Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
1X2HDR | CON2_3_1X2HDR_HEADER 1X2 | HEADER 1x2 | IC | 1 | J3 |
1X2HDR | CON2_3_1X2HDR_HEADER_1X2 | HEADER_1x2 | IC | 6 | J10; J11; J12; J13; J31; J35 |
2X5HDR_50MIL | HEADER_2X5_2X5HDR_50MIL_HEADER_ | HEADER_2X5_50MIL | IC | 1 | J32 |
4-SMD-DFN | ASEMB-50.000MHZ-LC-T_4-SMD-DFN_ | ASEMB-50.000MHZ-LC-T | IC | 1 | Y2 |
8-SOIC | RUS100N02TB_8-SOIC_IRF3717TRPBF | IRF3717TRPBF | IC | 2 | Q3; Q12 |
14TSSOP | TXS0104EPWR_14TSSOP_TXS0104EPWR | TXS0104EPWR | IC | 1 | U37 |
16-PQFN | IR3895MTRPBF_16-PQFN_IR3895MTRP | IR3895MTRPBF | IC | 2 | U3; U6 |
74CBTLV3257PW | 74CBTLV3257PW_74CBTLV3257PW_74C | 74CBTLV3257PW,118 | IC | 3 | U15; U16; U36 |
74LVC1G157GV-Q100H | 74LVC1G157GV-Q_100H_74LVC1G157G | 74LVC1G157GV-Q100H | IC | 1 | U8 |
402 | CAPACITOR NON-POL_0402_27PF | 27PF | IC | 2 | C47; C49 |
402 | CAPACITOR NON-POL_0402_1UF_10V | 1uF_10V | IC | 4 | C50; C51; C187; C188 |
402 | CAPACITOR NON-POL_0402_0.1UF/16 | 0.1uF/16V | IC | 16 | C52; C58; C76; C80; C82; C124; C126; C191; C195; C198; C210; C245; C283; C312; C314; C503 |
402 | CAPACITOR NON-POL_0402_1UF/16V/ | 1uF/16V/X5R | IC | 3 | C84; C121; C127 |
402 | CAPACITOR NON-POL_0402_1NF/25V | 1nF/25V | IC | 1 | C90 |
402 | CAPACITOR NON-POL_0402_8PF/50V | 8pF/50V | IC | 1 | C118 |
402 | CAPACITOR NON-POL_0402_0.1UF | 0.1uF | IC | 13 | C154; C160; C164; C171; C175; C177; C178; C180; C184; C186; C189; C192; C510 |
402 | CAPACITOR NON-POL_0402_1UF/10V | 1uF/10V | IC | 2 | C162; C317 |
402 | CAPACITOR NON-POL_0402_4.7UF/10 | 4.7uF/10V | IC | 2 | C172; C182 |
402 | CAPACITOR NON-POL_0402_3.3UF | 3.3uF | IC | 1 | C185 |
402 | CAPACITOR NON-POL_0402_1UF_NL | 1uF_NL | IC | 1 | C460 |
402 | CAPACITOR NON-POL_0402_0.1UF/25 | 0.1uF/25V | IC | 1 | C511 |
402 | RESISTOR_0402_20.5K_1% | 20.5K_1% | IC | 1 | R23 |
402 | RESISTOR_0402_4.7K/1% | 4.7K/1% | IC | 14 | R28; R154; R155; R187; R240; R283; R284; R285; R299; R301; R349; R388; R389; R414 |
402 | RESISTOR_0402_0R | 0R | IC | 25 | R29; R38; R39; R41; R44; R55; R64; R72; R78; R125; R138; R144; R183; R201; R203; R206; R209; R230; R242; R280; R287; R291; R297; R402; R416 |
402 | RESISTOR_0402_1K/1% | 1K/1% | IC | 8 | R30; R68; R195; R241; R286; R306; R310; R403 |
402 | RESISTOR_0402_22R | 22R | IC | 1 | R32 |
402 | RESISTOR_0402_10K/1% | 10K/1% | IC | 10 | R34; R47; R52; R71; R180; R243; R270; R272; R274; R275 |
402 | RESISTOR_0402_499R_1% | 499R_1% | IC | 5 | R43; R263; R264; R271; R273 |
402 | RESISTOR_0402_2K/1% | 2K/1% | IC | 1 | R46 |
402 | RESISTOR_0402_4.99K_0.1% | 4.99K_0.1% | IC | 10 | R48; R49; R81; R82; R163; R167; R170; R176; R255; R256 |
402 | R_0_0402_39_1% | 39_1% | IC | 10 | R56; R57; R61; R83; R90; R93; R99; R254; R317; R327 |
402 | RESISTOR_0402_1K/1%_DNL | 1K/1%_DNL | IC | 11 | R60; R73; R135; R158; R161; R174; R207; R372; R374; R375; R404 |
402 | RESISTOR_0402_2.49K | 2.49K | IC | 1 | R66 |
402 | RESISTOR_0402_10K_1%_DNL | 10k_1%_DNL | IC | 17 | R79; R85; R86; R97; R98; R266; R267; R268; R312; R315; R316; R318; R319; R320; R321; R323; R326 |
402 | RESISTOR_0402_10K_1% | 10k_1% | IC | 28 | R80; R84; R87; R88; R89; R91; R92; R94; R95; R96; R258; R259; R260; R265; R269; R282; R296; R313; R314; R322; R324; R325; R339; R340; R341; R344; R373; R376 |
402 | RESISTOR_0402_22R_1% | 22R_1% | IC | 6 | R126; R127; R128; R129; R130; R131 |
402 | RESISTOR_0402_16.2K_1% | 16.2K_1% | IC | 1 | R133 |
402 | RESISTOR_0402_100K | 100K | IC | 4 | R152; R237; R288; R337 |
402 | RESISTOR_0402_10K_0.1% | 10K_0.1% | IC | 2 | R156; R159 |
402 | RESISTOR_0402_9.09K | 9.09K | IC | 1 | R181 |
402 | RESISTOR_0402_0R/DNL | 0R/DNL | IC | 8 | R184; R196; R198; R200; R202; R247; R415; R417 |
402 | RESISTOR_0402_75K_1% | 75K_1% | IC | 1 | R189 |
402 | RESISTOR_0402_113K_1% | 113K_1% | IC | 1 | R190 |
402 | RESISTOR_0402_300K_1% | 300K_1% | IC | 1 | R192 |
402 | RESISTOR_0402_604K_1% | 604K_1% | IC | 1 | R193 |
402 | RESISTOR_0402_4.7K/1%_NL | 4.7K/1%_NL | IC | 2 | R197; R199 |
402 | RESISTOR_0402_9.76K_1%_NL | 9.76K_1%_NL | IC | 1 | R211 |
402 | RESISTOR_0402_33K/1% | 33K/1% | IC | 2 | R212; R233 |
402 | RESISTOR_0402_22K_1% | 22K_1% | IC | 2 | R213; R232 |
402 | RESISTOR_0402_1.5K/0.1% | 1.5K/0.1% | IC | 1 | R222 |
402 | RESISTOR_0402_DNL | DNL | IC | 1 | R244 |
402 | RESISTOR_0402_12K_1% | 12K_1% | IC | 1 | R248 |
402 | RESISTOR_0402_2K_1% | 2K_1% | IC | 1 | R249 |
402 | R_0402_1.5K | 1.5K | IC | 1 | R250 |
402 | RESISTOR_0402_499_1% | 499_1% | IC | 1 | R253 |
402 | RESISTOR_0402_100K_DNL | 100K_DNL | IC | 1 | R257 |
402 | RESISTOR_0402_1K/1%_NL | 1K/1%_NL | IC | 1 | R350 |
402 | RESISTOR_0402_39_1% | 39_1% | IC | 2 | R367; R369 |
402 | RESISTOR_0402_330R | 330R | IC | 8 | R406; R407; R408; R409; R410; R411; R412; R413 |
0402_HS | CAPACITOR NON-POL_0402_HS_0.1UF | 0.1uF/16V | DISCRETE | 14 | C100; C102; C103; C104; C105; C106; C107; C108; C109; C110; C111; C112; C119; C122 |
0402_HS | RESISTOR_0402_HS_0R | 0R | IC | 2 | R394; R395 |
0402_HS1 | RESISTOR_0402_HS1_0R | 0R | IC | 4 | R391; R392; R397; R398 |
603 | CAPACITOR NON-POL_0603_0.1UF_50 | 0.1uF_50V | IC | 6 | C48; C56; C101; C170; C286; C508 |
603 | CAPACITOR NON-POL_0603_1UF_16V | 1uF_16V | IC | 6 | C62; C63; C113; C117; C120; C125 |
603 | CAPACITOR NON-POL_0603_33PF/16V | 33pF/16V | IC | 2 | C77; C512 |
603 | CAPACITOR NON-POL_0603_10UF/6.3 | 10uF/6.3V | IC | 5 | C83; C85; C89; C450; C471 |
603 | CAPACITOR NON-POL_0603_10UF/25V | 10uF/25V | IC | 3 | C208; C502; C504 |
603 | CAPACITOR NON-POL_0603_10UF_10V | 10uF_10V | IC | 4 | C219; C297; C311; C509 |
603 | CAPACITOR NON-POL_0603_0.1UF | 0.1uF | IC | 1 | C440 |
603 | RESISTOR_0603_0R | 0R | IC | 18 | R4; R31; R42; R141; R149; R165; R175; R178; R186; R208; R220; R224; R245; R246; R292; R305; R393; R399 |
603 | RESISTOR_0603_133K_0.1% | 133K_0.1% | IC | 1 | R24 |
603 | RESISTOR_0603_8.45K/0.1% | 8.45K/0.1% | IC | 2 | R25; R221 |
603 | RESISTOR_0603_100_0.1% | 100_0.1% | IC | 10 | R53; R54; R101; R102; R162; R166; R172; R177; R261; R262 |
603 | RESISTOR_0603_2.61K_DNL | 2.61K_DNL | IC | 8 | R137; R160; R210; R279; R379; R385; R396; R405 |
603 | R_0603_330R | 330R | IC | 1 | R251 |
603 | R_0603_300R | 300R | IC | 1 | R252 |
603 | RESISTOR_0603_DNL | DNL | IC | 2 | R295; R298 |
603 | RESISTOR_0603_0R_DNL | 0R_DNL | IC | 3 | R309; R335; R1531 |
805 | CAPACITOR NON-POL_0805_10UF/16V | 10uF/16V/X7R | IC | 1 | C57 |
805 | CAPACITOR NON-POL_0805_DNL | DNL | IC | 3 | C74; C130; C505 |
805 | CAPACITOR NON-POL_0805_22UF/16V | 22uF/16V/X5R | IC | 6 | C87; C116; C128; C461; C507; C513 |
805 | CAPACITOR NON-POL_0805_4.7UF/10 | 4.7UF/10V | IC | 1 | C92 |
805 | CAPACITOR NON-POL_0805_22UF/10V | 22uF/10V/X5R | IC | 4 | C114; C115; C129; C514 |
805 | CAPACITOR NON-POL_0805_22UF/6.3 | 22uF/6.3V/X5R | IC | 1 | C332 |
805 | CAPACITOR NON-POL_0805_4.7U/25V | 4.7u/25V/X5R | IC | 1 | C357 |
805 | FERRITE_BEAD_0_0805_HZ0805E601R | HZ0805E601R-10 | IC | 2 | L11; L13 |
805 | RESISTOR_0805_0R_0805 | 0R_0805 | IC | 2 | R122; R331 |
805 | RESISTOR_0805_4.7R_1% | 4.7R_1% | IC | 2 | R215; R218 |
1206 | CAPACITOR NON-POL_1206_10UF/50V | 10uF/50V | IC | 1 | C147 |
1206 | CAPACITOR NON-POL_1206_22UF/35V | 22uF/35V | IC | 2 | C173; C174 |
1206 | CAPACITOR NON-POL_1206_10UF/25V | 10uF/25V | IC | 3 | C176; C194; C207 |
1206 | CAPACITOR NON-POL_1206_100UF/10 | 100uF/10V | IC | 2 | C214; C496 |
1210 | CAPACITOR NON-POL_1210_100UF/16 | 100uF/16V_NL | IC | 2 | C149; C167 |
ASP-134603-01-LPC | FMC_LPC_CONNECTOR_ASP-134603-01 | ASP-134603-01 | IC | 1 | J17 |
ASPI-7318-R47M-T | INDUCTOR_ASPI-7318-R47M-T_470NH | 470nH | IC | 3 | L7; L8; L9 |
BGA0402 | CAPACITOR NON-POL_BGA0402_0.01U | 0.01uF/16V | IC | 11 | C190; C324; C329; C362; C363; C372; C400; C415; C468; C480; C487 |
BGA0402 | CAPACITOR NON-POL_BGA0402_0.1UF | 0.1uF-0402 | IC | 43 | C196; C197; C199; C205; C209; C212; C213; C215; C216; C218; C221; C222; C223; C224; C225; C229; C230; C231; C235; C236; C237; C238; C239; C241; C242; C253; C254; C255; C257; C259; C260; C263; C264; C267; C268; C271; C272; C275; C276; C277; C281; C282; C284 |
BGA0402 | CAP NP_BGA0402_0.1UF-0402 | 0.1uF-0402 | IC | 4 | C200; C211; C250; C252 |
BGA0402 | CAPACITOR NON-POL_BGA0402_0.0_1 | 0.01uF-0402 | IC | 2 | C206; C234 |
BGA0402 | CAPACITOR NON-POL_BGA0402_1UF_1 | 1uF_10V | IC | 1 | C220 |
BGA0402 | CAPACITOR NON-POL_BGA0402_0.1_1 | 0.1uF/16V | IC | 26 | C226; C227; C232; C233; C240; C251; C256; C261; C262; C266; C269; C270; C273; C278; C319; C330; C331; C333; C344; C371; C451; C462; C463; C497; C498; C501 |
BGA0402 | CAPACITOR NON-POL_BGA0402_0.1_2 | 0.1uF_16V | IC | 64 | C339; C340; C348; C350; C352; C353; C355; C356; C360; C361; C364; C376; C377; C378; C383; C384; C385; C391; C392; C393; C402; C403; C404; C405; C406; C412; C416; C417; C418; C419; C420; C421; C422; C423; C424; C427; C429; C430; C432; C433; C434; C435; C436; C438; C439; C443; C444; C445; C446; C447; C452; C453; C454; C455; C456; C458; C459; C464; C465; C469; C489; C490; C492; C494 |
BGA0402 | CAPACITOR NON-POL_BGA0402_1UF/1 | 1uF/16V_NL | IC | 1 | C370 |
BGA0402 | CAPACITOR NON-POL_BGA0402_10NF_ | 10nF_16V | IC | 1 | C470 |
BGA0402 | CAPACITOR NON-POL_BGA0402_4.7NF | 4.7nF_16V | IC | 3 | C488; C491; C495 |
BGA0402 | RESISTOR_BGA0402_10K_1% | 10K_1% | IC | 3 | R289; R290; R346 |
BGA0402 | RESISTOR_BGA0402_22R_1% | 22R_1% | IC | 1 | R342 |
BGA0402 | RESISTOR_BGA0402_22R | 22R | IC | 1 | R343 |
BGA0402 | RESISTOR_BGA0402_1K/1% | 1K/1% | IC | 1 | R345 |
BGA0402 | RESISTOR_BGA0402_0R | 0R | IC | 4 | R347; R365; R386; R387 |
BGA0402 | RESISTOR_BGA0402_4.7K/1% | 4.7K/1% | IC | 1 | R354 |
BREAD_BOARD | BREAD BOARD_BREAD_BOARD_BREAD B | BREAD BOARD | IC | 1 | J33 |
C0402 | CAPACITOR NON-POL_C0402_10NF/16 | 10nF/16V | IC | 1 | C1 |
C0402 | CAPACITOR NON-POL_C0402_1.0UF | 1.0uF | IC | 2 | C5; C45 |
C0402 | CAPACITOR NON-POL_C0402_NL | NL | IC | 18 | C7; C19; C22; C23; C28; C31; C42; C142; C144; C145; C148; C151; C152; C158; C159; C161; C166; C168 |
C0402 | CAPACITOR NON-POL_C0402_22NF | 22nF | IC | 1 | C14 |
C0402 | CAPACITOR NON-POL_C0402_0.1UF | 0.1uF | IC | 2 | C15; C36 |
C0402 | CAPACITOR NON-POL_C0402_390PF | 390pF | IC | 1 | C16 |
C0402 | CAPACITOR NON-POL_C0402_2.2NF | 2.2nF | IC | 2 | C25; C26 |
C0402 | CAPACITOR NON-POL_C0402_680PF | 680pF | IC | 1 | C33 |
C0402 | CAPACITOR NON-POL_C0402_33NF | 33nF | IC | 1 | C35 |
C0402 | CAPACITOR NON-POL_C0402_0.1UF/1 | 0.1uF/16V | IC | 49 | C79; C81; C86; C88; C91; C93; C95; C96; C98; C318; C320; C321; C322; C323; C325; C328; C341; C343; C351; C358; C365; C366; C379; C381; C382; C387; C388; C389; C390; C394; C395; C396; C397; C398; C401; C425; C431; C441; C442; C449; C457; C466; C472; C478; C481; C482; C484; C485; C486 |
C0402 | CAPACITOR NON-POL_C0402_0.01UF/ | 0.01uF/16V | IC | 36 | C94; C326; C327; C334; C335; C336; C337; C338; C342; C345; C349; C359; C367; C368; C369; C373; C374; C375; C380; C399; C407; C408; C409; C410; C411; C413; C426; C437; C467; C473; C474; C475; C476; C477; C479; C493 |
C0402 | CAP_0402_C0402_0.01UF/16V/X5R | 0.01uF/16V/X5R | IC | 1 | C217 |
C0402 | CAPACITOR NON-POL_C0402_0.1UF/2 | 0.1uF/25V_NL | IC | 1 | C515 |
C0603 | CAPACITOR NON-POL_C0603_2.2UF | 2.2uF | IC | 2 | C8; C44 |
C0603 | CAPACITOR NON-POL_C0603_0.1UF | 0.1uF | IC | 4 | C24; C27; C139; C157 |
C0603 | CAPACITOR NON-POL_C0603_100PF | 100pF | IC | 2 | C30; C140 |
C0603 | CAP_0603_C0603_18PF_50V | 18pF_50V | IC | 2 | C53; C54 |
C0603 | CAPACITOR NON-POL_C0603_10UF/16 | 10uF/16V | IC | 6 | C73; C78; C99; C346; C428; C500 |
C0603 | CAP_0_C0603_0.1UF | 0.1uF | IC | 4 | C258; C274; C285; C296 |
C0805 | CAPACITOR NON-POL_C0805_47UF | 47uF | IC | 12 | C3; C4; C12; C13; C20; C21; C29; C34; C40; C41; C143; C153 |
C0805 | CAPACITOR NON-POL_C0805_22UF | 22uF | IC | 1 | C55 |
C0805 | CAPACITOR NON-POL_C0805_22UF/6. | 22uF/6.3V/X5R | IC | 2 | C75; C386 |
C0805 | CAPACITOR NON-POL_C0805_22UF/16 | 22uF/16V/X5R | IC | 1 | C137 |
C1206 | CAPACITOR NON-POL_C1206_10UF | 10uF | IC | 10 | C2; C6; C10; C11; C17; C32; C37; C46; C155; C156 |
C1206 | CAPACITOR NON-POL_C1206_47UF_10 | 47uF_10V | IC | 10 | C71; C72; C97; C123; C315; C347; C354; C483; C499; C506 |
C1206 | CAPACITOR NON-POL_C1206_10UF/25 | 10uF/25V/X5R | IC | 1 | C134 |
C1812 | CAP_1812_C1812_1000PF, 3KV | 1000pF, 3KV | IC | 2 | C248; C316 |
CASE-A | CAP POL_CASE-A_10UF/16V | 10uF/16V | IC | 6 | C228; C249; C265; C279; C288; C298 |
CC0402 | CAP NP_CC0402_1UF/16V | 1uF/16V | IC | 4 | C38; C59; C60; C247 |
CC0402 | CAP NP_CC0402_0.1UF/16V | 0.1uF/16V | IC | 8 | C39; C201; C202; C203; C204; C243; C244; C246 |
CC0603 | CAPACITOR NON-POL_CC0603_22UF/1 | 22uF/10V | IC | 2 | C9; C163 |
CC0603 | CAPACITOR NON-POL_CC0603_4.7UF/ | 4.7uF/16V | IC | 2 | C18; C150 |
CCLD-033-50-125_000 | OSC_PECL_1_CCLD-033-50-125_000_ | 125_MHz | IC | 1 | Y3 |
CLF7045NIT-4R7N-D | INDUCTOR_CLF7045NIT-4R7N-D_4.7U | 4.7uH | IC | 1 | L1 |
CRYSTAL_ABM3 | CRYSTAL_CRYSTAL_ABM3_ABM3-20.00 | ABM3-20.000MHZ-B2-T | IC | 1 | Y1 |
CSRN2512FK10L0 | RESISTOR_CSRN2512FK10L0_0.01R_2 | 0.01R_2W_1% | IC | 2 | R63; R136 |
CSRN2512FK50L0 | RESISTOR_CSRN2512FK50L0_0.05R_1 | 0.05R_1%.2W | IC | 1 | R164 |
CSRN2512FK50L0 | RESISTOR_CSRN2512FK50L0_0.05R_2 | 0.05R_2W_1% | IC | 1 | R278 |
CSRN2512FK75L0 | RESISTOR_CSRN2512FK75L0_0.075R | 0.075R | IC | 2 | R121; R173 |
DIP_SW_4 | SW DIP-4_DIP_SW_4_DIP_SW_4 | DIP_SW_4 | IC | 1 | SW8 |
DO1813H-222MLB | INDUCTOR_DO1813H-222MLB_2.2UH | 2.2uH | IC | 1 | L6 |
EEE-FT1V331AP | CAPACITOR POL_EEE-FT1V331AP_330 | 330uF/35V | IC | 3 | C43; C136; C146 |
EEV-FK1E331P | CAPACITOR POL_EEV-FK1E331P_NL | NL | IC | 4 | C132; C133; C165; C179 |
EVQ-PAD04M | PB_SWITCH_0_EVQ-PAD04M_EVQ-PAD0 | EVQ-PAD04M | IC | 1 | SW2 |
FBGA96 | IS43QR16256A-96BALL_FBGA96_MT40 | MT40A256M16GE-083E:B | IC | 2 | U18; U22 |
FCG484 | MPF300T-FCG484_FCG484_MPF300TS- | MPF300TS-1FCG484EES | IC | 1 | U20 |
FGG256 | F2-200_3_FGG256_A2F200M3F-1FGG2 | A2F200M3F-1FGG256I | IC | 1 | U13 |
FP4_HDR_5X2 | CONN FB 8-H_0_FP4_HDR_5X2_FP4 | FP4 | IC | 1 | J15 |
GF-126-0159 | SW DPDT/SM_0_GF-126-0159_GF-126 | GF-126-0159 | IC | 1 | SW1 |
GRPB031VWVN-RC | JUMPER_1_GRPB031VWVN-RC_GRPB031 | GRPB031VWVN-RC | IC | 5 | J5; J6; J7; J8; J9 |
HDR_1X1 | HEADER 1_HDR_1X1_HDR1X1 | HDR1X1 | IC | 6 | J24; J25; J26; J27; J28; J30 |
HDR_1X2 | HEADER 2_HDR_1X2_HDR_1X2 | HDR_1X2 | IC | 1 | J36 |
IHLP1616BZER2R2M01 | INDUCTOR_IHLP1616BZER2R2M01_IHL | IHLP1616BZER2R2M01 | IC | 2 | L10; L12 |
JUM_3X1 | JUMPER_1_JUM_3X1_3 PIN JUMPER | 3 PIN JUMPER | IC | 2 | J4; J20 |
KSC403J | PB_SWITCH_0_KSC403J_KSC403J 50S | KSC403J 50SH LFG | IC | 4 | SW3; SW4; SW5; SW6 |
L1206 | COIL_1206_L1206_BLM31PG121SN1L | BLM31PG121SN1L | IC | 4 | L4; L5; L14; L17 |
L-0805 | LED_1_L-0805_LTST-C171TBKT | LTST-C171TBKT | IC | 1 | DS4 |
L-0805 | LED_1_L-0805_LTST-C171KGKT | LTST-C171KGKT | IC | 1 | DS5 |
LB2012T6R8M | INDUCTOR_LB2012T6R8M_6.8UH-0805 | 6.8uH-0805 | IC | 1 | L16 |
LX7104ISF | LX7104_LX7104ISF_LX7104ISF | LX7104ISF | IC | 1 | U1 |
LX7186AILU-TR | LX7186AILU-TR_LX7186AILU-TR_LX7 | LX7186AILU-TR | IC | 3 | U19; U30; U31 |
MCP6071T-E_OT | OP-15_MCP6071T-E_OT_MCP6071T-E/ | MCP6071T-E/OT | IC | 5 | U9; U25; U26; U34; U38 |
MT25QL01GBBB8ESF-0SIT | MT25QU01GBBB8E12-0SIT_MT25QL01G | MT25QL01GBBB8ESF-0SIT | IC | 1 | U33 |
PA4341-122NLT | INDUCTOR_PA4341-122NLT_1.2UH | 1.2UH | IC | 1 | L2 |
PCIEXP_4X_EDGE_FINGER | PCIEXP_4X_EDGE_PCIEXP_4X_EDGE_F | PCIEXP_4X_EDGE_FINGER | IC | 1 | CON1 |
PGB1010603MR | ZENER DIODES_PGB1010603MR_PGB10 | PGB1010603MR | IC | 2 | CR1; CR2 |
PJ-102BH | CONN_JACK_PWR_3_PJ-102BH_PJ-102 | PJ-102BH | IC | 1 | J2 |
PTH08T220WAZT | PTH04T240W_PTH08T220WAZT_PTH08T | PTH08T220WAZT | IC | 1 | U4 |
QFN10_0O5MM_3X3MM_TEXAS | IC_TPS51200_0_QFN10_0O5MM_3X3MM | TPS51200 | IC | 1 | U23 |
QFN68_8X8 | VSC8541XMV_QFN68_8X8_VSC8541XMV | VSC8541XMV | IC | 1 | U14 |
QFP64_0O5MM_12X12_FTDI | USB_0_QFP64_0O5MM_12X12_FTDI_FT | FT4232H | IC | 1 | U7 |
R0402 | RESISTOR_R0402_6.65K_1% | 6.65K_1% | IC | 4 | R1; R14; R21; R40 |
R0402 | RESISTOR_R0402_1.18K_1% | 1.18K_1% | IC | 2 | R2; R22 |
R0402 | RESISTOR_R0402_39.2K | 39.2K | IC | 2 | R6; R27 |
R0402 | RESISTOR_R0402_49.9K | 49.9K | IC | 1 | R7 |
R0402 | RESISTOR_R0402_9.53K | 9.53K | IC | 1 | R8 |
R0402 | RESISTOR_R0402_1.37K | 1.37K | IC | 1 | R10 |
R0402 | RESISTOR_R0402_NL | NL | IC | 2 | R11; R236 |
R0402 | RESISTOR_R0402_732R_1% | 732R_1% | IC | 2 | R12; R37 |
R0402 | RESISTOR_R0402_0R | 0R | IC | 2 | R13; R20 |
R0402 | RESISTOR_R0402_4.7K_1% | 4.7K_1% | IC | 15 | R15; R74; R76; R134; R142; R148; R150; R171; R179; R188; R281; R356; R380; R390; R401 |
R0402 | RESISTOR_R0402_215R | 215R | IC | 2 | R16; R19 |
R0402 | RESISTOR_R0402_20R | 20R | IC | 2 | R17; R18 |
R0402 | RESISTOR_R0402_845R | 845R | IC | 1 | R26 |
R0402 | RES_0402_R0402_10K | 10K | IC | 3 | R58; R59; R70 |
R0402 | RES_0402_R0402_1M | 1M | IC | 1 | R62 |
R0402 | RES_0402_R0402_2K_1% | 2K_1% | IC | 1 | R67 |
R0402 | RESISTOR_R0402_39_1% | 39_1% | IC | 25 | R143; R145; R147; R151; R153; R351; R352; R353; R355; R357; R358; R359; R360; R361; R362; R363; R364; R366; R368; R370; R371; R378; R382; R383; R384 |
R0402 | RESISTOR_R0402_10K | 10K | IC | 2 | R146; R182 |
R0402 | RESISTOR_R0402_200K_1% | 200K_1% | IC | 4 | R168; R169; R185; R191 |
R0402 | R_R0402_1.5K | 1.5K | IC | 1 | R204 |
R0402 | RESISTOR_R0402_1K/1%_NL | 1K/1%_NL | IC | 2 | R234; R235 |
R0402 | RESISTOR_R0402_2.61K_NL | 2.61K_NL | IC | 2 | R238; R239 |
R0402 | RESISTOR_R0402_240R/1% | 240R/1% | IC | 2 | R348; R381 |
R0402 | RES_0402_R0402_2K | 2K | IC | 1 | R377 |
R0603 | RESISTOR_R0603_49.9K | 49.9K | IC | 4 | R3; R36; R225; R228 |
R0603 | RESISTOR_R0603_0R_NL | 0R_NL | IC | 2 | R5; R33 |
R0603 | RES_0603_R0603_510 | 510 | IC | 2 | R50; R51 |
R0603 | RESISTOR_R0603_7.5K | 7.5K | IC | 2 | R219; R227 |
R0603 | RESISTOR_R0603_1.5K/0.1% | 1.5K/0.1% | IC | 1 | R229 |
R0603 | RES_0603_R0603_75 | 75 | IC | 4 | R293; R300; R308; R330 |
R0805 | RESISTOR_R0805_0R | 0R | IC | 2 | R35; R45 |
RC0402 | RESISTOR_RC0402_100K_1% | 100K_1% | IC | 4 | R9; R140; R217; R223 |
RC0402 | RESISTOR_RC0402_24.3K_1% | 24.3K_1% | IC | 3 | R132; R216; R226 |
RC0402 | RESISTOR_RC0402_300K_1% | 300K_1% | IC | 1 | R139 |
RC0402 | RESISTOR_RC0402_110K_1% | 110K_1% | IC | 1 | R214 |
RC0402 | RESISTOR_RC0402_36.5K_1% | 36.5K_1% | IC | 1 | R231 |
RC1210 | RESISTOR_RC1210_0.001R/1W/DNL | 0.001R/1W/DNL | IC | 1 | R194 |
RJHSE-5384 | RJHS-5384-04_RJHSE-5384_RJHSE-5 | RJHSE-5384 | IC | 1 | J14 |
S-PAK-7 | MIC69502WR_S-PAK-7_MIC69502WR | MIC69502WR | IC | 2 | U10; U24 |
SD2114S040S8R0 | MBR0530T1G_SD2114S040S8R0_SD211 | SD2114S040S8R0 | IC | 3 | D2; D6; D7 |
SMD_40 | T POINT A_SMD_40_TP_SMD | TP_SMD | IC | 15 | ABPS0_VDD_REG; ABPS2_VDDA25; ABPS3_VDD1; ABPS6_VDD_REG; ABPS7_VDDA; ADC5; D14; D15; GNDTM0; GNDTM1; LPXIN; LPXOUT; P7_F2; SCL; SDA |
SMD_40 | TEST POINT_SMD_40_TP_SMD | TP_SMD | IC | 1 | VDD_EN |
SMD_0603 | LED_GRN | SM_LED_GRN | DISCRETE | 3 | DS2; DS3; DS6 |
SMD_0603 | LED_GRN_0_SMD_0603_DISCRETE_SM_ | SM_LED_YLW | DISCRETE | 2 | LED3; LED4 |
SMD_0603 | LED_GRN_0_SMD_0603_DISCRETE_S_1 | SM_LED_ORANGE | DISCRETE | 2 | LED5; LED6 |
SMD_0603 | LED_GRN_0_SMD_0603_DISCRETE_S_2 | SM_LED_RED | DISCRETE | 2 | LED7; LED8 |
SMD_TP | TEST POINT_SMD_TP_SMD_TP | SMD_TP | IC | 2 | VDDQ1; VDDQ2 |
SML-310MTT86 | LED_GRN_0_SML-310MTT86_DISCRETE | SM_LED_GRN | DISCRETE | 2 | LED1; LED2 |
SMT_XTAL_5MMX3P2MM | XTAL-25M_0_SMT_XTAL_5MMX3P2MM_2 | 25MHz | IC | 1 | X2 |
SM_CT_3216_TANT_A | CAP_POL_SM_CT_3216_TANT_A_10UF | 10uF 16V-TantA | IC | 1 | C69 |
SM_C_0402 | CAP NP_SM_C_0402_2.2UF 10V-0402 | 2.2uF 10V-0402 | IC | 2 | C64; C65 |
SM_C_0402 | CAPACITOR NON-POL_SM_C_0402_18P | 18pF-0402 | IC | 2 | C66; C67 |
SM_C_0402 | CAPACITOR NON-POL_SM_C_0402_0.1 | 0.1uF-0402 | IC | 3 | C70; C131; C138 |
SM_C_0402 | CAP NP_SM_C_0402_2200PF/25V-040 | 2200PF/25V-0402 | IC | 19 | C287; C290; C291; C292; C293; C294; C295; C299; C300; C301; C302; C303; C304; C305; C306; C307; C308; C309; C310 |
SM_C_0603 | CAPACITOR NON-POL_SM_C_0603_10U | 10uF-0603 | IC | 1 | C169 |
SM_C_0805 | CAP NP_0_SM_C_0805_10UF 10V-080 | 10uF 10V-0805 | IC | 4 | C61; C68; C289; C313 |
SM_C_0805 | CAPACITOR NON-POL_SM_C_0805_22U | 22uF-0805 | IC | 1 | C280 |
SM_LED_0603 | LED_SM_LED_0603_SMD GREEN LED-0 | SMD Green LED-0603 | IC | 3 | D3; D4; DS1 |
SM_LED_0603 | LED_SM_LED_0603_LED_ORANGE-0603 | LED_ORANGE-0603 | IC | 1 | D5 |
SM_L_0603 | INDUCTOR_SM_L_0603_33NH-0603 | 33nH-0603 | IC | 1 | L15 |
SM_R_0402 | R_0_SM_R_0402_510R_NL | 510R_NL | IC | 1 | R65 |
SM_R_0402 | R_0_SM_R_0402_1K,1%-0402 | 1K,1%-0402 | IC | 11 | R69; R100; R105; R106; R109; R112; R113; R116; R117; R277; R294 |
SM_R_0402 | R_0_SM_R_0402_39R-0402 | 39R-0402 | IC | 3 | R75; R77; R338 |
SM_R_0402 | R_0_SM_R_0402_1.82K/0.1% | 1.82K/0.1% | IC | 1 | R103 |
SM_R_0402 | R_0_SM_R_0402_100R,1%-0402 | 100R,1%-0402 | IC | 16 | R104; R107; R108; R110; R111; R114; R115; R118; R119; R302; R303; R304; R307; R311; R328; R329 |
SM_R_0402 | R_0_SM_R_0402_4.7K/0.1% | 4.7K/0.1% | IC | 1 | R120 |
SM_R_0402 | R_0_SM_R_0402_1.2K/0.1% | 1.2K/0.1% | IC | 1 | R123 |
SM_R_0402 | R_0_SM_R_0402_2.7K/0.1% | 2.7K/0.1% | IC | 1 | R124 |
SM_R_0402 | R_0_SM_R_0402_4.75K/0.1% | 4.75K/0.1% | IC | 1 | R333 |
SM_R_0402 | R_0_SM_R_0402_1K/0.1% | 1K/0.1% | IC | 1 | R334 |
SM_R_0603 | RESISTOR_SM_R_0603_1K/1% | 1K/1% | IC | 1 | R205 |
SM_R_0603 | R_SM_R_0603_1.5K-0603 | 1.5K-0603 | IC | 1 | R276 |
SM_R_1206 | INDUCTOR_SM_R_1206_BLM31PG500SN | BLM31PG500SN1L-1206 | IC | 2 | FB1; FB2 |
SM_R_2512 | R_SM_R_2512_0R-2512 | 0R-2512 | IC | 4 | R157; R332; R336; R400 |
SOIC-8 | IRF9317TRPBF_SOIC-8_IRF9317TRPB | IRF9317TRPBF | IC | 2 | U2; U5 |
SOT23-6 | 93LC56_SN_2_SOT23-6_93LC56BT-I/ | 93LC56BT-I/OT | IC | 1 | U11 |
SOT-23 | TRANSISTOR_NPN_SOT-23_BC817-25- | BC817-25-7-F | IC | 1 | Q2 |
SOT-23 | 2N7002_0_SOT-23_2N7002 | 2N7002 | IC | 1 | Q14 |
SOT-23 | MCP121T-240E_SOT-23_MCP121T-240 | MCP121T-240E/TT | IC | 1 | U29 |
SOT-23 | DS1818_SOT-23_DS1818R-5+T&R_NL | DS1818R-5+T&R_NL | IC | 2 | U32; U35 |
SOT-23-3 | BSS138LT1G_SOT-23-3_BSS138 | BSS138 | IC | 14 | Q1; Q4; Q5; Q6; Q7; Q8; Q9; Q10; Q11; Q13; Q15; Q16; Q17; Q18 |
SOT_23 | DS1818_SOT_23_DS1818_NL | DS1818_NL | IC | 1 | U39 |
SRP6540-1R5M | INDUCTOR_SRP6540-1R5M_1.5UH | 1.5UH | IC | 1 | L3 |
SS24 | MBR0530T1G_SS24_SS24 | SS24 | IC | 1 | D1 |
ST7343 | CAPACITOR POL_ST7343_330UF/10V | 330uF/10V | IC | 3 | C141; C183; C193 |
SW_B3U-1000P | SW TACT-SPST_0_SW_B3U-1000P_B3U | B3U-1000P | IC | 1 | SW9 |
TG111-MSC13LF | H5008NL_TG111-MSC13LF_TG111-MSC | TG111-MSC13LF | IC | 1 | U17 |
TH_VIA | HDR_VIA_TH_VIA_TH_VIA | TH_VIA | IC | 4 | J405; J406; J407; J408 |
TP_5011 | T POINT A_TP_5011_TP_BLACK | TP_BLACK | IC | 6 | GND1; GND2; GND3; GND4; GND5; GND6 |
TSSOP20 | TXB0106_0_TSSOP20_TXS0108EPWR | TXS0108EPWR | IC | 1 | U12 |
TSW-105-08-G-D | CONN FB 8-H_0_TSW-105-08-G-D_FA | FABRIC_JTAG_HEADER | IC | 1 | J16 |
TSW-105-08-G-S | HEADER 5_TSW-105-08-G-S_HEADER | HEADER 5_DNL | IC | 1 | J23 |
USB_MINI_RECEP | USB_MINI_RECEP_USB_MINI_RECEP_U | USB_MINI_RECEP | IC | 1 | J1 |
UWT0J471MNL1GS | CAPACITOR POL_UWT0J471MNL1GS_47 | 470uF/6.3V | IC | 2 | C135; C181 |
WLCSP20_LX7165 | LX7165_WLCSP20_LX7165_LX7165-01 | LX7165-01CSP | IC | 3 | U21; U27; U28 |
XTAL_2P_SMT_KYOCERA | 12MHZ CRYSTAL_0_XTAL_2P_SMT_KYO | 12MHZ | IC | 1 | X1 |
附件:
