2 _, |; u$ X' z, K+ U, V# q
关闭时有提示的,而且help文件中也说明了这个情况:
6 |; b3 i8 \/ K/ u6 O% mReporting Teardrop Errors' k7 _, Z% R4 w' |
' D- z. G( F2 I4 E' yYou can check the design for teardrop errors and report them.+ C: O7 s9 ~& W* q9 I( c
4 | Y$ Z k R+ b
To report teardrop errors:
3 v# \+ K7 V2 L4 s& f! I- y b% K Z) F q! v
1. Tools menu > Options > Teardrops tab.2 \, M" u6 y+ @6 E' d8 f) r
& S9 j [; v, [8 E' Q
2. To the right of the Parameters area, click the Check button.
1 D! |; N5 u/ k6 S
4 R( n c. L3 p2 L! A7 _4 D5 MResult: The Check Teardrop button dialog box appears.
4 A# s& u* w0 W$ _) u/ v' r! |: k* {; Y+ q7 I+ u4 F
Tip: The Check button is unavailable unless the Generate Teardrops check box on the Routing tab is selected. |
