作品名:[AD 10][2层] VL812方案 USB3.0 1拖4 HUB PCB文件共享7 v; V! E+ v* F- Q- s" k
6 B4 I, N) T: m- O2 H2 ?! J
文件描述
, J/ x& z4 U p1. 作品用途:USB3.0 1拖4 HUB 9 M& W5 b. ^6 L: P" [: s
2. 软件版本:AD 10
1 I7 V$ w0 V/ ~# V/ v3. 层数:2层板! I9 U) x. `! f4 |+ Q* p
4. 用到的主要芯片:SOT23-132
8 H6 ^5 o' l+ o1 f$ H9 N5. PCB尺寸:52.3mm*40.6mm* C _% u v5 v
4 f% v* V: a9 ]1 T
作品截图如下:
# j; h R; B" r0 y( ~顶层截图:
$ U, c/ j6 E9 ?: g
: \: e% ~2 n4 c; L3 u& E
5 p. ~3 m8 s4 F- V* L底层截图:
5 _+ X" z% T3 J. k/ t: E
1 o3 f" \9 `$ R9 o7 P! C6 z; t
u- [% f& M7 g9 r
全层截图:! D' K% u1 V4 B7 @% p
y. U s- _+ g% {* [7 n O' Z; c2 i. V' e( v# y+ v. ?, |
叠层信息截图如下:
4 r% ]& h- G6 ]. w
( z1 g% c K8 ]3 \
% R6 Y5 b. v5 {2 }' w/ Z7 g
BOM:4 N+ t, A7 U$ U. r1 Z
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | CAP0603 | C1, C4, C7, C19, C20, C28, C45 | CAP0603 | 7 | CAP0402 | C2, C3, C5, C6, C9, C10, C11, C12, C13, C14, C15, C16, C17, C18, C21, C22, C23, C24, C25, C26, C29, C30, C31, C32, C33, C34, C36, C37, C38, C39, C40, C42, C43, C44, C46, C47, C48, C50, C51, C52, C53, C54, C55, C56, C57, C58, C60 | CAP0402 | 47 | CAP0805 | C8, C27 | CAP0805 | 2 | CAP1210 | C35, C41, C49, C59 | CAP1210 | 4 | EC5X7-80 | CE1 | EC5X7-80 | 1 | D-MELF | D1 | D-MELF | 1 | SMD_TP_1 | Designator1 | SMD_TP_1 | 4 | FUSE1206 | F1 | FUSE1206 | 1 | BEAD-CB-2012ES | FB1, FB2, FB3, FB4, FB5 | BEAD-CB-2012ES | 5 | DCJACK-IDJ-D22-6T | J1 | DCJACK-IDJ-D22-6T | 1 | USB-UEA11123-4HK1-4H | J2, J3, J4, J6 | USB-UEA11123-4HK1-4H | 4 | MICROUSB-B-S_D | J5 | MICROUSB-B-S_D | 1 | L-ZAD2512 | L1 | L-ZAD2512 | 1 | SOT23-GDS | Q1 | SOT23-GDS | 1 | RES0402 | R1, R2, R3, R4, R5, R6, R7, R8, R9, R10, R11, R12, R13, R14, R15, R16, R17, R18, R19 | RES0402 | 19 | RES0603 | R20 | RES0603 | 1 | SOT23-132 | U1 | SOT23-132 | 1 | TSSOP8-25P6X228 | U2 | TSSOP8-25P6X228 | 1 | QFN76-15P7-TH | U3 | QFN76-15P7-TH | 1 | LED-LT8A23-51-UR96-T5 | U4, U5, U6, U7 | LED-LT8A23-51-UR96-T5 | 4 | MSOP8-25P6X172 | U8 | MSOP8-25P6X172 | 1 | OSC4-085X061 | X1 | OSC4-085X061 | 1 | & R+ l# n% x( {. E; x! l- w- Z6 n
附件:2 M6 X2 L9 Y+ I5 b
原理图和PCB源文件如下:8 ]. ~# |9 V) `( _9 _
" b2 m6 G' e* R/ g) w5 g% L
# |/ A0 X% o' b7 l% l* p |
