查看: 286|回复: 0
[allegro17.2][4层]KITFS4503CAEEVM FS4503系统基础芯片线性0.5A Vcore, FS1b, LDT...
发表于 2020-1-9 14:13 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][4层]KITFS4503CAEEVM FS4503系统基础芯片线性0.5A Vcore, FS1b, LDT, CAN(PHPT60603PY+MKL25Z128VFT4+PHPT60603PY)原理图和pcb文件
文件描述:
1. 作品用途:KITFS4503CAEEVM FS4503系统基础芯片线性0.5A Vcore, FS1b, LDT, CAN
2. 软件版本:allegro17.2
3. 层数:4层
4. 用到的主要芯片:PHPT60603PY+MKL25Z128VFT4+PHPT60603PY
5. PCB尺寸:5120*4330 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
叠层阻抗信息:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
97C04SW_DIP-4_SM_97C04_IC_1.50 MM_51SW DIP-4/SMIC3SW1; SW5; SW6
CAP_ALEL_10X10MM_SMTCAP_POL_CAP_ALEL_10X10MM_SMT_DI47uFDISCRETE1C17
CASE403A_03DIODE_SCHTKY_CASE403A_03_IC_2.4SS24T3GIC2D2; D6
CASE403A_03ZDIODE_CASE403A_03_IC_2.56 MM_41SMB5919BT3GIC1D19
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UFDISCRETE10C23; C68; C70; C75; C76; C82; C84; C85; C87; C88
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UFDISCRETE19C30; C32; C60; C61; C62; C64; C65; C67; C71; C72; C73; C74; C77; C78; C80; C81; C83; C89; C90
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.63522PFDISCRETE2C79; C86
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM680PFDISCRETE1C3
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.87M220PFDISCRETE1C4
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_1150pFDISCRETE1C7
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.965470PFDISCRETE1C8
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.8610nFDISCRETE4C9; C27; C28; C66
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.86M180PFDISCRETE1C15
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UFDISCRETE3C18; C19; C50
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.91M1000PFDISCRETE4C20; C29; C52; C69
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9 M0.22UFDISCRETE1C25
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.95M0.22uFDISCRETE1C51
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_10.47UFDISCRETE2C91; C93
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10uFDISCRETE2C1; C2
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_12.2UFDISCRETE2C21; C31
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_23.3uFDISCRETE1C24
CC1206_OVCAP_NP_CC1206_OV_DISCRETE_1.8MM4.7uFDISCRETE4C12; C16; C53; C56
CC1206_OVCAP_NP_CC1206_OV_DISCRETE_1.9MM1uFDISCRETE1C57
CC1210CAP_NP_CC1210_DISCRETE_2.7MM_1522uFDISCRETE3C5; C6; C13
CON1X2_3P81_9P2X9P01CONN_HDR_2X1_CON1X2_3P81_9P2X9PPLUG_1X2IO3J8; J23; J30
CON1X10_3P81_9P2X39P49CONN_HDR_10X1_CON1X10_3P81_9P2XPLUG_1X10IO1JP1
CON5_USB_RA_SMTUSB_MINI_AB_RECEPTACLE_CON5_USBCONN USB MINI-BIO1J33
CON_2RH_10_50CONN_HDR_5X2_CON_2RH_10_50_IO_3HDR 2X5IO1J20
FUSE_2X1P4FUSE_FUSE_2X1P4_IC_0.55 MM_510-MFU0805FF00500P100IC1F50
HALF-PITCH6SW_DIP-6_HALF-PITCH6_IC_1.50MM_SW_DIP-6_SMIC1SW3
HDR2X4CONN_HDR_4X2_HDR2X4_IO_8.71 MM_HDR_2X4IO1J24
HDR102CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR 1X2IO15J1; J3; J6; J9; J14; J15; J16; J25; J26; J27; J28; J35; J39; J40; J43
HDR103CONN_HDR_3X1_HDR103_IO_8.72MM_2HDR 1X3IO7J5; J11; J18; J21; J22; J32; J38
HDR203CONN_HDR_3X2_HDR203_IO_8.5MM_21HDR 2X3IO2J13; J31
HDR205CONN_HDR_5X2_HDR205_IO_8.6MM_21HDR 2X5IO1J36
HDR210CONN_HDR_10X2_HDR210_IO_8.71 MMHDR_10X2IO1J37
IND2_6P4_7P5SQINDUCTOR_FERRITE_A_IND2_6P4_7P51uHDISCRETE1L2
IND2_6P4_7P5SQINDUCTOR_FERRITE_A_IND2_6P4_7_12.2uHDISCRETE1L4
IND2_10P4X10P4COIL_IND2_10P4X10P4_DISCRETE_4.22UHDISCRETE1L1
IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHMDISCRETE2L5; L50
IND_1608IND_IND_1608_DISCRETE_0.75MM_18100OHMDISCRETE1L3
JUMP2X2-6040HDR-2X2_JUMP2X2-6040_IO_8.58MM_HDR 2X2IO6J2; J7; J10; J12; J29; J34
LED2_2P1X1P5_NSPLED_LED2_2P1X1P5_NSP_IC_1.4 MM_LED/GRNIC9D1; D3; D4; D5; D10; D11; D15; D17; D18
LED2_2P1X1P5_NSPLED_LED2_2P1X1P5_NSP_IC_1.4MM_3REDIC4D13; D14; D20; D21
LFPAK5_1P27_5X4PNP_4B123E5C_LFPAK5_1P27_5X4_ICPHPT60603PYIC2Q50; Q51
LQFP48_EP146MILMC33FS6522LAE_LQFP_48_A_LQFP48_MC33FS6522LAEIC1U55
PJ-102AHDC POWER JACK_PJ-102AH_IO_11MM_CON_1_PWRIO1J4
PMC_MECH_HOLEMOUNT_HOLE_PMC_MECH_HOLE_IC_0MMMTG1IC4BH1; BH2; BH3; BH4
POT3_3224WPOT_POT3_3224W_DISCRETE_5.3MM_45.0KDISCRETE1R40
QFN_48_0P5_7X7MKL25Z128VFT4_49P_QFN_48_0P5_7XMKL25Z128VFT4IC1U54
RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_410KDISCRETE7R21; R34; R59; R61; R62; R67; R68
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4733DISCRETE2R38; R41
RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_11KDISCRETE7R72; R73; R77; R78; R85; R86; R88
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_16.49KDISCRETE1R84
RC0402_25RES_RC0402_25_DISCRETE_0.45 MM_0DISCRETE1R92
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 M_11.5KDISCRETE5R2; R5; R19; R30; R31
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__1560DISCRETE4R3; R4; R35; R37
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 M_4510DISCRETE1R6
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 M_58.06KDISCRETE1R9
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_4200DISCRETE1R10
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 MM_24.9KDISCRETE2R13; R33
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_310KDISCRETE5R14; R93; R96; R99; R103
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_64.32KDISCRETE2R15; R32
RC0603_OVRES_RC0603_OV_DISCRETE_0.5 MM_45.1KDISCRETE10R16; R26; R27; R66; R74; R75; R76; R94; R95; R104
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470DISCRETE5R17; R28; R29; R106; R111
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_71.2KDISCRETE2R20; R39
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_2510KDISCRETE6R22; R23; R43; R97; R102; R110
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_8120DISCRETE1R36
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_15.6KDISCRETE3R42; R100; R101
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 M_218KDISCRETE1R56
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 M_339KDISCRETE1R57
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_943KDISCRETE2R58; R60
RC0603_OVRES_RC0603_OV_DISCRETE_0.5 MM_151KDISCRETE1R63
RC0603_OVRES_RC0603_OV_DISCRETE_0.55M_1024KDISCRETE1R64
RC0603_OVRES_RC0603_OV_DISCRETE_0.55M_1112KDISCRETE1R65
RC0603_OVRES_RC0603_OV_DISCRETE_0.55M_129.09kDISCRETE7R70; R71; R79; R80; R82; R89; R90
RC0603_OVRES_RC0603_OV_DISCRETE_0.55M_1311.0KDISCRETE1R81
RC0603_OVRES_RC0603_OV_DISCRETE_0.55M_1413.3KDISCRETE1R83
RC0603_OVRES_RC0603_OV_DISCRETE_0.55M_1510KDISCRETE1R87
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_516.2KDISCRETE1R108
RC1206_OVRES_RC1206_OV_DISCRETE_0.6MM_4715DISCRETE2R11; R12
RC1206_OVRES_RC1206_OV_DISCRETE_0.65MM_42KDISCRETE2R24; R25
RC1210RES_RC1210_DISCRETE_0.7 MM_470-0DISCRETE4R1; R8; R50; R53
RC2512RES_RC2512_DISCRETE_0.7MM_470-70DISCRETE1R105
RC2512RES_RC2512_DISCRETE_0.7 MM_470-2.4DISCRETE1R109
RC2512_DRES_RC2512_D_DISCRETE_0.65MM_4715DISCRETE2R51; R52
RC2512_ERES_RC2512_E_DISCRETE_0.65MM_4730DISCRETE2R54; R55
SO61T45_SO6_IC_0.6 MM_312-79762_SNSN74LVC1T45IC1U52
SO16_1P27_10X474HC4050_16P_SO16_1P27_10X4_IC_74HC4050DIC1U51
SOD123LFZDIODE_SOD123LF_IC_1.2MM_480-78BZT52H-B18IC2D55; D56
SOD123LFZDIODE_SOD123LF_IC_1.2MM_480-79BZT52H-C20IC1D57
SOD323DIODE_SOD323_IC_1.05MM_480-75131N4148WSIC1D12
SOD-128DIODE_SCHTKY_SOD-128_IC_1.1MM_4PMEG3030BEPIC1D7
SOD-128DIODE_SCHTKY_SOD-128_IC_1.1MM_1PMEG10030ELPIC1D8
SOD-323-AZDIODE_SOD-323-A_IC_1.1MM_480-7PDZ36BIC7D9; D16; D50; D51; D52; D53; D54
SOIC14_1P27_4X8OPAMP_QUAD_14P_SOIC14_1P27_4X8_MCP6004-I/SLIC2U50; U53
SOT23_ANMOS_NX3008NBK_SOT23_A_IC_1.1MMNX3008NBKIC2Q2; Q53
SOT23_ADIODE_2LINE_ESD_SOT23_A_IC_1.15GSOT05C-GS08IC1U1
SOT223NDT3055_SOT223_IC_1.8 MM_480-78BUK9832-55AIC1Q1
SOT-23MOSFET_P_SOT-23_IC_1.11MM_480-7BSS84LT1IC2Q3; Q4
SW3_SLD_SPDT_RASW3_SPDT_SLD_TH_SW3_SLD_SPDT_RA500SSP3S1M6QEAIC2SW2; SW4
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030IO8TP20; TP50; TP51; TP52; TP54; TP55; TP56; TP57
TP_TH_063TESTLOOP_TP_TH_063_IO_8.13MM_21TESTLOOP_BLACKIO8TP1; TP12; TP13; TP14; TP17; TP22; TP31; TP33
TP_TH_063TESTLOOP_TP_TH_063_IO_8.13MM__1TESTLOOP_REDIO7TP3; TP5; TP7; TP9; TP11; TP16; TP32
TP_TH_063TESTLOOP_TP_TH_063_IO_8.28 MM_2TESTLOOP_YELLOWIO12TP15; TP18; TP19; TP21; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP30
XTLOSC4_5X3MM_SMCRYSTAL_JXS63_XTLOSC4_5X3MM_SM_8MHZIC1Y50
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
- V# w, q$ p1 G9 \" A: E  r5 Z+ }
GMT+8, 2025-7-23 09:00 , Processed in 0.156250 second(s), 35 queries , Gzip On.
