查看: 899|回复: 0
关于自动布线,只布了一小部分,布的四层板,但是自动布线连过孔都没打,哪位帮我分析
发表于 2011-4-18 16:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Mon Apr 18 16:23:26 2011$ b. p- i% \3 y2 P
; Z, K0 o  |% ]7 X) X5 j* PAutorouting C:\pads Projects\default_blz.pcb
# |' z; g: k. X- K; e& O* z==============================================================================================
) z, ~, X/ c' d4 \3 E9 OPre-routing analysis . U9 q. Y4 h, W: e+ v, {
- C1 M, N# d/ K, ^: q/ ~! a( N, HWarning:Not enough vias for routing from the top to the bottom of the design.
: g5 r9 o  f, v5 Y, D. s* H8 q        To correct the problem, define additional vias or enable vias for routing using6 C' k, U5 A# n0 a
        the Via Biasing tab of the Design Properties dialog box.
6 ~  d3 H+ T5 N% ?- _3 |Warningins K1.1, K1.2, K2.2, K3.2, K4.2, K5.2, K6.2, K7.2, K8.2, K9.2, K10.1, : q# N: z. }6 Q, S& B6 |" D
        K10.2, K11.1, K11.2, K12.1, K12.2 are covered by board outline, trace(s) keepout(s), text(s) or copper(s).
; G$ o# a; x  m7 N& M5 D' d        To correct the problem, use Move commands in PADS Layout or PADS Router.
5 m+ P* @) O' N4 f==============================================================================================: Y5 R% C, K3 d; `) ?' t
Passes Processed:          Fanout, Route, Optimize
" l9 `& |2 f* Y9 i. o, I2 {+ O  D* bRouted Connections:        91(+91)
6 M9 H' f. `9 i) }Vias:                      0(+0)( v, E+ B- P+ L4 _: P1 k7 z
Trace length:              49800(+49723) Mils6 a- C2 f, ~$ Y$ ^7 g( i1 S' A
Test points:               0(+0): a2 X6 t2 d; q# U! z; t
Accessible nets:           0(+0)$ ~& q) i  x4 m+ f' f, c
Duration                   00:00:39; h; h+ y6 O4 g# R. [" n1 v$ x+ R8 |
==============================================================================================! f) t+ j0 o8 ?) `8 \
' M' V% A( C6 ]. m+ J  {Pass:                      1 (Fanout)
' q* T8 K2 {/ G4 [! n3 b/ W! APins processed:            0  |* _' y  r4 K7 x; u
Fanouts created:           0
; E9 U. a1 b# b* J, J$ KRouted Connections:        0(+0)
" h' Z- \- F1 ^! E3 f5 t% c+ IVias:                      0(+0)1 t* g& S! I9 U3 l. g* Y6 ?8 l
Trace length:              77(+0) Mils
  ?2 k5 g( Z! R7 yDuration                   00:00:00(+00:00:00)7 p+ {4 E# j2 D5 u* ?
& Q6 W3 @; Z8 y# T+ H6 c4 Q8 G/ `9 m  h" P$ `! _" C! n
Pass:                      3 (Route)
% Q. T" E* {; _( e) F2 D: jRouted Connections:        91(+91)6 f, P/ m1 k7 B! e& c" ~' J3 u  U
Vias:                      0(+0)
: n; B" F7 l, ]! k2 QTrace length:              49796(+49719) Mils
+ n1 G; b5 ^; u5 T' s, Q; fDuration                   00:00:36(+00:00:35)
9 F  Y3 s3 I8 T. b& f! J==============================================================================================, o* d; m: E3 C! b+ \' j  c/ ~
% G' e  i7 H4 ^6 U1 c1 b$ |) q3 e
Pass:                      4 (Optimize)1 \# `; m" P( o) V# C. g2 e
Vias:                      0(+0): e: b" N2 s5 q( k
Trace length:              49800(+4) Mils" Z, ]4 c. p6 u. ?, c9 {
Rerouted:                  0
. Z! C& L4 I& X0 `7 Q/ c) EDuration                   00:00:39(+00:00:03)) o1 h7 X1 N+ X% }
/ m1 s) S& }2 R* H
GMT+8, 2025-7-8 10:36 , Processed in 0.125000 second(s), 24 queries , Gzip On.
