; l$ ?7 [6 E( H0 e; z- F6 [
[AD9][2层]1023模块参考板方案(LM7905CT+max4135+LM7171)pcb文件
% F7 b* l, G7 W$ K4 h- i. l* D: o. {6 S& j0 K0 u. n# [
文件描述:" ]5 y) P9 d5 @# v7 B6 c
3 @/ p" J' I1 ?+ U1. 作品用途:023模块参考板方案
' Q$ N6 P: M* l2. 软件版本:AD9. Z4 ]- Z8 Q( Y. g* F
3. 层数:2层4 c. q+ b3 u0 H5 }$ |2 J4 d( b
4. 用到的主要芯片:LM7905CT+max4135+LM7171
- ]) p y7 m! G# |5. pcb尺寸:9140*6440 MIL0 \( T% }% S$ L" @3 u) U
1 D- T! ]0 |2 l0 e8 d
作品截图如下:
* b6 |, V3 Z' b" L+ r/ Z
8 Q/ o7 p" S& R K% ~9 r5 Y顶层截图:0 j8 v5 o: v& o
2 W5 P T+ U2 E0 Q
底层截图:* L( c+ [ ^& ~ m1 P8 [
7 K+ B7 `7 {5 e5 R: j0 G3 w
$ S! F+ x* C1 Q1 ?, X+ H$ a全层截图:
4 L; F S# U4 ?' |: T
; L0 k# f1 l1 I4 P2 x! r
: j# H( A/ Q$ s- J叠层阻抗信息如下:# H% e2 V# X8 l- ]3 v
# b% w5 \4 E w+ {$ x- K2 g
BOM:/ b+ M+ M5 v( V- p5 }% s
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 102 | C01, C12, C40, C43, C44, C45, C48, C52, C57, R44 | 0805 | 10 | 104 | C1, C2, C3, C4, C5, C6, C9, C11, C13, C14, C15, C16, C17, C29, C30, C41, C46, C51, C62, C63, C64, C65, C66, C113, C114, C115 | 0805 | 26 | 106 | C7, C8, C116, C117, C118, C_FUWEI, C_FW1 | 1210 | 7 | 2.2P | C25 | 0805 | 1 | 1P | C26 | 0805 | 1 | 103 | C27, C34, C36, C58, C59, C60, C67, C68, C69, C70, C71 | 0805 | 11 | 2.2uF | C28 | 1210 | 1 | 27 | C31 | 0805 | 1 | 270 | C32, C61 | 0805 | 2 | 0.1uF | C33 | 0805 | 1 | 103uF | C35 | 0805 | 1 | 105 | C37, C39 | 0805 | 2 | 102uF | C38 | 0805 | 1 | 106/25V | C42, C47, C53 | 1210 | 3 | 107 | C49, C50, C54, C55 | 1210 | 4 | CAP | C101, C102, C104, C105, C106, C107, C109, C110, C111, C120, C121, C130, C131, C132, C134, C135 | 0805 | 16 | CAP | C108, C112, C119, C133, C138, C139 | 1210 | 6 | CAP | C137, C140 | 1812 | 2 | 30P | C_mcu1, C_MCU2, C_MCU11, C_MCU22 | 0805 | 4 | DIODE | D1, D2 | 1206 | 2 | CON3 | DWQ | DWQ | 1 | RES2 | D_10M, R29, R39 | 0805 | 3 | 10K | fuwei, fuwei1, R43 | 0805 | 3 | CON3 | J1, J3, J6 | SIP-3 | 3 | CON8 | J2 | IDC-10 | 1 | CON4 | J4 | POWER | 1 | 163.68M | J5 | BEIPIN | 1 | R | J7 | SIP-9 | 1 | CON6 | J8, J9 | JDQ | 2 | HEADER 6X2 | JP1 | DIP-12 | 1 | 10MHz | JZ | 10MOCXO2 | 1 | 100uH | L7 | 1206 | 1 | 1.5uH | L8, L9, L10, L11 | 1206 | 4 | RES1 | L12, L13, L14, L15, L16 | 1206 | 5 | 2N3904 | Q1, Q2, Q3, Q4, Q5 | SOT-23/P1.9 | 5 | 6.8K | R01, R20, R22, R34, R41 | 0805 | 5 | 50 | R1, R2, R3, R4, R5, R6 | 1206 | 6 | 2.7K | R02, R17, R21, R23, R35, R42 | 0805 | 6 | 510 | R10, R11, R33 | 0805 | 3 | 100 | R13, R49, R55, R_10M, R_10M1 | 0805 | 5 | 1K | R14, R15, R24, R26, R32, R54, R56, R_WM | 0805 | 8 | 2k | R16 | 0805 | 1 | 499 | R18 | 0805 | 1 | 51 | R19 | 0805 | 1 | 390 | R25 | 0805 | 1 | 2.2K | R27 | 0805 | 1 | 47 | R28 | 0805 | 1 | 20K | R30 | 0805 | 1 | 4.3K | R31 | 0805 | 1 | 240K | R36 | 0805 | 1 | 750 | R37, R38 | 0805 | 2 | 6.8 | R45 | 0805 | 1 | 2.7 | R46 | 0805 | 1 | 1.3K | R47 | 0805 | 1 | 4K | R48 | 0805 | 1 | 10 | R50, R51, R52, R53 | 0805 | 4 | 5.1K | R_LED | 0805 | 1 | max4135 | U1 | SOP24 | 1 | LM7905CT | U2 | TO-252AA | 1 | LM7171 | U4 | SO-8 | 1 | OP-07 | U5 | SO-8 | 1 | MC12040 | U6 | DIP-14 | 1 | ADM202 | U7, U13 | SO-16 | 2 | | U9, U10 | SOL-28 | 2 | AD9852 | U11 | AD9852 | 1 | AD835 | U12 | SO-8 | 1 | EPM7064SLC44-10(44) | U14 | cpld-44 | 1 | 74541 | U15 | SOL-20 | 1 | LM1117 | U17, U18, U19 | SOT-223/P2.3 | 3 | 74HC00 | U20 | SO-14 | 1 | 1k | W4 | DWQ | 1 | 11.0592 | XTAL, XTAL1 | XTAL1 | 2 | E% }2 k9 Q2 J& ~2 J1 g: v. M" G9 y
附件:1 F. T: R3 W, d) V8 k" I
pcb文件如下:* Z0 o# T& @5 j" Y
5 T; ?. u8 I0 ^% N6 o |
