查看: 402|回复: 1
[AD 16][4层]米联客MZ702开发板底板 (FT232HL)原理图和PCB源文件
发表于 2020-2-20 14:22 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名:[AD 16][4层]米联客MZ702开发板底板 (FT232HL)原理图和PCB源文件
- N( j# U) \8 d7 z* h4 }* r+ U) j! U' d, i& b- i" {
文件描述
, x4 H# _) H3 l$ T2 S' O' l4 v1. 作品用途:米联客MZ702开发板底板
3 o4 p& X8 [) {3 l' C2. 软件版本:AD 16
- [! e& j4 I8 G( S! q. y8 u3. 层数:4层板
0 a4 f/ N0 x5 i8 I1 ^' O# g! o4. 用到的主要芯片:FT232HL+ N& ~; w! l9 K/ P2 z7 ]* O  F" \$ @! j
5. PCB尺寸:120mm*120mm
8 i, ]! p9 Y8 @$ m/ |3 W& {+ _) i0 x3 v* {
作品截图如下:4 v& Z) w, m3 V8 ^# B2 H, j
顶层截图:6 }8 ?. I: X) m0 _5 S
, x/ A9 X$ i) `) \9 g, J
. L6 i4 r7 k4 M3 k* k4 f
底层截图:
) Z3 M; h% S3 f% A4 c% E 1 j( ?8 \4 I# `7 H0 U2 t
# V; v4 U9 J! t# t全层截图:
$ u, x- N, V) u4 G % t: M' z  }1 d0 y" J3 N6 M+ s
; b6 x5 ?4 w! m, Q- b/ L# y1 ]/ a叠层信息截图如下:
1 D0 d% N! m- Q8 x4 n. V/ G # T# e3 g7 z8 w, ^  x: y
# ^6 C7 P; Z- i- Q$ k& T
BOM:' S( `; m0 j4 e
Comment(属性)
Designator(位号)
Footprint(封装)
Quantity(数量)
22uf/16V
AC9, AC10
CAP1206
0.1uf
C1, C2, C3, C4, C5,  C6, C7, C8, C11, C12, C13, C14, C15, C17, C32, C38, CA1, CA2, CA3, CA4, CA5,  CA6, CA7, CA8, CA9, CA10, CA14
CAP0402
27
12pf
C9, C10
CAP0402
10uf
C16
CAP0402
10uf/6V3
C30
CAP0603
2.2uf
CA11, CA13
CAP0402
1uf/6V3
CA12
CAP0402
RCLAMP0524P
CE1A, CE1B, CE1C,  CE2A, CE2B, CE2C, CE3A, CE3B, CE3C, CE4A, CE4B, CE4C, U1, U2, U3, U6
SLP2510P8_10
16
RCLAMP0522P
CE1D, CE2D, CE3D,  CE4D, U7
SLP1610P4_6
HEADER20
CEP1, CEP2, CEP3,  CEP4
HEADER10X2X2.5
0.3A
CEP1_F, CEP2_F,  CEP3_F, CEP4_F
CAP0603
1N5822
D1, D4
SMA_DO_214AC
TVS_SMAJ5.0CA_5V
D2
SMA_DO_214AC
1PS79
D3
SOD-523
BAS16XV2T1-D
DA1
SOD-523
FUSE
F1
1206
300mA
F2
CAP0603
100R
FBA1, FBA2
CAP0603
FEP
FEP1
FEP-X2
FX8-100P-SV92
HT1, HT2, HT3
FX8-100P-SV92
TXS02612RTWR
IC1
QFN24
100MHZ
IC2
3225
RTL8211E-VL
ICA1
QFN48
50MHZ
ICX
3225
J1, J2
MicroUsb
MINIUSB2.0
J3
MINI_USB2.0
SDK
J4
TF_K
HY911130A
J6, JA1
HY911130A
HDMI_A
JH1
HDMI_1903015
FB
L1
CAP0603
FB100r
L2, L3
CAP0603
LD0, LD1, LD2, LD3,  LD4, LD5, LD6, LD7, LD8, LD9, LD10
D0603
11
HEADER6
P2
HEADER1X6
DC
P3
DC5.0
AO3400
Q1, Q2
SOT23
49.9R
R1, R9
RA4_0603
100R
R2, R3, R4, R5
RES0402
2.2K
R6, R8, R17, R19,  R34, R36, R37, R52, R53, R63, R64, R65, R66, R67, R68, R69
RES0402
16
10K
R7, R10, R18, R22,  R25, R26
RES0402
12K1
R11
RES0402
2K2
R12, R16, R27, R28,  R29, R30, R31, R32, R33, R58
RES0402
10
620R
R13
RES0402
0R
R14
RES0402
27K
R15
RES0402
150R
R20
RES0402
R21
RES0402
4.7K
R23, R24, RA9, RA11,  RA12
RES0402
20R
R35, RA14
RES0402
4K7
RA1, RA13
RES0402
2.49K1%
RA7
RES0402
390R
RA8, RA10
RES0402
SW-1
SW0, SW1, SW2, SW3
SW-3X9
SW123
SW5
SW123
FT232HL
U4
LQFP48-50P7X7X1.6
93LC56BT-I/OT
U5
SOT6-95P
12M
XT1
3225
& g" E! D3 D: D& q0 [1 M9 O附件:/ h2 b1 N5 B! h0 y& V
原理图和PCB源文件如下:; X' n0 c$ J( R- g# j' H9 `8 z
游客,如果您要查看本帖隐藏内容请回复
  q* i' W( _% z. _2 B6 l) f, [1 H7 n+ F  K" K' i' a
发表于 2020-12-10 18:39 | 只看该作者
ASFDSDGHGGHJ- _( ^- {6 H: H/ C% q) H, j( H
GMT+8, 2025-7-29 17:30 , Processed in 0.140625 second(s), 28 queries , Gzip On.
