查看: 3842|回复: 8
如何读懂灌铜错误报告?
发表于 2011-5-16 11:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
灌铜时产生如下err问件 求各位大侠帮小弟看看:! f7 r: G( U& z
3 A% K6 k3 _+ ?5 T/ YTHERMAL RELIEF ERRORS REPORT -- X1-V-4S-M-V1.0.pcb -- Mon May 16 10:55:51 2011
" Q: E( Z5 J% Y( U' j% A; H+ S3 @
; j# Q( V9 E$ `; H) i0 a       Drilled pads with                    Nondrilled pads with
* x7 r6 O: Y4 T+ }+ d, x, Kless than 100% thermal extensions      less than 25% thermal extensions
3 T: [$ c/ L& R# D, ^+ b& DReport of Thermal Spokes Generator.; l6 P7 v1 J' U  ~
On Top:
1 i* P: \0 [8 u7 Z3 LJ3.7    (3385, -1340) # = 0: D, j5 c  x  L1 a
                                        U2.7    (2380, 340) # = 0
+ l' h2 x2 g/ Z8 g! D' z- d                                        U8.7    (3630, 350) # = 0- c0 W6 }8 [* c2 n3 w. [5 E" K
J3.15   (2985, -1340) # = 0
1 n  D" X' h9 i2 D) X" ?+ `7 s* vJ1.9    (2989, -1625) # = 2
* @4 `) a5 y) q/ [0 Q8 H. _J1.11   (2889, -1625) # = 1/ {' ]$ o) h+ F6 ~6 Y8 f5 M
U5.17   (1965, 237) # = 08 l+ S9 d7 G& T4 p, Y- b$ x
J1.13   (2789, -1625) # = 04 X% Q3 D" @) u# e% J
J1.15   (2689, -1625) # = 0# S$ _/ I- j2 L  p0 y
J1.7    (3089, -1625) # = 2
0 S1 `0 j, }' k( G' qU11.17  (3205, 232) # = 0
  Q- i2 z4 ~* E/ z3 Z! e                                        U11.7   (3080, 345) # = 08 F& R9 @* W; q! d
J3.13   (3085, -1340) # = 0+ v. A- r" D: X% N) b  u) D
J3.11   (3185, -1340) # = 0
! @4 G4 l, o! T# O4 sU9.65   (3542.36, -731.22) # = 2, c9 D5 F3 u; P0 w! w8 P
U3.65   (2237.36, -731.22) # = 2
* L4 k8 U2 c' H5 x, A; ~5 KU2.17   (2505, 227) # = 0
# V/ q! i+ m0 x) i9 w% s. r) [3 w, x& cU8.17   (3755, 237) # = 0/ b8 [8 C; F+ d6 q' J
                                        U9.41   (3552.2, -967.44) # = 0
3 b+ \% I/ o0 Q                                        U9.38   (3493.15, -967.44) # = 0( G8 I, V  _# u+ f! j) }
                                        U9.56   (3778.58, -741.06) # = 0) n8 F3 [: M) h/ B
                                        U9.25   (3306.14, -741.06) # = 0
4 R. u, }1 R/ \" k                                        U3.56   (2473.58, -741.06) # = 05 b! R, B6 G% m. U
                                        U3.41   (2247.2, -967.44) # = 03 L; u' t1 j6 \  I# P+ ?/ n
                                        U3.38   (2188.15, -967.44) # = 0
4 N& U$ R! m1 S0 j2 G6 ~3 U9 |' m" x                                        U3.25   (2001.14, -741.06) # = 0
  S) e- G1 t; F& d                                        U5.7    (1840, 350) # = 0
. T3 o- p9 g" nJ3.9    (3285, -1340) # = 0
' K2 \% E# V* p  M& x% k. J3 [Total Drilled pads:   16               Total Nondrilled pads:   12: f& E" ]6 d& y7 E; ]
( q: j8 E) n- E
发表于 2011-5-16 14:07 | 只看该作者
a: 覆铜时有下面的坐标的管脚应该连接而没连接,或者只连接一个。考虑单线引出。不过应根据实际情况解决。9 w) n+ N- y7 o1 T& Y$ l7 m9 |
b:这是thermals下的drilled thermals和non-drilled thermals的min.spoke个数小于您设定的数,请把drilled thermals和non-drilled thermals的设置变为flood over就可。  v: ]- M$ Z" n$ u/ Z1 v
c:列出的是网络相同应该覆铜的但没有覆铜或者焊盘引出线少于Thermals中设置的参数。焊盘没覆铜可能是因为安全距离过大,可以添加走线;Thermals中Min.Spoke设置成1即可。
1 \* \/ @" f( f  ^d:这个应该是焊盘覆铜没超过50%吧!& [& D3 x% A" f  {+ m( k
版主解释的真详细!学习!  发表于 2011-8-26 20:16
 楼主| 发表于 2011-5-16 16:48 | 只看该作者
回复 jimmy 的帖子% g3 I. e8 H. X' B* B' |5 m. x
0 Z* p  t/ m' _6 @5 n) [" ^: r
jimmy 能在详细解释下么?a、b、c、d指的是?# \( v& ^. c+ G6 n/ h; n
发表于 2011-5-16 17:02 | 只看该作者
1: 覆铜时有下面的坐标的管脚应该连接而没连接,或者只连接一个。考虑单线引出。不过应根据实际情况解决。+ ^5 O; l7 H3 Z: ?, P  M$ _
2:这是thermals下的drilled thermals和non-drilled thermals的min.spoke个数小于您设定的数,请把drilled thermals和non-drilled thermals的设置变为flood over就可。& A  L/ g4 Y* v& U. D0 m- j
3:列出的是网络相同应该覆铜的但没有覆铜或者焊盘引出线少于Thermals中设置的参数。焊盘没覆铜可能是因为安全距离过大,可以添加走线;Thermals中Min.Spoke设置成1即可。1 {! u) S; W8 Y' _  U
4:这个应该是焊盘覆铜没超过50%吧! * V! \& e' |) {, p9 \7 H
 楼主| 发表于 2011-5-16 17:15 | 只看该作者
回复 jimmy 的帖子0 [. N4 h+ P0 r0 t$ o' B! ]% O
$ O: Q" j- M8 C" E' H: S8 s
哈哈 多谢 明白了 版主真是热心啊!以后会常请教的!3 _& L( Q; }9 `$ e" A/ a% {5 j' V3 A7 C
6 M% S( d; O. `! c- p
发表于 2011-5-18 21:13 | 只看该作者
原来这样,收藏
发表于 2011-8-26 20:07 | 只看该作者
发表于 2011-8-26 21:22 | 只看该作者
还有这回事吗,我都从来都没有去理会他呢,照样出图,好像也没有问题呀?
发表于 2011-8-27 09:28 | 只看该作者
111
( B. q( ^% t' q9 y. c
GMT+8, 2025-7-15 06:50 , Processed in 0.125000 second(s), 28 queries , Gzip On.
