作品名:[AD 15][4层]电机驱动板(TC1002+GBU1010+IR2101)原理图和PCB源文件
2 v! i. F; K8 ~0 F7 ?4 u' X& ~1 x* w6 r5 \' q8 f# c1 {
文件描述
G0 f' r' `& f3 y- P& k! U
, y6 W4 b$ Y, b$ Z1. 作品用途:电机驱动板
! S% j# e' h H) g3 `, A5 P+ N$ a9 p, \: _
2. 软件版本:AD 15: C5 [5 [9 N' K! L5 ^: ]2 {$ g
# w4 j6 |& I: I0 k
3. 层数:4层板( ?0 j3 n( c0 C
% X! V' h8 X! z: v9 `) b4. 用到的主要芯片:TC1002+GBU1010+IR2101
3 W, O% X1 f8 r# }% z) v' c$ x5 X t$ I5 T
5. PCB尺寸:120.1mm*89.1mm/ V0 N+ d" |# k- t
. z) \ @% f/ a. y" S
" |/ U0 G; o' c u8 G% \1 `作品截图如下:* s4 Y- z+ e# [2 z4 W
2 E1 s, g5 `' f8 J& Z5 k( \顶层截图:% u- X& j$ T9 u' p/ A
) T; w/ V @. {( A9 P1 m5 t: N
* Z. s2 M5 e; h; r$ m: w7 U, O
底层截图:1 {) t5 H5 P! O
; W4 J, M/ B& d
0 c, w+ n# N6 {全层截图:6 E `9 W- V! [/ E8 u+ a
H- N$ l" y* |- `3 X2 p- Y9 T
/ N& ^4 V% ~8 D& y. ^% t叠层信息截图如下:
' ^- q$ w" I. I: T4 s, p
) O& `) G& x$ u7 m* l) z2 X. N
& B. {+ w2 Q/ R& p& v2 \BOM:5 O2 ^& W; b7 |, S1 n' s4 `% `
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | Comment | | LOGO_JINGDIAN | 1 | 100nf | C1, C2, C3, C4, C5, C6, C11, C16, C17, C18, C19, C25, C32, C33, C34 | 0805C | 15 | CAP | C7, C8, C9 | 0805C | 3 | 0.47uf | C10 | 0805C | 1 | 1uF | C12, C13, C15, C20, C23 | 0805C | 5 | 1nf | C14 | 0805C | 1 | 220P | C21, C22 | 0805C | 2 | 25V/100UF | C24, C39 | CAP@7 | 2 | 470pf | C26, C27 | 0805C | 2 | 25V/100UF | C28, C29 | CAP@6 | 2 | 100nf | C30 | RAD7.2 | 1 | 100nf | C31, C35, C37 | 0805 | 3 | Comment | C38 | CAP3 | 1 | CON6 | CON1, CON2 | CON6@5.08G | 2 | 100nf | CON3 | XH2.54@2P | 1 | LED | D1, D2 | LED2 | 2 | 1N4148 | D3, D4, D5, D6 | SOD123 | 4 | 1N4148 | D7, D8, D11, D12, D17, D18, D21, D22 | LL4148 | 8 | ES2G | D9, D13, D14, D15, D19, D23 | SMB | 6 | 1N4148 | D10, D16, D20 | SOD123B | 3 | Comment | D26 | DIODE2 | 1 | UF2G | D27, D28, D29, D30 | SMB | 4 | Comment | D31, D32, D33, D34 | LL4148 | 4 | 100V/470UF | EC1, EC2 | CAP1000UF | 2 | Comment | EC3 | CAP1000UF | 1 | L1 | L1 | SCK2010C | 1 | IRF540N | Q1, Q2, Q3, Q4, Q5, Q6, Q7, Q8 | TO220 | 8 | FU 220N | Q9 | MOS-1N | 1 | 10K | R1, R2, R8, R27, R64 | 0805 | 5 | 36K | R3 | 0805 | 1 | 68K | R4 | 0805 | 1 | 2.7K | R5 | 0805 | 1 | 1K | R6, R9, R10, R11, R12, R67 | 0805 | 6 | RES2 | R7, R21, R22, R23, R24, R31, R32, R33, R34, R35, R36, R37, R40, R41, R42, R47, R48, R49, R54, R55, R58 | 0805 | 21 | 3.6K | R13 | 0805 | 1 | 10R | R14, R15 | 0805 | 2 | 4.7K | R16, R17 | 0805 | 2 | 82R | R18, R25 | 0805 | 2 | 39R | R19, R66 | 0805 | 2 | 20R | R20 | 0805 | 1 | 360R | R26 | 0805 | 1 | 240 | R28, R29, R30 | 0805 | 3 | RES2 | R38, R39, R43, R44, R52, R53, R59, R60 | 1206 | 8 | 4.7k | R45, R46, R65 | 1206 | 3 | RES2 | R50, R51, R56, R57 | RXA15 | 4 | 15K | R61 | 0805 | 1 | 3.9K | R62 | 0805 | 1 | 470K | R63 | 0805 | 1 | 0.5R 0.5W | R68 | 1206 | 1 | Comment | R69 | RES2 | 1 | SW DIP-8 | S1 | SW16B | 1 | | T1 | EE13H | 1 | LM358 | U1 | SO-8 | 1 | LM393 | U2, U3 | SO-8 | 2 | LM339 | U4 | SO-14 | 1 | LM317 | U5 | LM317 | 1 | 6N137 | U6 | DIP8 | 1 | EL817 | U7, U8 | DIP4 | 2 | IR2101 | U9, U10, U13, U14 | SO-8 | 4 | 78L05 | U11 | SO-8 | 1 | TC1002 | U12 | QFP44 | 1 | 3843B | U15 | SO-8 | 1 | GBU1010 | U16 | KBU1510B | 1 |
/ H M F' A: y9 t& @附件:: Q9 |8 k. j$ W& p- \1 r
$ {( E+ S. {. U3 H' o2 M' p5 o原理图和PCB源文件如下: q* W/ ~8 B0 T8 A. ?3 t
7 r& Y! D' W; ], ^0 Q: H5 g9 D4 W* {
- X, T3 }6 `7 k: c9 b$ M3 ^
6 D! X C: U& A# W |
