查看: 1654|回复: 4
哪位高手帮我看看怎么回事,覆铜后出现这样的错误?????
发表于 2010-7-15 09:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
THERMAL RELIEF ERRORS REPORT -- max6.pcb -- Thu Jul 15 09:33:28 2010- c- v+ A; z( m; a6 ^
2 W3 X+ Y! J& ^% h- C8 }" r       Drilled pads with                    Nondrilled pads with
$ r/ O. J5 ]5 T9 L% Aless than 50% thermal extensions      less than 25% thermal extensions
: G3 i% b1 Z5 N3 I' a' }1 Z  GReport of Violating Thermal Spokes Remover.! j& O2 ]2 ?% c6 r0 |* v
On Top:8 z) I6 p* }. }- V, _- A0 E' A
                                        IC3.3   (2012.7, 1408.9) # = 0
" o9 p0 b9 S1 H4 B0 A5 a2 }                                        IC3.5   (2012.7, 1369.5) # = 0" {" h# L' A  Y$ z& R/ _9 @
                                        IC3.7   (2012.7, 1330.2) # = 0
5 y8 `4 f% d9 w7 n. O                                        IC3.11  (2012.7, 1251.4) # = 0
2 U2 `7 F' T1 R) {! I2 W! x                                        IC3.17  (2150.5, 1172.7) # = 0+ o, ?  b3 i# n8 a1 D# {
                                        IC3.22  (2248.9, 1172.7) # = 0
' S* |, G6 c" ~& C: K8 {1 T                                        IC3.26  (2347.3, 1251.4) # = 0
% K3 V+ }$ R% o- a; I& e. k. Q                                        IC3.28  (2347.3, 1290.8) # = 04 @/ O" W- a5 V1 `5 S2 t1 G. A
                                        IC3.35  (2347.3, 1428.6) # = 05 o- A& \' T* Y1 ~1 p
                                        IC3.39  (2248.9, 1507.3) # = 0; r8 [2 {" X. g+ j' Z9 w
                                        IC3.42  (2189.8, 1507.3) # = 02 [& t0 C7 I9 u; `# J
                                        IC7.22  (1997.5, 3648.5) # = 0/ B/ [2 H% m; K  ]+ O4 a
                                        IC7.53  (2602.5, 3460.1) # = 0
; R! W1 l, |' d" z7 F                                        IC7.63  (2602.5, 3774.1) # = 0
, g; @) G% u. [& p0 n6 u/ J                                        IC1.14  (1572.5, 4562.75) # = 00 X7 d2 t1 t" o& m: E. a9 w6 v
                                        IC1.29  (1907.5, 4625.75) # = 0. T" {; y) V( \- s$ n
                                        IC1.31  (1907.5, 4688.75) # = 03 C) q9 m" q9 r- A
                                        SP1.2   (927.5, 775) # = 0) J0 g% _+ q) r3 a. q) B3 y1 ~
                                        SP1.5   (1052.5, 775) # = 0
4 l! `% N: C. h( p3 m; @: j! ]1 `Total Drilled pads:    0               Total Nondrilled pads:   19
- N  y; Q6 e9 [* u已经按网上说的修改了这里“thermals”
发表于 2010-7-15 10:41 | 只看该作者
不保密把图发上来给你看看啊
发表于 2010-7-15 13:47 | 只看该作者
这些地方没铺上铜
发表于 2010-7-15 20:14 | 只看该作者
你可能设置了花孔,致使有些地方无法普通,你可以把一些花孔去掉,或者强行走线的方式连通。
发表于 2010-7-15 21:03 | 只看该作者
应该不影响,设计验证通过就好了
GMT+8, 2025-7-5 11:36 , Processed in 0.109375 second(s), 24 queries , Gzip On.
