查看: 476|回复: 3
[allegro16.2][10层] AT91SAM9G45开发板(WM9711L+AT91SAM9G45+2片DDR)原理图和pc...
发表于 2020-5-21 19:54 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.2][10层] AT91SAM9G45开发板(WM9711L+AT91SAM9G45+2片DDR)原理图和pcb文件3 ]& l3 ?( u& M! Y% z: t
" i; h* M  N9 P
文件描述:5 ]) A6 g' ?1 ?* Y+ r6 ?
) w' j' T* F0 O4 q! n
1. 作品用途: LGA2011 主板
2 g5 j# F9 r( a2. 软件版本:allegro16.2! g3 g4 E" I7 }  l( {' t- k! r
3. 层数:10层$ C# i, J1 N! M9 u" X
4. 用到的主要芯片:WM9711L+AT91SAM9G45+2片DDR# x" |" F1 p$ R1 E+ ?: C: [
5. pcb尺寸:180*140 MIL
& E+ X# g5 p. k) O( |8 o: }7 o# V5 R# h! C+ r( K3 }& _6 \
作品截图如下:
! I7 d* e6 T' w! r2 `, v# o/ S. s2 o. Y0 c
顶层截图:; V! O* n: g. a  b$ B
9 Y- m6 k4 Z5 E# e- m/ ]底层截图:; @; }3 r, x; P* Z$ f
3 v5 ]& _5 \; Q
  s8 y& o( W6 `
全层截图:
- Y/ d7 v& t( k1 N$ ?$ e9 m8 O6 p- v + {' \9 L$ X! q& s3 L
: j2 n" `! K# u7 o6 Y" L6 @8 ]1 q
叠层阻抗信息如下:
9 V5 h' X% K0 X3 p3 b8 Y
# }- C7 ]' X  o- {" ?BOM:) B6 G0 R1 j2 P3 X  y3 w
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
4_8X4_8L_SMT_4_8X4_8_22UH22uHIC1L16
A06-H-E_138SWITCH2_A06-H-E_138_SWITCHSwitchIC4BP1; BP2; BP4; BP5
BAR2PTS02SIP2_BAR2PTS02_SIP2SIP2IC11JP4; JP8; JP9; JP10; JP12; JP13; JP14; JP15; JP16; JP17; JP18
BAR3PTS02SIP3-DROIT_BAR3PTS02_SIP3SIP3IC7JP1; JP2; JP3; JP5; JP6; JP7; JP11
BGA56_8X7_0295_039M58WR032KT_VFBGA56_BGA56_8X7_02M58WR032KT_VFBGA56IC1MN10
BP_KNITTER_TSSJ30JOYSTICK2_BP_KNITTER_TSSJ30_JOYJoyStickIC1BP3
C0603C0603_C0603_100N100nIC129C1; C8; C18; C28; C30; C38; C39; C40; C41; C42; C43; C44; C45; C47; C48; C49; C51; C52; C54; C55; C56; C58; C59; C60; C61; C62; C63; C64; C65; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C104; C105; C106; C107; C108; C109; C110; C111; C112; C113; C114; C115; C116; C117; C118; C119; C120; C121; C122; C123; C124; C125; C130; C131; C135; C136; C138; C139; C141; C143; C145; C153; C157; C158; C159; C160; C161; C162; C163; C164; C165; C166; C167; C169; C172; C173; C176; C177; C178; C179; C182; C183; C184; C185; C186; C188; C196; C197; C200; C202; C203; C207; C210; C212
C0603C0603_C0603_10N10nIC14C3; C5; C16; C19; C31; C32; C33; C34; C35; C36; C37; C192; C193; C194
C0603C0603_C0603_1U1uIC12C7; C10; C11; C13; C22; C24; C25; C26; C146; C147; C150; C151
C0603C0603_C0603_15P15pIC3C17; C53; C57
C0603C0603_C0603_22P22pIC6C46; C50; C133; C137; C174; C175
C0603C0603_C0603_10P10pIC4C66; C171; C208; C209
C0603C0603_C0603_470P470pIC6C128; C129; C148; C149; C155; C156
C0603C0603_C0603_33P33pIC1C204
C0603C0603_C0603_100P100pIC2C205; C206
C0603R0603_C0603_220K220KIC1R205
C0805C0805_C0805_4.7U4.7uIC5C2; C14; C20; C29; C90
C1206C1206_C1206_2.2U_10% X5R2.2uIC2C15; C191
C1206C1206_C1206_10U10uIC2C189; C190
CE1206CE1206_CE1206_10U10uIC20C6; C9; C12; C21; C23; C27; C132; C134; C140; C142; C144; C152; C154; C180; C181; C187; C198; C199; C201; C211
CI_ATMEL_TFBGA324_0MM8_SOCKET6088AT91SAM9M10_CI_ATMEL_TFBGA324_0AT91SAM9G45IC1MN5
CI_MICRON_FBGA60_8X10DDRII64M8-FBGA60_CI_MICRON_FBGAMT47H64M8CF-3 -FIC4MN6; MN7; MN8; MN9
CI_MICRON_VFBGA63_0MM8NAND2G08_VFBGA63_CI_MICRON_VFBGMT29F2G08ABDHCIC1MN11
CON_3_WDC001_575DC POWER JACK_CON_3_WDC001_575_DC POWER JACKIC1J2
CON_AMP_787616USB_A_CON_AMP_787616_G3505-4NBTG3505-4NBT1S1WIC1J12
CON_FPS_SDCARD_009_3202SD_MMC_12PIN_CON_FPS_SDCARD_009FPS009-3202-BLIC1J6
CON_JACK_KLBR-4JSTEREO CMS_CON_JACK_KLBR-4J_STESTEREO_3.5mmIC3J7; J8; J9
CON_KINGCONN_7SDMM_2211SD_MMCPLUS_CON_KINGCONN_7SDMM_27SDMM-B0-2211IC1J5
CON_LCD_TFT1N4633_40FPC_40PINS_CON_LCD_TFT1N4633_40FPC_top_40pinsIC1J24
CON_RJ45_J00_00XX_SHIELDJ0061NL_CON_RJ45_J00_00XX_SHIELJ00-0061NLIC1J15
CON_SAMTEC_SSM_110_X_DVHDR_2X10_SMT_CON_SAMTEC_SSM_110HDR_2x10_SMTIC1J18
CON_SAMTEC_SSM_120_X_DVHDR_2X20_SMT_CON_SAMTEC_SSM_120HDR_2x20_SMTIC1J23
CON_SAMTEC_TSM_104_01_DV_ATSM 2X4 PTS-DROIT_0_CON_SAMTEC_TSM-104-01-LM-DV-TRIC1J1
CON_SAMTEC_TSM_115_01_DV_AHDR_2X15_SMT_CON_SAMTEC_TSM_115HDR_2x15_SMTIC1J17
CRS_DO214AB_01TVS_CRS_DO214AB_01_5V5VIC1CR1
C_6032CE_SMT_C_6032_33U33uIC3C4; C168; C170
C_PANASONIC_FK_DCE_SMT_C_PANASONIC_FK_D_100U/6.100u/6.3VIC2C126; C127
HE10M2X10THHDR_2X10_TH_HE10M2X10TH_HTST-11HTST-110-01-SM-DIC1J13
JACK2P_815X512_728RCA JACK_JACK2P_815X512_728_RCARCA JACkIC1J20
JEDEC_MS026_BBC_LQFP7X7_48DM9161AE_0_JEDEC_MS026_BBC_LQFPDM9161AEPIC1MN18
JEDEC_MS026_BBC_LQFP7X7_48CH7024B_JEDEC_MS026_BBC_LQFP7X7CH7024BIC1MN20
L1210L1206_L1210_10UH10uHIC6L1; L2; L3; L4; L5; L11
LED0805LED_LED0805_GREENGreenIC4D1; D2; D5; D6
LED0805LED_LED0805_REDRedIC1D3
LED0805LED_LED0805_YELLOWYellowIC1D4
OSC4SM_126X98_039OSCILLATOR_OSC4SM_126X98_039_5050MHzIC1Y4
OSC4SM_126X98_039OSCILLATOR_OSC4SM_126X98_039_1313MHzIC1Y6
OSC-7MCRYSTAL_4PIN_OSC-7M_12MHZ12MHzIC1Y1
OSC-7MCRYSTAL_4PIN_OSC-7M_25MHZ25MHzIC1Y5
OSC-7MCRYSTAL_4PIN_OSC-7M_13MHZ13MHzIC1Y7
OSC-9HCRYSTAL_OSC-9H_32.768KHZ32.768KHzIC1Y2
PILE_KEYSTONE_3000_DIA12MM0BATTERYHOLDER_PILE_KEYSTONE_300BatteryHolderIC1J3
QFN48_276_0197_039WM9711L_0_QFN48_276_0197_039_WMWM9711LIC1MN14
R0603R0603_R0603_1R1RIC5R1; R5; R12; R20; R50
R0603R0603_R0603_100K100kIC16R2; R3; R9; R10; R11; R13; R23; R26; R53; R55; R74; R86; R87; R88; R89; R199
R0603R0603_R0603_47K47kIC7R4; R8; R19; R71; R72; R95; R97
R0603R0603_R0603_12K12kIC3R6; R14; R18
R0603R0603_R0603_15K15kIC2R7; R15
R0603R0603_R0603_10K10kIC10R16; R17; R38; R64; R65; R66; R73; R98; R162; R184
R0603R0603_R0603_470R470RIC6R21; R22; R25; R118; R119; R121
R0603R0603_R0603_1K1kIC2R24; R61
R0603R0603_R0603_100R100RIC3R27; R28; R29
R0603R0603_R0603_39R39RIC4R30; R31; R32; R33
R0603R0603_R0603_0R0RIC86R34; R35; R36; R54; R57; R58; R60; R63; R68; R69; R70; R75; R76; R77; R85; R90; R91; R92; R93; R94; R99; R100; R101; R103; R104; R105; R106; R108; R109; R110; R112; R114; R116; R120; R122; R123; R127; R128; R129; R130; R131; R132; R133; R134; R136; R137; R138; R139; R140; R141; R142; R143; R144; R145; R146; R147; R148; R149; R150; R151; R152; R153; R154; R155; R156; R157; R158; R159; R160; R161; R163; R165; R166; R167; R168; R169; R170; R171; R172; R173; R174; R175; R176; R185; R186; R200
R0603R0603_R0603_6.8K6.8kIC2R37; R117
R0603R0603_R0603_4.7K4.7kIC4R39; R126; R179; R180
R0603R0603_R0603_27R27RIC11R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R125
R0603R0603_R0603_1.5K1.5kIC3R51; R52; R115
R0603R0603_R0603_470K470kIC4R56; R59; R62; R67
R0603R0603_R0603_49.9R49.9RIC5R78; R102; R107; R111; R113
R0603R0603_R0603_8.2K8.2KIC4R79; R80; R81; R82
R0603R0603_R0603_680R680RIC2R83; R84
R0603R0603_R0603_68K68kIC13R96; R187; R188; R189; R190; R191; R192; R193; R194; R195; R196; R197; R198
R0603R0603_R0603_10R10RIC5R164; R201; R202; R203; R204
R0603R0603_R0603_1.2K_1%1.2kIC1R178
R0603R0603_R0603_75R75RIC3R181; R182; R183
R0805BEAD_ FERRITE_R0805_220OHM AT 1220ohm at 100MHzIC8L6; L7; L8; L9; L10; L12; L13; L14
R0805BEAD_ FERRITE_R0805_2200R2200RIC6L15; L17; L18; L19; L20; L21
R0805L0805_R0805_1.8UH1.8uHIC1L22
RN0402RN0402X4_RN0402_33R33RIC5RR1; RR4; RR8; RR14; RR54
RN0402RN0402X4_RN0402_27R27RIC29RR2; RR3; RR5; RR6; RR7; RR9; RR10; RR11; RR12; RR13; RR15; RR16; RR17; RR18; RR19; RR20; RR21; RR22; RR23; RR24; RR25; RR26; RR27; RR28; RR29; RR30; RR31; RR32; RR33
RN0402RR0402_RN0402_10K10kIC5RR36; RR44; RR45; RR46; RR47
RN0402RR0402_RN0402_27R27RIC5RR38; RR39; RR40; RR41; RR42
RN0402RN0402_RN0402_27R27RIC6RR48; RR49; RR50; RR51; RR52; RR53
RN0603RR0402_RN0603_100K100kIC1RR43
SM_5_SOT23_70HCP2122_SM_5_SOT23_70H_CP2122STCP2122STIC1MN19
SO8AT24_IICFLASH_SO8_AT24C512BNAT24C512BNIC1MN12
SO16ADM3202-SOIC16N_SO16_ADM3202ARNADM3202ARNZIC2MN15; MN16
SOD-123SCH_SOD-123_RB160M-60RB160M-60IC1D7
SOIC8_325_0500_085AT45D_SPIFLASH_SOIC8_325_0500_0AT45DB321D-SUIC1MN13
SOP8_244_0500_069SP2526A-SO8_SOP8_244_0500_069_AAIC1526-0GSIC1MN17
SOP_8__50_154X193_69RT9018A_SOP_8__50_154X193_69_RTRT9018AIC2MN2; MN4
SOT23SCH_2SERIES_SOT23_SOT23_BAT54SLBAT54SLT1GIC1D8
SOT23T02NMOS_SOT23T02_IRLML2402IRLML2402IC1Q2
SOT-363SI1563EDH_SOT-363_SI1563EDHSi1563EDHIC1Q1
SUBD9MDSUB9_M_SUBD9M_DB9M_RDB9M_RIC2J10; J11
TP_0MM4_0MM9TEST_POINT_TP_0MM4_0MM9_TP PADTP padIC1TP5
TP_KEYSTONE_5012TEST_POINT_TP_KEYSTONE_5012_TPTPIC5TP1; TP2; TP3; TP4; TP6
USBCONN_5SM_315X217_118USB_MICROAB_USBCONN_5SM_315X217G3515-09010101-00IC1J14
VDFN_8_026_120X120_39RT9186A_VDFN_8_026_120X120_39_RRT9186AIC2MN1; MN3
XTAL4SM_197X126_035CRYSTAL_4PIN_XTAL4SM_197X126_0324.576MHzIC1Y3
附件:
  {, ?3 R- p* B4 E9 Y' m3 h! V( X原理图和PCB文件如下:
3 b2 ^8 V8 ?4 ^. f* f2 i: y7 s5 _0 N5 A
游客,如果您要查看本帖隐藏内容请回复
    2022-12-26 15:46
    发表于 2020-5-21 20:21 | 只看该作者
    高手一出手,就知有没有
    2021-10-7 15:37
  • 签到天数: 44 天
    [LV.5]常住居民I
    发表于 2020-10-26 13:46 | 只看该作者
    原理图和PCB文件
    “来自电巢APP”
    GMT+8, 2025-7-29 07:18 , Processed in 0.125000 second(s), 27 queries , Gzip On.
