$ {3 n, F; @. P- G2 K" |
Error in line: 1490.* m) G: d' @, p: b0 Y1 _6 }" o$ @
4 q1 c( y1 K( V( CError in line: 1500.
, T6 f" L) z* W( i/ O& ~Nothing to load, empty line!
( P) ?# S" G" X4 h9 P2 e3 iError in line: 1510.5 v. L. J! R/ t1 n8 S5 M Z. k, K
^2 z9 A/ K W9 s' ZError in line: 1520. y% w) c$ |2 h, C! d2 s7 ?# b
Nothing to load, empty line!& L; z% Z! q5 h# A
Error in line: 1530.: A) Z& r$ @, _% _
Nothing to load, empty line!6 U7 }1 C/ q) m& i" e9 r
Error in line: 1540.
- i7 f/ ^2 K$ k& z8 b+ c, g- vNothing to load, empty line!
: S) \0 I$ F7 P( RError in line: 1550.
7 Y7 ~0 p1 o$ N0 u- [2 b& ONothing to load, empty line!
0 {' B6 h* e2 @* R+ y1 o8 BError in line: 1560.
% k2 W* `: h/ O6 t( |" E7 nNothing to load, empty line!" f* {$ A6 v% n# b( G" M6 R2 w
Error in line: 1568.
4 d& @/ O9 e; `Nothing to load, empty line!3 ?& Z( P3 E$ q
Error in line: 1578.
+ @4 G+ T5 V3 ^) w% j7 D& aNothing to load, empty line!' A) f U8 m% @3 _+ J5 n) f
# z8 f$ a! v, z2 t, t4 m
Import Warnings : 10( ^+ X$ W" e* [, `5 M$ U
Polygon track width changed from:3mil to:4mil to comply with appropriate width rule. Polygon's bounding Rect: -28000mil, -28000mil -28000mil, -28000mil+ Y! d- L9 T5 m0 G+ X
4 u# k8 u2 X" a. x- H2 q3 ~Polygon track width changed from:3mil to:4mil to comply with appropriate width rule. Polygon's bounding Rect: -28000mil, -28000mil -28000mil, -28000mil
& L% w& G6 p( M3 A1 d4 wPolygon track width changed from:3mil to:4mil to comply with appropriate width rule. Polygon's bounding Rect: -28000mil, -28000mil -28000mil, -28000mil8 [) A( Z {& n" ?$ b
6 |1 ?( T2 |. Q, G Q1 ?Polygon track width changed from:3mil to:4mil to comply with appropriate width rule. Polygon's bounding Rect: -28000mil, -28000mil -28000mil, -28000mil" G- ?3 q# q' V/ N
' q, Y" d5 g& B0 q6 IPolygon track width changed from:3mil to:4mil to comply with appropriate width rule. Polygon's bounding Rect: -28000mil, -28000mil -28000mil, -28000mil5 W; ?/ A$ f# B8 j5 m+ `
! M7 b0 {' M4 W5 X: Z% U" KPolygon track width changed from:3mil to:4mil to comply with appropriate width rule. Polygon's bounding Rect: -28000mil, -28000mil -28000mil, -28000mil+ U4 L# A+ k7 F' Z
' Q* G. C: a1 r( c f0 I3 y
3 K% P7 ?6 ? o" r+ K- {6 e
