Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
402 | CAP_0402_0.01UF | 0.01uF | DISCRETE | 77 | C1; C8; C10; C34; C36; C37; C38; C42; C43; C83; C85; C86; C87; C90; C92; C100; C101; C118; C120; C121; C123; C134; C155; C163; C171; C185; C188; C206; C208; C220; C225; C230; C233; C238; C246; C267; C287; C289; C290; C291; C296; C297; C305; C312; C314; C315; C319; C325; C326; C329; C334; C343; C345; C346; C348; C353; C354; C360; C366; C368; C373; C398; C400; C407; C408; C410; C427; C433; C440; C446; C453; C461; C463; C477; C485; C487; C489 |
402 | CAP_0402_1000PF | 1000pF | DISCRETE | 5 | C6; C11; C16; C29; C66 |
402 | CAP_0402_100PF | 100pF | DISCRETE | 1 | C7 |
402 | CAP_0402_0.1UF | 0.1uF | DISCRETE | 147 | C12; C13; C28; C48; C49; C50; C57; C58; C73; C74; C75; C76; C77; C81; C82; C84; C95; C107; C108; C109; C111; C115; C116; C117; C124; C125; C126; C127; C132; C136; C137; C138; C142; C144; C145; C146; C147; C148; C151; C153; C156; C157; C158; C159; C160; C164; C165; C166; C167; C172; C174; C175; C177; C178; C179; C181; C183; C184; C187; C191; C192; C193; C197; C198; C199; C200; C203; C204; C205; C211; C212; C213; C216; C218; C219; C221; C222; C223; C226; C228; C229; C231; C232; C234; C235; C240; C241; C242; C243; C244; C245; C247; C248; C263; C265; C273; C277; C279; C281; C282; C283; C298; C316; C317; C327; C335; C347; C350; C351; C362; C363; C378; C383; C386; C395; C396; C397; C399; C401; C402; C405; C411; C412; C413; C414; C425; C426; C428; C429; C430; C431; C442; C443; C449; C451; C452; C454; C455; C456; C457; C468; C469; C479; C481; C482; C493; C499 |
402 | CAP_0402_2.2NF | 2.2nF | DISCRETE | 36 | C17; C64; C91; C114; C133; C170; C194; C196; C253; C254; C255; C259; C260; C269; C272; C293; C294; C300; C308; C321; C322; C323; C330; C340; C375; C379; C385; C387; C392; C404; C416; C420; C424; C437; C480; C495 |
402 | CAP_0402_0.47UF | 0.47uF | DISCRETE | 5 | C88; C119; C122; C173; C488 |
402 | CAP_0402_47NF | 47nF | DISCRETE | 10 | C89; C99; C112; C140; C180; C286; C311; C342; C358; C391 |
402 | CAP_0402_12PF | 12pF | IC | 2 | C97; C106 |
402 | CAP_0402_3.3NF | 3.3nF | DISCRETE | 13 | C98; C141; C168; C288; C303; C313; C333; C344; C359; C435; C436; C466; C491 |
402 | CAP_0402_22NF | 22nF | DISCRETE | 24 | C102; C104; C110; C113; C169; C176; C195; C249; C268; C280; C285; C295; C332; C339; C341; C352; C364; C365; C393; C421; C462; C467; C483; C492 |
402 | CAP_0402_4.7NF | 4.7nF | DISCRETE | 36 | C103; C135; C139; C162; C186; C201; C202; C215; C224; C227; C264; C278; C284; C301; C302; C307; C309; C310; C320; C324; C331; C338; C356; C357; C370; C382; C406; C415; C417; C432; C441; C458; C460; C464; C465; C494 |
402 | CAP_0402_33NF | 33nF | DISCRETE | 1 | C143 |
402 | CAP_0402_1.0NF | 1.0nF | DISCRETE | 30 | C154; C161; C190; C214; C250; C251; C252; C256; C258; C262; C266; C270; C271; C337; C371; C372; C374; C376; C377; C380; C381; C394; C403; C409; C422; C423; C434; C438; C439; C496 |
402 | CAP_0402_1PF | 1pF | DISCRETE | 2 | C182; C217 |
402 | CAP_0402_DNI | DNI | IC | 2 | C390; C490 |
402 | BEAD_FERRITE_SM_0402_BLM15AG221 | BLM15AG221SN1 | IC | 3 | L4; L5; L7 |
402 | RESISTOR_0402_1.00K | 1.00k | DISCRETE | 16 | R1; R2; R9; R84; R112; R130; R220; R221; R222; R223; R227; R228; R229; R230; R233; R234 |
402 | RESISTOR_0402_787K | 787K | DISCRETE | 1 | R3 |
402 | RESISTOR_0402_100K | 100K | DISCRETE | 3 | R4; R5; R27 |
402 | RESISTOR_0402_13.3K | 13.3K | DISCRETE | 1 | R6 |
402 | RESISTOR_0402_30.1K | 30.1K | DISCRETE | 3 | R7; R25; R68 |
402 | RESISTOR_0402_49.9 | 49.9 | DISCRETE | 13 | R8; R10; R11; R12; R105; R106; R107; R108; R145; R146; R194; R195; R196 |
402 | RESISTOR_0402_10.0K | 10.0K | DISCRETE | 36 | R14; R19; R20; R22; R29; R34; R35; R50; R53; R59; R69; R70; R71; R72; R83; R94; R95; R96; R97; R98; R101; R102; R103; R104; R111; R113; R127; R135; R136; R137; R138; R143; R164; R170; R171; R241 |
402 | RESISTOR_0402_12.7K | 12.7K | DISCRETE | 1 | R15 |
402 | RESISTOR_0402_5.1K | 5.1K | DISCRETE | 3 | R16; R57; R58 |
402 | RESISTOR_0402_2.2K | 2.2K | DISCRETE | 5 | R17; R18; R21; R144; R242 |
402 | RESISTOR_0402_78.7K | 78.7K | DISCRETE | 1 | R23 |
402 | RESISTOR_0402_845K | 845K | DISCRETE | 1 | R26 |
402 | RESISTOR_0402_56.2 | 56.2 | DISCRETE | 22 | R30; R33; R45; R47; R76; R177; R182; R191; R193; R207; R213; R219; R231; R235; R243; R244; R245; R246; R247; R248; R249; R250 |
402 | RESISTOR_0402_3.24K | 3.24K | DISCRETE | 1 | R31 |
402 | RESISTOR_0402_0 | 0 | DISCRETE | 3 | R36; R41; R163 |
402 | RESISTOR_0402_DNI | DNI | DISCRETE | 43 | R37; R40; R147; R148; R149; R150; R151; R152; R153; R154; R155; R156; R157; R158; R159; R160; R161; R162; R165; R166; R167; R168; R169; R172; R173; R174; R175; R176; R178; R179; R180; R181; R183; R184; R185; R186; R187; R188; R189; R190; R192; R197; R211 |
402 | RESISTOR_0402_20.0K | 20.0K | IC | 2 | R38; R39 |
402 | RESISTOR_0402_100, 1% | 100, 1% | DISCRETE | 7 | R42; R122; R132; R133; R206; R224; R251 |
402 | RESISTOR_0402_220 | 220 | DISCRETE | 24 | R52; R54; R55; R56; R60; R61; R62; R63; R64; R65; R66; R67; R73; R74; R75; R77; R78; R79; R109; R114; R119; R126; R129; R131 |
402 | RESISTOR_0402_6.81K | 6.81K | IC | 1 | R82 |
402 | RESISTOR_0402_0.047 | 0.047 | IC | 1 | R85 |
402 | RESISTOR_0402_1.0K | 1.0K | IC | 2 | R86; R99 |
402 | RESISTOR_0402_1.2K | 1.2K | IC | 2 | R87; R100 |
402 | RESISTOR_0402_4.7K | 4.7K | DISCRETE | 9 | R88; R89; R91; R92; R115; R116; R118; R123; R125 |
402 | RESISTOR_0402_22K | 22K | IC | 1 | R90 |
402 | RESISTOR_0402_27 | 27 | DISCRETE | 3 | R110; R120; R121 |
402 | RESISTOR_0402_4.99K | 4.99K | DISCRETE | 1 | R117 |
402 | RESISTOR_0402_470 | 470 | DISCRETE | 1 | R124 |
402 | RESISTOR_0402_1.5K | 1.5K | DISCRETE | 1 | R128 |
402 | RESISTOR_0402_56 | 56 | IC | 4 | R139; R140; R141; R142 |
402 | RESISTOR_0402_910 | 910 | IC | 2 | R198; R199 |
402 | RESISTOR_0402_10K | 10K | DISCRETE | 16 | R200; R203; R204; R205; R208; R209; R210; R212; R216; R225; R226; R232; R236; R237; R238; R239 |
402 | RESISTOR_0402_390 | 390 | IC | 2 | R201; R202 |
402 | RESISTOR_0402_2.1K | 2.1K | IC | 2 | R214; R215 |
402 | RESISTOR_0402_300 | 300 | IC | 2 | R217; R218 |
402 | RESISTOR_0402_80.6K | 80.6K | IC | 1 | R240 |
603 | CAP_0603_2.2UF | 2.2uF | DISCRETE | 2 | C9; C67 |
603 | CAP_0603_1.0UF | 1.0uF | DISCRETE | 23 | C18; C20; C23; C32; C39; C41; C53; C65; C72; C80; C261; C274; C275; C299; C306; C318; C336; C349; C355; C367; C369; C450; C478 |
603 | CAP_0603_330PF | 330pF | DISCRETE | 1 | C30 |
603 | CAP_0603_0.22UF | 0.22uF | DISCRETE | 2 | C44; C210 |
603 | CAP_0603_10UF | 10uF | IC | 2 | C78; C79 |
603 | CAP_0603_36PF | 36pF | IC | 2 | C96; C105 |
603 | CAP_0603_1UF | 1uF | DISCRETE | 2 | C150; C444 |
805 | CAP_0805_10UF | 10uF | DISCRETE | 18 | C22; C51; C128; C129; C130; C131; C149; C207; C257; C445; C459; C470; C471; C472; C473; C474; C484; C486 |
805 | CAP_0805_4.7UF | 4.7uF | DISCRETE | 9 | C45; C46; C55; C70; C71; C236; C237; C239; C388 |
1206 | CAP_1206_100UF | 100uF | DISCRETE | 19 | C14; C15; C21; C26; C27; C31; C52; C63; C152; C189; C276; C292; C328; C361; C384; C418; C419; C447; C448 |
1206 | CAP_1206_47UF | 47uF | IC | 1 | C56 |
1210 | CAP_1210_10UF | 10uF | DISCRETE | 13 | C2; C3; C4; C5; C68; C69; C93; C94; C209; C475; C476; C497; C500 |
1210 | CAP_1210_4.7UF | 4.7uF | IC | 1 | C498 |
2512 | RESISTOR_2512_100 | 100 | IC | 1 | R93 |
3216 | CAP_SMD_POL_3216_10UF | 10uF | DISCRETE | 1 | C47 |
6032P | CAP_SMD_POL_6032P_10UF | 10uF | DISCRETE | 1 | C389 |
7343P | CAP_SMD_POL_7343P_470UF | 470uF | DISCRETE | 10 | C24; C25; C33; C40; C54; C59; C60; C61; C62; C304 |
BCC96 | 88E1111_BCC96_88E1111 | 88E1111 | IC | 1 | U5 |
CAP_594D_C | CAP_SMD_POL_CAP_594D_C_22UF | 22uF | DISCRETE | 1 | C35 |
CAP_PACK_4_1206 | CAP_ARRAY_0_CAP_PACK_4_1206_0.1 | 0.1uf x 4 | DISCRETE | 19 | CN1; CN2; CN3; CN4; CN5; CN6; CN7; CN8; CN9; CN10; CN11; CN12; CN13; CN14; CN15; CN16; CN17; CN18; CN19 |
CAP_SMD_8MM | PCAP_CAP_SMD_8MM_150U | 150u | DISCRETE | 1 | C19 |
CONN_39_26_7108 | 70247-1051_CONN_39_26_7108_7024 | 70247-1051 | IO | 1 | J14 |
DDR2_60_SPEC | MT47H32M8BP_DDR2_60_SPEC_MT47H3 | MT47H32M8BP | IC | 1 | U13 |
DFM10-EPAD | LT3481_DFM10-EPAD_LT3481 | LT3481 | IC | 1 | U10 |
DIPSWITCH16 | SPST8_DIPSWITCH16_DIP_SW_8 | DIP_SW_8 | IC | 2 | SW1; SW6 |
DIPSWITCH_SMT_QUAD | SPST4_DIPSWITCH_SMT_QUAD_TDA04H | TDA04H0SB1 | IC | 1 | SW3 |
DO-214AB_RECTRON | DIODE_DO-214AB_RECTRON_FM540 | FM540 | IC | 1 | D34 |
EG2201A | SW SLIDE-DPDT_EG2201A_EG2201A | EG2201A | IC | 1 | SW2 |
F54 | K1B3216B2E_F54_K1B3216B2E | K1B3216B2E | IC | 2 | U23; U24 |
F64 | S29GLXXXN_BGA_F64_S29GL512N | S29GL512N | IC | 1 | U31 |
F256 | EPM2210GF256_F256_(S1+S2),(S3+S | EPM2210_F256FBGA | IC | 1 | U7 |
F780 | EP3C780_F780_(S1+S2+S3+S4+S5+S6 | EP3C120F780C6NES | IC | 1 | U20 |
FH12X_18S_0P5SH | FPC_FFC_18PIN_FH12X_18S_0P5SH_D | DNI | IC | 1 | J15 |
FH12X_30S_0P5SH | FPC_FFC_30PIN_FH12X_30S_0P5SH_F | FPC_FFC_30PIN | IC | 1 | J13 |
HDR2X1_2MM | 1X2_HDR2X1_2MM_HDR2X1 | HDR2X1 | IC | 1 | J12 |
HDR2X1_100MIL | CON2_HDR2X1_100MIL_CON2 | CON2 | IC | 2 | J6; J7 |
HDR2X7_100MIL | HDR2X7_HDR2X7_100MIL_HDR2X7 | HDR2X7 | IO | 1 | J4 |
HDR4X1_100MIL | 1X4_HDR4X1_100MIL_HDR4X1 | HDR4X1 | IO | 1 | J5 |
IHLP2525 | INDUCTOR_IHLP2525_0.2UH | 0.2uH | DISCRETE | 2 | L2; L6 |
IHLP2525 | INDUCTOR_IHLP2525_10UH | 10uH | DISCRETE | 1 | L3 |
IND_0805 | BEAD_FERRITE_SM_IND_0805_BLM21P | BLM21PG331SN1 | DISCRETE | 1 | L1 |
LGA118 | LTM4601_LGA118_LTM4601 | LTM4601 | IC | 1 | U1 |
LQFP-32 | FT245BL_LQFP-32_FT245BL | FT245BL | IC | 1 | U8 |
LQFP-48 | ADG726_0_LQFP-48_ADG725 | ADG725 | IC | 1 | U35 |
LQH1210 | INDUCTOR_LQH1210_10UH | 10uH | IC | 2 | L8; L9 |
LUMEX_LED1206 | LED_LUMEX_LED1206_GREEN_LED | Green_LED | IC | 29 | D1; D3; D4; D6; D7; D8; D10; D11; D12; D13; D14; D15; D16; D17; D18; D19; D20; D22; D23; D24; D25; D26; D27; D28; D29; D30; D31; D32; D33 |
LUMEX_LED1206 | LED_LUMEX_LED1206_BLUE_LED | Blue_Led | IC | 1 | D5 |
LUMEX_LED1206 | LED_LUMEX_LED1206_RED_LED | Red_LED | IC | 1 | D21 |
MICRON_DDR2_84_12X12P5 | MT47H32M16CC_MICRON_DDR2_84_12X | MT47H32M16CC | IC | 4 | U11; U12; U25; U26 |
MSOP8 | LM4990MM_MSOP8_LM4990 | LM4990 | IC | 1 | U16 |
MSOP10 | LTC1865L_MSOP10_LTC1865L | LTC1865L | IC | 1 | U32 |
PSOP-DGQ10 | TPS51100_PSOP-DGQ10_TPS51100DGQ | TPS51100DGQ | IC | 2 | U6; U27 |
PUSHBUTTON_EVQ | EVQPAC07K_PUSHBUTTON_EVQ_PBSWIT | PBSwitch | IC | 7 | S1; S2; S3; S4; S5; S6; S7 |
QFN38 | LTC3418_QFN38_LTC3418 | LTC3418 | IC | 2 | U2; U29 |
QFN56 | CY7C680_56QFN_QFN56_CY7C68013A- | CY7C68013A-56LFXC | IC | 1 | U9 |
QUAD_7SEG | QUAD_7_SEG_DSPLY_7_QUAD_7SEG_QU | QUAD_7SEG_M2212RI | IC | 2 | U28; U30 |
RAPC712 | CONN_JACK_PWR_RAPC712_RAPC712X | RAPC712X | IO | 1 | J2 |
RES_PACK_8 | RES_PACK_8_RES_PACK_8_10K | 10K | DISCRETE | 2 | RN1; RN2 |
RES_PACK_8 | RES_PACK_8_RES_PACK_8_56 | 56 | DISCRETE | 19 | RN3; RN4; RN5; RN6; RN7; RN8; RN9; RN10; RN11; RN12; RN13; RN14; RN15; RN16; RN17; RN18; RN19; RN20; RN21 |
RJ45 | HFJ11-1G02E_RJ45_HFJ11-1G02E | HFJ11-1G02E | IO | 1 | J1 |
SAMTEC_QSHDP120CUSTOM | QSH_HSM_SAMTEC_QSHDP120CUSTOM_A | ASP-122953-01 | IO | 2 | J8; J9 |
SC70-5 | FXLP34_SC70-5_FXLP34 | FXLP34 | IC | 2 | U19; U22 |
SM55-OSC | OSC_ALT_SM55-OSC_24MHZ | 24MHz | IC | 1 | Y3 |
SM55-OSC | OSC_ALT_SM55-OSC_125MHZ | 125MHz | IC | 1 | Y4 |
SM55-OSC | OSC_ALT_SM55-OSC_50MHZ | 50MHz | IC | 1 | Y5 |
SMA_LTI-SASF546-P26-X1 | SMA_SMA_LTI-SASF546-P26-X1_LTI- | LTI-SASF546-P26-X1 | IO | 2 | J10; J11 |
SMB403A_03 | ZENERDIODE_SMB403A_03_20V ZENER | 20V Zener | DISCRETE | 1 | D2 |
SMC | ZC2800E/SOT_SMC_B520C-13 | B520C-13 | IC | 1 | D9 |
SO8 | 24XX128_SO8_QUSB2CP1 | QUSB2CP1 | IC | 1 | U15 |
SO8 | AT93C46-10_SO8_AT93C46DN-SH-B | AT93C46DN-SH-B | IC | 1 | U17 |
SO8 | LT1963_SO8_LT1963A | LT1963A | IC | 2 | U21; U33 |
SO8 | TPS271_SO8_INA271 | INA271 | IC | 1 | U36 |
SOD-123 | ZENERDIODE_SOD-123_40V SCHOTTKY | 40V Schottky | IC | 1 | D35 |
SOT23-5 | LT1761_SOT23-5_LT1761 | LT1761 | IC | 2 | U14; U34 |
SOT23-5 | AD8531_SOT23-5_AD8531 | AD8531 | IC | 1 | U37 |
SOT23-5 | LT1931_SOT23-5_LT1931 | LT1931 | IC | 1 | U38 |
SOT23-DBV | SN65220DBV_SOT23-DBV_SN65220DBV | SN65220DBV | IC | 1 | U18 |
SSOP16N | TS3A5018_SSOP16N_TS3A5018 | TS3A5018 | IC | 2 | U3; U4 |
STAR_VIA | VIA_1_STAR_VIA_VIA_1 | VIA_1 | IC | 25 | V1; V2; V3; V4; V5; V6; V7; V8; V9; V10; V11; V12; V13; V14; V15; V16; V17; V18; V19; V20; V21; V22; V23; V24; V25 |
SW_ROTARY_94H | SW_ROTARY_SW_ROTARY_94H_94HCB16 | 94HCB16WT | IC | 2 | SW4; SW5 |
TP_060SQ040 | T_POINT_R_TP_060SQ040_54101-G05 | 54101-G05-01LF | IC | 6 | TP1; TP2; TP3; TP4; TP5; TP6 |
USB2_0-RA | USB_CON_USB2_0-RA_USB CON | USB CON | IO | 1 | J3 |
WSL2010 | RESISTOR_WSL2010_.003 | 0.003 | DISCRETE | 13 | R13; R24; R28; R32; R43; R44; R46; R48; R49; R51; R80; R81; R134 |
XTAL_HC49 | CRYSTAL_XTAL_HC49_24.000 MHZ | 24.000 MHZ | DISCRETE | 1 | Y1 |
XTAL_HC49 | CRYSTAL_XTAL_HC49_6.000 MHZ | 6.000 MHZ | DISCRETE | 1 | Y2 |
XTAL_PACK_D | XTAL_XTAL_PACK_D_25MHZ | 25MHz | IC | 1 | X1 |
附件:
