2. 软件版本:allegro17.2
3. 层数:2层
5. PCB尺寸:异形
Bill of Material Report (Condensed) | | | | | |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 2200PF | DISCRETE | 12 | C1; C4; C8; C10; C11; C12; C14; C15; C16; C17; C19; C36 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.25M | 2.2UF | DISCRETE | 6 | C2; C5; C20; C21; C24; C35 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 0.10UF | DISCRETE | 14 | C3; C6; C7; C25; C26; C27; C28; C30; C37; C38; C39; C40; C41; C42 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 390PF | DISCRETE | 3 | C9; C13; C18 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 22 PF | DISCRETE | 2 | C22; C23 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.0_1 | 10uF | DISCRETE | 2 | C32; C33 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 22UF | DISCRETE | 2 | C29; C31 |
CON5_USB_RA_SMT | USB_MINI_AB_RECEPTACLE_CON5_USB | CONN USB MINI-B | IO | 1 | J2 |
CONN_2X32_FINGERS | CONN_PCIEXP_64P_CUST_CONN_2X32_ | PCI express x4 edge connector | IO | 1 | J4 |
DQFN14_3X2P5MM | 74LVC125_DHVQFN_14P_DQFN14_3X2P | 74LVC125 | IC | 1 | U4 |
HSMX-C170 | LED_HSMX-C170_IC_0.9 MM_370-300 | HSMG-C170 | IC | 3 | D2; D4; D8 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.05 MM_ | 330 OHM | DISCRETE | 2 | L1; L2 |
LED_2P_0805 | LED_LED_2P_0805_IC_0.9MM_370-76 | RED | IC | 1 | D1 |
LQFP100_0P5_14X14 | MKV10FN_LQFP_100P_LQFP100_0P5_1 | MKV31F512VLL12 | IC | 1 | U1 |
QFN32_S142EP | PK20DX128V_QFN_32P_QFN32_S142EP | MK20DX128VFM5 | IC | 1 | U2 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7542 | 100 | DISCRETE | 15 | R1; R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7551 | 330 | DISCRETE | 4 | R16; R24; R39; R44 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | DISCRETE | 5 | R17; R18; R22; R23; R26 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7538 | 33 | DISCRETE | 2 | R19; R20 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_1 | 4.7K | DISCRETE | 5 | R21; R25; R36; R37; R38 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-3046 | 1 | DISCRETE | 1 | R27 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7591 | 2.7K | DISCRETE | 9 | R28; R29; R31; R32; R33; R34; R35; R40; R41 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | DISCRETE | 2 | R42; R45 |
SHORTBAR_1206 | SHORTBAR1206_SHORTBAR_1206_IC_0 | ShortingBar1206 | IC | 1 | BAR1 |
SOIC16_1P27_7P6X10P5 | SI8605AD-B-IS_16P_SOIC16_1P27_7 | Si8605AD-B-IS | IC | 1 | U5 |
SOIC16_1P27_7P6X10P5 | ADUM6201_16P_SOIC16_1P27_7P6X10 | ADuM6201 | IC | 1 | U6 |
SOT23_A | DIODE_2LINE_ESD_SOT23_A_IC_1.15 | GSOT05C-GS08 | IC | 1 | U3 |
SOT223 | LD1117AS18_SOT223_IC_1.8MM_312- | NCP1117ST33T3G | IC | 1 | U7 |
SW2_SPST_3P5X6P0_5P0 | SW2P_SW2_SPST_3P5X6P0_5P0_IC_5. | EVQ-PE105K | IC | 1 | SW1 |
TESTPOINT_060_039MIL | T POINT TH_TESTPOINT_060_039MIL | TEST_POINT | IC | 17 | TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | IO | 5 | TP1; TP2; TP5; TP6; TP7 |
TP_PTH | TESTLOOP_TP_PTH_IO_0.1 MM_210-7 | TP_PTH | IO | 2 | TP3; TP4 |
XTLOSC4_5X3MM_SM | CRYSTAL_JXS63_XTLOSC4_5X3MM_SM_ | 8MHZ | IC | 1 | Y1 |
