[AD9][2层]nios_5505主板(EP2C8Q208+K4S641632H-TC75+74HC541)原理图和pcb文件
# X9 @- \1 D& s3 j' _' R( I0 Z v7 {& [. Q q* @
文件描述:, q- \2 m9 t. B a$ F" G
% q9 e- E' G5 r* P6 [9 t2 k1. 作品用途:nios_5505主板
) F* z3 f/ V% Q1 }7 g' J2. 软件版本:AD9* C0 a/ A+ y/ Y+ `% b8 F
3. 层数:2层
W" k$ {. H& P' |4. 用到的主要芯片:EP2C8Q208+K4S641632H-TC75+74HC541
! d4 a$ r4 k( l$ ^, E; p2 E5. pcb尺寸:190*115 MM
9 V: v* z9 e. F+ Y! L作品截图如下:- Y k, Q5 z9 \& `& {# F$ K
' T6 H- W1 ]* j
顶层截图:, |+ [/ A% v+ N! x+ z1 @; P$ T
& O$ |- r- I% [8 B5 s' n
底层截图:
0 H/ B2 Q% v$ \* J, H
1 X5 }3 ], K5 P( A. x5 j$ f, S
$ c9 _. R6 E' M2 v& x7 {
全层截图:" z- r0 O( [9 z, _, h
% h- B3 g0 S. B: X: K2 C8 @0 z- o; a
8 a5 N3 z H6 i4 Y/ e$ f4 F! [叠层阻抗信息如下:
5 Y/ Q( y4 z; _
) G9 z0 l, ~9 p( m: N% `
" w/ h1 E* b+ i" _( ]4 BBOM:- t* j) v/ U8 g% P( n
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | | 4, 8, 9, 10, 11, 12, 13, 14, 15, 16 | SMA | 10 | C13 | 271 | 0805 | 1 | 0.1uF | C1, C2, C5, C6, C7, C8, C9, C10, C11, C14, C21, C22, C23, C24, C25, C26, C27, C28, C516 | 0805 | 19 | 27 | C12 | 0805 | 1 | 103uF | C18 | 0805 | 1 | 104 | C29, C30, C31, C32, C34, C35, C36, C37, C38, C39, C45, C46, C47, C48, C49, C50, C51, C52, C53, C54, C55, C56, C57, C58, C59, C61, C62, C63, C64, C65, C66, C67, C68, C69, C72, C73, C82, C84, C97, C98, C100 | 0805 | 41 | CAP | C101 | 0805 | 1 | 10uF | C102, C103 | 1210 | 2 | 106 | C104, C105 | 1210 | 2 | 102 | C106 | 0805 | 1 | 1uF | C111 | 0805 | 1 | 103 | C511, C514, C515, C517, C520 | 0805 | 5 | 105 | C519, C522 | 0805 | 2 | 102uF | C521 | 0805 | 1 | DIODE | D2 | 1206 | 1 | LED | D3 | 0805 | 1 | CON5 | J2 | LEA5T | 1 | | J6 | SIP-7 | 1 | CON8 | J8 | SIP-8 | 1 | CON3 | J200 | SIP3 | 1 | CON4 | J205 | SIP3 | 1 | JD-1 | JD2 | JRC-23 | 1 | HEADER 20X2 | JP1 | IDC-40 | 1 | HEADER 18X2 | JP6 | BD | 1 | HEADER 17X2 | JP8 | IDC-34 | 1 | HEADER 5X2 | JP9 | IDC-10 | 1 | HEADER 2X2 | JP10 | JINGZHEN | 1 | SN65LBC184 | JP11, JP12, JP14 | SO-8 | 3 | CON8 | J_JTAG1 | IDC-10 | 1 | RS232 | KP2, KP3 | DIP-4 | 2 | 1R5J | L54, L55 | 1210 | 2 | PC817 | O2 | DIP4 | 1 | LM1117-3.3V | PW1 | SOT-223/P2.3 | 1 | LM1117 | PW2 | SOT-223/P2.3 | 1 | 2N3904 | Q51, Q52 | SOT-23 | 2 | 100 | R1 | 0805 | 1 | 4.7K | R2, R3, R4, R5, R6, R7, R8 | 0805 | 7 | 10K | R9, R10, R11, R12, R18, R19, R20, R21, R22, R23, R27, R527 | 0805 | 12 | 0 | R30 | 0805 | 1 | 2 | R38, R39, R40, R41, R42, R46 | 0805 | 6 | 1K | R50, R160, R170, R180, R622, R780, R781, R782 | 0805 | 8 | 30Ω | R58 | 0805 | 1 | 240 | R59 | 0805 | 1 | 33 | R60 | 0805 | 1 | 511 | R518, R522 | 0805 | 2 | 7.5K | R520 | 0805 | 1 | 3.9K | R521 | 0805 | 1 | 201 | R523 | 0805 | 1 | 101 | R524 | 0805 | 1 | 51 | R525 | 0805 | 1 | 2.2K | R526 | 0805 | 1 | TRANS4 | T1 | zhongzhou1 | 1 | K4S641632H-TC75 | U1 | SDRAM_TSOP-54 | 1 | 74LVC4245 | U3, U6, U8 | 74LVC4245 | 3 | 74LVC4245 | U11, U13 | LVC | 2 | MC74HC541 | U14 | SOL-20 | 1 | CAT1025JI-30 | U28 | SO-8 | 1 | EP2C8Q208 | U29 | PQFP208 | 1 | EPCS4 | U30 | SO-8 | 1 | 74HC541 | U31, U32, U33, U34, U35, U36, U101, U102 | SOL-20 | 8 | MAX3232 | U37, U38, U40 | SO-16 | 3 | MAX232 | U39 | SO-16 | 1 | 附件:
+ f0 y. j0 f0 ^$ l% w6 e原理图和pcb文件如下:( [: I* ^( ?: j; U( a. [
| 3 N7 X. O# H, b8 F6 K' Y
