查看: 248|回复: 1
[allegro16.6][6层] TMS320C5515 eZDSP USB STICK v2 (Revision A)(TMS320C5515+F...
发表于 2020-2-13 10:19 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
7 L* q; {' J1 D- s4 c
[allegro16.6][6层] TMS320C5515 eZDSP USB STICK v2 (Revision A)(TMS320C5515+FT2232HL+TLV320AIC3204IRHBT)原理图和pcb文件
  G+ ^9 @( L' |; e7 \, T3 s& S5 N& `: P
文件描述:3 i( W# A6 w5 O  }- Y  x
/ P& z% C3 |! f. n2 o- r2 x0 V1. 作品用途:TMS320C5515 eZDSP USB STICK v2 (Revision A)6 p5 D  W0 y# U. ~% i
2. 软件版本:allegro16.6
5 W& z( Y0 A4 L; }1 U3. 层数:6层8 |1 y' g2 Y0 _$ b
4. 用到的主要芯片:TMS320C5515+FT2232HL+TLV320AIC3204IRHBT3 Z+ l" a# K7 ]0 r7 P- z
5. pcb尺寸: 2838*2638 MIL
4 W' n$ M: W3 H$ U  F& p5 _9 q+ Z9 U2 S- f, T" U
作品截图如下:
: k: h  m9 p" R( @) A6 M' d7 r+ X& ~  w2 J! U/ D0 ]# o
顶层截图:
9 X/ h5 J; }& Y/ }4 ^( r4 i
7 ^! J! t2 M; l. |8 M* x+ |底层截图:& q) j- K  P% D
" h9 f: n- a. c: x; R1 p% |5 k% H5 ]1 I4 @* U8 B& ]
全层截图:
# O4 m* Y5 }' t( e
: T+ |) B+ B( P " X: Z  B0 j# z5 }; I. z5 h
BOM:
9 {; Y1 b3 l- ]- [4 b# r6 J
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
C402-25CAP_0_C402-25_100NF100nFIC11C5; C37; C47; C55; C56; C72; C80; C118; C119; C121; C124
C402-25CAP_0_C402-25_10NF10nFIC4C9; C49; C77; C122
C402-25CAP 10UF CERMC 6.3V 20% 1206_C41uFIC3C10; C15; C78
C402-2510UF16V10%SMD_0_C402-25_.1UF.1uFIC2C30; C94
C402-25CAP .1 UF 10% 0603_C402-25_.1UF.1uFIC5C32; C34; C35; C36; C107
C402-25CAP 100NF CERMC 16V 10% 603_C400.1uFIC32C33; C38; C39; C42; C43; C46; C48; C59; C61; C63; C64; C65; C67; C70; C71; C73; C74; C75; C76; C79; C81; C82; C83; C84; C87; C88; C98; C100; C102; C105; C108; C109
C402-25CAP 100NF CERMC 16V 10% 603_C_11uFIC5C40; C45; C50; C53; C66
C402-25CAP 10NF CERMC 50V 10% 603_C4020.01uFIC7C41; C44; C51; C52; C60; C68; C86
C402-25CAP 1000PF CERMC 50V 10% 402_C41000pFIC4C54; C58; C62; C69
C402-25CAP 1.0UF CERMC 25V 10% 603_C_21uFIC1C85
C402-25CAP 680NF CERMC 6.3V 20% 402_C40.1uFIC1C89
C402-25CAP 18PF CERMC 50V 5% 603_C402-33pFIC2C90; C91
C402-25CAP NP_2_C402-25_.1UF.1uFIC1C93
C402-25CAP 10PF CERMC 50V 5% 603_C402-10pFIC1C96
C402-25CAP NP_5_C402-25_0.1UF0.1uFIC1C99
C402-25CAP 1.0UF CERMC 25V 10% 603_C40.1uFIC1C112
C402-25CAP NP_2_C402-25_NO-POPNO-POPIC1C115
C402-25C_0_C402-25_1UF1uFIC1C116
C603-35X45CAP .1 UF 10% 0603_C603-35X45_44.7uFIC1C1
C603-35X45CAP NP_2_C603-35X45_4.7UF4.7uFIC2C17; C117
C603-35X45CAP 470NF CERMC 16V 20% 603_C600.47uFIC2C25; C26
C603-35X4510UF16V10%SMD_0_C603-35X45_4.7U4.7uFIC4C29; C31; C92; C95
C603-35X45CAP 1.0UF CERMC 25V 10% 603_C601uFIC3C101; C103; C110
C603-35X45CAP .1 UF 10% 0603_C603-35X45_11uFIC1C104
C603-35X45CAP 10UF CERMC 6.3V 20% 1206_C61uFIC1C106
C603-35X45CAP 1.0UF CERMC 25V 10% 603_C_1.022uFIC1C111
C603-35X45CAP_0_C603-35X45_4.7UF4.7uFIC2C120; C123
C1206-40X70CAP 10UF CERMC 6.3V 20% 1206_C110uFIC10C2; C3; C4; C7; C12; C13; C16; C18; C20; C27
C1206-40X70CAP 22UF CERMC 16V 20% 1206_C1210uFIC3C21; C22; C28
C1206-40X70CAP 10 UF TANTALUM_C1206-40X70_10uFIC1C97
C1206-40X70CAP 1.0UF CERMC 25V 10% 603_C122.2uFIC2C113; C114
C1206-40X70-POLCAPACITOR POL_0_C1206-40X70-POL10uFIC1C6
C3528-64X112CAP 10UF CERMC 6.3V 20% 1206_C310uF,16VIC1C19
C3528-64X112CAP 47UF TAN 10V 20% EIA_D_0_C3100uFIC2C23; C24
CONN14-12X30-VLLFCI_10051922-1410ELF_CONN14-12XFCI_10051922-1410ELFIC1J5
DBV6-27X39-674LXV1G175_DBV6-27X39-6_74LVC1G74LVC1G175-DBV6IC1U3
DBV-20X60-5U-TPS61041-28-V, 250-MA BOOST_DTPS61041IC1U9
DBV-20X60-5TPS76901_0_DBV-20X60-5_TPS76901TPS76901IC1U12
DRL5-12X40TPD2E001_DRL5-12X40_TPD2E001TPD2E001IC1U13
FCI-87409-110HEADER 10X2_0_FCI-87409-110_HEAHEADER 10X2IC2P1; P2
IND-VLF3010TMP_083348_IND-VLF3010_2.2UH2.2uHIC1L3
JUMP1X2-6040JUMPER_1X2_100_530L_JUMP1X2-604CON2IC1JP1
L603-35X45FERRITE BEAD_0_L603-35X45_BLM18BLM18AG601SN1DIC6FB1; FB4; FB5; FB6; FB7; L4
L805-35X60FERRITE BEAD_0_L805-35X60_BLM21BLM21AG151SN1DIC2FB2; FB3
L805-35X60FERRITE CHIP_L805-35X60_BLM21P2BLM21P221SNIC3L1; L5; L6
LED1206-59X59LED_1_LED1206-59X59_LED_GRNLED_GRNIC1DS1
LED1206-59X59LED_1_LED1206-59X59_LED GRNLED GRNIC1DS2
LED1206-59X59LED_1_LED1206-59X59_LED REDLED REDIC1DS3
LED1206-59X59LED_1_LED1206-59X59_LED YELLOWLED YELLOWIC1DS4
LED1206-59X59LED_1_LED1206-59X59_LED BLUELED BLUEIC1DS5
LED1206-59X59LED_0_LED1206-59X59_GREENGREENIC1DS6
MEC1-EDGE-2X30_21-22HEADER 20X2_2_MEC1-EDGE-2X30_21EDGE CONN 30X2IC1P4
MELF1206-40X70DIODE ZENER_0_MELF1206-40X70_6.6.2VIC1D1
MOLEX-49225-201MM_CARD_0_MOLEX-49225-201_MICROMicroSD_CARDIC1J6
MOLEX_48037-001USB-B CONNECTOR_2_MOLEX_48037-0USB-A connectorIC1J2
OSC4-71X79CLK-4PIN_0_OSC4-71X79_12MHZ12MHzIC1U10
PQFP64PMFT2232_2_PQFP64PM_FT2232HLFT2232HLIC1U6
PW14-12X70SN74LVC126_0_PW14-12X70_SN74LV1SN74LV125IC1U7
QFN32_202SQU-TLV320AIC3254 CODEC_3_QFN32_2TLV320AIC3204IRHBTIC1U11
R402-25R_0_R402-25_10K10KIC6R2; R5; R22; R42; R59; R107
R402-25R_R402-25_NO-POPNO-POPIC1R3
R402-25RESISTOR 10K OHM 5% 1/16W 603_R10KIC12R10; R15; R16; R30; R31; R50; R52; R83; R84; R85; R87; R88
R402-25RESISTOR 0.0 OHM 1/16W 603_R4020IC24R13; R14; R24; R25; R26; R27; R37; R43; R44; R54; R55; R56; R57; R58; R62; R63; R71; R72; R73; R74; R75; R76; R77; R92
R402-25RESISTOR 1K OHM 5% 1/16W 603_R4220IC5R17; R67; R68; R69; R70
R402-25RESISTOR 0.0 OHM 1/16W 603_R4_1220KIC2R18; R66
R402-25RESISTOR 100K OHM 5% 1/16W 603_100KIC4R21; R38; R41; R45
R402-25R_0_R402-25_2K22K2IC1R23
R402-25R_0_R402-25_00IC1R28
R402-25R_0_R402-25_NO-POPNO-POPIC1R29
R402-25RESISTOR 0.0 OHM 1/16W 603_R4_210KIC5R32; R33; R36; R61; R90
R402-25TMP_3_R402-25_10K 1%10K 1%IC1R35
R402-25RESISTOR 0.0 OHM 1/16W 603_R4_3NO-POPIC7R39; R40; R51; R53; R78; R79; R91
R402-25R_0_R402-25_4747IC6R46; R47; R48; R49; R60; R104
R402-25RESISTOR_1_R402-25_100100IC1R81
R402-25RESISTOR 10K OHM 5% 1/16W 603_1NO-POPIC1R86
R402-25RESISTOR 1K OHM 5% 1/16W 603__110KIC2R94; R96
R402-25RESISTOR 0.0 OHM 1/16W 603_R4_4100IC1R95
R402-25RESISTOR 0.0 OHM 1/16W 603_R4_520KIC1R97
R402-25R_0_R402-25_10.7K10.7KIC1R98
R402-25R_0_R402-25_169K169KIC1R99
R402-25R_0_R402-25_47-NOPOP47-NOPOPIC2R102; R106
R402-25R_R402-25_220220IC1R105
R603-35X45RESISTOR 180K OHM 1% 1/16W 603_180KIC1R11
R603-35X45RESISTOR 1.6M OHM 1% 1/10W 603_1.6M 1%IC1R12
R603-35X45RESISTOR 0.0 OHM 1/16W 603_R603169K 1%IC2R19; R65
R603-35X45RESISTOR 0.0 OHM 1/16W 603_R6_112K 1%IC1R20
R603-35X45RESISTOR 0.0 OHM 1/16W 603_R6_2294K 1%IC1R64
R603-35X45RESISTOR 0.0 OHM 1/16W 603_R6_34.7KIC1R80
R603-35X45RESISTOR 4.7K OHM 5% 1/16W 603_NO-POPIC1R82
R603-35X45RESISTOR 4.7K OHM 5% 1/16W 60_14.7KIC1R89
R603-35X45RESISTOR 910K OHM 1% 1/16W 603_392K 1%IC1R93
R603-35X45R_R603-35X45_12K 1%12K 1%IC1R103
R1206-40X70RESISTOR 0.0 OHM 1/16W 603_R1200IC2R1; R9
R1206-40X70R_R1206-40X70_0.020.02IC1R6
R1206-40X70R_2_R1206-40X70_0.020.02IC2R7; R8
R1206-40X70R_R1206-40X70_00IC1R100
R1206-40X70R_R1206-40X70_NO-POPNO-POPIC1R101
SAMTEC-MUSBUSBMINI_B_SAMTEC-MUSB_USBMINI_BUSBMINI_BIC1J1
SJ1_3515J - ST-3515 AUDIO JACK_0_SJ1_35SJ1-3515-SMT, 5PJACK STEREOIC2J3; J4
SO8-25X75TPS76601_SO8-25X75_TPS76601TPS76601IC2U1; U8
SO8-25X7593C46_SO8-25X75_93C46_56_6693C46_56_66IC1U2
SOD123-36X48DIODE SCHOTTKY_1_SOD123-36X48_MMBR0520IC1D2
SW-KSC4-GWSW PUSHBUTTON_0_SW-KSC4-GW_USERUSER1IC1SW1
SW-KSC4-GWSW PUSHBUTTON_0_SW-KSC4-GW_US_1USER2IC1SW2
TP1-6040TEST POINT_1_TP1-6040_VCOREVcoreIC1TP1
TP1-6040TEST POINT_1_TP1-6040_VBUSVBUSIC1TP2
TP1-6040TEST POINT_1_TP1-6040_CLKOUTCLKOUTIC1TP3
TP1-6040TEST POINT_1_TP1-6040_GNDGNDIC2TP4; TP6
TP1-6040TEST POINT_1_TP1-6040_3V33V3IC1TP5
TSOP48-10X60AM29LV160B_0_TSOP48-10X60_S29ALS29AL032D70TFI04IC1U5
XTAL4-23X47-SSP-T7CRYSTAL_0_XTAL4-23X47-SSP-T7_3232.768KHzIC1Y1
ZCH196-P65MMTMS320VC5505_2_ZCH196-P65MM_TMSTMS320C5515IC1U4
附件:: X4 G6 ]1 _1 |" n* S
原理图和PCB文件如下:6 a: S. o9 {3 y' v/ ?5 `
游客,如果您要查看本帖隐藏内容请回复
0 y/ T7 l$ {! y6 P& G7 _, f
- @, ?0 O: F3 D1 ]1 Q) |% N& E! W
发表于 2020-10-25 23:31 | 只看该作者
不会也得要积分吧
GMT+8, 2025-7-29 07:13 , Processed in 0.125000 second(s), 27 queries , Gzip On.
