! U3 Z2 G9 x. a; [
[AD9][4层] 视频处理板(LM2596+LM1117+MAX708ESA)原理图和pcb文件
1 `& b/ u# B0 t1 Q6 b8 C5 p6 n# E/ c9 v$ w2 A& Z
文件描述:
/ S9 ~2 P$ A4 N/ k) @& D! o9 R1 t& X0 W% P
1. 作品用途:视频处理板7 w; p' |+ q o8 h! g2 R
2. 软件版本:AD9
& a- Q6 I8 O$ a; h# ]3. 层数:4层
- \ |$ x& t' p. C. V0 y4. 用到的主要芯片:LM2596+LM1117+MAX708ESA
' k/ o" a0 \) i5 ~- w7 c$ i5. pcb尺寸: 4153*4175 MIL4 K5 i8 S- ?2 Z [" X z
4 l4 ^1 _8 h0 q& x* @& e4 H# j. I作品截图如下:$ f1 F. [; I' `, I! j+ @7 W8 O
9 k! Q/ L' e' V4 B* g
顶层截图:
+ \! ]$ S" o% L! v T9 R' j# v# j
3 r$ E# k+ a4 T; \
底层截图:
. U0 _# z) U3 p9 @+ s$ D
; X$ y' j- j* @! n m1 P4 ? v5 J5 u
" Q* C* D- s" L9 b) E2 a( e: |
全层截图:$ R' i* j( `0 ]& Z
/ ]7 o$ {7 u9 n. h: U
9 L' ]: I! Q5 _" O. P5 \4 h叠层阻抗信息如下:0 k: A. C2 D; y
3 [: N! h2 C: Y, ^0 f0 ZBOM:1 i' T, w9 ^' Y' E* {2 c
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 0.1uF | C1, C2, C3, C4, C5, C6, C14, C15 | 0603 | 8 | 0.1uF | C7, C8, C9, C10, C11, C12, C13, C16, C17, C18, C19, C20, C25, C26, C55, C57, C59, C60, C61, C62, C63, C64, C66, C67, C68, C69, C70, C71, C72, C73, C74, C75, C76, C77, C78, C79, C80, C81, C82, C83, C84, C85, C86, C87, C88, C89, C90, C91, C92, C93, C94, C95, C96, C97, C98, C99, C100 | S0603 | 57 | 0.1uF | C21 | SIP4 | 1 | 47pF | C22, C23 | S0603 | 2 | 10nF | C24, C28, C29 | 0603 | 3 | 10nF | C27, C30, C56, C58, C65 | S0603 | 5 | 8.2nF | C31 | 0603 | 1 | 0.1U | C32 | S0603 | 1 | 47uf | C33, C37, E8 | 3528 | 3 | 220uF | C34, E7 | S7642 | 2 | 22uF | C35, C36 | 3528 | 2 | 33nF | C38 | S0603 | 1 | 100uF | C39 | S7642 | 1 | 10uF | C40, C41, C46, C49, C50, C101, C102, C103, C104, C105, C106, C107, C109, C110 | 1206 | 14 | 1uF | C42, C43, C44, C45 | S0603 | 4 | 1nF | C47, C48 | S0603 | 2 | 10uF | C51, C52 | 3528 | 2 | 104 | C53 | S0603 | 1 | 104 | C54 | 0603 | 1 | IN5819 | D1 | DIODE0.4 | 1 | SS34 | D2 | SS34 | 1 | LED | D3, D4, D5 | S0603 | 3 | 470U | E1 | S7642 | 1 | 22U | E2 | 3528 | 1 | AS_PORT | J1 | IDC10 | 1 | JTAG_PORT | J2 | IDC10 | 1 | CON2 | J3, J7 | POWER1 | 2 | 20M | J4 | 4CRYSTAL | 1 | JTAG | J5 | IDC_14 | 1 | 40PIN | J6 | IDC40 | 1 | INDUCTOR IRON | J8 | TIEPIANDIANGAN | 1 | 8050 | J9, J10 | 8050 | 2 | 24M | JZ1 | 4CRYSTAL | 1 | INDUCTOR | L5 | 1206 | 1 | DO3316P-104 | L6 | DO3316 | 1 | 88uH | L7 | 1206 | 1 | RCA | P1 | BNC_SM | 1 | 39 | R1, R2, R3 | 0603 | 3 | 36 | R4, R5, R6 | 0603 | 3 | 1M | R7 | S0603 | 1 | 4K | R8 | S0603 | 1 | 33 | R9, R10 | S0603 | 2 | 1.69K | R11 | 0603 | 1 | RES2 | R12, R13, R14, R15, R16, R17, R18, R19 | S0603 | 8 | 470uF/16V | R20, R21 | S7642 | 2 | 137R 1% | R22 | S0603 | 1 | 10K | R23, R28, R29, R30, R31, R35, R37, R38, R39 | S0603 | 9 | 1K | R24, R25, R26, R34 | S0603 | 4 | 600 | R27, R36 | 0805 | 2 | 100 | R32, R33 | S0603 | 2 | SW-PB | S1 | S1 | 1 | ADV7180_64 | U1 | ADV7180_64 | 1 | EP1C3T144 | U2 | EP1C3T144C8 | 1 | EPCS1 | U3 | SO-8 | 1 | 1117_5.0 | U6 | SOT223 | 1 | 1117_1.5 | U7 | SOT223 | 1 | EMI_FILTEER | U8 | EMI_FILTER | 1 | LM2596 | U9 | LM2596 | 1 | ADP_3335 | U12, U13 | ADP3335 | 2 | MAX708ESA | U14 | SO-8 | 1 | LM1117 | U15 | SOT223 | 1 | C_5502 | U16 | 5502 | 1 | HY57V643220CT | U17 | MT48LC4M32 | 1 | SST39VF800 | U18 | SST39VF400 | 1 | IS61LV25616 | U19 | IS61LV5616 | 1 | AMS1084-3.3V | U20 | TO-263-3 | 1 | 28.63636MHz | Y1 | XTAL1 | 1 | 附件:
7 X4 ]/ H% V0 \' q% c原理图和PCB文件如下:
% F& Z5 Z7 a% T+ T% B4 P
2 g' W% T) x7 o+ `5 w) w- \7 l7 F3 H3 d4 |1 Q9 ], ^
