Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
402 | CAP_0402_0.1UF | 0.1uF | IC | 214 | C1; C2; C6; C12; C13; C14; C15; C16; C19; C20; C23; C27; C28; C32; C33; C34; C42; C44; C69; C70; C71; C72; C73; C74; C76; C82; C83; C85; C86; C87; C89; C90; C91; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C106; C107; C108; C109; C110; C115; C116; C117; C118; C119; C120; C121; C122; C123; C125; C126; C127; C128; C129; C130; C132; C133; C134; C135; C136; C137; C138; C149; C150; C151; C152; C153; C158; C159; C160; C161; C162; C163; C164; C165; C168; C169; C172; C173; C174; C175; C184; C186; C191; C192; C193; C194; C195; C196; C197; C198; C199; C204; C205; C206; C207; C208; C210; C211; C212; C214; C215; C216; C217; C219; C220; C222; C224; C226; C227; C230; C231; C234; C235; C236; C237; C238; C239; C240; C241; C242; C244; C246; C251; C252; C253; C255; C257; C258; C259; C260; C262; C263; C266; C268; C273; C274; C275; C276; C277; C278; C279; C280; C281; C282; C283; C284; C287; C289; C291; C292; C294; C295; C296; C300; C302; C303; C304; C312; C313; C315; C317; C319; C320; C321; C324; C326; C328; C330; C334; C336; C338; C339; C341; C343; C345; C347; C348; C349; C351; C352; C353; C354; C355; C356; C357; C358; C360; C361; C362; C365; C366; C367; C370; C371; C377; C382; C383; C384; C385; C386; C387; C388; C389; C390 |
402 | CAP_0402_0.01UF | 0.01uF | IC | 23 | C4; C7; C21; C25; C67; C68; C104; C105; C139; C146; C190; C213; C229; C254; C261; C267; C293; C301; C305; C314; C318; C322; C369 |
402 | CAP_0402_4.7NF | 4.7nF | IC | 9 | C35; C218; C256; C264; C269; C272; C286; C316; C368 |
402 | CAP_0402_1UF | 1uF | IC | 3 | C131; C180; C381 |
402 | CAP_0402_1500PF | 1500pF | IC | 1 | C142 |
402 | CAP_0402_10PF | 10pF | IC | 7 | C143; C157; C189; C308; C309; C310; C311 |
402 | CAP_0402_18PF | 18pF | IC | 2 | C154; C170 |
402 | CAP_0402_470PF | 470pF | IC | 1 | C156 |
402 | CAP_0402_220PF | 220pF | IC | 1 | C171 |
402 | CAP_0402_33NF | 33nF | IC | 1 | C185 |
402 | CAP_0402_680PF | 680pF | IC | 1 | C188 |
402 | CAP_0402_DNI | DNI | IC | 11 | C323; C325; C327; C329; C331; C340; C342; C344; C346; C373; C374 |
402 | CAP_0402_560PF | 560pF | IC | 1 | C363 |
402 | CAP_0402_1000PF | 1000pF | IC | 1 | C364 |
402 | CAP_0402_5600PF | 5600pF | IC | 1 | C372 |
402 | CAP_0402_3300PF | 3300pF | IC | 1 | C375 |
402 | BEAD_FERRITE_SM_0402_BLM15AG221 | BLM15AG221SN1 | IC | 6 | L1; L2; L3; L10; L11; L12 |
402 | RESISTOR_0402_56.2 | 56.2 | IC | 21 | R1; R2; R77; R78; R102; R103; R104; R105; R113; R114; R115; R116; R119; R120; R121; R122; R130; R131; R133; R134; R192 |
402 | RESISTOR_0402_100, 1% | 100, 1% | IC | 30 | R3; R8; R12; R74; R75; R79; R132; R167; R168; R169; R174; R175; R176; R177; R178; R179; R180; R181; R185; R186; R187; R188; R189; R190; R191; R193; R194; R213; R223; R228 |
402 | RESISTOR_0402_10.0K | 10.0K | IC | 29 | R4; R5; R6; R7; R9; R10; R11; R50; R53; R76; R106; R151; R154; R156; R161; R173; R183; R214; R215; R217; R218; R219; R220; R225; R226; R227; R230; R237; R242 |
402 | RESISTOR_0402_1.00K | 1.00K | IC | 20 | R13; R54; R107; R108; R109; R110; R111; R112; R158; R195; R196; R207; R210; R212; R216; R232; R241; R243; R244; R245 |
402 | R_0402_1.00K | 1.00K | IC | 6 | R14; R17; R18; R21; R22; R45 |
402 | RESISTOR_0402_10K | 10K | IC | 12 | R15; R19; R23; R24; R25; R26; R32; R44; R47; R199; R200; R201 |
402 | RESISTOR_0402_11.5K | 11.5K | IC | 3 | R16; R153; R164 |
402 | RESISTOR_0402_68.1K | 68.1K | IC | 1 | R20 |
402 | RESISTOR_0402_1.5K | 1.5K | IC | 1 | R27 |
402 | RESISTOR_0402_27 | 27 | IC | 2 | R29; R48 |
402 | RESISTOR_0402_0 | 0 | IC | 27 | R30; R31; R34; R35; R36; R37; R38; R40; R41; R42; R43; R84; R85; R88; R90; R92; R93; R96; R100; R125; R140; R163; R204; R211; R234; R267; R268 |
402 | RESISTOR_0402_2.61K | 2.61K | IC | 1 | R39 |
402 | RESISTOR_0402_4.32K | 4.32K | IC | 1 | R46 |
402 | RESISTOR_0402_1.37K | 1.37K | IC | 1 | R49 |
402 | RESISTOR_0402_4.70M | 4.70M | IC | 1 | R51 |
402 | RESISTOR_0402_590K | 590K | IC | 1 | R52 |
402 | RESISTOR_0402_3.90K | 3.90K | IC | 1 | R55 |
402 | RESISTOR_0402_2.20K | 2.20K | IC | 1 | R56 |
402 | RESISTOR_0402_49.9 | 49.9 | IC | 19 | R57; R58; R59; R60; R67; R80; R81; R82; R83; R165; R166; R170; R171; R197; R198; R205; R206; R208; R209 |
402 | RESISTOR_0402_4.7K | 4.7K | IC | 12 | R61; R62; R63; R64; R65; R70; R71; R123; R148; R250; R259; R260 |
402 | RESISTOR_0402_4.99K | 4.99K | IC | 1 | R66 |
402 | RESISTOR_0402_124 | 124 | IC | 2 | R68; R69 |
402 | RESISTOR_0402_84.5 | 84.5 | IC | 2 | R72; R73 |
402 | RESISTOR_0402_DNI | DNI | IC | 14 | R86; R87; R89; R91; R94; R95; R97; R98; R99; R101; R162; R203; R229; R248 |
402 | RESISTOR_0402_5.23K | 5.23K | IC | 2 | R117; R147 |
402 | RESISTOR_0402_1.50K | 1.50K | IC | 2 | R118; R135 |
402 | RESISTOR_0402_100K | 100K | IC | 7 | R124; R138; R157; R159; R160; R236; R255 |
402 | RESISTOR_0402_20.0K | 20.0K | IC | 4 | R126; R150; R252; R253 |
402 | RES 249K OHM 1% 1/16W 0402_0402 | 249K | IC | 1 | R127 |
402 | RES 261K OHM 1% 1/16W 0402_0402 | 261K | IC | 1 | R128 |
402 | RESISTOR_0402_43.2K | 43.2K | IC | 2 | R129; R152 |
402 | RESISTOR_0402_3.0K | 3.0K | IC | 1 | R136 |
402 | RESISTOR_0402_316K | 316K | IC | 1 | R139 |
402 | RESISTOR_0402_5.49K | 5.49K | IC | 1 | R141 |
402 | RESISTOR_0402_1.00M | 1.00M | IC | 1 | R142 |
402 | RESISTOR_0402_1.62K | 1.62K | IC | 2 | R143; R247 |
402 | RESISTOR_0402_5.36K | 5.36K | IC | 1 | R144 |
402 | RESISTOR_0402_470 | 470 | IC | 1 | R149 |
402 | RESISTOR_0402_3.24K | 3.24K | IC | 1 | R155 |
402 | RESISTOR_0402_140.0K | 140.0K | IC | 1 | R172 |
402 | RESISTOR_0402_2.2K | 2.2K | IC | 1 | R182 |
402 | RESISTOR_0402_2.20 | 2.2 | IC | 2 | R184; R231 |
402 | R_0402_10.0K | 10.0K | IC | 1 | R202 |
402 | RESISTOR_0402_2.00K | 2.00K | IC | 1 | R221 |
402 | RES 24.9 OHM 1% 1/16W 0402_0402 | 24.9 | IC | 2 | R222; R224 |
402 | RESISTOR_0402_2.55K | 2.55K | IC | 1 | R233 |
402 | RESISTOR_0402_10.2K | 10.2K | IC | 1 | R235 |
402 | RESISTOR_0402_2.21K | 2.21K | IC | 1 | R246 |
402 | RESISTOR_0402_2.87K | 2.87K | IC | 1 | R249 |
402 | RESISTOR_0402_2.15K | 2.15K | IC | 2 | R251; R258 |
402 | RESISTOR_0402_5.11K | 5.11K | IC | 1 | R254 |
402 | RESISTOR_0402_25.5K | 25.5K | IC | 1 | R256 |
402 | RESISTOR_0402_63.4K | 63.4K | IC | 1 | R257 |
402 | RESISTOR_0402_220 | 220 | IC | 6 | R261; R262; R263; R264; R265; R266 |
603 | CAP_0603_2.2UF | 2.2uF | IC | 7 | C10; C17; C64; C65; C203; C335; C376 |
603 | CAP_0603_4.7UF | 4.7uF | IC | 5 | C11; C38; C41; C49; C55 |
603 | CAP_0603_10UF | 10uF | IC | 1 | C53 |
603 | CAP_0603_330PF | 330pF | IC | 2 | C144; C155 |
603 | CAP_0603_1UF | 1uF | IC | 2 | C270; C307 |
805 | CAP_0805_4.7UF | 4.7uF | IC | 4 | C3; C8; C202; C337 |
805 | CAP_0805_10UF | 10uF | IC | 27 | C51; C75; C88; C124; C140; C141; C145; C147; C166; C178; C200; C201; C232; C245; C247; C248; C249; C265; C285; C306; C332; C333; C350; C359; C378; C379; C380 |
1206 | CAP_1206_10UF | 10uF | IC | 15 | C30; C37; C39; C43; C58; C62; C63; C77; C78; C79; C80; C111; C112; C113; C114 |
1210 | CAP_1210_22UF | 22uF | IC | 2 | C29; C36 |
1210 | CAP_1210_10UF | 10uF | IC | 2 | C148; C167 |
1210 | CAP_1210_4.7UF | 4.7uF | IC | 5 | C221; C223; C225; C288; C290 |
6032P | CAP_SMD_POL_6032P_330UF | 330uF | IC | 5 | C61; C81; C183; C187; C297 |
7343P | PCAP_7343P_330UF | 330uF | IC | 8 | C5; C9; C18; C26; C46; C48; C66; C84 |
7343P | CAP_SMD_POL_7343P_470UF | 470uF | IC | 1 | C92 |
BCC96 | 88E1111_BCC96_88E1111 | 88E1111 | IC | 1 | U21 |
CAP_PACK_4_1206 | CAP_ARRAY_CAP_PACK_4_1206_0.1UF | 0.1uf x 4 | IC | 20 | CN1; CN2; CN3; CN4; CN5; CN6; CN7; CN8; CN9; CN10; CN11; CN12; CN13; CN14; CN15; CN16; CN17; CN18; CN19; CN20 |
CAP_SMD_6_3MM | PCAP_CAP_SMD_6_3MM_220UF | 220uF | IC | 1 | C24 |
CAP_SMD_8MM | PCAP_CAP_SMD_8MM_150UF | 150uF | IC | 2 | C54; C56 |
CONN_39_26_7108 | 70247-1051_CONN_39_26_7108_7024 | 70247-1051 | IC | 1 | J6 |
DDR2_84_SPEC | MT47H16M16_DDR2_84_SPEC_MT47H16 | MT47H16M16 | IC | 4 | U8; U15; U17; U19 |
DFM10-EPAD | LTC3026_DFM10-EPAD_LTC3026 | LTC3026 | IC | 3 | U40; U42; U53 |
DFN6-2X2_EPAD | LT3009XDC_DFN6-2X2_EPAD_LT3009X | LT3009xDC | IC | 1 | U16 |
DFN6_EPAD | LTC4357XDCB_DFN6_EPAD_LTC4357XD | LTC4357xDCB | IC | 2 | U48; U52 |
DFN10_EPAD | REGULATOR, LT3027_DFN10_EPAD_LT | LT3027 | IC | 1 | U41 |
DIPSWITCH_SMT_OCTAL | 76SB08_DIPSWITCH_SMT_OCTAL_TDA0 | TDA08H0SB1 | IC | 1 | SW2 |
DIPSWITCH_SMT_QUAD | SPST4_DIPSWITCH_SMT_QUAD_TDA04H | TDA04H0SB1 | IC | 3 | SW1; SW4; SW5 |
DO-214AB_RECTRON | DIODE_DO-214AB_RECTRON_FM540 | FM540 | IC | 1 | D23 |
DQFN20 | FXMA108_0_DQFN20_FXLA108 | FXLA108 | IC | 8 | U28; U29; U35; U36; U37; U38; U46; U49 |
ECS3525 | OSC_ALT_ECS3525_ECS-3525-500-B | ECS-3525-500-B | IC | 1 | X3 |
EG2201A | SW SLIDE-DPDT_EG2201A_EG2201A | EG2201A | IC | 1 | SW3 |
F64_10X8 | PC28FXXXP30B85_F64_10X8_PC28F51 | PC28F512P30BF | IC | 1 | U6 |
F256 | EPM2210GF256_1_F256_(S1+S2)_EPM | EPM2210GF256FBGA | IC | 1 | U7 |
F896 | EP4CGX150DF896_DDR2_SWAP_HSMC_F | EP4CGX150DF896_DDR2_Swap_hsmc | IC | 1 | U10 |
HDR2X1_2MM | 1X2_HDR2X1_2MM_HDR2X1 | HDR2X1 | IC | 1 | J3 |
HDR2X5_100MIL_SMT | 2X5_HDR2X5_100MIL_SMT_DNI | DNI | IC | 2 | J15; J16 |
HDR2X7_100MIL | HDR2X7_HDR2X7_100MIL_HDR2X7 | HDR2X7 | IC | 1 | J13 |
IHLP2525 | INDUCTOR_IHLP2525_3.3UH | 3.3uH | IC | 2 | L8; L9 |
IND_0805 | BEAD_FERRITE_SM_IND_0805_BLM21P | BLM21PG331SN1 | IC | 1 | L7 |
IND_COOPER_DR1050 | INDUCTOR_IND_COOPER_DR1050_8.2U | 8.2uH | IC | 1 | L6 |
IND_SUSUMU_PCMC_BTYPE | INDUCTOR_IND_SUSUMU_PCMC_BTYPE_ | 1.2uH | IC | 1 | L5 |
IND_WURTH_74456056 | INDUCTOR_IND_WURTH_74456056_5.6 | 5.6uH | IC | 1 | L4 |
LQFP-32 | FT245BL_LQFP-32_FT245BL | FT245BL | IC | 1 | U4 |
LUMEX_LED0805 | LED_LUMEX_LED0805_GREEN_LED | Green_LED | IC | 28 | D1; D2; D3; D4; D5; D6; D7; D8; D9; D10; D12; D13; D14; D15; D16; D17; D19; D20; D21; D22; D24; D25; D26; D27; D28; D29; D30; D31 |
LUMEX_LED0805 | LED_LUMEX_LED0805_RED_LED | Red_LED | IC | 1 | D18 |
LUMEX_LED1206 | LED_LUMEX_LED1206_BLUE_LED | Blue_Led | IC | 1 | D11 |
M100 | EPM240M100_M100_EPM240M100 | EPM240M100 | IC | 1 | U3 |
MLX_22_23_2021_VRT_HDR_2P | CON2_MLX_22_23_2021_MLX_22_23_2 | 22_23_2021 | IC | 1 | J8 |
PCIX-4PORT | PCIE_BRACKET_X4_PCIX-4PORT_PCIE | PCIE_Slot | IC | 1 | J14 |
PSOP-DGQ10 | TPS51100_PSOP-DGQ10_TPS51100DGQ | TPS51100DGQ | IC | 2 | U45; U47 |
PUSHBUTTON_SMT | TS-A02SA-2-S100_PUSHBUTTON_SMT_ | PB Switch | IC | 8 | S1; S2; S3; S4; S5; S6; S7; S8 |
QFN28-4X4 | LTC3850XUF_QFN28-4X4_LTC3850XUF | LTC3850xUF | IC | 1 | U50 |
QFN40 | LTC3853XUJ_QFN40_LTC3853XUJ | LTC3853xUJ | IC | 1 | U43 |
RAPC712 | CONN_JACK_PWR_RAPC712_RAPC712X | RAPC712X | IC | 1 | J5 |
RES_PACK_8 | RES_PACK_8_RES_PACK_8_10K | 10K | IC | 1 | RN1 |
RES_PACK_8 | RES_PACK_8_RES_PACK_8_56 | 56 | IC | 20 | RN2; RN3; RN4; RN5; RN6; RN7; RN8; RN9; RN10; RN11; RN12; RN13; RN14; RN15; RN16; RN17; RN18; RN19; RN20; RN21 |
RJ45 | HFJ11-1G02E_RJ45_HFJ11-1G02E | HFJ11-1G02E | IC | 1 | J7 |
SAMTEC_QSHDP120CUSTOM | QSH_HSM_SAMTEC_QSHDP120CUSTOM_A | ASP-122953-01 | IC | 2 | J1; J2 |
SC70-TI | SN74AVC1T45_SC70-TI_SN74AVC1T45 | SN74AVC1T45 | IC | 7 | U20; U22; U23; U30; U32; U33; U34 |
SENSE | SENSE_PAD_SENSE_SENSE_PAD | SENSE_PAD | IC | 16 | V1; V2; V3; V4; V47; V48; V49; V50; V51; V52; V53; V54; V55; V56; V57; V58 |
SM55-OSC | OSC_ALT_SM55-OSC_100MHZ | 100MHz | IC | 1 | Y1 |
SMA_LTI-SASF546-P26-X1 | SMA_SMA_LTI-SASF546-P26-X1_LTI- | LTI-SASF546-P26-X1 | IC | 2 | J9; J10 |
SMA_LTI-SASF546-P26-X1 | SMA_LTI_SASF54GT_0_SMA_LTI-SASF | LTI-SASF546-P26-X1 | IC | 2 | J11; J12 |
SO8 | FDS8880_SO8_FDS8880 | FDS8880 | IC | 2 | Q1; Q3 |
SO8 | SI4816BDY_SO8_SI4816BDY-T1 | SI4816BDY-T1 | IC | 5 | Q4; Q5; Q6; Q7; Q8 |
SO8 | AT93C46-10_SO8_AT93C46DN-SH-B | AT93C46DN-SH-B | IC | 1 | U5 |
SO16_WIDE | EPCS128_SO16_WIDE_EPCS128 | EPCS128 | IC | 1 | U18 |
SOD323 | ZENERDIODE_SOD323_CMDSH2_3 | CMDSH2_3 | IC | 9 | D32; D33; D34; D35; D36; D37; D38; D39; D40 |
SOT23 | PWRMOSFET_EN_GSD_0_SOT23_FDV305 | FDV305N | IC | 1 | Q2 |
SOT23-8 | MAX3372EEKA_0_SOT23-8_MAX3373 | MAX3373 | IC | 6 | U9; U14; U24; U27; U31; U39 |
SOT23-DBV | SN65220DBV_SOT23-DBV_SN65220DBV | SN65220DBV | IC | 1 | U11 |
SSOP28_NAR | LTC2418_SSOP28_NAR_LTC2418 | LTC2418 | IC | 1 | U13 |
STAR_VIA | VIA_1_STAR_VIA_VIA_1 | VIA_1 | IC | 42 | V5; V6; V7; V8; V9; V10; V11; V12; V13; V14; V15; V16; V17; V18; V19; V20; V21; V22; V23; V24; V25; V26; V27; V28; V29; V30; V31; V32; V33; V34; V35; V36; V37; V38; V39; V40; V41; V42; V43; V44; V45; V46 |
TP_060SQ040 | T_POINT_R_TP_060SQ040_54101-G05 | 54101-G05-01LF | IC | 7 | TP1; TP2; TP3; TP4; TP5; TP6; TP7 |
TQFP100P | GS832018GT_TQFP100_0_TQFP100P_G | GS832018GT_TQFP100 | IC | 1 | U44 |
TSSOP14 | MAX3378_0_TSSOP14_MAX3378 | MAX3378 | IC | 2 | U12; U26 |
TSSOP14 | ADG3304_TSSOP14_DNI | DNI | IC | 1 | U51 |
TSSOP20 | ICS8543_TSSOP20_ICS8543 | ICS8543 | IC | 1 | U25 |
USB2_0-RA | USB_CON_USB2_0-RA_USB CON | USB CON | IC | 1 | J4 |
UTQFN10 | ISL54050_UTQFN10_NLAS4717EPMTR2 | NLAS4717EPMTR2G | IC | 2 | U1; U2 |
WSL2010 | RESISTOR_WSL2010_0.003 | 0.003 | IC | 5 | R28; R33; R238; R239; R240 |
WSL2010 | RESISTOR_WSL2010_.009 | 0.009 | IC | 3 | R137; R145; R146 |
X2Y_0603 | CAP_X2Y_X2Y_0603_47NF | 47nF | IC | 1 | C22 |
X2Y_0603 | CAP_X2Y_X2Y_0603_1UF | 1uF | IC | 6 | C31; C177; C181; C209; C228; C250 |
X2Y_0603 | CAP_X2Y_X2Y_0603_220NF | 220nF | IC | 4 | C40; C50; C176; C182 |
X2Y_0603 | CAP_X2Y_X2Y_0603_10NF | 10nF | IC | 3 | C45; C233; C271 |
X2Y_0603 | CAP_X2Y_X2Y_0603_22NF | 22nF | IC | 3 | C47; C57; C243 |
X2Y_0603 | CAP_X2Y_X2Y_0603_100NF | 100nF | IC | 3 | C52; C59; C60 |
X2Y_0603 | CAP_X2Y_X2Y_0603_470NF | 470nF | IC | 3 | C179; C298; C299 |
XTAL_EG2100 | 635L3C3_XTAL_EG2100_125.0MHZ | 125.0MHz | IC | 1 | X2 |
XTAL_HC49 | CRYSTAL_XTAL_HC49_6.000MHZ | 6.000MHz | IC | 1 | Y2 |
XTAL_PACK_D | XTAL_XTAL_PACK_D_25MHZ | 25MHz | IC | 1 | X5 |
XTAL_SG310 | OSC_ALT_XTAL_SG310_24MHZ | 24MHz | IC | 1 | X1 |
XTAL_SI570 | SI570_0_XTAL_SI570_100MHZ | 100MHz | IC | 1 | X4 |
附件:
