查看: 268|回复: 0
[PADS VX.2.4][2层]RK3188 CX100底板(AP6210+LGA16+MU509AAA+SN74LVC2GU04YZAR+C...
发表于 2020-3-3 10:05 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名字:[pads  VX.2.4][2层]RK3188 CX100底板(AP6210+LGA16+MU509AAA+SN74LVC2GU04YZAR+CR2032)PCB文件
. H$ r0 y$ l0 M- A) Z# u
4 W$ H% O* }# P  w7 Z; b! W8 g文件描述; ^8 {" a1 P) C7 k: ?- t7 i
3 g! r* K9 m  a6 }1 S3 F
1.功能描述:CX100底板
, |4 j: b) h& C2 D8 n% H- w : {( y: y! i( Y! }
2.软件版本:PADS  VX.2.48 S! ~. D* R' f# A( R9 X, P9 ]3 @! R
1 b- z2 w; V2 U( N3.层数:2层板7 i8 G+ s4 j+ b4 ]5 a  f9 ^3 {
3 a: s5 ?7 i# G6 M; f' e
4.用到的主要芯片:AP6210
, N; N+ m8 C+ Q4 ]5.PCB板尺寸:197mm*120mm6 j$ f/ I" w* Q) ^% o$ y
+ L: p; \) ^* l' x! h/ P% p
作品截图如下:
7 |- t" {$ E6 m0 q
0 B1 A9 a5 c. i* p  n, B顶层截图:
9 a3 Q8 f6 _* j/ F) }! ~
" U3 d9 C/ i. t1 O+ y; v' S底层截图:# {2 N" s2 X; _) m1 ^' ]
. }7 w' H( E% G% y
全层截图:
7 x$ L3 p2 o/ Q, \
( ~( Q8 y0 c# [& |# ~- S8 Z% c叠层截图:% K  `2 O  g% s' q6 q: \
BOM:
REFDESCOMP_DEVICE_TYPECOMP_VALUE
位号类型属性
ATN1U.FL
ATN3U.FL
C1C06032.2uF
C2C060310uF
C3C0603
C4C060310uF
C5C06030.1uF
C6C060310uF
C7C06034.7uF
C8C06030.1uF
C9C060333nF
C10C060322pF
C11C060322pF
C12C060310uF
C13C060310uF
C15C06030.1uF
C16C06032.2uF
C176031uF
C18C06030.1uF
C19C06030.1uF
C20C06030.1uF
C21C060310uF
C22C06034.7uF
C23C06030.1uF
C24C06031uF
C25C06030.1uF
C26C06031nF
C27C060322pF
C28C060333nF
C30C06031nF
C31C06031uF
C32C060333pF
C34C06030.1uF
C35C060333pF
C36C0603100pF
C37C060310uF
C41C06034.7uF
C51C06031nF
C52C060310uF
C57C060312pF
C59C0603NC
C60C0603NC/4.7uF
C61C0603NC/0.1uF
C63C0603NC
C66C06034.7uF
C70C060322uF
C107C060310uF
C118C06034.7uF
C120C06030.1uF
C157C06030.1uF
C169C0603NC
C174C080522uF
C176C080522uF
C177C080510uF
C181C06031uF
C182C06030.1uF
C184C06031uF
C185C06030.1uF
C196C06034.7uF
C201C06032.2uF
C202C06034.7uF
C203C060310pF
C204C0603NC
C205C0603100nF
C207C06038pF
C208C06038pF
C216C080510uF
C217C060322pF
C229C06030.1uF
C232C0603NC/0.1uF/25V
C233C0805NC/10uF/16V
C234C0603NC/0.1uF
C235C0603NC/10uF
C236C0603NC/0.1uF
C238C0603NC/0.1uF
C239C0603NC/1uF/25V
C240C0603NC/0.1uF
C241C0603NC/0.1uF/25V
C242C0603NC/1uF/16V
C243C0603NC/1uF/25V
C244C080510uF
C245C0603NC/120pF/50V
C246C06030.1uF
C249C06030.1uF
C253C06030.1uF
C257C06038pF
C260C06030.1uF
C264C0603NC/0.1uF
C265C06030.22uF
C266C06030.1uF
C268C06030.1uF
C271C06030.1uF
C272C06030.1uF
C280C06031uF
C283C06031nF
C302C06030.1uF
C303C06034.7uF
C318C0603NC
C587C06034.7uF
C588C08051uF/25V
C589C06030.1uF
C597C06030.1uF
C705C0603NC
C719C08051uF/25V
C720C080510uF/25V
C721C06031uF
C723C08051uF/25V
C728C06030.1uF
C729C06030.1uF
C730C0603NC/4.7uF
D1SOD3231N4148
D2SOD1231N5819
D5SOD123NC
D6SOD323NC/1N4148
D7SOD323NC
D9E0402NESD9B5V
D11E0402NESD9B5V
D12E0402NESD9B5V
D13E0402NESD9B5V
D16D1206NC/18V
D17SOD3231N4148
D18D1206NC/6.5V
D19SOD123NC/1N5819
D20SOT23NC/BAT54S
D21E0402NESD9B5V
D22SOD1231N5819
D24SOT23NC/BAT54S
D29SOD1231N5819
ED1E0402NNC/ESD9B5V
ED2E0402NNC/ESD9B5V
ED13E0402NESD9B5V
ED14E0402NESD9B5V
ED15E0402NESD9B5V
ED16E0402NESD9B5V
ED17E0402NESD9B5V
ED18E0402NESD9B5V
ED19E0402NESD9B5V
ED20E0402NESD9B5V
ED21E0402NESD9B5V
ED22E0402NNC
ED24E0402NESD9B5V
ED30E0402NESD9B5VL
ED31E0402NESD9B5VL
ED32E0402NESD9B5V
ED33E0402NESD9B5VL
ED39E0402NESD9B5V
ED41E0402N0R
ED42E0402NNC
FB1L060333nH
FB2L060333nH
FB3L06034.7nH
FB4L06034.7nH
FB12L0603BLM18PG181SN1
J1CON2PINWSBEEP蜂鸣器连接器
J2TF-CARDTF_SD_SOCKET
J3CON2PLSBUUZ蜂鸣器连接器
J4CON4PLS
J55P_OTG
J7CON4PLSWF-250-01D-4
J8HDMI_AHDMI_C
J9FPC24PINOV2659
J10FPC40PINNC
J12SIP30
J14CONN_12PIN_(046298004000883)_2011
J17CON2PLSA-2.54MMBUUZ蜂鸣器连接器
J20CON-TJ50
J23USB5P_UAF95-05254-1500-D
J24CON-TJ50
J25CON-TJ50
J26CON-TJ50
J705SIMCARDSIM_CARD_PS-47308-001_2011_D917
L1IND-4X44.7uH/1.5A
L4603NC
L5603NC
L7IND_5X53.3uH/2.5A
L11L08053.3uH/0.7A
L12IND-4X44.7uH/1.5A
L14IND-4X4_3X3NC/22uH/500mA
L40SLP2510P8NC/AZ1045-04F/ESDA6V8UD
L41SLP2510P8NC/AZ1045-04F/ESDA6V8UD
L42IND-4X410uH
MIC1CON4PLS
MIC2MIC45MIC
MIPI1MIPI_36PINAA07-P032VA1 Female
PA1T-1TEST
PA5T-1TEST
PA6T-1TEST
PA7T-1TEST
PA8T-1TEST
Q1SOT238050
Q2SOT238050/SOT23
Q3SOT23WPM2341
Q4SOT238050
Q5SOT238050
Q6SOT238050
Q7SOT238050
Q8SOT238050
Q9SOT238050
Q10SOT23WPM2341
Q12SOT23WPM2341
Q22SOT23NC/S8550
Q25SOT-523NC/DTC114EE
R160310K
R260310K
R3603100K
R4R060347K
R560351K
R6603100K
R8C06031K
R9603NC
R1060347K
R1160310K
R126030R
R136030R
R14603330K
R1660343K
R18603NC
R19603NC
R20603NC
R21603100K
R226031M
R2360310K
R2460347K
R25603100K
R27603NC/15K%1
R28603200K
R29603100K
R3260310K
R3360333R
R3460333R
R35603NC
R36603NC
R376032R
R38603NC/10K%1
R39603NC/5.1K
R4060333R
R41603NC
R4260333R
R43603NC
R44603NC
R45603NC
R46603NC
R4760310K
R4860310K
R4960310K
R5060310K
R516031M
R5260310K
R5360310K
R5460322K
R55603100K
R56603NC
R5760310K
R586030R
R596030R
R606030R
R6160330K
R626030R
R646030R
R65603NC
R696030R
R70603NC
R7360310K
R7860310K
R816034.7K
R95603210K
R9660310R
R10060315K
R102603100K
R1046031.5K
R105R06030R
R10960323K%1
R11060310K
R111603100K
R11260310K/NC
R119603NC
R124603NC
R12560310K
R1266030R
R1326030R
R133603100K
R1346030R
R1406031K
R141603NC/2K
R142603120K
R146603NC
R147603100K
R148C06031K
R150R060312K
R1516034.7K
R1556030R
R15660333R
R15760333R
R158603NC
R1596032K
R160603100K
R161603330K
R162603NC/140K
R163603NC/820K%1
R1646032K
R16660333R
R167603NC/47K
R16860333R
R173603NC
R17460333R
R175603NC
R177603100K
R17860333R
R179603NC
R18060322R
R1816030R
R18260322R
R18960310K
R1906030R
R1916030R
R1926030R
R19360310K
R1946030R
R195603NC/47K
R196603NC/0R
R198603NC/0R
R199603NC/10K
R200603NC
R20260310K
R2036030R
R2046030R
R205603100K
R206603100k
R2076030R
R20860333R
R20960333R
R2106030R
R211603470R
R212603560K
R213603NC
R214603100R
R221603NC/10K
R22760310K
R228603NC
R2296032K
R230603100K
R23160310K
R233603NC
R235603NC
R236603NC
R243603330K
R24460343K
R2456031K
R24660330K
R2476031M
R24960310k
R2526030R
R271603NC/1K
R272603NC/10K
R273R0603NC/10R
R36860310K/NC
R36960320K
R370603330K
R371603330K
R372R06031.7R
R373603NC/1.62M
R374603100K
R375603NC/10K
R45260333R
R45360333R
R454603NC
R4796030R
R481R06031.7R
R485603NC
R486603NC
R487603NC
R488603NC
SW1SW6X6SMTHOME
SW3SW6X6SMTVOL-
SW5SW6X6SMTVOL+
SW6SW6X6SMTreset
SW10SW6X6SMTPOWER
T1T-155
T2T-157
T14T-156
T16T-1TEST
T22T-1TEST
T23T-1TEST
T27T-1TEST
T28T-1TEST
T29T-1TEST
T30T-1TEST
T31T-1TEST
T32T-1TEST
T33T-1TEST
T35T-1
T38T-1
T39T-1
T40T-1TEST
T41T-1
T42T-1
T43T-1
) n. `5 F  l& O4 a
5 ^& ]1 }- d3 w
" Q- u' A! ^9 W" L/ @5 Z
7 A/ P' q; y( p( |9 Q
附件:
原理图和PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
9 j  e  t1 H* h/ c0 ]8 a* H7 M5 O" m9 ?
GMT+8, 2025-7-28 05:12 , Processed in 0.140625 second(s), 28 queries , Gzip On.
