查看: 333|回复: 1
[allegro15.6][20层]stratixIII_3sl150,Altera 开发板(EP3SL150F1152+EPM2210_F2...
发表于 2020-2-11 18:42 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
. C0 X9 K; N" ^/ C( u- j5 y* v[allegro15.6][20层]stratixIII_3sl150,Altera 开发板(EP3SL150F1152+EPM2210_F256FBGA+DDR)原理图和pcb文件
, p! h' i6 A2 D3 k$ p6 Z1 }; }; y5 ^3 S# E1 W7 }: G1 J
文件描述:
! V# j1 e; f& M, |* ^/ }, ?/ i6 o# I/ K" D
1. 作品用途:stratixIII_3sl150,Altera 开发板
) v2 u# A! `0 d% D2. 软件版本:allegro15.6: H, S; Y* |  h: a* g( r; i( v
3. 层数:20层  G  g# X6 a' w% `1 v
4. 用到的主要芯片:EP3SL150F1152+EPM2210_F256FBGA+DDR
& V* C1 d7 \+ z* g1 B1 Z5. pcb尺寸: 8200*6950 MIL
4 O& w: O, g- {; q8 W1 e
( x: M- P# L6 N作品截图如下:: R# I/ V# M6 R3 U4 x& X
! q* }  c4 {# X顶层截图:; P* h8 u% w. k) D; W1 u
$ \5 \' H. V3 N2 _底层截图:! I$ j+ v0 G+ }4 h
1 U' c, O% u, d. e% M# `
& q$ b. Z; I) }$ E  w全层截图:
5 @7 J- p' Z' D4 K% T( n+ \$ y   d' T. n: \9 T( @2 u, X! s
8 b) }+ X# i' {# B: L0 z, j叠层阻抗信息如下:
- l. e! T4 E" C' T
# E3 U+ a- q4 Z( F, U6 d! H5 eBOM:
. ]% u& d" X2 B
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
402CAP_0402_0.1UF0.1uFDISCRETE112C1; C2; C11; C129; C130; C132; C133; C134; C135; C137; C138; C139; C140; C143; C144; C145; C146; C147; C150; C151; C152; C153; C154; C155; C157; C158; C159; C160; C161; C162; C163; C164; C165; C171; C174; C176; C179; C182; C186; C187; C188; C194; C195; C196; C197; C199; C202; C206; C207; C209; C210; C217; C218; C219; C223; C226; C229; C231; C232; C233; C235; C236; C238; C239; C240; C247; C249; C254; C255; C256; C257; C258; C261; C265; C267; C268; C276; C277; C282; C292; C293; C294; C295; C296; C299; C300; C301; C303; C307; C310; C311; C312; C313; C314; C315; C316; C317; C370; C372; C373; C375; C376; C377; C381; C384; C385; C387; C388; C390; C392; C393; C402
402CAP_0402_1UF1uFDISCRETE19C6; C7; C8; C9; C10; C44; C61; C67; C82; C269; C273; C283; C284; C285; C286; C287; C288; C291; C302
402CAP_0402_0.01UF0.01uFDISCRETE28C15; C113; C115; C117; C128; C131; C136; C175; C181; C184; C185; C201; C225; C228; C230; C234; C237; C264; C272; C274; C278; C279; C337; C338; C374; C380; C386; C391
402CAP_0402_7.0PF7.0pFIC3C87; C88; C89
402CAP_0402_DNIDNIIC2C93; C213
402CAP_0402_1000PF1000pFDISCRETE4C106; C109; C110; C111
402CAP_0402_1NF1nFIC1C108
402CAP_0402_47NF47nFDISCRETE3C112; C114; C116
402CAP_0402_12PF12pFIC2C142; C170
402CAP_NP_0402_0.1UF0.1uFIC5C148; C156; C166; C167; C383
402CAP_0402_33NF33nFDISCRETE1C172
402CAP_0402_4.7NF4.7nFDISCRETE10C177; C178; C180; C211; C215; C222; C227; C266; C379; C389
402CAP_0402_100PF100pFDISCRETE4C200; C403; C404; C405
402CAPACITOR_NP_1_0402_0.1UF0.1uFIC2C214; C216
402CAP_0402_33PF33pFIC28C344; C345; C346; C347; C348; C349; C350; C351; C352; C353; C354; C355; C356; C357; C358; C359; C360; C361; C362; C363; C364; C365; C366; C367; C368; C369; C371; C378
402BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1IC9L2; L4; L5; L6; L7; L9; L11; L16; L17
402BEAD_FERRITE_SM_0402_DNIDNIIC4L3; L10; L12; L15
402RESISTOR_0402_00DISCRETE5R1; R7; R74; R146; R160
402RESISTOR_0402_DNIDNIIC11R2; R8; R18; R19; R20; R55; R91; R137; R139; R140; R142
402RESISTOR_0402_10.0K10.0KDISCRETE35R3; R4; R9; R45; R66; R69; R83; R84; R85; R86; R87; R88; R99; R112; R113; R114; R115; R122; R132; R134; R154; R159; R162; R164; R165; R184; R185; R188; R189; R190; R191; R193; R223; R224; R245
402RESISTOR_0402_20.0K20.0KIC3R5; R6; R72
402RESISTOR_0402_4.7K4.7KDISCRETE15R10; R11; R13; R14; R25; R32; R36; R37; R39; R40; R44; R138; R161; R201; R204
402RESISTOR_0402_22K22KIC1R12
402RESISTOR_0402_100, 1%100, 1%DISCRETE6R15; R141; R153; R206; R221; R243
402RESISTOR_0402_2727IC3R16; R17; R89
402RESISTOR_0402_1.00K1.00kDISCRETE24R21; R30; R33; R35; R42; R71; R90; R93; R94; R95; R96; R126; R136; R148; R171; R172; R174; R176; R177; R202; R229; R230; R239; R240
402RESISTOR_0402_1.30K1.30KIC1R22
402RESISTOR_0402_3.57K3.57KIC1R23
402RESISTOR_0402_100K100KDISCRETE8R24; R31; R38; R43; R65; R77; R79; R81
402RESISTOR_7_0402_249249IC1R27
402RESISTOR_7_0402_301301IC1R28
402RESISTOR_0402_1.78K1.78KIC1R29
402RESISTOR_0402_5.23K5.23KIC2R34; R41
402RESISTOR_0402_220220DISCRETE24R46; R47; R48; R49; R50; R51; R52; R53; R54; R56; R57; R58; R59; R60; R61; R62; R63; R64; R167; R170; R175; R179; R212; R213
402RESISTOR_0402_6.81K6.81KIC1R67
402RESISTOR_0402_2.2K2.2KDISCRETE5R68; R100; R111; R120; R133
402RESISTOR_0402_3.24K3.24KIC1R70
402RESISTOR_0402_4.99K4.99KDISCRETE2R73; R200
402RESISTOR_0402_13.3K13.3KDISCRETE1R75
402RESISTOR_0402_30.1K30.1KDISCRETE1R76
402RESISTOR_0402_787K787KDISCRETE3R78; R80; R82
402RESISTOR_0402_56.256.2DISCRETE18R92; R104; R110; R187; R199; R203; R225; R231; R232; R233; R234; R235; R236; R237; R238; R241; R242; R244
402RESISTOR_0402_10K10KDISCRETE15R97; R101; R102; R103; R105; R106; R107; R116; R117; R118; R119; R123; R124; R125; R128
402RES_SMD_0_0402_10.0K10.0KIC3R108; R109; R144
402RESISTOR_0402_470470IC1R121
402RESISTOR_0402_1.5K1.5KIC1R127
402R_0402_56.256.2IC6R129; R130; R145; R147; R150; R151
402RESISTOR_0402_80.6K80.6KIC1R131
402RESISTOR_7_0402_10.0K10.0KIC3R143; R149; R152
402RESISTOR_0402_49.949.9DISCRETE21R155; R156; R157; R158; R168; R169; R180; R181; R182; R183; R192; R194; R195; R197; R198; R205; R207; R208; R209; R210; R211
402R_0402_10.0K10.0KIC2R219; R220
402RESISTOR_0402_71.5K71.5KIC2R226; R227
603CAP_0603_1.0UF1.0uFDISCRETE4C3; C4; C192; C245
603CAP_0603_0.22UF0.22uFIC2C5; C104
603CAP_0603_36PF36pFIC2C141; C169
603CAP_0603_DNIDNIIC2C190; C191
603CAP_0603_1UF1uFDISCRETE3C259; C262; C395
805CAP_0805_10UF10uFDISCRETE40C12; C27; C36; C37; C50; C51; C53; C56; C57; C58; C76; C77; C81; C168; C183; C193; C198; C208; C212; C220; C224; C241; C246; C248; C252; C253; C260; C263; C270; C289; C340; C341; C342; C394; C396; C397; C398; C399; C400; C401
805CAP_0805_4.7UF4.7uFDISCRETE7C18; C91; C92; C101; C127; C173; C271
805CAP_0805_1.0UF1.0uFIC1C204
1206CAP_1206_100UF100uFDISCRETE6C94; C95; C96; C97; C98; C99
1210CAP_1210_10UF10uFDISCRETE14C100; C105; C119; C120; C122; C123; C125; C126; C189; C203; C205; C221; C343; C382
2512RESISTOR_2512_100100IC1R98
3216CAP_SMD_POL_3216_10UF10uFDISCRETE1C13
6032PPCAP_6032P_100UF100ufIC21C14; C19; C22; C23; C24; C25; C35; C40; C43; C45; C64; C65; C68; C72; C73; C74; C75; C83; C84; C85; C86
6032PCAP_SMD_POL_6032P_10UF10uFDISCRETE1C149
7260PCAP_7260_100UF100uFIC1C90
7343PCAP_SMD_POL_7343P_470UF470uFDISCRETE4C78; C102; C103; C107
BB165ACY7C1313V18_0_BB165A_CY7C1263V1CY7C1263V18-375BZXCIC1U15
BCC9688E1111_BCC96_88E111188E1111IC1U25
CAP_PACK_4_1206CAP_ARRAY_0_CAP_PACK_4_1206_0.10.1uf x 4DISCRETE16CN1; CN2; CN3; CN4; CN5; CN6; CN7; CN8; CN9; CN10; CN11; CN12; CN13; CN14; CN15; CN16
CAP_SMD_8MMPCAP_CAP_SMD_8MM_150U150uIC3C118; C121; C124
CONN_39_26_710870247-1051_CONN_39_26_7108_702470247-1051IO1J23
DDR2_60_SPECMT47H32M8BP_DDR2_60_SPEC_MT47H3MT47H32M8BPIC2U17; U20
DFM10-EPADLTC3026_DFM10-EPAD_LTC3026LTC3026IC4U21; U23; U24; U26
DIMM240DDRII_DIMM_DIMM240_DDR2_DIMMDDR2_DIMMIC1J19
DIPSWITCH16SPST8_DIPSWITCH16_DIP_SW_8DIP_SW_8IC2SW2; SW5
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1IC1SW1
DO-214AB_RECTRONDIODE_DO-214AB_RECTRON_FM540FM540IC1D28
EG2201ASW SLIDE-DPDT_EG2201A_EG2201AEG2201AIC1SW4
F54K1B3216B2E_F54_K1B3216B2EK1B3216B2EIC2U4; U10
F64_10X13PC28FXXXP30B85_F64_10X13_PC48F4PC48F4400P0VB00IC1U9
F256EPM2210GF256_F256_(S1+S2),(S3+SEPM2210_F256FBGAIC1U5
F1152S3_F1152_HOST_SWAP_EPSL150F1152EP3SL150F1152IC1U22
FH12X_18S_0P5SHFPC_FFC_18PIN_FH12X_18S_0P5SH_DDNIIC1J24
FH12X_30S_0P5SHFPC_FFC_30PIN_FH12X_30S_0P5SH_FFPC_FFC_30PINIC1J4
HDR2X1_2MM1X2_HDR2X1_2MM_HDR2X1HDR2x1IC1J6
HDR2X1_100MILCON2_HDR2X1_100MIL_CON2CON2IC3J2; J3; J13
HDR2X1_100MILCON2_HDR2X1_100MIL_DNIDNIIC2J7; J11
HDR2X7_100MILHDR2X7_HDR2X7_100MIL_HDR2X7HDR2X7IC1J22
HDR3X1_100MILCON3_0_HDR3X1_100MIL_TSW-103-07TSW-103-07-L-SIC3J10; J12; J20
HDR3X2_100MILCON6A_HDR3X2_100MIL_TSW-103-07-TSW-103-07-L-DIC1J9
HDR4X1_100MIL1X4_HDR4X1_100MIL_HDR4X1HDR4X1IC1J1
IHLP2525INDUCTOR_IHLP2525_10UH10uHIC3L8; L13; L14
IND_0805BEAD_FERRITE_SM_IND_0805_BLM21PBLM21PG331SN1DISCRETE1L1
KEYSTONE_BT1_1060BATTERY_0_KEYSTONE_BT1_1060_BATBatteryIC1BT1
LGA118LTM4601_LGA118_LTM4601LTM4601IC3U32; U33; U34
LQFP-32FT245BL_LQFP-32_FT245BLFT245BLIC1U11
LQFP-48ADG726_0_LQFP-48_ADG725ADG725IC1U19
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDIC25D1; D2; D3; D6; D7; D8; D9; D10; D11; D12; D14; D15; D17; D20; D21; D22; D23; D24; D25; D26; D27; D32; D33; D35; D36
LUMEX_LED1206LED_LUMEX_LED1206_RED_LEDRed_LEDIC2D13; D34
LUMEX_LED1206LED_LUMEX_LED1206_BLUE_LEDBlue_LedIC1D16
MLX_22_23_2021_VRT_HDR_2PCON2_MLX_22_23_2021_MLX_22_23_222_23_2021IC1J15
MSOP8LM4990MM_MSOP8_LM4990LM4990IC1U1
MSOP8LM95235_MSOP8_DNIDNIIC1U16
MSOP10LTC2402_MSOP10_LTC2402LTC2402IC1U18
PSOP-DGQ10TPS51100_PSOP-DGQ10_TPS51100DGQTPS51100DGQIC3U36; U37; U38
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBSwitchIC7S1; S2; S3; S4; S5; S6; S7
QFN56CY7C680_56QFN_QFN56_CY7C68013A-CY7C68013A-56LFXCIC1U12
QUAD_7SEGQUAD_7_SEG_DSPLY_7_QUAD_7SEG_QUQUAD_7SEG_M2212RIIC2U27; U28
RAPC712CONN_JACK_PWR_RAPC712_RAPC712XRAPC712XIC1J21
RES_PACK_8RES_PACK_8_RES_PACK_8_10K10KDISCRETE2RN1; RN2
RES_PACK_8RES_PACK_8_RES_PACK_8_5656DISCRETE15RN3; RN4; RN5; RN6; RN7; RN8; RN9; RN10; RN11; RN12; RN13; RN14; RN15; RN16; RN17
RJ45HFJ11-1G02E_RJ45_HFJ11-1G02EHFJ11-1G02EIO1J14
SAMTEC_QSHDP120CUSTOMQSH_HSM_SAMTEC_QSHDP120CUSTOM_AASP-122953-01IO2J8; J18
SM55-OSCOSC_ALT_SM55-OSC_125MHZ125MHzIC2Y1; Y5
SM55-OSCOSC_ALT_SM55-OSC_24MHZ24MHzIC1Y4
SM55-OSCOSC_ALT_SM55-OSC_50MHZ50MHzIC1Y6
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1IO2J16; J17
SMB403A_03ZENERDIODE_SMB403A_03_20V ZENER20V ZenerDISCRETE3D29; D30; D31
SMCZC2800E/SOT_SMC_B530C-13B530C-13IC1D18
SO8AT93C46-10_SO8_AT93C46DN-SH-BAT93C46DN-SH-BIC1U6
SO824XX128_SO8_QUSB2CP1QUSB2CP1IC1U7
SO8TPS271_SO8_DNIDNIIC1U13
SOD-123DIODE_SOD-123_1N6263-W1N6263-WIC2D4; D5
SOD-123ZC2800E/SOT_SOD-123_MMSD914MMSD914IC1D19
SOD-123ZENERDIODE_SOD-123_40V SCHOTTKY40V SchottkyIC1D37
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NIC2Q1; Q2
SOT23-5AD8531_SOT23-5_DNIDNIIC1U14
SOT23-5LT1761_SOT23-5_LT1761LT1761IC2U29; U31
SOT23-5LT1931_SOT23-5_LT1931LT1931IC1U35
SOT23-DBVSN65220DBV_SOT23-DBV_SN65220DBVSN65220DBVIC1U8
SSOP16NTS3A5018_0_SSOP16N_TS3A5018TS3A5018IC2U2; U3
SW_ROTARY_94HSW_ROTARY_SW_ROTARY_94H_94HCB1694HCB16WTIC1SW3
SW_ROTARY_94HSW_ROTARY_SW_ROTARY_94H_94HAB1694HAB16WTIC1SW6
TP_060SQ040T_POINT_R_TP_060SQ040_54101-G0554101-G05-01LFIC10TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10
TSSOP16-EPADLT1374_TSSOP16-EPAD_LT1374LT1374IC1U30
USB2_0-RAUSB_CON_USB2_0-RA_USB CONUSB CONIO1J5
WSL2010RESISTOR_WSL2010_.0090.009IC15R26; R135; R163; R166; R173; R178; R186; R196; R214; R215; R216; R217; R218; R222; R228
X2Y_0603CAP_X2Y_X2Y_0603_10NF10nFIC12C16; C33; C41; C42; C52; C55; C60; C66; C79; C319; C329; C333
X2Y_0603CAP_X2Y_X2Y_0603_47NF47nFIC16C20; C30; C46; C54; C80; C242; C244; C251; C290; C297; C298; C309; C318; C320; C328; C334
X2Y_0603CAP_X2Y_X2Y_0603_22NF22nFIC15C26; C31; C34; C47; C48; C59; C63; C70; C250; C275; C281; C324; C325; C330; C332
X2Y_0603CAP_X2Y_X2Y_0603_100NF100nFIC4C29; C71; C321; C339
X2Y_0603CAP_X2Y_X2Y_0603_4.7NF4.7nFIC6C32; C38; C39; C322; C323; C331
X2Y_0805CAP_X2Y_X2Y_0805_180NF180nFIC7C243; C280; C305; C308; C326; C335; C336
X2Y_1206CAP_X2Y_X2Y_1206_220NF220nFIC5C17; C21; C62; C304; C306
X2Y_1206CAP_X2Y_X2Y_1206_470NF470nFIC1C327
X2Y_1210CAP_X2Y_X2Y_1210_1UF1uFIC3C28; C49; C69
XTAL_HC49CRYSTAL_XTAL_HC49_24.000 MHZ24.000 MHZDISCRETE1Y2
XTAL_HC49CRYSTAL_XTAL_HC49_6.000 MHZ6.000 MHZDISCRETE1Y3
XTAL_PACK_DXTAL_XTAL_PACK_D_25MHZ25MHzIC1X1
附件:
# b9 L/ e0 @" ?$ h6 _, tPCB文件如下:
% g8 ^2 p! q$ J0 Z. L
游客,如果您要查看本帖隐藏内容请回复
& b) Q  c; f' |2 K& n# _2 [" b% W) W2 t
; w, p4 r: d" [/ |  @' K8 n
发表于 2020-7-9 09:21 | 只看该作者
感谢楼主分享
GMT+8, 2025-7-28 18:57 , Processed in 0.140625 second(s), 27 queries , Gzip On.
