作品名:[AD 10][2层]蓝牙音箱(CS8573+ETA9638)PCB源文件共享
+ A. }, i# l" P& L# L' j
3 D: y+ N; j+ |9 m2 g. g0 _文件描述
0 E3 h ^% s! ?$ i1 L$ J& `4 D1. 作品用途:蓝牙音箱 r' d7 c2 \$ u
2. 软件版本:AD 105 ^! i! t" M, X
3. 层数:2层板
: p1 `# d) s: A) ^4 h0 C4. 用到的主要芯片:CS8573+ETA96382 q& Y, T4 `) X! m. \6 ]
5. PCB尺寸:53.2mm*62.5mm
# i3 m w" G2 @7 m/ |3 ]8 }6 E% f
; v$ N' ]( Z! o: ~- W8 e作品截图如下:
8 [. v( o+ m" M8 O- K顶层截图:
- e" z1 z# y* J* w; F
: i( r% J5 a. `+ c6 G5 F" ^! }
0 L# {/ f( b. ?0 y- R底层截图:& z+ ~- w0 l5 c! i0 Q
6 i r+ F, X4 P+ S6 \
6 m) u" o: z# d5 h: V1 }0 z( k
全层截图:
2 U. F4 n b# Q# P9 y% t
/ L9 M- Q( |, r6 o2 {1 u- R" C, X' S) f$ W% ~
叠层信息截图如下:
8 |8 M# Q, u' {) \9 [/ ^9 ]
6 v6 k$ g6 q R/ S; q
. p" H* {+ v/ I" ?. x
BOM:
+ E' f- l/ t4 pComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | BATTERY/3.7V | BT1 | CON2-DIP | 1 | 24PF | C1 | C0603 | 1 | 102PF | C2 | C0603 | 1 | 104PF | C3, C26, C27, C28, C29 | C0603 | 5 | 1UF | C4, C14, C15, C16, C17, C18, C19, C20, C21 | C0603 | 9 | 4.7UF | C5, C6 | C0603 | 2 | 2.7PF | C7 | C0603 | 1 | 10UF | C8, C9, C10, C11, C12, C13, C24, C25 | C0603 | 8 | 15PF | C22, C23 | C0603 | 2 | 22UF | C30, C31, C32, C33 | C0805 | 4 | 18P | C34, C35 | C0402 | 2 | 100UF | C36, C37 | C0805 | 2 | 2.2UF | C38 | C0603 | 1 | SK34 | D1 | D-SS34 | 1 | ANTENNA | E1 | ANT-AC4602 | 1 | ANTENNA | E2 | PASTE | 1 | TF_CARD | J1 | CARD-TF1 | 1 | CON20 | J3 | FPC20_0_5MM | 1 | CON7 | J4 | USB-MICRO | 1 | PHONE | JS1 | PHONE-ST3505 | 1 | 100NH | L1 | 0603 | 1 | 2.8NH | L2 | 0603 | 1 | 2.2UH | L3 | L-CD25 | 1 | | LED1 | D0603 | 1 | | MIC1 | MIC | 1 | MOTOR SERVO | MOTOR CON1 | CON2-DIP | 1 | S8050 | Q1 | SOT-23 | 1 | S2300 | Q2 | SOT-23 | 1 | 1K | R1, R21, R22, R23, R24 | R0603 | 5 | 2.2K | R2 | R0603 | 1 | 2.2R | R3 | R0603 | 1 | 3.3K | R4 | R0603 | 1 | 0R | R5, R6 | R0603 | 2 | 22K/1% | R7 | R0603 | 1 | 100K | R8, R9, R10, R11, R12, R13 | R0603 | 6 | 3K/1% | R14 | R0603 | 1 | 10K | R15, R16, R17, R18 | R0603 | 4 | 1R | R19 | R0603 | 1 | 300K 1% | R20 | R0603 | 1 | 300K | R25 | R0603 | 1 | 20K | R26 | R0603 | 1 | 100K 1% | R27, R28, R29, R30, R31 | R0603 | 5 | 1K 1% | R32, R33 | R0603 | 2 | 0.05R | R34 | R1206 | 1 | 100R | R35 | R0603 | 1 | RESET | S1 | KEY-B | 1 | POWER/PLAY | S2 | KEY-4 | 1 | PREV/VOL- | S3 | KEY-4 | 1 | NEXT/V+ | S4 | KEY-4 | 1 | SPEAKER | SPK_R1, SPK_R2 | CON2-DIP | 2 | AC_PAD1 | U1 | LQFP_48 | 1 | ETA9638 | U2 | SOP-8 | 1 | CS8573 | U4 | SOP-16 | 1 | 32.768K/NC | Y1 | MC-146 | 1 | 24MHz | Y2 | XY-SOP4 | 1 | * c( a/ B! X1 q* h% v' y: |% @
附件:, L- q6 \4 K/ j& ~8 Y4 u
PCB源文件如下:
% B* Y' E3 F( M5 w2 U. n8 d9 e5 U, U! N
$ H/ s E" ?5 S u8 s0 C' M1 C% E
