查看: 362|回复: 0
[allegro17.2][2层]HVP-MC3PH高压开发平台HVP-MC3PH-PWB(SI8622BD-B-IS+MC000049...
发表于 2020-1-9 13:38 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][2层]HVP-MC3PH高压开发平台HVP-MC3PH-PWB(SI8622BD-B-IS+MC000049)原理图和pcb文件
文件描述:
1. 作品用途:HVP-MC3PH高压开发平台HVP-MC3PH-PWB
2. 软件版本:allegro17.2
3. 层数:2层
4. 用到的主要芯片:SI8622BD-B-IS+MC000049
5. PCB尺寸:250*100 mm
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BRIDGE_DFB20_THBRIDGE_RECTIFIER_BRIDGE_DFB20_TDFB2060IC1D6
C402_520_154_35CAP_NP_C402_520_154_35_DISCRETE2200PFDISCRETE2C19; C20
CAP_10P5_RADCAP_POL_CAP_10P5_RAD_DISCRETE_24.7uFDISCRETE1C45
CAP_METPLY_15MM_18P2X6P9CAP_NP_CAP_METPLY_15MM_18P2X6P90.68uFDISCRETE1C17
CAP_MET_PLY_18X6MMCAP_NP_CAP_MET_PLY_18X6MM_DISCR0.15UFDISCRETE1C46
CASE403D_02DIODE_CASE403D_02_IC_2.41MM_480MURA160T3GIC3D17; D18; D23
CC0805CAP_NP_CC0805_DISCRETE_1.27MM_12.2UFDISCRETE2C6; C9
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4 M47PFDISCRETE10C1; C4; C14; C15; C18; C58; C61; C65; C75; C77
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.350.1UFDISCRETE23C2; C3; C8; C10; C11; C13; C21; C22; C25; C28; C31; C34; C35; C41; C42; C43; C47; C52; C68; C69; C70; C71; C82
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.3_10.1UFDISCRETE7C5; C62; C66; C67; C72; C76; C79
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_24.7UFDISCRETE1C7
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M1.0uFDISCRETE3C12; C27; C40
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_0.88M0.01UFDISCRETE2C16; C81
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM1000PFDISCRETE11C26; C30; C33; C36; C37; C38; C39; C44; C49; C50; C51
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_110UFDISCRETE3C48; C53; C73
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UFDISCRETE3C78; C80; C84
CC1812CAP_NP_CC1812_DISCRETE_2 MM_1500.1uFDISCRETE2C59; C83
CCE8P3X8P3CAP_POL_CCE8P3X8P3_DISCRETE_10.100uFDISCRETE1C57
CCE10_3X10_3CAP_POL_CCE10_3X10_3_DISCRETE_1150uFDISCRETE1C64
CCE50X54CAP_POL_CCE50X54_DISCRETE_5.4MM47UFDISCRETE1C23
CCE50X54CAP_POL_CCE50X54_DISCRETE_5.5MM47UFDISCRETE2C24; C32
CCE50X54CAP_POL_CCE50X54_DISCRETE_5.5 M10UFDISCRETE5C54; C55; C56; C60; C74
CON3_TB_5P08_THCONN_HDR_3X1_CON3_TB_5P08_TH_IOMC000049IO2J8; J13
CONN_2X32_THRUHOLECONN_PCIEXP_64P_CUST_CONN_2X32_CONN PCI EXP 64IO1J11
CON_2_TB_5P08_THCONN_HDR_2X1_CON_2_TB_5P08_TH_IMC000048IO1J12
CON_5M_100_THCONN_HDR_5X1_CON_5M_100_TH_IO_1CON_1X5IO1J9
CON_USB_RAUSB_B_RCPT_CON_USB_RA_IO_11.50MUSB_TYPE_BIO1J4
CR1653_1220_POLCAP_POL_CR1653_1220_POL_DISCRET330uFDISCRETE2C29; C63
D2PAK_BMOSFET_N_D4_D2PAK_B_IC_4.82 MM_600V 20.2AIC1Q4
DIP_26P_39P5X23P5_SPMAA-C26_THFNB41560_26P_DIP_26P_39P5X23P5_FNB41560IC1U12
DO214AC_4P06DIODE_DO214AC_4P06_IC_2.64MM_48ES1J-LTPIC2D8; D9
DPAK_MC33269MC33269_DPAK_DPAK_MC33269_IC_2.MC33269DT-3.3GIC1U5
HDR102CONN_HDR_2X1_HDR102_IO_8.6MM_21HDR 1X2IO1J5
HSMX-C170LED_HSMX-C170_IC_0.9 MM_370-300HSMG-C170IC2D1; D20
HSMX-C170LED_HSMX-C170_IC_0.8MM_370-7578HSMY-C170IC1D2
IND12X12INDUCTOR_IND12X12_DISCRETE_8.0M1000UHDISCRETE1L4
IND_12P_45P5X42P4GA3199_12P_IND_12P_45P5X42P4_DI650uHDISCRETE2L2; L3
IND_2012INDUCTOR_IND_2012_DISCRETE_0.851uHDISCRETE1L1
JUMP1X4-6040CONN_HDR_4X1_JUMP1X4-6040_IO_8.HDR_1X4IO3J1; J2; J3
LED0805LED_LED0805_IC_1.2MM_370-76452_BLUEIC1D22
LED_2P_0805LED_LED_2P_0805_IC_0.9MM_370-76REDIC1D19
PLATED_HOLE_3_5MMMOUNT_HOLE_PLATED_HOLE_3_5MM_ICMOUNTING HOLEIC1BH1
QFN28_5X5MM_3P3_EPCP2102_QFN28_5X5MM_3P3_EP_IC_1MCP2102IC1U3
RC0805_OVRES_RC0805_OV_DISCRETE_470-754615.0KDISCRETE4R1; R20; R117; R118
RC0805_OVRES_RC0805_OV_DISCRETE_0.55MM_41.6KDISCRETE19R2; R8; R12; R16; R26; R27; R29; R30; R34; R35; R66; R68; R72; R75; R97; R103; R109; R112; R122
RC0805_OVRES_RC0805_OV_DISCRETE_0.6MM_47220DISCRETE12R3; R7; R13; R17; R67; R69; R73; R76; R98; R104; R110; R113
RC0805_OVRES_RC0805_OV_DISCRETE_470-7557470DISCRETE4R4; R5; R126; R137
RC0805_OVRES_RC0805_OV_DISCRETE_470-784282KDISCRETE4R9; R10; R11; R119
RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_424DISCRETE4R14; R24; R64; R125
RC0805_OVRES_RC0805_OV_DISCRETE_470-75_110.0KDISCRETE3R15; R80; R121
RC0805_OVRES_RC0805_OV_DISCRETE_470-75904.7KDISCRETE13R18; R22; R23; R25; R38; R42; R45; R47; R79; R86; R87; R115; R127
RC0805_OVRES_RC0805_OV_DISCRETE_470-75_2560KDISCRETE1R21
RC0805_OVRES_RC0805_OV_DISCRETE_470-75_31.0KDISCRETE2R28; R52
RC0805_OVRES_RC0805_OV_DISCRETE_470-7881120DISCRETE11R36; R39; R40; R43; R44; R46; R48; R84; R102; R124; R128
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440DISCRETE2R37; R41
RC0805_OVRES_RC0805_OV_DISCRETE_470-787722.0KDISCRETE2R49; R74
RC0805_OVRES_RC0805_OV_DISCRETE_0.55MM_17.5KDISCRETE9R65; R77; R82; R83; R85; R89; R93; R95; R114
RC0805_OVRES_RC0805_OV_DISCRETE_470-76342KDISCRETE4R70; R71; R88; R123
RC0805_OVRES_RC0805_OV_DISCRETE_470-759516.5KDISCRETE1R78
RC0805_OVRES_RC0805_OV_DISCRETE_470-796830KDISCRETE1R81
RC1206_OVRES_RC1206_OV_DISCRETE_470-8065130KDISCRETE18R31; R32; R33; R50; R53; R55; R56; R57; R58; R90; R91; R92; R99; R100; R101; R106; R107; R108
RC1206_OVRES_RC1206_OV_DISCRETE_470-78683.01KDISCRETE4R54; R96; R105; R111
RC1206_OVRES_RC1206_OV_DISCRETE_470-30061.5KDISCRETE3R59; R63; R116
RC2512_BRES_RC2512_B_DISCRETE_470-802630.05DISCRETE6R6; R19; R51; R60; R61; R62
RELAY_4P_19P8X15P8G5LA-1A4-DC12_RELAY_4P_19P8X15PG5LA-1A4 DC12IC1K1
S08_1P27_4X5MC33152D_S08_1P27_4X5_IC_1.75MMMC33152IC1U9
SHORTBAR_1206SHORTBAR1206_SHORTBAR_1206_IC_0ShortingBar1206IC1BAR1
SIP3_2P54_12X8P6_THMC78XXCT_SIP3_2P54_12X8P6_TH_ICR-78E5.0-0.5IC1U6
SMAZDIODE_SMA_IC_2.41MM_480-77778_1SMA5936BT3GIC1D16
SMC_CASE403DIODE_SMC_CASE403_IC_2.616MM_48ES3JIC1D21
SMD-8BLNK306G_SMD-8B_IC_3.98MM_312-79LNK306GIC1U7
SO8_1P27_4X5MC33502D_SO8_1P27_4X5_IC_1.75MMMC33502DGIC3U2; U8; U11
SO8_1P27_4X5FAN3224_SO_8P_SO8_1P27_4X5_IC_1FAN3224IC1U14
SO16WSI8622BD_16P_SO16W_IC_2.65MM_31SI8622BD-B-ISIC1U1
SOD123ZDIODE_SOD123_IC_1.35MM_480-780MMSZ5248ET1IC2D7; D10
SOD123DIODE_SCHTKY_SOD123_IC_1.45MM_4MBR0520LT1GIC5D14; D15; D26; D27; D28
SOD-123DIODE_SOD-123_IC_1.35MM_480-760MMSD4148T1GIC3D11; D12; D13
SOT23-3DUALDIODE_CC_SOT23_SOT23-3_IC_1BAS70-05IC1D24
SOT23-3LM4041_SOT23-3_IC_1.12MM_315-78LM4041IC1D25
SOT-23MOSFET_EN_SOT-23_IC_1.11 MM_480BSS138LT1GIC1Q3
SOT-23-5LMV7271MF_SOT-23-5_IC_1.22MM_31LMV7271MFIC2U10; U13
TESTPOINT_060_039MILT POINT TH_TESTPOINT_060_039MILTEST_POINTIC46TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP30; TP31; TP32; TP33; TP34; TP35; TP36; TP37; TP38; TP39; TP40; TP41; TP42; TP43; TP44; TP45; TP46
THERMISTOR_328_770X220_THTHERMISTOR_THERMISTOR_328_770X216 OHMDISCRETE1RT1
TO-220AB_NSPMOSFET_N3_TO-220AB_NSP_IC_19.62SIHF22N60E-E3IC2Q1; Q2
TO-220AC_VERTDIODE_TO-220AC_VERT_IC_19.07 MMVS-15ETL06PIC1D5
TO-220AC_VERT_2PDIODE_SCHTKY_TO-220AC_VERT_2P_IC3D10060AIC2D3; D4
VARISTOR_7P5_17X5P6_THVARISTOR_VARISTOR_7P5_17X5P6_THV14E275PDISCRETE1RV1
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
2 ~9 @( K; O( l. |
GMT+8, 2025-7-23 08:58 , Processed in 0.140625 second(s), 28 queries , Gzip On.
