作品名字:[pads VX.2.4][4层]CS4525+CS8416+51单片机音频小功放PCB文件共享2 M% H8 d$ G) }9 K
+ j- H( t; c" r n文件描述
6 ?5 m' b$ N( x& t y v
2 V2 }$ C4 V! n, J9 w, L/ T9 o4 a1.功能描述:单片机音频小功放9 A/ p# J# Q* b4 P+ R+ z! e8 M
! ^$ q9 u2 p! T5 b# W% k5 r* a
2.软件版本:PADS VX.2.4
: V$ N8 U. p$ d 8 [; {! v3 E, e: | N
3.层数:4层板% P. B/ `: H! Z3 p8 f
/ P6 `6 S. _( j3 r1 w4.用到的主要芯片:CS4525
* G" N5 m8 t. a6 w) b' b5.PCB板尺寸:67mm*114mm
" B# \, b8 g, h8 u7 | m ) {, P4 ?- f& G
作品截图如下:
* @# }0 e" W+ k0 V9 `* F # S5 f! d, c: K1 q* w- m
顶层截图:
( N) y& q3 e8 y5 H! X
- f. C3 C. o) n& i, A% A3 _! D底层截图:( |9 T4 a5 _0 F+ y' j
. M2 }/ t9 {# j全层截图:
0 K& n. f) K3 |/ G
2 { |' c. f3 _) e9 [
叠层截图:" J; H0 W1 Q6 A2 C p
BOM: REFDES | COMP_DEVICE_TYPE | COMP_VALUE | 位号 | 类型 | 属性 | C1 | CSP_ELEC_130SQ_CASE_A | 10uF | C2 | CSN_0603 | 0.1uF | C3 | CSP_ELEC_130SQ_CASE_A | 10uF | C4 | CSN_0603 | 0.1uF | C6 | CSN_0603 | 0.1uF | C7 | CSP_ELEC_130SQ_CASE_A | 10uF | C8 | CSP_ELEC_130SQ_CASE_A | 1uF | C9 | CSN_0402 | 150pF | C10 | CSN_0402 | 150pF | C11 | CSN_0805 | 0.033UF | C12 | CSP_ELEC_130SQ_CASE_A | 1uF | C13 | CSN_0603 | 100pF | C14 | CSP_ELEC_130SQ_CASE_A | 1uF | C15 | CSN_0603 | 100pF | C16 | CSN_0603 | 0.1uF | C17 | CSN_0603 | 0.1uF | C18 | CSN_0603 | 0.1uF | C19 | CSN_0603 | 0.1uF | C20 | CRP_200400 | 470uF | C21 | CSN_0402 | 22pF | C22 | CSN_0402 | 22pF | C23 | CSN_0603 | 330pF | C24 | CSP_ELEC_130SQ_CASE_A | 10uF | C25 | CSN_0603 | 0.1uF | C26 | CSN_0603 | 0.1uF | C27 | CSN_0603 | 0.1uF | C28 | CSN_0603 | 0.1uF | C29 | ECQV1H474JL | 0.47UF | C30 | CSN_0603 | 1000pF | C31 | CSN_0603 | 1000pF | C32 | CSN_0603 | 330pF | C34 | CSN_0603 | 0.1uF | C35 | CSN_0603 | 0.1uF | C36 | CSN_0603 | 0.1uF | C37 | CSN_0603 | 0.1uF | C38 | ECQV1H474JL | 0.47UF | C39 | CSN_0603 | 1000pF | C40 | CSN_0603 | 1000pF | C41 | CSN_0603 | 0.01uF | C42 | CSN_0603 | 0.01uF | C43 | CSN_0603 | 1000pF | C44 | CSN_0603 | 0.1uF | C45 | CSN_0603 | 10uF | C46 | CSN_0603 | 0.1uF | C47 | CSN_0603 | 0.01uF | C48 | CSN_0603 | 0.022UF | C49 | CSN_0603 | 1000pF | C50 | CSN_0603 | 1000pF | C51 | CSN_0603 | 0.1uF | C52 | CSN_0603 | 10uF | C53 | CSN_0603 | 22pF | C54 | CSP_ELEC_130SQ_CASE_A | 1uF | C55 | CSN_0603 | 0.1uF | C56 | CSN_0603 | 0.1uF | C57 | CSN_0603 | 0.1uF | C58 | CSN_0603 | 0.1uF | C60 | CSN_0603 | 0.1uF | C62 | CSP_6032 | 100uF | C63 | CSP_ELEC_130SQ_CASE_A | 1uF | C64 | CSP_6032 | 100uF | C65 | CSN_0603 | 0.1uF | C66 | CSN_0603 | 100pF | C67 | CSP_6032 | 100uF | C68 | CSN_0603 | 100pF | C69 | CSN_0603 | 0.1uF | C70 | CSN_0603 | 1uF | C71 | CSN_0603 | 0.1uF | C72 | CRP_200400 | 470uF | D1 | SOD323 | 40V | D2 | SOD323 | 40V | D3 | SOD323 | 40V | D4 | SOD323 | 40V | D5 | SOD323 | 40V | D6 | SOD323 | 40V | D7 | SOD323 | 40V | D8 | SOD323 | 40V | D9 | CMD28-21SRC | RED | D10 | SOT143 | SP0503BAHTG | D11 | CMD28-21 | GREEN | D12 | CMD28-21 | GREEN | D13 | CMD28-21 | GREEN | D14 | CMD28-21 | GREEN | D15 | CMD28-21SRC | RED | D16 | CMD28-21 | GREEN | FD1 | FDLOCAL | | FD2 | FDLOCAL | | FD3 | FDLOCAL | | J1 | CON_RCA_RA_4_TH | ARJ-2018-GOLD | J2 | HDR4X3 | HDR4X3 | J3 | CON_PJ-202A | PJ-002AH | J4 | HDR10X2_SM_RA_FML_SSM | HDR10X2-RA-SHRD-FML | J5 | CON4P_RA_DWPT-422 | DWPT-422 | J6 | CON_RCA_RA_4_TH | ARJ-2018-GOLD | J7 | TORX141PL_7P_TH | TORX147PL(F,T) | J8 | AMP_787780-1 | 292304-1 | J9 | HDR5X2_100_SM-SAMTEC-TSM | HDR5X2-SM | J10 | CON_RCA_RA_4_TH | ARJ-2018-GOLD | J11 | HDR4X2_100_SM-SAMTEC-TSM | HDR4X2-SM | L1 | IND_41320035 | 22uH | L2 | IND_41320035 | 22uH | L3 | IND_41320035 | 22uH | L4 | IND_41320035 | 22uH | L5 | IND_1210 | 47uH | MH1 | STANDOFF#4_NPTH | STANDOFF | MH2 | STANDOFF#4_NPTH | STANDOFF | MH3 | STANDOFF#4_NPTH | STANDOFF | MH4 | STANDOFF#4_NPTH | STANDOFF | R1 | RES_0402 | 47.5K | R2 | RES_0603 | 20.0K | R3 | RES_0603 | 8.06K | R4 | RES_0603 | 5.62K | R5 | RES_0603 | 8.06K | R6 | RES_0603 | 5.62K | R7 | RES_0402 | 47.5K | R8 | RES_0402 | 22.1 | R9 | RES_0402 | 22.1 | R10 | RES_0402 | 22.1 | R11 | RES_0402 | 22.1 | R12 | RES_0402 | 47.5K | R13 | RES_0402 | 22.1 | R14 | RES_0402 | 22.1 | R15 | RES_0402 | 22.1 | R16 | RES_0402 | 22.1 | R17 | RES_0402 | 22.1 | R18 | RES_0402 | 22.1 | R19 | RES_0402 | 22.1 | R20 | RES_0402 | 22.1 | R21 | RES_0402 | 22.1 | R22 | RES_0402 | 22.1 | R23 | RES_0402 | 22.1 | R24 | RES_0603 | 20 | R25 | RES_0603 | 100 | R26 | RES_0805 | 6.2 | R27 | RES_0805 | 6.2 | R28 | RES_0603 | 20 | R29 | RES_0603 | 100 | R30 | RES_0805 | 6.2 | R31 | RES_0805 | 6.2 | R32 | RES_0603 | 75 | R33 | RES_0603 | 3.01K | R34 | RES_0402 | 47.5K | R35 | RES_0603 | 590 | R36 | RES_0603 | 2K | R37 | RES_0402 | 47.5K | R38 | RES_0402 | 22.1 | R39 | RES_0402 | 22.1 | R40 | RES_0402 | 22.1 | R41 | RES_0603 | 1K | R42 | RES_0603 | 1K | R43 | RES_0603 | 1K | R44 | RES_0603 | 1K | R45 | RES_0603 | 1K | R46 | RES_0603 | 10K | R47 | RES_0603 | 10K | R48 | RES_0402 | 22.1 | R49 | RES_0603 | 10K | R50 | RES_0603 | 0 | R51 | RES_0805 | 17.8K | R52 | RES_0603 | 383 | R53 | RES_0603 | 10K | R54 | RES_0603 | 100 | R55 | RES_0603 | 10K | R56 | RES_0603 | 1.82K | R57 | RES_0603 | 2K | R58 | RES_0603 | 2K | R59 | RES_0603 | 0 | R60 | RES_0603 | 0 | R61 | RES_0603 | 590 | R62 | RES_0603 | 100 | R63 | RES_0603 | 100 | R64 | RES_0402 | 47.5K | S1 | SW_5P_ROT_H_ALPS_ELEC_EC11B15202AAA | EC11B15202AA | S2 | PANA-EVQ-PH | MOM SW | S3 | PANA-EVQ-PH | MOM SW | U1 | QFN48_9X9 | CS4525-CNZ | U2 | QFN28_5X5 | CS8416-CNZ | U3 | LQFP32-7X7 | C8051F343-GQ | U4 | SOT23-5 | 24LC00-I/OT | U5 | SOT223-5 | LP3965EMP-ADJ/NOPB | U6 | DCDC_CONV_7P_858X362 | NDL1205SC | Y1 | XTL-HC49S | 24.576MHz | 1 L3 n/ I3 C/ T9 u/ P- U/ r+ K
+ m( O. m# {7 \% D/ b | | | | |
8 W9 z5 I$ C( f/ S* Z8 m t |
6 q9 ^; r5 n }- `2 N 4 _9 q X' i; p8 f1 \% B3 x0 P9 J
附件:
0 ?1 f: Z4 O2 N+ x8 i/ \ |
