Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
1SMB5920BT3 | 1SMB5920BT3G-6_2V_1SMB5920BT3_O | Onsemi 1SMB5920BT3G (6.2V) | IC | 1 | ZD3 |
156-1001000901 | SD_HSMMC_TAISOL_4_156-100100090 | SD/HSMMC Socket (BS178-0001-00) | IC | 3 | CON8; CON12; CON13 |
A2-4PA-2_54DSA | A2-4PA-2_54DSA-MALE_A2-4PA-2_54 | A2-4PA-2.54DSA | IC | 1 | J4 |
A2-6PA-2_54DSA | A2-6PA-2_54DSA-6P-2_54-MALE_A2- | A2-6PA-2.54DSA | IC | 1 | J1 |
A3B-12PA-2DSA | A3B-12PA-2DSA_A3B-12PA-2DSA_A3B | A3B-12PA-2DSA | IC | 1 | CON16 |
A4B-2PA-2DSA | A4B-2PA-2DSA_A4B-2PA-2DSA_A4B-2 | A4B-2PA-2DSA | IC | 35 | JP1; JP2; JP3; JP4; JP5; JP6; JP7; JP8; JP9; JP10; JP11; JP12; JP13; JP14; JP15; JP16; JP17; JP18; JP19; JP20; JP21; JP22; JP23; JP24; JP25; JP26; JP27; JP28; JP29; JP30; JP31; JP32; JP33; JP34; JP35 |
A4B-3PA-2DSA | A4B-3PA-2DSA_A4B-3PA-2DSA_A4B-3 | A4B-3PA-2DSA | IC | 3 | J2; J3; J5 |
A4B-5PA-2DSA | A3B-10PA-2DSA_2_A4B-5PA-2DSA_A4 | A4B-5PA-2DSA(1x5, 2mm pitch) | IC | 3 | CON9; CON10; CON11 |
AXK8L24125B | AXK8L20125B_HEADER_0_AXK8L24125 | AXK8L24125B | IC | 1 | CON6 |
AXT634124 | AXT634124_AXT634124_AXT634124AW | AXT634124AW1 | IC | 1 | CON7 |
B320 | B320_0_B320_B320A | B320A | IC | 1 | D1 |
BEAD1608 | BLM18BPG121_BEAD1608_BLM18PG121 | BLM18PG121SN1 | IC | 3 | FB1; FB2; FB3 |
BGA60_W9_0X11_0_P0_8_PAD0_4 | K4T1G084QQ-HCE6-DDR2_BGA60_W9_0 | K4T1G084QQ-HCE6 or HCF7 (DDR2, 1Gb) | IC | 4 | U51; U52; U53; U54 |
BGA68_W11_0X18_0_P0_8_PAD0_45 | K4T2G084QA-HCE6_0_BGA68_W11_0X1 | K4T2G084QA-HCE6 or HCF7 (DDR2, 2Gb) | IC | 4 | U47; U48; U49; U50 |
BGA584_W35_0_P0_65_PAD0_35 | S5PV210_3_BGA584_W35_0_P0_65_PA | S5PV210 | IC | 1 | U55 |
C1005 | C1005_C1005_1.8NF | 1.8nF | IC | 2 | C1; CB172 |
C1005 | C1005_C1005_47PF | 47pF | DISCRETE | 1 | C2 |
C1005 | SMALL CAP_C1005_100NF | 100nF | DISCRETE | 1 | C3 |
C1005 | C1005_C1005_1UF | 1uF | DISCRETE | 1 | C4 |
C1005 | C1005_C1005_1UF/6V | 1uF/6V | DISCRETE | 2 | C5; C6 |
C1005 | C1005_C1005_22PF | 22pF | DISCRETE | 11 | C16; C35; C36; C37; C38; C39; C40; C41; C42; C49; C56 |
C1005 | C1005_C1005_100NF | 100nF | DISCRETE | 122 | C24; C45; C51; C55; CB1; CB2; CB3; CB4; CB5; CB7; CB8; CB9; CB10; CB11; CB12; CB13; CB14; CB15; CB16; CB17; CB19; CB20; CB21; CB22; CB23; CB24; CB25; CB26; CB27; CB28; CB31; CB32; CB33; CB34; CB35; CB36; CB37; CB38; CB39; CB40; CB41; CB42; CB43; CB44; CB45; CB46; CB47; CB50; CB51; CB52; CB55; CB56; CB59; CB60; CB61; CB62; CB63; CB64; CB67; CB68; CB71; CB72; CB73; CB74; CB75; CB76; CB79; CB80; CB83; CB84; CB85; CB86; CB87; CB88; CB91; CB92; CB95; CB96; CB97; CB98; CB99; CB100; CB101; CB102; CB105; CB108; CB109; CB117; CB118; CB120; CB121; CB122; CB123; CB124; CB126; CB127; CB128; CB129; CB130; CB131; CB132; CB133; CB134; CB135; CB137; CB139; CB141; CB142; CB143; CB144; CB145; CB146; CB147; CB148; CB149; CB150; CB151; CB152; CB153; CB161; CB166; CB170 |
C1005 | C1005_C1005_1NF | 1nF | DISCRETE | 30 | C34; CB53; CB54; CB57; CB58; CB65; CB66; CB69; CB70; CB77; CB78; CB81; CB82; CB89; CB90; CB93; CB94; CB103; CB104; CB110; CB111; CB116; CB119; CB136; CB138; CB140; CB156; CB157; CB167; CB168 |
C1005 | CAP_0_C1005_100NF | 100nF | DISCRETE | 2 | C50; CT1 |
C1005 | C1005_C1005_470PF | 470pF | IC | 1 | C54 |
C1005 | C1608_C1005_100NF | 100nF | DISCRETE | 2 | CB29; CB48 |
C1005 | C1005_C1005_2NF | 2nF | DISCRETE | 1 | CB169 |
C1608 | C1005_C1608_4.7UF/X5R | 4.7uF/X5R | IC | 26 | C7; C8; C9; C10; C11; C13; C17; C18; C19; C20; C21; C22; C23; C25; C26; C27; C28; C29; C30; C31; C32; C33; C43; C44; C52; C53 |
C1608 | C1608_C1608_100NF/C1608 | 100nF/C1608 | DISCRETE | 3 | CB18; CB30; CB49 |
C2012 | C2012_C2012_22UF,6.3V | 22uF,6.3V | IC | 3 | C46; C47; C48 |
C3216 | C3216_1_C3216_2.2UF/50V | 2.2uF/50V | DISCRETE | 1 | CB6 |
CDRH6D28 | CDRH6D28_0_CDRH6D28_CDRH6D28 (1 | CDRH6D28 (10uH) | IC | 1 | L12 |
CH-308 | CRYSTAL_CH-308_CH-308_32.768KHZ | 32.768KHz (CH-308) | IC | 1 | X3 |
COIL_1005 | INDUCTOR_COIL_1005_BLM15HD102SN | BLM15HD102SN1 | IC | 3 | L3; L4; L5 |
COIL_3225 | LQH32C_0_COIL_3225_22UH (LQH32C | 22uH (LQH32CN220K23) | IC | 1 | L1 |
COIL_3225 | LQH32C_0_COIL_3225_1UH (LQH32CN | 1uH (LQH32CN1R0M33) | DISCRETE | 1 | L2 |
COIL_3225 | LQH32C_0_COIL_3225_2.2UH (LQH_1 | 2.2uH (LQH32CN2R2M33) | IC | 3 | L6; L8; L13 |
COIL_3225 | LQH32C_0_COIL_3225_2.2UH (LQH32 | 2.2uH (LQH32C_53) | IC | 3 | L9; L10; L11 |
DC-JACK | POWER JACK_0_DC-JACK_POWER JACK | POWER JACK (DC-JACK, DC-003) | IC | 1 | JACK1 |
FUSE3225 | FUSE_MICROSMD150-2_FUSE3225_MIC | MicroSMD150-2 | IC | 1 | F1 |
GF056-60S-LSS-P2000 | CON60_GF056_GF056-60S-LSS-P2000 | GF056-60S-LSS-P2000 | IC | 1 | M1 |
HIF3F-20PA-2_54DS | HIF3F-20PA-2_54DS_HIF3F-20PA-2_ | HIF3F-20PA-2.54DS (Box,Male,Right Angle) | IC | 1 | CON15 |
KHS02 | SW-SLIDE2_KHS02_KHS02_KHS02 | KHS02 | IC | 1 | CFG1 |
KHS02 | SW-SLIDE2_KHS02_SW-DIP2 | SW-DIP2 | IC | 1 | CFG2 |
KHS06 | SW-SLIDE6_KHS06_KHS06_KHS06 | KHS06 | IC | 2 | CFG3; CFG4 |
LED-2012 | LED-RED_SMD_LED-2012_LED-BLUE ( | LED-Blue (SMD 2012) | IC | 3 | LED1; LED2; LED3 |
LED-2012 | LED-RED_SMD_1_LED-2012_LED-RED | LED-Red (SMD 2012) | IC | 1 | LED4 |
LED-2012 | LED-RED_SMD_1_LED-2012_LED-GREE | LED-GREEN (SMD 2012) | IC | 1 | LED5 |
LM2832XMY | LM2832XMY_LM2832XMY_LM2832XMY | LM2832XMY | IC | 1 | U39 |
LT3591EDDB | LT3591EDDB_1_LT3591EDDB_LT3591E | LT3591EDDB | IC | 1 | U2 |
LTC3872 | LTC3872ETS8_LTC3872_LTC3872ETS8 | LTC3872ETS8 | IC | 1 | U3 |
MAX8698C | MAX8698C_0_MAX8698C_MAX8698C | MAX8698C | IC | 1 | U33 |
MBRS320T3 | MBRS320T3_MBRS320T3_MBRS320T3 | MBRS320T3 | IC | 1 | ZD2 |
MD60-19P | MD60-19P_1_MD60-19P_MD60-19P | MD60-19P | IC | 1 | CON3 |
MSOP08P-0_65-3X3 | PCA9517DGK_0_MSOP08P-0_65-3X3_1 | PCA9517DGK | IC | 1 | U5 |
MSOP08P-0_65-3X3 | PCA9517DGK_0_MSOP08P-0_65-3X3_P | PCA9517DGK(NC) | IC | 1 | U14 |
QSE-020-01-X-D-A | QSE-020-01-L-D-A_0_QSE-020-01-X | QSE-020-01-L-D-A | IC | 2 | CON1; CON2 |
QSH-030-01-F-D-A | QSH-030-01-F-D-A_0_QSH-030-01-F | QSH-030-01-F-D-A | IC | 1 | CON14 |
QSS-075-01-F-D-A | QSS-075-01-F-D-A_4_QSS-075-01-F | QSS-075-01-F-D-A | IC | 2 | JB1; JB2 |
R1005 | R1005_0_R1005_100K | 100K | DISCRETE | 29 | R1; R3; R5; R26; R82; R84; R86; R93; R96; R108; R127; R128; R129; R130; R131; R138; R140; R147; R159; R161; R173; R268; R270; R271; R272; R273; R274; R275; R277 |
R1005 | R1005_0_R1005_0 | 0 | DISCRETE | 53 | R2; R7; R9; R10; R11; R12; R19; R20; R23; R24; R27; R34; R35; R49; R53; R54; R58; R59; R62; R64; R85; R95; R109; R121; R122; R123; R124; R126; R132; R133; R134; R135; R136; R139; R141; R143; R155; R170; R180; R183; R185; R186; R188; R192; R197; R200; R211; R223; R233; R257; R258; R260; R276 |
R1005 | R1005_0_R1005_10 | 10 | DISCRETE | 1 | R4 |
R1005 | RESISTER_0_R1005_100K | 100K | DISCRETE | 1 | R6 |
R1005 | RESISTER_0_R1005_17.4K, 1% | 17.4K, 1% | IC | 1 | R8 |
R1005 | RESISTER_0_R1005_10K/1% | 10K/1% | IC | 1 | R13 |
R1005 | R1005_0_R1005_NC | NC | IC | 34 | R14; R15; R17; R18; R30; R32; R36; R40; R47; R50; R51; R57; R111; R112; R113; R114; R115; R116; R117; R118; R120; R125; R137; R144; R145; R146; R148; R149; R152; R153; R154; R157; R160; R269 |
R1005 | RESISTER_0_R1005_40.2K/1% | 40.2K/1% | IC | 1 | R16 |
R1005 | R1005_0_R1005_4.7K | 4.7K | DISCRETE | 8 | R21; R22; R33; R263; R264; R265; R266; R267 |
R1005 | R1005_0_R1005_44.2/1% | 44.2/1% | DISCRETE | 2 | R25; R39 |
R1005 | R1005_0_R1005_1K | 1K | DISCRETE | 10 | R28; R29; R83; R94; R107; R210; R278; R279; R282; R283 |
R1005 | R1005_0_R1005_10K | 10K | DISCRETE | 7 | R31; R52; R79; R89; R100; R240; R250 |
R1005 | RESISTOR_R1005_0 | 0 | DISCRETE | 2 | R37; R45 |
R1005 | RESISTOR_R1005_10K | 10K | DISCRETE | 1 | R38 |
R1005 | R1005_0_R1005_20K | 20K | DISCRETE | 1 | R41 |
R1005 | RESISTOR_R1005_NC | NC | IC | 1 | R42 |
R1005 | RESISTOR_R1005_1.8K | 1.8K | DISCRETE | 1 | R43 |
R1005 | R_R1005_NC | NC | IC | 2 | R44; R46 |
R1005 | R_R1005_0 | 0 | DISCRETE | 3 | R48; R55; R56 |
R1005 | R1608_R1005_249K | 249K | IC | 1 | R66 |
R1005 | R1608_R1005_68K | 68K | IC | 1 | R67 |
R1005 | R1608_R1005_150K,1% | 150K,1% | IC | 1 | R70 |
R1005 | R1608_R1005_100K/1% | 100K/1% | DISCRETE | 1 | R71 |
R1005 | R1005_0_R1005_330 | 330 | DISCRETE | 4 | R72; R92; R106; R172 |
R1005 | R1005_0_R1005_51K | 51K | IC | 20 | R73; R74; R75; R76; R77; R78; R80; R81; R87; R88; R90; R91; R97; R98; R99; R101; R102; R103; R104; R105 |
R1005 | R1608_R1005_100K | 100K | DISCRETE | 3 | R110; R163; R166 |
R1005 | R_0_R1005_NC | NC | IC | 1 | R119 |
R1005 | R1005_0_R1005_10K/R1005 | 10K/R1005 | DISCRETE | 1 | R142 |
R1005 | R1005_0_R1005_5.1M | 5.1M | IC | 3 | R150; R151; R158 |
R1005 | R1005_0_R1005_10M | 10M | IC | 1 | R156 |
R1005 | R1005_0_R1005_20K,1% | 20K,1% | IC | 1 | R162 |
R1005 | R1005_0_R1005_10K,1% | 10K,1% | IC | 1 | R164 |
R1005 | R1005_0_R1005_510 | 510 | DISCRETE | 1 | R171 |
R1005 | RESISTOR_1_R1005_47K | 47K | DISCRETE | 1 | R176 |
R1005 | RESISTOR_1_R1005_10K | 10K | DISCRETE | 2 | R177; R179 |
R1005 | RESISTOR_1_R1005_12.7K | 12.7K | DISCRETE | 1 | R178 |
R1005 | R_R1005_240K | 240K | IC | 1 | R230 |
R1005 | R_R1005_300K | 300K | IC | 1 | R232 |
R1005 | R1005_0_R1005_10K/1% | 10K/1% | IC | 16 | R236; R237; R238; R239; R242; R243; R244; R245; R246; R247; R248; R249; R252; R253; R254; R255 |
R1005 | R1005_0_R1005_10K/NC | 10K/NC | IC | 2 | R241; R251 |
R1005 | R1005_0_R1005_1.2K/1% | 1.2K/1% | IC | 1 | R256 |
R1005 | R1005_0_R1005_75/1% | 75/1% | DISCRETE | 1 | R262 |
R1005 | R1005_0_R1005_1.8K | 1.8K | DISCRETE | 2 | R280; R281 |
R1608 | R1608_R1608_100K,1%/R1608 | 100K,1%/R1608 | IC | 3 | R60; R65; R167 |
R1608 | R1608_R1608_20K,1%/R1608 | 20K,1%/R1608 | IC | 2 | R61; R169 |
R1608 | R1608_R1608_44.2K,1%/R1608 | 44.2K,1%/R1608 | IC | 2 | R63; R165 |
R1608 | R_R1608_0/1608 | 0/1608 | IC | 1 | R68 |
R1608 | R1608_R1608_91K,1%/R1608 | 91K,1%/R1608 | IC | 1 | R168 |
R1608 | R1005_0_R1608_453K,1%/R1608 | 453K,1%/R1608 | IC | 1 | R174 |
R1608 | R1005_0_R1608_100K,1%/R1608 | 100K,1%/R1608 | IC | 1 | R175 |
R1608 | R1005_0_R1608_NC/R1608 | NC/R1608 | IC | 38 | R181; R182; R184; R187; R189; R190; R191; R193; R194; R195; R196; R198; R199; R201; R202; R203; R204; R205; R206; R207; R208; R209; R212; R213; R215; R216; R217; R220; R221; R222; R224; R225; R226; R228; R229; R231; R235; R285 |
R1608 | R1005_0_R1608_0/R1608 | 0/R1608 | DISCRETE | 3 | R227; R234; R284 |
R-AR4 | RP_0_R-AR4_0 | 0 | IC | 5 | RA1; RA2; RA3; RA4; RA5 |
RB414-IV02N | BATT_2_RB414-IV02N_RB414_IV02N( | RB414_IV02N(NC) | IC | 1 | BAT1 |
SCO-103 | OSCILLATOR_SMD_SCO-103_SCO-103_ | 24MHz (SMD,SCO-103) | IC | 1 | OSC1 |
SOP8_W6_0_E1_27 | LP3962_EMP_0_SOP8_W6_0_E1_27_SI | Si4884DY | IC | 1 | U4 |
SOP8_W6_0_E1_27 | MAX1818EUT33_0_SOP8_W6_0_E1_27_ | LT3021ES8(ADJ) | IC | 2 | U16; U41 |
SOP8_W6_0_E1_27 | SI4423DY_SOP8_W6_0_E1_27_SI4423 | SI4423DY | IC | 1 | U43 |
SOP24P-0_4-5X4_4 | SN74AVC8T245-DGV_3_SOP24P-0_4-5 | SN74AVC8T245-DGV | IC | 1 | U1 |
SOT23 | MOSFET P DGS_2_SOT23_FDV301N | FDV301N | IC | 1 | Q1 |
SOT23 | IRF4905/TO_0_SOT23_SI2333DS | SI2333DS | IC | 4 | Q2; Q3; Q4; Q5 |
SOT23-5 | SN74LVC1G04DBV_2_SOT23-5_SN74LV | SN74LVC1G04DBV | IC | 3 | U10; U34; U36 |
SOT23-5 | TPS2051BDBV_0_SOT23-5_TPS2051BD | TPS2051BDBV | IC | 2 | U11; U13 |
SOT23-5 | LTC3406ES5_SOT23-5_LTC3406ES5 | LTC3406ES5 | IC | 3 | U18; U21; U42 |
SOT23-5 | LTC3406ES5_0_SOT23-5_MIC5319-3. | MIC5319-3.3BD5 | IC | 2 | U19; U37 |
SOT23-5 | 54ALS32/LCC_1_SOT23-5_74LVC1G32 | 74LVC1G32DBV | IC | 3 | U22; U23; U24 |
SOT23-5 | SN74LVC1G08DBV_SOT23-5_SN74LVC1 | SN74LVC1G08DBV | IC | 2 | U30; U38 |
SOT23-5 | MAX6458_SOT23-5_MAX6458 | MAX6458 | IC | 1 | U44 |
SOT23-5 | LTC3406ES5_1_SOT23-5_MIC5219BM5 | MIC5219BM5 | IC | 1 | U46 |
SOT23-6 | NDC7002N_SOT23-6_NDC7002N | NDC7002N | IC | 1 | Q-1 |
SOT23-6 | MAX1818EUT33_SOT23-6_MAX1818EUT | MAX1818EUT33 | IC | 2 | U17; U40 |
SOT23-6 | SN74LVC1G11DBV_SOT23-6_SN74LVC1 | SN74LVC1G11DBV | IC | 2 | U29; U31 |
SOT23-6 | MAX16054AZT_SOT23-6_MAX16054AZT | MAX16054AZT | IC | 1 | U35 |
SOT-523 | RCLAMP0502B_SOT-523_RCLAMP0502B | Rclamp0502B(N.C) | IC | 4 | U6; U7; U8; U9 |
SOT-523_BEC | SDMP0340LT_SOT-523_BEC_SDMP0340 | SDMP0340LT | IC | 1 | U12 |
SW-TACT-1105SMD-4_3MM | SW-TACT_SW-TACT-1105SMD-4_3MM_S | SW-TACT (Red) | IC | 1 | SW1 |
SW-TACT-1105SMD-4_3MM | SW-TACT_SW-TACT-1105SMD-4_3MM_1 | SW-TACT (Black) | IC | 2 | SW2; SW3 |
SX-8 | CRYSTAL_SX-8_SX-8_24MHZ (SMD,SX | 24MHz (SMD,SX-8) | IC | 2 | X1; X2 |
SX-8 | CRYSTAL_SX-8_SX-8_27MHZ (SMD,SX | 27MHz (SMD,SX-8) | IC | 1 | X4 |
T2012 | CT2012_0_T2012_10UF/6.3V | 10uF/6.3V | DISCRETE | 29 | C14; CTB4; CTB5; CTB8; CTB9; CTB14; CTB15; CTB16; CTB17; CTB18; CTB25; CTB28; CTB29; CTB31; CTB32; CTB35; CTB36; CTB37; CTB38; CTB39; CTB40; CTB41; CTB42; CTB44; CTB46; CTB48; CTB69; CTB71; CTB72 |
T2012 | CT2012_T2012_10UF/6.3V | 10uF/6.3V | DISCRETE | 4 | CT2; CTB20; CTB22; CTB24 |
T2012 | CT2012_0_T2012_10UF/10V | 10uF/10V | IC | 12 | CTB1; CTB2; CTB3; CTB6; CTB10; CTB11; CTB12; CTB13; CTB26; CTB27; CTB30; CTB33 |
T2012 | CT2012_0_T2012_1UF/6.3V | 1uF/6.3V | DISCRETE | 2 | CTB19; CTB23 |
T2012 | CT2012_0_T2012_1UF/6.3V/T2012 | 1uF/6.3V/T2012 | DISCRETE | 1 | CTB21 |
T2012 | CT2012_0_T2012_10UF/6.3V/T2012 | 10uF/6.3V/T2012 | DISCRETE | 1 | CTB34 |
T7343 | CT6032_T7343_330UF/16V | 330uF/16V | DISCRETE | 1 | CTB7 |
TH3_2S6_0 | MTH_P1_D0.6X12_TH3_2S6_0_GND | GND | IC | 4 | MTH1; MTH2; MTH3; MTH4 |
TP0_8-SMD | TP_TP0_8-SMD_TP | TP | IC | 10 | TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10 |
TP0_8-SMD | TP_P0_0.8_D0_TP0_8-SMD_TP | TP | IC | 39 | TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP40; TP41; TP42; TP43; TP44; TP45; TP46; TP47; TP48; TP49; TP50; TP51; TP52; TP53; TP54; TP55; TP56; TP57; TP58; TP59 |
TP0_8-SMD | TP_P0_0.8_D0_TP0_8-SMD_A_CAMDAT | A_CAMDATA7 | IC | 4 | TP30; TP31; TP32; TP33 |
TP0_8-SMD | TP_P0_0.8_D0_TP0_8-SMD_A_FIELD | A_FIELD | IC | 1 | TP34 |
TP0_8-SMD | TP_P0_0.8_D0_TP0_8-SMD_A_CAMPCL | A_CAMPCLK | IC | 1 | TP35 |
TP0_8-SMD | TP_P0_0.8_D0_TP0_8-SMD_A_CAMVSY | A_CAMVSYNC | IC | 1 | TP36 |
TP0_8-SMD | TP_P0_0.8_D0_TP0_8-SMD_A_CAMHRE | A_CAMHREF | IC | 1 | TP37 |
TP0_8-SMD | TP_P0_0.8_D0_TP0_8-SMD_A_CAMD_1 | A_CAMDATA0 | IC | 1 | TP38 |
TP0_8-SMD | TP_P0_0.8_D0_TP0_8-SMD_FLASH | FLASH | IC | 1 | TP39 |
TP0_9-TH | TP_TP0_9-TH_GND | GND | IC | 3 | TPH1; TPH2; TPH3 |
TSSOP16P-0_65-5X4_4 | SN74CBTLV3257_TSSOP16P-0_65-5X4 | SN74CBTLV3257PWR | IC | 2 | U25; U26 |
TSSOP48P-0_5-12X6 | SN74AVCA164245DGG_TSSOP48P-0_5- | SN74AVCA164245DGG | IC | 3 | U27; U28; U32 |
TVSOP16_W6_4_E0_4 | SN74AVC8T245-DGV_2_TVSOP16_W6_4 | SN74AVC4T245DGV | IC | 1 | U15 |
USB_CON_A | USB_SINGLE_A-TYPE_HOST_2_USB_CO | USB SINGLE Port - A Type (Host) | IC | 1 | CON4 |
USB_MINI_AB | USB-MINIAB_0_USB_MINI_AB_USB-MI | USB-MINIAB | IC | 1 | CON5 |
附件:
