1. 作品用途:采用MC9S12HY设计的带LCD接口的S12HY汽车HVAC控制板
2. 软件版本:allegro16.6
3. 层数:2层
5. PCB尺寸:181.61*76.2 mm
Bill of Material Report (Condensed) | | | | | |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
1206LD | LED_1206LD_IC_0.75MM_370-75142_ | LED GREEN | IC | 1 | D4 |
C200_RAD_POL | CAP_POL_C200_RAD_POL_DISCRETE_2 | 1000UF | DISCRETE | 1 | C5 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | 0.047UF | DISCRETE | 1 | C32 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.473 | 0.01UF | DISCRETE | 11 | C1; C16; C30; C47; C48; C49; C50; C55; C56; C57; C58 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_1 | 0.1 UF | DISCRETE | 13 | C2; C6; C11; C12; C14; C15; C17; C18; C27; C34; C35; C36; C37 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_2 | 1000PF | DISCRETE | 1 | C3 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4MM | 18PF | DISCRETE | 2 | C19; C20 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.1 M | 3.3 UF | DISCRETE | 1 | C29 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_0.7 M | 0.1uF | DISCRETE | 1 | C31 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_3 | 1UF | DISCRETE | 1 | C41 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.35M | 1uF | DISCRETE | 1 | C42 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_4 | 0.033UF | DISCRETE | 4 | C45; C46; C53; C54 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.79MM_1 | 10UF | DISCRETE | 1 | C28 |
CC2012-12 | CAP_POL_CC2012-12_DISCRETE_1.2M | 10uF | DISCRETE | 1 | C13 |
CC7343-31 | CAP_POL_CC7343-31_DISCRETE_3.1M | 10UF | DISCRETE | 1 | C7 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 68UF | DISCRETE | 1 | C4 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4._1 | 68UF | DISCRETE | 1 | C8 |
CC7343A | CAP_POL_CC7343A_DISCRETE_3.1MM_ | 47UF | DISCRETE | 2 | C9; C10 |
CCE63X55 | CAP_POL_CCE63X55_DISCRETE_5.5MM | 47UF | DISCRETE | 4 | C43; C44; C51; C52 |
CON_2X1_5P08 | CONN_HDR_2X1_CON_2X1_5P08_IO_18 | CON TB 2 | IO | 1 | J1 |
DIOMELF_5025 | ZDIODE_DIOMELF_5025_IC_2.6MM_48 | ZM4728A | IC | 1 | D18 |
DR127 | INDUCTOR_FERRITE_DR127_DISCRETE | 68UH | DISCRETE | 1 | L2 |
D_SMC | ZDIODE_D_SMC_IC_2.56 MM_480-300 | 1SMC12AT3 | IC | 1 | D19 |
FUSE_26X9 | FUSE_FUSE_26X9_IC_13.5MM_510-00 | Fuse Holder | IC | 1 | F1 |
HDR2X8_4P2_SHRD_TH | PLUG_8X2_HDR2X8_4P2_SHRD_TH_IO_ | CON_2X8 | IO | 1 | J7 |
HDR101 | CONN_HDR_1X1_HDR101_IO_8.585 MM | HDR 1X1 | IO | 7 | JP1; JP2; JP3; JP4; JP5; JP6; JP7 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.58MM_2 | HDR 1X2 | IO | 3 | J2; J12; J17 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71 MM_ | HDR 1X2 TH | IO | 2 | J8; J13 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.6MM_21 | HDR TH 1X3 | IO | 2 | J9; J18 |
HDR203_M20 | CONN_HDR_3X2_HDR203_M20_IO_8.64 | HDR 2X3 | IO | 1 | J3 |
HDR205 | CONN_HDR_5X2_HDR205_IO_330MIL_2 | HDR_2X5 | IO | 1 | J20 |
HSOP44_11X16MM | MC33932_HSOP44_11X16MM_IC_3.4 M | MC33932 | IC | 2 | U10; U11 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.05 MM_ | 330 OHM | DISCRETE | 5 | L3; L4; L5; L10; L11 |
IND_SRU1038_SM | INDUCTOR_FERRITE_A_IND_SRU1038_ | 47UH | DISCRETE | 1 | L1 |
JUMP1X4-6040 | HDR-1X4_JUMP1X4-6040_IO_8.4MM_2 | HDR_1X4 | IO | 2 | J4; J11 |
JUMP2X2-6040 | HDR-2X2_JUMP2X2-6040_IO_8.58MM_ | HDR 2X2 | IO | 1 | J10 |
LCD4_5P02_79X45MM | LCD_LX88461594WS6_LCD4_5P02_79X | LX88461594WS6 | IC | 1 | DS2 |
LCD41_2P54_70X51MM | LCD_41P_LCD41_2P54_70X51MM_IC_3 | GDC8799 | IC | 1 | DS1 |
LQFP100_0P5_14X14 | P9S12HY64J0MLL_LQFP100_0P5_14X1 | MC9S12HY/HA | IC | 1 | U2 |
MH140P108 | MOUNT_HOLE_MH140P108_0.1MM_280- | MOUNTING HOLE | IC | 4 | BH1; BH2; BH3; BH4 |
MH180-135P | MOUNT_HOLE_MH180-135P_0.1 MM_28 | MH_180 | IC | 4 | BH5; BH6; BH7; BH8 |
POT3_3310Y | POT_POT3_3310Y_DISCRETE_18.9MM_ | 10k | DISCRETE | 1 | R46 |
PQFN_16_12X12_A | MC33988_16P_PQFN_16_12X12_A_IC_ | MC33984CPNA | IC | 1 | U7 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.6MM_47 | 560 | DISCRETE | 1 | R1 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.7MM_47 | 10.0K | DISCRETE | 14 | R3; R7; R12; R14; R15; R16; R17; R19; R24; R26; R43; R44; R60; R61 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.6 MM_4 | 0ohm | DISCRETE | 12 | R4; R6; R9; R10; R20; R37; R40; R42; R45; R64; R65; R66 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.7 MM_2 | 1.0K | DISCRETE | 7 | R5; R18; R47; R58; R59; R62; R63 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.6 MM_1 | 3.9K | DISCRETE | 1 | R8 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.7 MM_4 | 4.7K | DISCRETE | 6 | R11; R32; R36; R39; R56; R57 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.7 MM_1 | 100 | DISCRETE | 1 | R13 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.7 MM_3 | 2.2K | DISCRETE | 1 | R25 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.65MM_4 | 1.0K | DISCRETE | 1 | R27 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7590 | 10K | DISCRETE | 1 | R30 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.7 MM_5 | 220 | DISCRETE | 1 | R34 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.55MM_4 | 1M | DISCRETE | 1 | R38 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.7 MM_6 | 820.0K | DISCRETE | 8 | R48; R49; R50; R51; R52; R53; R54; R55 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.70 MM_ | 1.5K | DISCRETE | 1 | R67 |
RC1206_OV | RES_RC1206_OV_DISCRETE_470-7824 | 60.4 | DISCRETE | 2 | R29; R31 |
RC2010 | RES_RC2010_DISCRETE_0.889MM_470 | 0.01 OHM | DISCRETE | 1 | R2 |
SC70-5_A | CI_LM94022_SC70-5_A_IC_1.1 MM_3 | LM94022 | IC | 1 | U4 |
SMB_4P57X3P94MM | DIODE_SCHTKY_SMB_4P57X3P94MM_IC | B130LB-13 | IC | 3 | D2; D3; D17 |
SMB_4P57X3P94MM | DIODE_SMB_4P57X3P94MM_IC_2.40 M | S1MB-13-F | IC | 1 | D5 |
SO8_1P27_4X5 | TJA1040T_SO_8P_SO8_1P27_4X5_IC_ | TJA1040T | IC | 1 | U8 |
SOT23 | NPN_SOT23_IC_1.26 MM_480-75156_ | BC847AL | IC | 2 | Q1; Q3 |
SOT23 | MOSFET_N_SOT23_IC_1.11MM_480-75 | MGSF1N02LT1G | IC | 1 | Q2 |
TESTPOINT_135_070MIL | TESTLOOP_TESTPOINT_135_070MIL_I | TESTLOOP | IO | 4 | TP9; TP10; TP11; TP12 |
TESTPOINT_400MIL | T_POINT_S_TESTPOINT_400MIL_IC_0 | TOUCH PAD | IC | 8 | TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8 |
TO263_8 | LM2676_8P_TO263_8_IC_4.64MM_312 | LM2676S-5.0 | IC | 1 | U1 |
TSOP3_2P54_6X5P6 | TSOP34838_3P_TSOP3_2P54_6X5P6_I | TSOP34838 | IC | 1 | U3 |
TSSOP16 | MPR083EJR2_TSSOP16_IC_1.2MM_312 | MPR084EJ | IC | 1 | U9 |
XTAL-XT49M | XTAL_XTAL-XT49M_IC_5.8MM_230-77 | 8MHz | IC | 1 | Y1 |
