1. 作品用途:采用M283核心板的一个射频识别阅读器的底板
2. 软件版本:allegro16.6
3. 层数:4层
Bill of Material Report (Condensed) | | | | | |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
1N4148 | BYW4200/DD_0_1N4148_1N4148 | 1N4148 | IC | 4 | D20; D1002; D1012; D1013 |
7E10N | INDUCTOR5_7E10N_TDK_15UH | TDK_15UH | IC | 3 | L201; L1003; L1004 |
7E10N | INDUCTOR5_7E10N_VLS4012ET-3R3M | VLS4012ET-3R3M | IC | 1 | L203 |
10TPB220M | CAP POL_10TPB220M_220UF/16V | 220uF/16V | IC | 2 | C501; C505 |
74HC244D | 74HC244D_74HC244D_(S1+S2+S3+S4) | 74HC244D | IC | 1 | U28 |
220KD07 | VARIABLE_RES_220KD07_VARIABLE_R | Variable_Res | IC | 1 | VR1 |
5504F1_09P_02A_03 | DB9_2_5504F1_09P_02A_03_RS232 | RS232 | IC | 1 | J20 |
AS-905I-LF | AS-905I-LF_AS-905I-LF_AS-905I-L | AS-905I-LF | IC | 1 | BZ1 |
B540C | BYW4200/DD_0_B540C_1N5408 | 1N5408 | IC | 2 | D1; D1003 |
B540C | BYW4200/DD_0_B540C_B340A | B340A | IC | 3 | D301; D302; D303 |
BAV74 | BAV74_BAV74_BAV74 | BAV74 | IC | 1 | D112 |
BLM21PG221SN1 | BEAD_BLM21PG221SN1_BLM18PG181SN | BLM18PG181SN1D | IC | 2 | L202; L1011 |
C0402 | CAP_C0402_0.1UF | 0.1uF | IC | 49 | 1003; 1004; 1005; C301; C302; C303; C305; C306; C307; C310; C311; C312; C313; C401; C502; C602; C603; C604; C605; C702; C703; C704; C705; C706; C707; C708; C709; C710; C711; C712; C910; C1101; C1103; C1104; C1105; C1106; C1107; C1108; C1109; C1110; C1111; C1112; C1113; C1114; C1115; C1116; C1131; C1141; C1142 |
C0402 | CAP_C0402_0.1UF/16V | 0.1uF/16V | IC | 6 | C150; C156; C207; C213; C218; C1123 |
C0402 | CAP_C0402_18PF | 18pF | IC | 1 | C208 |
C0402 | CAP_C0402_0.1UF/10V | 0.1UF/10V | IC | 1 | C210 |
C0402 | CAP_C0402_0.1UF/6.3V | 0.1UF/6.3V | IC | 1 | C217 |
C0402 | CAP_C0402_100PF/16V | 100pF/16V | IC | 1 | C219 |
C0402 | CAP_C0402_1NF | 1nF | IC | 1 | C309 |
C0402 | CAP_C0402_NC | NC | IC | 1 | C506 |
C0402 | CAP_C0402_270PF | 270pF | IC | 1 | C601 |
C0402 | CAP_C0402_100P | 100p | IC | 4 | C1145; C1146; C1147; C1148 |
C0603 | CAP_C0603_10UF | 10uF | IC | 2 | 1001; C308 |
C0603 | CAP_C0603_NC | NC | IC | 1 | 1002 |
C0603 | CAP_C0603_0.1U/25V | 0.1u/25V | IC | 2 | C103; C1140 |
C0603 | CAP_C0603_10NF/50V | 10NF/50V | IC | 2 | C202; C1118 |
C0603 | CAP_C0603_0.1UF/16V | 0.1uF/16V | IC | 2 | C205; C1132 |
C0603 | CAP_C0603_10UF/16V | 10UF/16V | IC | 1 | C206 |
C0603 | CAP_C0603_10UF/10V | 10UF/10V | IC | 1 | C209 |
C0603 | CAP_C0603_1.0UF/10V | 1.0UF/10V | IC | 1 | C216 |
C0603 | CAP_C0603_22UF | 22UF | IC | 1 | C701 |
C0603 | CAP_C0603_1NF | 1nF | IC | 8 | C1133; C1134; C1135; C1136; C1137; C1143; C1144; C1150 |
C0805 | CAP_C0805_4.7UF/16V | 4.7uF/16V | IC | 3 | C138; C152; C1121 |
C0805 | CAP_C0805_10UF/16V | 10uF/16V | IC | 2 | C155; C212 |
C0805 | CAP_C0805_4.7UF/50V | 4.7UF/50V | IC | 3 | C201; C1117; C1124 |
C0805 | CAP_C0805_22UF | 22UF | IC | 1 | C304 |
C0805 | CAP_C0805_4.7UF | 4.7UF | IC | 1 | C503 |
C0805 | CAP_C0805_10NF/50V | 10NF/50V | IC | 1 | C1125 |
C0805 | CAP_C0805_0.1UF | 0.1UF | IC | 1 | C1149 |
C1206 | CAP_C1206_10U/25V | 10u/25V | IC | 2 | C102; C1139 |
D1206 | SMAJ20A_D1206_SMAJ20A-13-F NF | SMAJ20A-13-F NF | IC | 3 | D109; D202; D1007 |
DISCHARGE_TUBE | DISCHARGE_TUBE_DISCHARGE_TUBE_D | Discharge_Tube | IC | 1 | DT1 |
DP83848K | DP83848K_DP83848K_DP83848K | DP83848K | IC | 1 | U5 |
DTC124XE | DTC124XE_DTC124XE_DTC124XE | DTC124XE | IC | 1 | Q7000 |
EL357N | EL357N_EL357N_EL357N | EL357N | IC | 16 | U702; U703; U704; U705; U706; U707; U708; U709; U710; U711; U712; U713; U714; U803; U808; U811 |
F0805 | FUSE1_F0805_FUSE1 | FUSE1 | IC | 1 | F3 |
F1206 | FUSE1_F1206_FUSE1 | FUSE1 | IC | 1 | F2 |
FM25CL64B-G | FM25CL64B-G_FM25CL64B-G_FM25CL6 | FM25CL64B-G | IC | 1 | U806 |
FUSE1 | FUSE1_FUSE1_FUSE1 | FUSE1 | IC | 1 | F1 |
G5V-1 | G5V-1_G5V-1_G5V-1 | G5V-1 | IC | 2 | RL1; RL2 |
HOLE_M3 | HOLE_HOLE_M3_HOLE | Hole | IC | 5 | H1; H2; H3; H4; H6 |
HS16-102CS | HS16-102CS_HS16-102CS_HS16-102C | HS16-102CS | IC | 1 | U6 |
JP_10 | JP_10_JP_10_JP_10 | JP_10 | IC | 1 | JP9 |
JP_RODAN | JP_RODAN_1_JP_RODAN_JP_RODAN | JP_Rodan | IC | 2 | JP6; JP7 |
JT2_2_54 | JP_2PIN_JT2_2_54_JP_2PIN | JP_2Pin | IC | 4 | JP1; JP2; JP3; JP4 |
JTAG_5_2_127 | JTAG_5_2_1.27_JTAG_5_2_127_JTAG | JTAG_5_2_1.27 | IC | 1 | J401 |
KF381_4PZ | KF381_4PZ_KF381_4PZ_KF381_4PZ | KF381_4PZ | IC | 4 | J3; J22; J23; J24 |
KF381_8P | KF381_8P_KF381_8P_KF381_8P | KF381_8P | IC | 3 | J6; J7; J8 |
KF381_12PZ | KF381_12PZ_KF381_12PZ_KF381_12P | KF381_12PZ | IC | 1 | J5 |
L0402 | BEAD_L0402_BEAD | Bead | IC | 3 | L1001; L1002; L1008 |
L0603 | BEAD_L0603_BLM15PD121SN1 | BLM15PD121SN1 | IC | 2 | L204; L1012 |
L0603 | BEAD_L0603_BEAD | Bead | IC | 3 | L1005; L1009; L1010 |
L0603 | BEAD_L0603_NC | NC | IC | 2 | L1006; L1007 |
LED0603 | CQX14/TO_1_LED0603_LED_UNDEFIND | LED_undefind | IC | 9 | D601; D602; D702; D703; D705; D1004; D1005; D1010; D1011 |
LED0603 | CQX14/TO_0_LED0603_LED_UNDEFIND | LED_undefind | IC | 1 | D701 |
LED_SDP | LED_SDP_LED_SDP_LED_SDP | LED_SDP | IC | 1 | LED1 |
LM60CIM3 | LM60_LM60CIM3_LM60BIM3 | LM60BIM3 | IC | 1 | U601 |
LXES15AAA1_C | LXES15AAA1-017_LXES15AAA1_C_LXE | LXES15AAA1-017 | IC | 1 | ESD1 |
LXES15AAA1_C | LXES15AAA1-017_LXES15AAA1_C_SMB | SMBJ33CA | IC | 1 | ESD2 |
M283_PACK | MX283_SPLIT_M283_PACK_(S1+S2+S3 | MX283_SPLIT | IC | 1 | U8 |
MAX3232 | MAX3232_MAX3232_(S1+S2)_MAX3232 | MAX3232 | IC | 2 | U29; U30 |
MICRO_USB | MICRO_USB_MICRO_USB_MICRO_USB | Micro_USB | IC | 1 | JP8 |
NUP4202W1T2G | NUP4202W1T2G_0_NUP4202W1T2G_NUP | NUP4202W1T2G | IC | 2 | U752; U753 |
P6SMB6_8CA | LXES15AAA1-017_P6SMB6_8CA_P6SMB | P6SMB6.8CA | IC | 4 | ESD7; ESD8; ESD9; ESD12 |
PCF8563T | PCF8563T_PCF8563T_PCF8563T | PCF8563T | IC | 1 | U9 |
PLUG_POWER | PLUG_POWER_0_PLUG_POWER_PLUG_PO | PLUG_Power | IC | 1 | J1 |
PLUG_RTX_POWER | PLUG_RTX_POWER_1_PLUG_RTX_POWER | Plug_RTX_Power | IC | 1 | J2 |
PRTR5V0U2X | PRTR5V0U2X_PRTR5V0U2X_PRTR5V0U2 | PRTR5V0U2X | IC | 2 | U10; U12 |
R0402 | BEAD_R0402_600 OHM 1A | 600 ohm 1A | IC | 11 | FB301; FB401; FB601; FB701; FB702; FB1101; FB1106; FB1107; FB1108; FB1111; FB1115 |
R0402 | RES_R0402_10K | 10K | IC | 5 | R202; R509; R512; R513; R514 |
R0402 | RES_R0402_12K | 12K | IC | 1 | R203 |
R0402 | RES_R0402_2K | 2K | IC | 1 | R204 |
R0402 | RES_R0402_50OHM | 50ohm | IC | 4 | R301; R302; R303; R304 |
R0402 | RES_R0402_2 KOHM | 2 kohm | IC | 7 | R305; R313; R314; R315; R316; R322; R323 |
R0402 | RES_R0402_2.87 KOHM | 2.87 kohm | IC | 1 | R306 |
R0402 | RES_R0402_75OHM | 75ohm | IC | 4 | R307; R308; R309; R310 |
R0402 | RES_R0402_330 OHM | 330 ohm | IC | 2 | R311; R312 |
R0402 | RES_R0402_0 OHM | 0 ohm | DISCRETE | 5 | R317; R318; R319; R320; R321 |
R0402 | RES_R0402_NC | NC | IC | 4 | R324; R325; R507; R510 |
R0402 | RES_R0402_2K OHM | 2K ohm | IC | 5 | R326; R327; R328; R330; R331 |
R0402 | RES_R0402_22OHM | 22ohm | DISCRETE | 4 | R501; R502; R505; R506 |
R0402 | RES_R0402_510OHM | 510ohm | IC | 1 | R508 |
R0402 | RES_R0402_0 OHMN | 0 ohmn | IC | 1 | R511 |
R0402 | RESISTOR_R0402_10K | 10k | IC | 18 | R601; R701; R706; R731; R732; R734; R735; R740; R741; R742; R743; R902; R903; R904; R905; R1016; R1243; R1246 |
R0402 | RESISTOR_R0402_4.7K | 4.7K | IC | 17 | R602; R603; R708; R709; R710; R719; R720; R723; R726; R749; R938; R1009; R1010; R1011; R1012; R1027; R1028 |
R0402 | RESISTOR_R0402_1K | 1K | IC | 19 | R604; R608; R609; R610; R611; R730; R739; R745; R747; R792; R1007; R1008; R1013; R1015; R1017; R1018; R1019; R1238; R1245 |
R0402 | RESISTOR_R0402_100K | 100K | IC | 2 | R605; R1224 |
R0402 | RESISTOR_R0402_22 OHM | 22 ohm | IC | 14 | R606; R1020; R1021; R1023; R1024; R1227; R1228; R1229; R1230; R1231; R1232; R1233; R1234; R1235 |
R0402 | RESISTOR_R0402_22 OHMN | 22 ohmn | DISCRETE | 4 | R702; R703; R704; R705 |
R0402 | RESISTOR_R0402_22OHMN | 22ohmn | IC | 1 | R707 |
R0402 | RESISTOR_R0402_680R | 680R | IC | 8 | R711; R713; R715; R717; R721; R724; R727; R737 |
R0402 | RESISTOR_R0402_0 OHM | 0 ohm | IC | 3 | R901; R1244; R1267 |
R0402 | RESISTOR_R0402_NC | NC | IC | 6 | R908; R909; R910; R911; R1264; R1265 |
R0402 | RES_R0402_4.7K | 4.7k | IC | 6 | R1001; R1002; R1003; R1004; R1005; R1006 |
R0402 | RESISTOR_R0402_1 K | 1 k | IC | 1 | R1266 |
R0402 | RESISTOR_R0402_120 OHM | 120 ohm | IC | 1 | R1268 |
R0603 | BEAD_R0603_600 OHM 1A | 600 ohm 1A | IC | 5 | FB501; FB502; FB1102; FB1113; FB1114 |
R0603 | BEAD_R0603_NC | NC | IC | 1 | FB1103 |
R0603 | RES_R0603_12K | 12K | IC | 3 | R201; R241; R1239 |
R0603 | RES_R0603_3.9K | 3.9K | IC | 3 | R242; R292; R1240 |
R0603 | RESISTOR_R0603_0 OHM | 0 ohm | IC | 1 | R607 |
R0603 | RESISTOR_R0603_NC | NC | IC | 5 | R1247; R1248; R1253; R1254; R1271 |
R0603 | RES_R0603_10M | 10M | IC | 8 | R1255; R1256; R1257; R1258; R1259; R1269; R1270; R1272 |
R0805 | FUSE1_R0805_FUSE1 | FUSE1 | IC | 1 | F4 |
R0805 | BEAD_R0805_600 OHM 1A | 600 ohm 1A | IC | 4 | FB1105; FB1109; FB1110; FB1112 |
R0805 | RESISTOR_R0805_NC | NC | IC | 2 | R1260; R1262 |
R0805 | RESISTOR_R0805_0 OHM | 0 ohm | IC | 2 | R1261; R1263 |
R1210 | RESISTOR_R1210_2K | 2K | IC | 8 | R712; R714; R716; R718; R722; R725; R728; R736 |
R1210 | RESISTOR_R1210_NC | NC | IC | 4 | R912; R913; R914; R915 |
RB5_10 | CAP-POL_RB5_10_330UF/35V | 330uF/35V | IC | 1 | C101 |
RB5_10 | CAP-POL_RB5_10_47UF/35V | 47uF/35V | IC | 1 | C1138 |
RJ45_PLUG | RJ45_PLUG_0_RJ45_PLUG_RJ45_PLUG | RJ45_PLUG | IC | 1 | U7 |
SI2301 | SI2301_SI2301_SI2301 | SI2301 | IC | 4 | Q701; Q702; Q703; Q704 |
SI2343CDS | SI2343CDS_SI2343CDS_IRLML6402 | IRLML6402 | IC | 1 | Q501 |
SIP6 | SIP6_SIP6_(S1+S2)_SIP6 | SIP6 | IC | 1 | TX1 |
SMAJ20A | SMAJ20A_SMAJ20A_SMAJ20A-13-F NF | SMAJ20A-13-F NF | IC | 1 | D2 |
SMBJ15CA-TR | LXES15AAA1-017_SMBJ15CA-TR_SMBJ | SMBJ15CA-TR | IC | 6 | ESD3; ESD4; ESD5; ESD6; ESD10; ESD11 |
SN74HCT138PW | SN74HCT138PW_SN74HCT138PW_SN74H | SN74HCT138PW | IC | 1 | U821 |
SOT-223 | AMS1117_0_SOT-223_AMS1117 | AMS1117 | IC | 1 | U3 |
SP3485 | SP3485_SP3485_SP3485 | SP3485 | IC | 1 | U807 |
SS8050LT | BFR360F_SS8050LT_SS8050LT(1.5A) | SS8050LT(1.5A) | IC | 1 | Q1001 |
SW_6_6 | OPEN_NORMAL_SW_6_6_OPEN_NORMAL | Open_normal | IC | 1 | S1 |
TCJY107M016 | CAP POL_TCJY107M016_47UF/16V | 47uF/16V | IC | 2 | C151; C1120 |
TCJY107M016 | CAP POL_TCJY107M016_22UF/16V | 22uF/16V | IC | 7 | C203; C204; C215; C1119; C1122; C1126; C1129 |
TCJ_A | CAP POL_TCJ_A_6.8UF/16V | 6.8uF/16V | IC | 1 | C214 |
TFCARD_14_5A1_475 | TF_CARD_TFCARD_14_5A1_475_TF_CA | TF_CARD | IC | 1 | U701 |
TJA1051 | TJA1051_TJA1051_TJA1051 | TJA1051 | IC | 1 | U813 |
TLV62565 | TLV62565_TLV62565_TLV62565 | TLV62565 | IC | 1 | U2 |
TP0_5 | TEST POINT_TP0_5_BIAS2 | bias2 | IC | 1 | TP1 |
TP0_5 | TP_TP0_5_TP | TP | IC | 5 | TP2; TP3; TP4; TP5; TP6 |
TPS5430 | TPS5430_TPS5430_TPS5430 | TPS5430 | IC | 3 | U1; U809; U810 |
ULN2803AG | ULN2803AG_ULN2803AG_ULN2803AG | ULN2803AG | IC | 1 | U804 |
USB_A | USB-A_USB_A_USB-A | USB-A | IC | 1 | CZ1 |
XB1085P501TR | XB1085P501TR_XB1085P501TR_XB108 | XB1085P501TR | IC | 1 | U812 |
Y_32768K | Y_32768K_Y_32768K_Y_32768K | Y_32768K | IC | 1 | Y1 |
