作品名:[AD 15][4层] DSP板子(MAX1951+LM1117-1.8+ICS512)原理图、PCB源文件4 b) \* B3 n& K5 |* @7 R% ?+ F6 c
7 s# ~3 l; P6 R3 K
# _6 ]8 A; q% Q5 W$ M文件描述
' M, J5 e% \, r7 |6 j1. 作品用途:DSP板子6 h0 q) J' E8 _5 `# I; R4 }
2. 软件版本:AD 15
- W7 ` d! i# H# B( s; F( W$ P3. 层数:4层板: ?+ F0 O9 @. ` \8 |. O& p
4. 用到的主要芯片:MAX1951+LM1117-1.8+ICS5125 Z5 j9 U/ R: e
5. PCB尺寸:112mm*106mm; w8 N; {& r& r
8 ]2 d2 x* p! ~* Z$ m u S. d! Y3 q! P- O5 H
作品截图如下:2 `1 f$ S+ R$ S
顶层截图:
0 f0 h [( a6 g# j. g
' ]0 ~5 E; h" k- r4 r0 h底层截图:. t* p A# j- {$ I( R6 u
# Z3 z! |9 d5 ~+ c$ J+ ?% Y; a
全层截图:
5 f6 a3 N# Y, |
, W0 k. A- ]& V0 r; ]- g
叠层信息截图如下:
1 ~! K: R. O2 A- A3 d$ A8 t
; f' K. {9 ]8 } T7 b$ FBOM:/ x" M" x5 W R* X% b/ l
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 100u | C1 | 6032 | 1 | 10u | C2, C5, C9, C10, C12, C13, C14, C15, C16, C17, C18, C19, C74, C92, C95, C130, C131, C149 | 1210 | 18 | 0.1u | C3, C4, C6, C7, C20, C27, C34, C35, C38, C46, C47, C49, C50, C51, C53, C66, C67, C68, C69, C70, C71, C85, C88, C91, C94, C97, C99, C101, C103, C106, C109, C112, C115, C118, C121, C124, C127, C142, C144, C148, C150, C151 | 0603 | 42 | 620p | C8, C11 | 0603 | 2 | 0.01u | C21, C22, C23, C24, C25, C26, C28, C29, C30, C31, C32, C33, C72, C73, C75, C132, C133, C134, C135, C136, C137, C138, C139, C143, C152 | 0603 | 25 | 33p | C36, C37, C48, C52, C63, C64 | 0603 | 6 | 1u | C39, C40, C41 | 0805 | 3 | 180p | C42, C43, C44, C45 | 0603 | 4 | 390p | C54, C55, C56 | 0603 | 3 | 120p | C57, C58, C59 | 0603 | 3 | 560p | C60, C61, C62 | 0603 | 3 | 1n | C65, C76, C77, C78, C79, C80, C81, C82, C83, C84, C87, C90, C93, C96, C98, C100, C102, C104, C105, C107, C108, C110, C111, C113, C114, C116, C117, C119, C120, C122, C123, C125, C126 | 0402 | 33 | 220u | C86, C89, C128, C129 | 6032 | 4 | 270p | C140, C141 | 0603 | 2 | 1nF/2kV | C145, C146, C147 | RAD0.2 | 3 | SL02 | D1 | DIOD_S2 | 1 | LED | D2, D3 | LED0805 | 2 | EMIFILTER | E1 | 321825 | 1 | 2A | F1 | FUSE_2 | 1 | IDPAD | ID1, ID2, ID3, ID4, ID5, ID6, ID7 | IDPAD | 7 | CON2 | J1 | SIP2 | 1 | UARTIF | J2 | SIP3 | 1 | VGA | J3 | VGA15_1 | 1 | NETIF | J4 | RJ45_1 | 1 | JTAG_D | JP1 | IDC14 | 1 | JTAG_C | JP2 | IDC10 | 1 | BUZZER | JP3 | BZR_1 | 1 | HEADER 5X2 | JP4 | IDC10 | 1 | 2uH | L1, L2 | SR63 | 2 | 2.2uH | L3, L4, L5, L6, L7, L8, L9, L10 | 0805 | 8 | 0.33uH | L11 | 0805 | 1 | JCB201209-301 | L12, L13, L14, L16, L18 | 0805 | 5 | JCB201209-601 | L15 | 0805 | 1 | 1mH | L17 | 1812 | 1 | PAD | M1, M2, M3, M4 | PADH-3 | 4 | 50M | OSC1 | OSC_1 | 1 | BNC | P1, P2 | SIP2 | 2 | TED485 | Q1, Q2 | TED485 | 2 | 8050 | Q3, Q4, Q5 | SOT-23 | 3 | 10 | R1, R4 | 0603 | 2 | 150k | R2 | 0603 | 1 | 31.6k | R3 | 0805 | 1 | 82k | R5 | 0603 | 1 | 10.0k | R6, R8 | 0805 | 2 | 7.50k | R7 | 0805 | 1 | 120 | R9 | 0603 | 1 | 4.7k | R10, R11, R18, R19, R27, R29, R33, R34, R35, R37, R38, R39, R42, R43, R44, R46, R52, R58, R59, R60, R62, R63, R64, R65 | 0603 | 24 | 0 | R12 | 0603 | 1 | 1k | R13, R20, R24, R28, R31, R32, R36, R40, R41, R45, R47, R61 | 0603 | 12 | 39 | R14, R15, R16, R17 | 0603 | 4 | 82 | R21, R22, R23 | 0603 | 3 | 12 | R25 | 0805 | 1 | 49.9 | R26, R48, R55, R56, R57, R67, R68, R69, R70, R71 | 0603 | 10 | 33 | R30 | 0603 | 1 | 330 | R49, R50, R53, R54 | 0603 | 4 | 10k | R51 | 0603 | 1 | 22.1k | R66 | 0805 | 1 | TG110-S050N5 | T1 | N5 | 1 | P6KE12CA | TV1, TV2 | 7227 | 2 | P6KE10CA | TV3, TV4 | 7227 | 2 | MAX1951 | U1, U2 | SO-8 | 2 | LM1117-1.8 | U3 | SOT223 | 1 | HY57V283220 | U4, U5 | TSOP-86 | 2 | CBT3245 | U6 | TSSOP-20 | 1 | AM29LV320 | U7 | TSOP-48 | 1 | 16C2550IB48 | U8 | LQFP-48 | 1 | MAX3072E | U9 | SO-8 | 1 | TVP5150 | U10 | PQFP32 | 1 | SAA7105H | U11 | QFP-64 | 1 | TMS320DM642-600A | U12 | BGA548ZDK | 1 | ICS512 | U13 | SO-8 | 1 | EPM3064ATC100 | U14 | TQFP-100 | 1 | MAX706 | U15 | SO-8 | 1 | LXT971_P | U16 | LQFP-64 | 1 | 1.8432M | Y1 | XTAL_1 | 1 | 14.31818M | Y2 | XTAL_1 | 1 | 27M | Y3 | XTAL_1 | 1 | RF60-050B | ZR1, ZR2 | AXIAL0.2 | 2 | 附件:
/ e9 y* Q! {0 F# a5 n% C原理图和PCB源文件如下:
7 n: A) [% W* J% M
3 t; T$ ]- W' x' O
! t! O9 }4 h9 ^% M |
