查看: 463|回复: 3
[allegro16.6][6层] ColdFire MCF5441X Tower System Module 塔式系统(MCF54418+M...
发表于 2020-1-16 14:58 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
% W- K+ ^# ~" m1 {3 t$ B, E[allegro16.6][6层] ColdFire MCF5441X Tower System Module 塔式系统(MCF54418+MC9S08JM60CLD+PCI)原理图和pcb文件7 P0 ?  f5 R3 d5 ~
7 C7 ]% `. U* x6 c5 m  A' M& m; k/ ]6 @文件描述:
$ u8 W' G1 C" u& w# ?3 F
6 V6 o2 z. O5 Z* D1. 作品用途: ColdFire MCF5441X Tower System Module 塔式系统3 H8 d2 S+ I7 }. Z
2. 软件版本:allegro16.6* x, r- ~" q1 K7 g
3. 层数:6层
8 @/ N8 x& Y, o! m6 u( h4. 用到的主要芯片:MCF54418+MC9S08JM60CLD+PCI( j( W. y2 P) x: q0 B  v! }
5. pcb尺寸: 3543*3175 MIL+ K4 U; Z3 e  y4 o2 O! g
* @/ V- W/ Z1 n# W( i作品截图如下:
" u; q7 P3 f5 L
/ b- ?( s# N8 G; S顶层截图:
3 {! R, c# ?2 a5 v 5 E# E, O- M3 K  z, m0 P
底层截图:. m* l8 ?$ W" ?, p( V! R. x) E) j3 M+ c1 Z
# J; E  }7 Q- Z6 a- W6 A, `$ ]5 w; a) Y4 Z/ p! i9 C* c
全层截图:
7 {! g/ ^) v" u: J ! k( A  y1 _9 z6 t" }0 I
! l! \8 j4 U! p# ]3 @; w1 J
叠层阻抗信息如下:$ e9 m5 |5 T+ o. ~5 Y& f
# ?# I7 w3 U9 F0 [& s! G+ v
BOM:
5 E3 o9 L$ i% i' K2 A6 h0 w
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
0603LEDLED_0603LED_IC_0.85MM_370-76464GRNIC3D2; D7; D10
BGA256_1MM_17X17MCF5441X_BGA256_1MM_17X17_IC_1.MCF54418IC1U4
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_10.1UFDISCRETE36C5; C12; C14; C30; C36; C37; C40; C42; C45; C46; C47; C48; C50; C51; C78; C82; C84; C88; C89; C112; C114; C115; C116; C117; C118; C127; C128; C129; C130; C131; C132; C134; C135; C139; C141; C150
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M3300pFDISCRETE10C6; C10; C11; C18; C21; C23; C26; C108; C110; C111
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_21.0UFDISCRETE8C8; C28; C29; C65; C70; C74; C80; C143
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6350.1UFDISCRETE25C9; C19; C22; C27; C31; C52; C55; C57; C59; C63; C64; C66; C67; C69; C71; C75; C79; C81; C85; C90; C95; C97; C99; C102; C124
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.7_10.01UFDISCRETE11C13; C15; C49; C93; C107; C113; C121; C126; C133; C138; C140
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.740.01UFDISCRETE16C53; C54; C56; C58; C60; C61; C62; C77; C92; C94; C98; C100; C101; C103; C151; C152
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M1000PFDISCRETE1C120
CC0603CAP_NP_CC0603_0.90MM_150-75116_18PFDISCRETE2C4; C7
CC0603_OVCAP_NP_CC0603_OV_0.9MM_150-77974.7uFDISCRETE7C1; C144; C145; C146; C147; C148; C149
CC0603_OVCAP_NP_CC0603_OV_0.90MM_150-75133PFDISCRETE2C16; C17
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PFDISCRETE2C136; C137
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_10.39UFDISCRETE1C142
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UFDISCRETE10C20; C68; C72; C73; C76; C83; C86; C87; C91; C109
CC1210CAP_NP_CC1210_DISCRETE_2.2MM_1547uFDISCRETE3C119; C123; C125
CC3216CAP_POL_CC3216_DISCRETE_1.8MM_110UFDISCRETE4C39; C41; C43; C44
CCE63X55CAP_POL_CCE63X55_DISCRETE_5.7MM100UFDISCRETE1C35
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWER SYSTEMIO1J13
CON5_MUSB_AB_0P8_RA_SMTUSB_MINI_B_SKT_CON5_MUSB_AB_0P8USB_MINI_B 5IO1J9
CUT_TRACECUT_TRACE_RADIAL_CUT_TRACE_DISC0DISCRETE15CT1; CT2; CT3; CT4; CT5; CT6; CT7; CT8; CT9; CT10; CT11; CT12; CT13; CT14; CT15
DFN_8_0P5_2X2MC34727AFC_DFN_8_0P5_2X2_IC_0.6MC34727CFCIC1U21
DFN_8_0P5_2X2MC34727AFC_DFN_8_0P5_2X2_IC_0_1MC34727BFCIC1U22
DFN_8_0P5_2X2MC34727AFC_DFN_8_0P5_2X2_0.65MMMC34727AFCIC1U23
FBGA60_8X10_AMT47H128M8_FBGA60_8X10_A_IC_1.2MT47H128M8IC1U10
HC49SDLFXTAL_HC49SDLF_IC_4.2MM_230-77704MHzDISCRETE1Y2
HDR102CONN_HDR_1X2_HDR102_IO_8.6MM_21HDR 1X2 THIO4J4; J6; J10; J12
HDR103CONN_HDR_3X1_HDR103_IO_8.6MM_21HDR TH 1X3IO2J2; J8
HDR203_M20CONN_HDR_3X2_HDR203_M20_IO_8.64HDR 2X3IO1J7
HDR205_SMCONN_HDR_5X2_HDR205_SM_IO_9.65HDR_2X5IO2J1; J3
HDR213_TSM_SMCONN_HDR_13X2_HDR213_TSM_SM_IO_HDR_2X13IO1J11
IND_0603IND_IND_0603_DISCRETE_0.8MM_180100MHZDISCRETE6L1; L2; L3; L4; L7; L11
IND_1206ABEAD_IND_1206A_DISCRETE_1.3MM_126OHMDISCRETE2L5; L6
IND_VLF4012IND_IND_VLF4012_1.2MM_180-750864.7UH@100KHZIC3L8; L9; L10
JUMP2X2-6040HDR-2X2_JUMP2X2-6040_IO_8.58MM_HDR 2X2IO1J5
LED_0603LED_LED_0603_IC_1.0MM_370-76473OR/REDIC2D1; D5
LED_0603LED_LED_0603_IC_1.0MM_370-76476YELIC2D3; D6
LED_0603LED_LED_0603_IC_1.0MM_370-76470AMBIC1D4
LGA14_0P80_3X5_SHMMA7360L_LGA14_0P80_3X5_SH_IC_1MMA7361LIC1U7
MINI_SOIC8LM4889_8P_MINI_SOIC8_IC_1.09MM_LM4889IC1U16
POT3_3352WPOT_POT3_3352W_DISCRETE_470-79910KDISCRETE1R11
PSOP8_1P27LP2997_PSOP8_1P27_IC_1.68MM_315LP2997MRIC1U9
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7KDISCRETE32R1; R2; R8; R13; R16; R17; R18; R19; R20; R21; R22; R23; R26; R27; R28; R33; R35; R54; R102; R103; R104; R105; R106; R111; R112; R113; R115; R116; R125; R137; R141; R146
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4722DISCRETE49R3; R4; R5; R14; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R123; R126; R139; R140; R145
RC0402_25RES_RC0402_25_DISCRETE_470-755510KDISCRETE21R7; R77; R78; R81; R84; R86; R88; R92; R93; R96; R97; R98; R99; R119; R122; R127; R129; R132; R133; R134; R136
RC0402_25RES_RC0402_25_0.55 MM_470-7563433DISCRETE2R9; R10
RC0402_25RES_RC0402_25_0.55MM_470-75642_1.0MDISCRETE2R12; R24
RC0402_25RES_RC0402_25_DISCRETE_470-7561330DISCRETE5R15; R25; R29; R31; R147
RC0402_25RES_RC0402_25_DISCRETE_470-75390DISCRETE8R30; R32; R100; R107; R130; R131; R142; R143
RC0402_25RES_RC0402_25_DISCRETE_0.55 MM_330DISCRETE1R34
RC0402_25RES_RC0402_25_DISCRETE_470-75_11KDISCRETE5R79; R80; R82; R83; R94
RC0402_25RES_RC0402_25_DISCRETE_470-756022DISCRETE1R85
RC0402_25RES_RC0402_25_DISCRETE_470-75624.7KDISCRETE3R87; R89; R120
RC0402_25RES_RC0402_25_DISCRETE_470-756333DISCRETE2R90; R91
RC0402_25RES_RC0402_25_DISCRETE_470-75641.8KDISCRETE1R95
RC0402_25RES_RC0402_25_470-75394_00DISCRETE6R108; R109; R110; R151; R152; R156
RC0402_25RES_RC0402_25_DISCRETE_470-760820KDISCRETE3R148; R149; R150
RC0402_25RES_RC0402_25_DISCRETE_470-3032100DISCRETE3R153; R154; R155
RC0603_OVRES_RC0603_OV_DISCRETE_470-75392.2KDISCRETE1R128
RC0603_OVRES_RC0603_OV_DISCRETE_470-755510MDISCRETE1R135
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400DISCRETE1R157
RNET_4_8RESISTOR_ARRAY_RNET_4_8_DISCRET10KDISCRETE1RN1
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P3LIC2D8; D11
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YMIC1U12
SOT23NPN_SOT23_IC_1.12 MM_480-75173_MMBT3904LT1GIC1Q3
SOT-23TRAN_NPN_RES_SOT-23_IC_1.3MM_48PDTC115TIC3Q1; Q2; Q4
SOT-553-5P2-INPUT_OR_SOT-553-5P_IC_0.6MM_NL17SZ32IC1U20
SW4_6P5X7MMSW_DIP-2_SW4_6P5X7MM_IC_4.2MM_5SW_DIP-2/SMIC1SW4
SW_DIP16_8POS_SMSW_DIP_8_SW_DIP16_8POS_SM_IC_2.218-8LPSTIC1SW1
SW_SPST_THSW_PSHBT_SPST_2_SW_SPST_TH_IC_7LIGHT TOUCH PUSH BUTTONIC3SW2; SW3; SW5
TP_0_3MM_SQ_0_9MMSQ_TESTPOINT_TP_0_3MM_SQ_0_9MM_TP_0_3MM_SQ_0_9MMIC4TP1; TP2; TP3; TP4
TQFP44MC9S08JM60CLD_TQFP44_IC_1.60 MMMC9S08JM60CLDIC1U18
TSOP48_18P5X12P4MT29F2G16AADWP_TSOP48_18P5X12P4MT29F2G16AADWPIC1U14
TSSOP1474LVC125_TSSOP14_IC_1.2MM_312-774LVC125IC4U2; U3; U11; U19
TSSOP16ICL3232_TSSOP16_IC_1.1 MM_312-7ICL3232IC1U15
TSSOP20SN74ACT573PWR_TSSOP20_IC_1.2MM_SN74ACT573IC1U13
TSSOP56_IDTIDTQS3VH16233_TSSOP56_IDT_IC_1.QS3VH16233PAGIC1U17
USOP-8DS18B20U_USOP-8_IC_1.1MM_312-79DS18B20IC1U5
XTL2_ECS_SMXTAL_XTL2_ECS_SM_2.25MM_230-30032.768KHzDISCRETE1Y1
XTL_HC49SLFCRYSTAL_XTL_HC49SLF_IC_3.6MM_2325MHZIC1X1
附件:8 y) R/ H% \" o+ |/ r: p
原理图和PCB文件如下:0 e' ^/ p2 C/ f5 ~/ r
游客,如果您要查看本帖隐藏内容请回复
1 g+ O0 _% i" B( a% k% v. R0 K' S
发表于 2020-6-6 21:39 | 只看该作者
kankankankanakanakanka
( N( r2 Q7 ~( I. n: d( q$ z
    2024-8-26 15:16
    发表于 2020-6-7 08:21 | 只看该作者
    多谢分享资料
    - q( B( _$ _5 C8 a9 n
    发表于 2020-10-15 17:11 | 只看该作者
    ganxie fenxiang ,heheheh
    , M$ }$ [- e  M  u9 g
    GMT+8, 2025-7-29 06:42 , Processed in 0.125000 second(s), 27 queries , Gzip On.
