查看: 3438|回复: 1
ORCAD导入PADS 2007 layout时,出现问题,急求助!!
发表于 2011-8-21 19:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Reading file --  E:\pads\capture_schematic\GL520.asc
) W. E8 n, w8 ~! U0 v) @*Unspecified or unsupported version of ASCII file2 ]6 T, [$ n+ L5 p/ L
*PADS2000*
, j" j3 Y6 V8 f2 X1 ~1 _*Not valid pin name for part type D401.K
% o+ ?& m% ~& v3 @. WU200-.G3 B401.1 C402.1 U200-.F16 D401.K L400.2 C414.1 J400.1, E# m7 J/ x0 p8 I1 u  \% _& p
Bad pin number in connection U114.6/ ?( h. y5 F! F/ @" }
C146.1 U114.6: n% F) T8 a. ^) T
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N1574224
2 E8 o+ {  Y- P4 c( [Bad pin number in connection U114.105 o6 U# D( N7 ~; d+ [" {' n# }
C131.2 U114.3 U114.5 U114.10 W101.1 C101.2 C102.2 A100.2  B8 j: b0 h& u
*Not valid pin name for part type Q600.E
: w1 s0 |' v, G3 ^- }J612.12 J612.1 U640.9 B641.2 B640.2 Q600.E J630.8 C641.2
) z! d% ^% g  p- RBad pin number in connection U114.7
( a0 N+ U' G1 V3 tC145.1 U114.7
; d) r0 A: k4 @2 }( J$ u* B*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N15741849 R3 i1 O+ ~  ]2 \- s' e( w8 Z
Bad pin number in connection U114.8/ v* D. @" S% p. J3 l/ d6 _
C144.1 U114.8
/ `+ ~( `- |, c8 }9 N*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N1574156
* @& l% f3 n" m*Not valid pin name for part type Q600.C' Y. B  S" L/ ^/ E$ ^) N
Q600.C R601.2
- W" g8 T/ y- n4 Q$ Y6 R3 V*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N1597491
" T9 e/ o1 V$ C3 R( eBad pin number in connection U114.9, T% T; v8 e9 M( v& X
C143.1 U114.9' W% h; X4 ?+ f- Y" t
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N1574132
4 Z/ u2 O0 u5 U*Not valid pin name for part type Q600.B7 \4 V" Z( ]& O3 c; M! ~# d% k
U200-.AK34 Q600.B
* \- g& M5 g+ g) \9 \" L*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal GPIO30_FLASHLED_EN
& t7 [7 M8 a* b$ h8 d+ {, D*Not valid pin name for part type D401.A4 x7 W3 s6 \+ x  u3 f9 s" ^
C402.2 C401.2 D401.A7 j0 q/ `/ `. |- b7 h# k. ^
*Not valid pin name for part type SPK342.SPK+2 V2 \; F1 v9 e6 R* m
C437.2 SPK342.SPK+ SPK341.SPK+ V342.1 C343.1 C345.2 B431.2( B, y5 X1 j, x0 X$ f. r
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal LSPK+
6 O9 {: s3 K* H" b& k! {' [2 R. R*Not valid pin name for part type SPK342.SPK-
# y- ?6 G$ L$ YSPK342.SPK- SPK341.SPK- V343.1 C343.2 C344.1 B432.2 C438.1
! B. ]: `) ]# k) e  z) V* h% M, K*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal LSPK-! d) {  H9 p( f; P. r% r
*Not valid pin name for part type J500.X+- ~- ?9 G4 [2 d
U200-.B8 J500.X+ V501.1 J701.430 ?3 w+ P6 }  \: G8 d
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal X+
7 z( c8 ]( L. S. L& S*Not valid pin name for part type U200-.V5
6 |; D3 M0 ~( I+ D$ B; [+ \2 xU200-.V5 U640.4
2 _, n5 i* ~2 t3 \" ]( h*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal USB_DM: @/ K7 @/ J8 }% z2 n* b' w' v
*Not valid pin name for part type J500.Y-! F0 j* k( {5 o9 G5 R
U200-.C5 J500.Y- V504.1 J701.42
: a3 z6 M" ^, b5 f, q*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal Y-
" [/ U' L5 {9 Y8 r*Not valid pin name for part type U200-.B3
' _9 u! A; P0 q& d# aU200-.B3 C331.1
4 ^8 T( [* u8 d0 v/ u$ M*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MICP1
9 D3 e8 S9 ?6 j, a2 i7 P*Not valid pin name for part type J500.Y+
* m( t$ h* ~" r& O/ VU200-.B4 J500.Y+ J500.X- V503.1 V502.1 J701.400 Y9 I5 S; a% q: \5 [8 u5 K5 ^  Y  E
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal Y+
; F/ h0 h# z# Y6 RWarning: deleting signal N1574224
' l2 v' c* ?' ]# t. K! qWarning: deleting signal N1574184
* E& g- G8 ^7 i! l" D, T* h3 VWarning: deleting signal N1574156/ u# y3 X1 s; L1 L
Warning: deleting signal N1597491
/ c: M  p$ X) W2 n7 QWarning: deleting signal N15741327 S! N9 i0 ~, y
Warning: deleting signal GPIO30_FLASHLED_EN
9 S5 [+ z: p+ ?2 F1 U* c4 Y/ }, _Warning: deleting signal LSPK+
' e9 j4 p3 w3 ]; V, r$ rWarning: deleting signal LSPK-
- I; ?) o7 {  T/ [* z( @Warning: deleting signal X+
# h1 r# k1 _8 F9 K  Y2 U% AWarning: deleting signal USB_DM8 \! `7 q5 Y# v: E* ^) b0 L2 e. q+ m
Warning: deleting signal Y-
8 x+ ?: j' H+ b; j! v8 V2 ]3 vWarning: deleting signal MICP1
- Y5 ~2 _- v$ W6 m* g0 ]0 r; W' kWarning: deleting signal Y+
8 c# j, f( u8 _" F, ?**INPUT WARNINGS FOUND**5 p  D" s0 x+ D
$ F0 a; Z5 g2 y' c" w5 g
联系QQ:271936212
发表于 2011-8-22 08:25 | 只看该作者
器件的PCB封装管脚名与原理图的不符如原理图用了k,pcb封装用了2)401,Q600
/ Z9 u. x7 r7 I5 n7 ?器件管脚数量与原理图不符:U114
GMT+8, 2025-7-18 07:45 , Processed in 0.140625 second(s), 24 queries , Gzip On.
