查看: 268|回复: 0
[allegro17.2][4层]Hi-speed USB 2.0-to-ATA_ATAPI Bus-Powered Reference(CY7C68...
发表于 2020-1-8 15:14 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][4层]Hi-speed USB 2.0-to-ATA_ATAPI Bus-Powered Reference(CY7C68320-100AXC+EXT PWR+PWR SEL)原理图和pcb文件
文件描述:
1. 作品用途:Hi-speed USB 2.0-to-ATA_ATAPI Bus-Powered Reference
2. 软件版本:allegro17.2
3. 层数:4层
4. 用到的主要芯片:CY7C68320-100AXC+EXT PWR+PWR SEL
5. PCB尺寸:5000*5000 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
171826-4171826_4EXT PWRIC1J12
C-CC06030P1UFD_06030.1 uFdIC14C1; C2; C3; C4; C5; C6; C7; C8; C9; C10; C14; C15; C16; C17
C-CC060322PFD_060312 pFdIC2C11; C12
C-CC08050P33UFD_08050.33 uFdIC1C19
C-CC0805ECU-V1H103KBV0.01 uFdIC1C21
C-PCC32162P2UFD_TANT_10V2.2 uFd 10vIC1C13
C-PCC321610UFD_TANT_16V10 uFd 16vIC2C20; C22
C-PCC7343100UFD_TANT_7343100 uFd 16vIC1C18
CR-LED1206LED_GREEN1206DASP#IC1D1
CR-LED1206LED_RED1206LOW PWRIC1D3
CR-LED1206LED_GREEN1206GPIO_0IC1D4
CR-LED1206LED_GREEN1206VCC3.3 GOODIC1D5
CR-LED1206LED_GREEN1206GPIO_1IC1D6
CR-LED1206LED_GREEN1206GPIO_2IC1D7
CR-LED1206LED_GREEN1206GPIO_3IC1D8
CR-LED1206LED_GREEN1206GPIO_4IC1D9
CR-LED1206LED_GREEN1206GPIO_5IC1D10
CR-SMINI2PDIODE_MA2J111DIODE MA2J111IC1D2
FLASH50-1CM-MA2NFLASH50-1CM-MA2NCF Card Type 2IC1J1
HDR2103185_2GPIO0IC1J5
HDR2103185_2GPIO1IC1J6
HDR2103185_2GPIO2IC1J8
HDR2103185_2EEPROMIC1J9
HDR2103185_2GPIO3IC1J10
HDR2103185_2GPIO4IC1J14
HDR2103185_2GPIO5IC1J15
HDR2103185_2DMACK#_CFIC1J16
HDR2103185_2DMARQ_CFIC1J17
HDR3HDR3_GVBUSPWRDIC1J4
HDR3HDR3_G3 PIN HDRIC1J11
HDR3HDR3_GPWR SELIC1J13
HDR3X2103186-3PWR SELIC1J7
HDR_2X20_0P1_SHRDHDR40_SHRDATA CONNECTORIC1J2
MAX809MAX809J_SOT23No LoadIC1U1
R-CR06031K_06031KIC6R1; R3; R19; R40; R51; R52
R-CR0603390_0603390IC9R2; R31; R44; R47; R49; R55; R58; R61; R64
R-CR0603100K_0603100KIC1R4
R-CR060310K_060310KIC11R5; R26; R48; R50; R53; R54; R56; R60; R63; R66; R67
R-CR060382_060382IC3R6; R39; R41
R-CR060333_060333IC23R7; R8; R9; R10; R12; R13; R14; R16; R17; R18; R20; R21; R23; R24; R25; R27; R28; R29; R30; R32; R34; R35; R36
R-CR060339K_060339KIC1R11
R-CR060362K_060362KIC1R15
R-CR06030_0603zeroIC3R22; R33; R62
R-CR060322_060322IC3R42; R43; R45
R-CR06035P6K_06035.6KIC2R46; R59
R-CR0603120K_0603120KIC1R57
R-CR0805NO_LOAD_0805_RNO LOADIC2R37; R65
S-EVQ-PBC07KSW_PUSHBUTTON_THSYSIRQIC1S1
S-EVQ-PBC07KSW_PUSHBUTTON_THGPIO0IC1S2
S-EVQ-PBC07KSW_PUSHBUTTON_THGPIO1IC1S3
S-EVQ-PBC07KSW_PUSHBUTTON_THGPIO2IC1S4
S-EVQ-PBC07KSW_PUSHBUTTON_THGPIO3IC1S5
S-EVQ-PBC07KSW_PUSHBUTTON_THGPIO4IC1S6
S-EVQ-PBC07KSW_PUSHBUTTON_THGPIO5IC1S7
SO8IRF7204IRF7204IC1Q4
SO824LC02B_S0824LC02B/PIC1U3
SO8LT1763CS8-33LT1763CS8-3.3IC1U4
SOT-232N7002_SOT232N7002IC6Q1; Q2; Q3; Q5; Q6; Q7
SW_DIP43_435640_54 POS SWIC1SW1
TP-43R_STP-43R_BGNDIC6TP1; TP2; TP3; TP4; TP5; TP6
TP-43R_STP-43R_RVCC_5VIC1TP7
TP-43R_STP-43R_OVCC_3.3VIC2TP8; TP9
TQFP100CY7C68320-100AXCCY7C68320-100AXCIC1U2
USB_B_90USB_B_90USB B RAIC1J3
Y-XTAL-HC-49V24MHZ_XTAL24 MHzIC1Y1
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
% K# V2 Y' ^7 ?  \* m; Q
GMT+8, 2025-7-23 12:11 , Processed in 0.140625 second(s), 28 queries , Gzip On.
