PCB-2007-000-B.rar
(308.2 KB, 下载次数: 15)
4 X$ y1 l* o( ?0 X
a.Copy the contents of the <PADS install dir>\SDD_HOME\translators\skill_scripts folder to the $HOME\pcbenv folder.$ b% \- Z2 z4 H h: \
b.For each design you want to translate:
# ~6 J7 f* J# M5 fi.Create a new folder (...myboards_<boardID>), for example), and copy into it the Allegro design (.brd) file you want to migrate.
$ e& X' Z5 {+ _ I2 _ii.Open the design file, and in the Allegro command prompt window enter these command lines:4 O/ l# S& }, a: ~, A. W& G
Command> skill load “dfl_main” (include quotes)) M- `2 b' M7 z2 I3 Q( k9 f
Command> main out3 G8 e4 a0 J4 l
# H: u7 ~0 h2 a1 `8 viii.In the Allegro to Expedition Translator dialog box, click the Start One Way Translation button.
. v6 f9 a+ R6 Qiv.When the SKILL script has completed, if any errors were found, fix them and rerun the SKILL script. The migration will not complete correctly if all errors are not fixed.
1 U, U* v3 \) t7 x9 v----------------------------------------------------------------------
( r2 B. b0 B* f( T$ xCommand> skill load "dfl_main.il"
' v, C; y4 [3 A$ U( N6 k) WCommand> main out
; ?* S1 n; E9 _. D' Z% z5 K1 ^----------------------------------------------------------------------0 X3 S& \+ i2 y _% ~
