作品名:[AD 16][6层]ARM9 Micro2440(S3C2440X)核心板原理图和PCB
! q7 Y, \+ R3 Q& K, ~* V0 w
7 d1 D, a; O! T5 o3 O5 [6 c6 |文件描述4 j# n! o y- y B2 e- c. z
1. 作品用途:ARM9 核心板4 H: n& r9 c# y) t( v0 B
2. 软件版本:AD 16
) o t) `! N- W3. 层数:6层板1 q. l* H5 y' C6 q
4. 用到的主要芯片:S3C2440X$ _8 h+ r* h' {
5. PCB尺寸:73.4mm*62.2mm
6 S8 x; o# j) s
" j0 y5 P/ H# M' M; n1 H9 j作品截图如下:" s: Q3 c! H) |% z
顶层截图:( a2 Y- ] n$ d0 a. H1 B
+ w( s( S6 t$ W( L5 M7 E- u0 A) C% s1 ?4 R' ^) f
底层截图:4 X" g( b2 h4 I, Y a5 e4 G- X
3 I- F0 ?( \0 b1 R, t" d
|$ K# S4 K7 c全层截图:* y. i B# N8 i( |
8 w2 ^, ~7 p! {+ y/ b3 ?
8 U7 E* f( K5 H4 \5 Z7 W" F
叠层信息截图如下:& \/ |4 q, w1 I# }* y, E
8 K4 p) z! o" O( {+ }3 p! ~! k6 c* I! e. E. s& n; j9 X- Z- S$ P
BOM:
, H& Q$ G6 o" }3 v7 QComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | GREEN | 1, 2, 4 | LED | 3 | 22p | C1 | 0603A | 1 | 100nF | C3, C7, C14, C16, C17, C18, C19, C21, C23, C24, C26, C29, C30, C31, C32, C33, C39, CA2, CA3, CA4, CA6, CA8, CA9, CA11, CA12, CA14, CA15, CA16, CA17, CA18, CA19, CA20, CA21, CA22 | 0603A | 34 | 10uF/10V | C4, C11 | 3216A | 2 | 10uF | C9, C12 | 3216A | 2 | 0.1uF | C10 | 0603A | 1 | 33nF/6.3V | C13 | 0603A | 1 | 104 | C34 | 0603A | 1 | 2n7 | C40 | 0603A | 1 | HEADER 5X2 | JTAG2 | IDC10S | 1 | 10K | NR1, NR2, NR3, R3, R4, R6, R58, R59 | 0603R | 8 | 1K | NR5, R40, R42, R57 | 0603R | 4 | 330 | R1 | 0603R | 1 | 470 | R2 | 0603R | 1 | 15K | R10 | 0603R | 1 | 0 | R31 | 0603R | 1 | 100K(1%) | R32 | 0603r | 1 | 10(1%) | R33 | 0603r | 1 | 22 | R36, R54, R55, R65 | 0603R | 4 | SW-PB | RST | SW-PB2 | 1 | CON1 | TP1 | TP1 | 1 | S3C2440X | U1 | BGA289 | 1 | K9Fxx08 | U2 | TSOP48 | 1 | LM1117-33 | U4 | TO-252 | 1 | HY57V561620FTP-H | U6, U7 | TSOP54 | 2 | MAX811 | U9 | MAX811 | 1 | AM29LV160DB/SST39VF1601 | U10 | TSOP48 | 1 | 32.768kHz | X1 | XTAL-B | 1 | ) `) ~0 I' r( X/ Q( W/ q
附件:
1 m% f5 E, }6 ^' \* p: z4 C原理图和PCB源文件如下:
" S( [$ k0 m# p- t8 P5 U+ z; H+ u, W) a3 J+ g% b% T
( z" H2 S& l& m* ` |
