返回列表 发新帖
楼主: laopi_eda
EE2007.9 PCB中元件的Ref对齐功能如何实现?
16#
发表于 2011-1-13 10:55 | 只看该作者
2007.9打开是不报错了 apply那儿是灰的,呵呵
17#
发表于 2011-1-13 11:03 | 只看该作者
好像搞定了,呵呵。谢谢!
! G7 {# |. G5 U; TWG2005为啥不好用呢?
18#
发表于 2011-1-13 11:13 | 只看该作者
4 L" I. D- y* ]# u3 ^2 v
wx37501 发表于 2011-1-13 11:03
& S2 ~* V; o3 |& H好像搞定了,呵呵。谢谢!) c, {# c/ y. d7 R* [
WG2005为啥不好用呢?
" @0 K5 c+ @6 c9 @" @
' B" a' x5 r* `. m& f3 U8 I
我也试了2005.3 的版本是会显示此错误,
也会显示此Form,
19#
发表于 2011-1-13 11:15 | 只看该作者
输入坐标是可以的,好像不能自动抓坐标。
20#
发表于 2011-8-8 08:23 | 只看该作者
这样的东西是不是和SKILL是一样的东西' k% P# B" O7 o' Z% [
21#
发表于 2011-8-8 09:29 | 只看该作者
kankan......
22#
发表于 2023-10-24 11:07 | 只看该作者
XYX365 发表于 2011-01-04 15:46:27: E7 H4 T# H; K+ s! w
[quote]laopi_eda 发表于 2010-12-29 19:51 ( B+ J+ w( G2 ~  a4 p% f8 I. e
请教一下,不知道在EE7.9中如何实现元件的标号对齐功能啊?
& \% f9 R  L( ~; y现在只发现只有对元件对齐选项才可以用,对标号 ...
1 C1 n( Y2 z0 L8 K1 [% V2 g7 ?. AThis script (AlignText.efm) will align selected Fabrication & UserLayer texts per the formats shown in the button icons. Selecting a format will change the "X :" to a "Y :" or visa versa, depending on whether alignment will be to the same X (Horizontal Justification) or same Y (Vertical Justification) of all the selected text. Users can manually enter an X or Y Coordinate value in the numeric entry box, or enter a mousedown in the layout. However, the numeric entry should be preceeded by a Format selection because a Format selection may clear the numeric entry value if the new selection's justification (Horizontal X) differs from the previous (Vertical Y). If text is previously selected when attempting to define the numeric entry wth a mousedown, the coordinate of the closest selected text (it's text origin) is captured (this is signified by the Move Cursor). If you wish to enter a mousedown location other than those selected texts location, before selecting the texts, execute a mousedown at the location you wish to enter into the numeric entry box.5 i$ _) d; C4 u2 i! K( W
% e' ]- H" _2 ~, K8 V[/quote]2 w0 i) M$ G- ?! w( E3 N% h
9 J0 `8 F2 `$ s1 |. X! e下载下来试试$ F6 }8 n  H5 s! O0 _. z2 H
“来自电巢APP”
GMT+8, 2025-8-2 18:44 , Processed in 0.125000 second(s), 19 queries , Gzip On.
