Bill of Material Report (Condensed) | | | | | |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
6-534237-1 | PINHD-1X13-FEMALE-ROUND_0_6-534 | PINHD-1X13-FEMALE-ROUND | IC | 1 | J8 |
8PIN_LFB0001 | LFB0001-R_0_8PIN_LFB0001_LFB000 | LFB0001-R | IC | 1 | U8 |
40MIL-TESTPOINT | T POINT R_40MIL-TESTPOINT_TESTP | TestPoint | IC | 22 | TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22 |
40MIL-TESTPOINT_BLACK | T POINT R_40MIL-TESTPOINT_BLACK | TestPoint | IC | 4 | TP23; TP24; TP25; TP26 |
741X083472JP | RESAR_IS_4/SM_741X083472JP_4_7K | 4_7K | IC | 1 | RN4 |
0862-1J1T-43-F | 0862-1J1T-43-F_0862-1J1T-43-F_0 | 0862-1J1T-43-F | IC | 1 | J12 |
8526-4500PL | PINHD-2X13-FEMALE-ROUND_0_8526- | PINHD-2X13-FEMALE-ROUND | IC | 1 | J7 |
ATS060SM | XTAL_ATS060SM_ATS060SM-1 HC-49/ | ATS060SM-1 HC-49/US-SM | IC | 1 | Y2 |
ATS240SM | XTAL_ATS240SM_ATS24ASM-1 HC-49/ | ATS24ASM-1 HC-49/US-SM | IC | 1 | Y3 |
C031-71045-10101 | RCA JACK_2_C031-71045-10101_BNC | BNC | IC | 1 | J11 |
C0402 | CAP_1_C0402_1NF-0402SMT | 1NF-0402SMT | IC | 17 | C1; C2; C121; C122; C127; C135; C138; C142; C150; C155; C157; C160; C161; C164; C166; C167; C169 |
C0402 | CAP NP_C0402_100NF | 100nF | IC | 25 | C6; C9; C10; C15; C18; C21; C23; C24; C53; C60; C61; C62; C86; C87; C90; C91; C94; C96; C99; C100; C188; C191; C193; C216; C217 |
C0402 | CAPACITOR NON-POL_C0402_10NF | 10nf | IC | 5 | C11; C92; C106; C110; C117 |
C0402 | CAPACITOR NON-POL_C0402_100NF | 100nf | IC | 7 | C12; C14; C103; C107; C108; C111; C118 |
C0402 | CAP NP_C0402_10NF | 10nf | IC | 11 | C16; C17; C19; C20; C22; C95; C97; C98; C105; C192; C222 |
C0402 | CAP_1_C0402_10NF-0402SMT | 10NF-0402SMT | IC | 17 | C27; C31; C33; C34; C36; C39; C40; C119; C123; C124; C132; C133; C134; C136; C151; C163; C172 |
C0402 | CAP NP_0_C0402_100NF-0402SMT | 100NF-0402SMT | IC | 10 | C47; C137; C144; C146; C152; C156; C159; C165; C170; C177 |
C0402 | CAP-NP_C0402_10PF | 10pF | IC | 4 | C63; C66; C68; C71 |
C0402 | CAP-NP_C0402_150PF | 150pF | IC | 4 | C64; C65; C70; C72 |
C0402 | CAP-NP_C0402_1000PF | 1000pF | IC | 4 | C67; C69; C75; C78 |
C0402 | CAP-NP_C0402_0.22UF | 0.22uF | IC | 4 | C73; C74; C81; C83 |
C0402 | CAP NP_0_C0402_1NF-0402SMT | 1NF-0402SMT | IC | 3 | C126; C131; C153 |
C0402 | CAP_1_C0402_100NF-0402SMT | 100NF-0402SMT | IC | 1 | C128 |
C0402 | CAP NP_0_C0402_10NF-0402SMT | 10NF-0402SMT | IC | 10 | C129; C139; C141; C143; C145; C147; C148; C149; C158; C162 |
C0402 | CAP NP_0_C0402_0.1UF | 0.1uF | IC | 2 | C130; C199 |
C0402 | CAP_S_C0402_1UF, X5R, 6.3V | 1uF, X5R, 6.3V | IC | 2 | C140; C200 |
C0402 | CAP NP_C0402_33NF | 33nF | IC | 1 | C190 |
C0402 | CAP NP_C0402_22PF | 22pF | IC | 1 | C207 |
C0402 | CAP NP_C0402_33PF | 33pF | IC | 4 | C211; C212; C213; C214 |
C0402 | CAP NP_C0402_0.01UF | 0.01uF | IC | 2 | CBYP1; CBYP2 |
C0603 | CAP_1_C0603_100NF-0603SMT | 100NF-0603SMT | IC | 16 | C3; C28; C30; C32; C37; C112; C114; C120; C125; C171; C175; C176; C198; C201; C203; C204 |
C0603 | CAP NP_C0603_100NF-0603SMT | 100NF-0603SMT | IC | 10 | C44; C45; C51; C54; C180; C184; C186; C187; C194; C215 |
C0603 | CAPACITOR NON-POL_C0603_1UF | 1uf | IC | 3 | C104; C109; C115 |
C0603 | CAP NP_C0603_1UF | 1uF | IC | 1 | C173 |
C0603 | C_C0603_12PF | 12pF | IC | 4 | C189; C195; C197; C202 |
C0603 | CAP NP_C0603_0.1UF | 0.1uF | IC | 2 | C205; C209 |
C0805 | CAP-NP_C0805_22UF,6.3V | 22uF,6.3V | IC | 9 | C4; C7; C8; C76; C77; C79; C82; C84; C85 |
C0805 | CAP_SMT_0805_C0805_1UF-16V-0805 | 1UF-16V-0805SMT | IC | 5 | C25; C41; C42; C46; C168 |
C0805 | CAP NP_C0805_10UF/6V3/X7R | 10uF/6V3/X7R | IC | 12 | C26; C29; C35; C38; C43; C48; C49; C50; C174; C181; C183; C185 |
C0805 | CAP NP_C0805_100NF | 100nF | IC | 1 | C59 |
C0805 | CAPACITOR NON-POL_C0805_22UF / | 22uF / 6V3 | IC | 3 | C101; C102; C116 |
C0805 | CAP NP_C0805_2.2UF | 2.2uF | IC | 1 | C196 |
C0805 | CAP NP_C0805_1UF | 1uF | IC | 3 | C206; CIN1; CIN2 |
C1206 | CAP-NP_C1206_10UF,25V | 10uF,25V | IC | 2 | C5; C80 |
C1206 | CAP NP_C1206_33UF/6V3 | 33uF/6V3 | IC | 1 | C52 |
C1206 | CAP NP_C1206_10UF | 10uF | IC | 2 | COUT1; COUT2 |
C1210 | CAP NP_C1210_22UF | 22uF | IC | 1 | C210 |
C7343-43 | CAP POL_C7343-43_10UF | 10uF | IC | 1 | C208 |
CAP_0603 | CAP NP_CAP_0603_1UF | 1uF | IC | 8 | C55; C56; C57; C58; C218; C219; C220; C221 |
CDRH4D15_S | INDUCTOR_CDRH4D15_S_2.2UH | 2.2uH | IC | 1 | L5 |
CNHDMIRA | CONN_500254_1927_CNHDMIRA_50025 | 500254_1927 | IC | 1 | J13 |
DF17-40DP-0_5V | DF17-4_0-40DP-0_5V_0_DF17-40DP- | DF17(4.0)-40DP-0.5V(5?) | IC | 1 | J9 |
DFN10DD-NS | LT3023EDD-10DFN_0_DFN10DD-NS_LT | LT3029EDE | IC | 1 | U4 |
DSC1001-CE-25-000 | OSC4/SM_0_DSC1001-CE-25-000_DSC | DSC1001-CE-25.000 | IC | 1 | Y4 |
DSC1001-CE-27_000 | OSC4/SM_0_DSC1001-CE-27_000_DSC | DSC1001-CE-27.000 | IC | 1 | Y1 |
FB0603 | FB17 | Z-600 ohm / 74279265 | IC | 8 | FB3; FB5; FB13; FB14; FB15; FB16; FB17; FB18 |
FB0805 | INDUCTOR_FB0805_BLM21AG601SN1D | BLM21AG601SN1D | IC | 3 | FB12; FB19; FB20 |
FBGA84 | IS43DR16320B_0_FBGA84_IS43DR163 | IS43DR16320B | IC | 1 | U1 |
FBGA-100PIN | BCM54810_FBGA-100PIN_BCM54810 | BCM54810 | IC | 1 | U3 |
FPBGA484 | ECP3_70EA_BGA484_FPBGA484_ECP3_ | ECP3_70EA_BGA484 | IC | 1 | U2 |
HD3X1 | HEADER 3_HD3X1_HEADER 3 | HEADER 3 | IC | 3 | J4; J5; J6 |
HD10X1 | 8 HEADER_0_HD10X1_HEADER 10 | HEADER 10 | IC | 1 | J3 |
HRS-DF12A-HEADER | DF12-4_0-40DP-0_5V_HEADER_HRS-D | DF12(4.0)-40DP-0.5V_HEADER | IC | 1 | J2 |
HRS-DF12A-RECEPTACLE-CENTER | DF12_40DS-0_5V_RECEPTACLE_HRS-D | DF12__-40DS-0.5V_RECEPTACLE | IC | 1 | J1 |
L1806 | INDUCTOR_1_L1806_BLM41PG600SN1 | BLM41PG600SN1 | IC | 3 | FB1; FB2; FB4 |
L1806 | BEAD FERRITE_0_L1806_BLM41PG600 | BLM41PG600SN1 | IC | 3 | FB6; FB7; FB21 |
L1806 | INDUCTOR_0_L1806_BLM41PG600SN1 | BLM41PG600SN1 | IC | 1 | FB10 |
L-CDRH3D18 | IND_L-CDRH3D18_6.8UH | 6.8uH | IC | 1 | L1 |
L-CDRH3D18 | IND_L-CDRH3D18_4.7UH | 4.7uH | IC | 1 | L3 |
L-CDRH4D18C | IND_L-CDRH4D18C_6.8UH | 6.8uH | IC | 1 | L2 |
L-CDRH4D18C | IND_L-CDRH4D18C_4.7UH | 4.7uH | IC | 1 | L4 |
L-EUL4516C | INDUCTOR_L-EUL4516C_BLM41PG600S | BLM41PG600SN1 | IC | 3 | FB8; FB9; FB11 |
LED1206 | LED_LED1206_RED | red | IC | 2 | LED1; LED2 |
LED1206 | LED_LED1206_GREEN | green | IC | 1 | LED3 |
LQFP48 | FTD2232D_LQFP48_FTD2232D | FTD2232D | IC | 1 | U5 |
LT_DCB6_2X3 | LTC3406_21_LT_DCB6_2X3_LT3503ED | LT3503EDCB#PBF | IC | 1 | U15 |
MMBT3904_SOT523F | MBT3904DW1T1G_0_MMBT3904_SOT523 | MMBT3904 | IC | 1 | Q1 |
MNR18E0APJ500 | RESISTOR_ARRAY_0602X8_MNR18E0AP | 50 OHM ARRAY | IC | 3 | RN1; RN2; RN3 |
PJ-032A | 22HP037A_PJ-032A_PJ-032A | PJ-032A | IC | 1 | J10 |
POWERDI123-KS | D-SCHOTTKY_0_POWERDI123-KS_DFLS | DFLS220L | IC | 4 | D1; D2; D3; D4 |
POWERMITE | DIODE SCHOTTKY_8_POWERMITE_MBRM | MBRM130LT3G | IC | 1 | D9 |
PROBEPOINT | TESTPOINT_4_PROBEPOINT_PROBEPOI | PROBEPOINT | IC | 7 | PP1; PP2; PP3; PP4; PP5; PP6; PP7 |
PUSHBUTTON | SW PUSHBUTTON-SPST_1_PUSHBUTTON | SW PUSHBUTTON-SPST | IC | 1 | SW1 |
QFN24UF-4X4 | LT3508EUF-QFN24UF-4X4_0_QFN24UF | LT3508EUF | IC | 2 | U10; U11 |
R0402 | R_R0402_10_0K | 10_0K | IC | 2 | R5; R52 |
R0402 | R_R0402_10K | 10k | IC | 1 | R6 |
R0402 | RESISTOR_R0402_33R | 33R | IC | 22 | R14; R15; R62; R63; R66; R67; R68; R69; R72; R73; R74; R75; R76; R77; R78; R79; R80; R81; R82; R83; R84; R85 |
R0402 | RESISTOR_R0402_301K | 301K | IC | 1 | R16 |
R0402 | RESISTOR_R0402_1_0K | 1_0K | IC | 1 | R17 |
R0402 | RESISTOR_R0402_1_24K | 1_24K | IC | 2 | R18; R20 |
R0402 | RESISTOR_R0402_DNI | DNI | IC | 4 | R22; R24; R25; R64 |
R0402 | RESISTOR_R0402_4_7K | 4_7K | IC | 6 | R23; R96; R98; R99; R103; R105 |
R0402 | RESISTOR_R0402_10K | 10k | IC | 1 | R26 |
R0402 | RESISTOR_R0402_150 | 150 | IC | 3 | R33; R34; R35 |
R0402 | R_R0402_51K | 51k | IC | 6 | R41; R42; R44; R47; R49; R50 |
R0402 | R_R0402_34K | 34k | IC | 1 | R43 |
R0402 | R_R0402_11.5K | 11.5k | IC | 1 | R45 |
R0402 | R_R0402_35.7K | 35.7k | IC | 1 | R46 |
R0402 | R_R0402_63.4K | 63.4k | IC | 1 | R48 |
R0402 | R_R0402_21_5K | 21_5K | IC | 1 | R53 |
R0402 | R_R0402_5_11K | 5_11K | IC | 1 | R54 |
R0402 | R_R0402_12.4K | 12.4k | IC | 1 | R55 |
R0402 | R_R0402_4_7K | 4_7K | IC | 4 | R57; R58; R95; R119 |
R0402 | RESISTOR_R0402_1K | 1k | IC | 1 | R59 |
R0402 | RESISTOR_R0402_50R | 50R | IC | 2 | R60; R61 |
R0402 | R_R0402_100_R | 100_R | IC | 4 | R87; R89; R92; R93 |
R0402 | RESISTOR_R0402_40_2R | 40_2R | IC | 1 | R88 |
R0402 | RESISTOR_R0402_10K1% | 10k1% | IC | 1 | R90 |
R0402 | RESISTOR_R0402_49_9R | 49_9R | IC | 2 | R91; R97 |
R0402 | R_R0402_33_R | 33_R | IC | 1 | R94 |
R0402 | RESISTOR_R0402_2_2K | 2_2K | IC | 2 | R108; R111 |
R0402 | RESISTOR_R0402_33 | 33 | IC | 1 | R115 |
R0402 | RESISTOR_R0402_1M | 1M | IC | 1 | R121 |
R0402 | AAC-0402_R0402_10_0K | 10_0K | IC | 1 | R122 |
R0402 | AAC-0402_R0402_54_9K | 54_9K | IC | 1 | R123 |
R0402 | AAC-0402_R0402_100K | 100K | IC | 1 | R124 |
R0603 | RESISTOR_R0603_1_0K | 1_0k | IC | 1 | R1 |
R0603 | RESISTOR_R0603_4_7K | 4_7K | IC | 8 | R2; R3; R4; R19; R65; R70; R71; R107 |
R0603 | RESISTOR_R0603_2K2 | 2k2 | IC | 6 | R7; R8; R9; R10; R11; R13 |
R0603 | RESISTOR_R0603_10K | 10k | IC | 7 | R12; R37; R38; R39; R40; R112; R116 |
R0603 | RESISTOR_R0603_DNI | DNI | IC | 4 | R21; R29; R30; R100 |
R0603 | RESISTOR_R0603_1K5 | 1k5 | IC | 1 | R27 |
R0603 | RESISTOR_R0603_1M | 1M | IC | 1 | R28 |
R0603 | RESISTOR_R0603_0R | 0R | IC | 8 | R31; R32; R86; R101; R102; R104; R106; R129 |
R0603 | R_R0603_22_1K-0603SMT | 22_1K-0603SMT | IC | 1 | R51 |
R0603 | R_R0603_8_06K-0603SMT | 8_06K-0603SMT | IC | 1 | R56 |
R0603 | RESISTOR_R0603_330R | 330R | IC | 1 | R109 |
R0603 | R_R0603_1M | 1M | IC | 2 | R110; R117 |
R0603 | R_R0603_1K | 1K | IC | 1 | R113 |
R0603 | R_R0603_2_2K | 2_2K | IC | 1 | R114 |
R0603 | R_R0603_0R | 0R | IC | 1 | R118 |
R0603 | R_R0603_10K | 10K | IC | 1 | R120 |
R0603 | RESISTOR_R0603_27 | 27 | IC | 4 | R125; R126; R127; R128 |
R0603 | RES_R0603_27K | 27K | IC | 1 | R133 |
R0603 | RES_R0603_4.7K | 4.7K | IC | 2 | R134; R135 |
R0805 | RESISTOR_R0805_1M | 1M | IC | 1 | R36 |
R0805 | RESISTOR_R0805_DNP | DNP | IC | 3 | R130; R131; R132 |
SMC_B | CAP POL_SMC_B_47UF | 47uF | IC | 4 | C13; C88; C89; C93 |
SMTFUSE | SMTFUSE_0_SMTFUSE_F1251CT-ND | F1251CT-ND | IC | 1 | F1 |
SO08_V2 | LP2998_SO08_V2_LP2998 | LP2998 | IC | 1 | U12 |
SO-08 | 24LC64I/SN_SO-08_24LC64I/SN | 24LC64I/SN | IC | 1 | U13 |
SO-08NARROW_150MIL | M93C46-WMN6TP_SO-08NARROW_150MI | M93C46-WMN6TP | IC | 1 | U7 |
SOD123 | DIODE_0_SOD123_1N4448W | 1N4448W | IC | 4 | D5; D6; D7; D8 |
SOD323 | DIODE 34/DD_0_SOD323_CMDSH-4E | CMDSH-4E | IC | 1 | D10 |
SOP16_2 | M25P64_SOP16_2_M25P64 | M25P64 | IC | 1 | U9 |
SQFP-R-14X20-100 | CY7C68013A-100AXC_1_SQFP-R-14X2 | CY7C68013A-100AXC | IC | 1 | U6 |
TANTB | CAPACITOR_SM_TANTALUM_0_TANTB_2 | 22UF-16V-TANTBSMT | IC | 5 | C113; C154; C178; C179; C182 |
TPS3836L30_SOT23-5 | TPS3836L30_TPS3836L30_SOT23-5_T | TPS3836L30 | IC | 1 | U14 |
附件:
