查看: 325|回复: 1
[allegro17.2][4层]FRDM-KE15Z面向Kinetis KE1xMCU的Freedom开发平台(KE15Z+MK20D...
发表于 2020-1-7 15:06 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][4层]FRDM-KE15Z面向Kinetis KE1xmcu的Freedom开发平台(KE15Z+MK20DX128VFM5+FXOS8700CQ)原理图和pcb文件
文件描述:
1. 作品用途:FRDM-KE15Z面向Kinetis KE1xMCU的Freedom开发平台
2. 软件版本:allegro17.2
3. 层数:4层
4. 用到的主要芯片:KE15Z+MK20DX128VFM5+FXOS8700CQ
5. PCB尺寸:3200*2100 mil
! s3 z8 v5 h  R# I9 J, P- R
作品截图如下:
顶层截图:
底层截图:
全层截图:
叠层阻抗信息:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M1000pFDISCRETE1C1
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UFDISCRETE24C5; C6; C7; C8; C9; C10; C11; C15; C16; C17; C18; C23; C29; C31; C34; C35; C36; C37; C38; C40; C43; C44; C55; C56
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_10.1UFDISCRETE5C12; C13; C21; C25; C45
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UFDISCRETE1C14
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.65M4.7uFDISCRETE1C20
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.63522PFDISCRETE2C26; C30
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_22200PFDISCRETE2C61; C64
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.01610uFDISCRETE3C2; C24; C60
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM2.2uFDISCRETE2C19; C67
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UFDISCRETE3C42; C47; C49
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9 M220PFDISCRETE5C46; C48; C52; C53; C58
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.954.7uFDISCRETE1C59
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UFDISCRETE1C50
CON2X10_2P54_THCONN_HDR_10X2_CON2X10_2P54_TH_ICON_2X10IO1J2
CON_SKT2X6_THCONN_HDR_6X2_CON_SKT2X6_TH_IO_8CON 2X6 SKTIO1J4
CON_SKT2X8_THHDR_2X8_M_CON_SKT2X8_TH_IO_8.76CON 2X8IO2J1; J3
ELECTRODE_8MM_SQ_CIRELECTRODE_ELECTRODE_8MM_SQ_CIR_Electrode_8mm*8mmIC2E1; E2
HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 THIO3J7; J8; J14
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3IO2J10; J15
IND_0603INDUCTOR_FERRITE_IND_0603_DISCR1000OHMDISCRETE3L3; L4; L5
IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHMDISCRETE2L1; L2
LED4_3P4X3MM_SMTCLV1A_LED_4P_LED4_3P4X3MM_SMT_ICLV1A-FKB-CJ1M1F1BB7R4S3IC1D4
LED_0603LED_LED_0603_IC_0.9MM_370-75079REDIC1D1
LED_0603LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWIC1D2
LED_0603LED_LED_0603_IC_0.8MM_370-75077LED_GREENIC1D3
LQFP100_0P5_14X14KE15Z_LQFP100_0P5_14X14_IC_KE15KE15ZIC1U13
MICRO_USB_CONN_9PINMICRO_USB_CONN_9PIN_MICRO_USB_CZX62-AB-5PIO1J5
POWERDI-123_3MMX2MMDIODE_SCHTKY_POWERDI-123_3MMX2MDFLS130L-7IC3D5; D6; D7
QFN5X3_0P5_3X3FXOS8700CQ_QFN_16P_QFN5X3_0P5_3FXOS8700CQIC1U8
QFN8_1P6X1P6MM74LVC2T45GM_8P_QFN8_1P6X1P6MM_I74LVC2T45GM,125IC1U9
QFN32_S142EPPK20DX128V_QFN_32P_QFN32_S142EPMK20DX128VFM5IC1U7
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0KDISCRETE7R1; R29; R30; R45; R66; R69; R70
RC0402_25RES_RC0402_25_DISCRETE_0.45 MM_0DISCRETE7R8; R9; R17; R20; R33; R40; R65
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0KDISCRETE8R10; R18; R19; R21; R27; R34; R50; R51
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7KDISCRETE12R11; R13; R14; R16; R23; R31; R52; R67; R68; R71; R72; R73
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__233DISCRETE2R15; R24
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__310.0KDISCRETE3R22; R35; R48
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__41.0KDISCRETE3R25; R26; R43
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_4100DISCRETE1R36
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__51MDISCRETE1R38
RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_270DISCRETE4R39; R44; R47; R53
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_115KDISCRETE1R41
RC0402_25RES_RC0402_25_DISCRETE_0.55 MM_100DISCRETE5R54; R58; R60; R61; R62
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__610.0KDISCRETE1R55
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_2430DISCRETE1R56
RC0402_25RES_RC0402_25_DISCRETE_470-3045100DISCRETE2R63; R64
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470DISCRETE2R3; R4
RC0603_OVRES_RC0603_OV_DISCRETE_470-75774.99KDISCRETE2R49; R57
RC0603_OVTHERMISTOR_RC0603_OV_DISCRETE_410KDISCRETE1RT1
SH0603RES_SHORT-2_SH0603_DISCRETE_0.10DISCRETE1SH1
SLP1616P6RCLAMP1654P_NEW_SLP1616P6_IC_0.RClamp0854P.TCTIC1U6
SOT23-6_AMIC2005-0.8YM6_SOT23-6_A_IC_1.4MIC2005-0.8YM6IC1U11
SOT223LD1117AS18_SOT223_IC_1.8MM_312-NCP1117ST33T3GIC1U14
SW2_SPST_4X3_SMSW_SPNO_2P_SW2_SPST_4X3_SM_IC_2TL1015AF160QGIC3SW1; SW2; SW3
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8 MM_21TEST POINT WHITEIO1TP18
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030IO19TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP19; TP20
UDFN6_1P45X1_0P5MMNLX2G14_6P_UDFN6_1P45X1_0P5MM_INLX2G14IC1U10
UDFN6_1X1P5MM74LVCH1T45_6P_UDFN6_1X1P5MM_IC_74LVCH1T45IC3U3; U4; U5
XQFN8_1P45X1P25MMNTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HIC3U1; U2; U12
XTAL2-3P2X1P5-SMXTAL_XTAL2-3P2X1P5-SM_IC_0.9MM_32.768KHZIC1Y2
XTAL3_3P35X1P45_SMXTAL_CS_XTAL3_3P35X1P45_SM_IC_08.00MHZIC1X1
XTAL4_5X3CRYSTAL_JXS63_XTAL4_5X3_IC_1.1M8MHzIC1Y1
附件:
原理图和Pcb文件
游客,如果您要查看本帖隐藏内容请回复
" T, g5 i" Z. i" X
GMT+8, 2025-8-3 12:34 , Processed in 0.140625 second(s), 27 queries , Gzip On.
