Can't exit from pin(s) U2.5, U3.33, U2.2, U2.1, U3.32, U3.31, U3.30, U6.2 with mimimum width because of largevalues. To correct the problem, use the Design Rules dialog box in pads Layout or the Routing tab of the Design (or Net or Component) Properties dialog box in PADS Router. 3 A/ s! ^9 A8 U" W8 H/ \ ?# G- y为什么这些器件的其他引脚可以布成功,布线设置也都是一样的, clearance 和width都是一样的,为什么布不上呢?
