Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
4P_XTAL_32K | 32_768_SMT_4P_XTAL_32K_32_768KH | | IC | 1 | DESIGNATOR1_4 |
169BGA_12X16 | INAND_0_169BGA_12X16_INAND | | IC | 1 | U12 |
A4B-5PA-2DSA | A3B-10PA-2DSA_2_A4B-5PA-2DSA_A4 | | IC | 1 | J1 |
BGA144_0D4_5X5 | S5M8751_0_BGA144_0D4_5X5_S5M876 | | IC | 1 | U9 |
C0402 | C1005_C0402_100NF_4 | 0.1 | DISCRETE | 4 | C51; C62; C65; C70 |
C0402 | C1005_100NF_C0402_100NF | 0.1 | DISCRETE | 2 | C264; C267 |
C0402_2 | C1005_C0402_100NF | 0.1 | DISCRETE | 3 | C53; C56; C69 |
C0402_2 | C1005_100NF_C0402_100NF_2 | 0.1 | DISCRETE | 3 | C265; C268; C269 |
C0402_3 | C0402_3 | 0.1 | DISCRETE | 1 | C193 |
C0402_3 | C1005_C0402_1UF | 0.1 | DISCRETE | 2 | C246; CB41 |
C0402_4 | C0402_4 | 0.1 | DISCRETE | 1 | C30 |
C0402_4 | C1005_C0402_18PF | 0.1 | DISCRETE | 2 | C386; C388 |
C0402_5 | C1005_C0402_1UF_2 | 0.1 | DISCRETE | 6 | C228; C257; C258; C375; CB42; CB43 |
C0402_6 | C1005_C0402_1UF_3 | 0.1 | DISCRETE | 18 | C12; C16; C224; C227; C231; C236; C238; C240; C242; C245; C250; C254; C374; C378; C384; C385; C387; C389 |
C0402_7 | C1005_C0402_0_1UF | 0.1 | DISCRETE | 1 | C373 |
C0402_8 | C1005_C0402_100NF_2 | 0.1 | DISCRETE | 2 | C66; C115 |
C0402_9 | C1005_C0402_1UF_4 | 0.1 | DISCRETE | 1 | CB40 |
C0402_10 | C1005_C0402_100NF_3 | 0.1 | DISCRETE | 2 | C48; C100 |
C0402_11 | C1005_C0402_10NF | 0.1 | DISCRETE | 2 | C64; C67 |
C0402_12 | C0402_12 | 0.1 | DISCRETE | 1 | C39 |
C0402_13 | C1005_C0402_10NF_2 | 0.1 | DISCRETE | 1 | C108 |
C0402_14 | C1005_C0402_100NF_5 | 0.1 | DISCRETE | 7 | C4; C19; C63; C68; C95; C106; C109 |
C0402_15 | C1005_C0402_100NF_6 | 0.1 | DISCRETE | 7 | C8; C43; C44; C46; C49; C103; C104 |
C0402_16 | C1005_C0402_1UF_5 | 0.1 | DISCRETE | 2 | C54; C59 |
C0402_17 | C1005_C0402_10NF_3 | 0.1 | DISCRETE | 7 | C35; C50; C61; C101; C117; C127; C132 |
C0402_18 | C1005_C0402_100NF_7 | 0.1 | DISCRETE | 3 | C58; C105; C110 |
C0402_19 | C1005_C0402_100NF_8 | 0.1 | DISCRETE | 9 | C3; C33; C47; C52; C55; C60; C107; C125; C130 |
C0402_20 | C1005_C0402_10NF_4 | 0.1 | DISCRETE | 2 | C57; C98 |
C0402_21 | C1005_C0402_10NF_5 | 0.1 | DISCRETE | 1 | C21 |
C0402_22 | C1005_C0402_2NF | 0.1 | DISCRETE | 1 | C5 |
C0402_23 | C1005_C0402_10NF_6 | 0.1 | DISCRETE | 2 | C10; C45 |
C0603 | C1608_C0603_10UF_C0603 | 0.1 | DISCRETE | 1 | C17 |
C0603_2 | C1005_C0603_22UF | 0.1 | DISCRETE | 1 | C225 |
C0603_3 | C1608_C0603_10UF_0603 | 0.1 | DISCRETE | 1 | C124 |
C0603_3 | C1005_C0603_10UF_0603 | 0.1 | DISCRETE | 2 | C393; C405 |
C0603_4 | C1608_C0603_10UF_C0603_2 | 0.1 | DISCRETE | 1 | C6 |
C0603_5 | C1005_C0603_10UF_604 | 0.1 | DISCRETE | 5 | C237; C256; C391; C395; C398 |
C0603_6 | C1005_100NF_C0603_10UF_C0603 | 0.1 | DISCRETE | 2 | C263; C266 |
C0603_7 | C1005_C0603_10UF_605 | 0.1 | DISCRETE | 5 | C226; C230; C232; C394; C400 |
C0603_8 | C1608_C0603_10UF_604 | 0.1 | DISCRETE | 2 | C94; C99 |
C0603_8 | C1005_C0603_10UF_606 | 0.1 | DISCRETE | 4 | C235; C241; C382; C397 |
C0603_9 | C1005_C0603_22UF_2 | 0.1 | DISCRETE | 2 | C229; C255 |
C0603_10 | C1608_C0603_10UF | 0.1 | DISCRETE | 1 | C142 |
C0603_11 | C1608_C0603_10UF_C0603_3 | 0.1 | DISCRETE | 1 | C271 |
C0603_12 | C1608_C0603_10UF_605 | 0.1 | DISCRETE | 1 | C114 |
C0603_13 | C1608_C0603_10UF_C0603_4 | 0.1 | DISCRETE | 2 | C7; C41 |
C0603_14 | C1608_C0603_10UF_C0603_5 | 0.1 | DISCRETE | 1 | C31 |
FMARKS | HOLE_3_FMARKS_FMARK | | IC | 3 | DESIGNATOR1_6; DESIGNATOR1_7; DESIGNATOR1_8 |
FMARKS_2 | HOLE_3_FMARKS_FMARK_2 | | IC | 4 | DESIGNATOR1_21; DESIGNATOR1_22; DESIGNATOR1_23; DESIGNATOR1_24 |
FPAD_1 | FPAD_1 | | IC | 7 | _4; _5; _6; _7; _8; _9; _10 |
FPAD_2 | FPAD_2 | | IC | 190 | _11; _12; _13; _14; _15; _16; _17; _18; _19; _20; _21; _22; _23; _24; _25; _26; _27; _28; _29; _30; _31; _32; _33; _34; _35; _36; _37; _38; _39; _40; _41; _42; _43; _44; _45; _46; _47; _48; _49; _50; _51; _52; _53; _54; _55; _56; _57; _58; _59; _60; _61; _62; _63; _64; _65; _66; _67; _68; _69; _70; _71; _72; _73; _74; _75; _76; _77; _78; _79; _80; _81; _82; _83; _84; _85; _86; _87; _88; _89; _90; _91; _92; _93; _94; _95; _96; _97; _98; _99; _100; _101; _102; _103; _104; _105; _106; _107; _108; _109; _110; _111; _112; _113; _114; _115; _116; _117; _118; _119; _120; _121; _122; _123; _124; _125; _126; _127; _128; _129; _130; _131; _132; _133; _134; _135; _136; _137; _138; _139; _140; _141; _142; _143; _144; _145; _146; _147; _148; _149; _150; _151; _152; _153; _154; _155; _156; _157; _158; _159; _160; _161; _162; _163; _164; _165; _166; _167; _168; _169; _170; _171; _172; _173; _174; _175; _176; _177; _178; _179; _180; _181; _182; _183; _184; _185; _186; _187; _188; _189; _190; _191; _192; _193; _194; _195; _196; _197; _198; _199; _200 |
IND2520 | LQH32C_0_IND2520_LQM2HPN1R0MG0 | 0.1 | DISCRETE | 2 | L23; L24 |
IND2520_2 | LQH32C_0_IND2520_LQM2HPN1R0MG0_2 | 0.1 | DISCRETE | 3 | L10; L11; L12 |
KIC-6508-015STP | HOLE_0_KIC-6508-015STP_SHIELD | | IC | 4 | DESIGNATOR1_9; DESIGNATOR1_10; DESIGNATOR1_11; DESIGNATOR1_12 |
KIC-6508-015STP_2 | HOLE_0_KIC-6508-015STP_SHIELD_2 | | IC | 6 | DESIGNATOR1_13; DESIGNATOR1_14; DESIGNATOR1_15; DESIGNATOR1_16; DESIGNATOR1_17; DESIGNATOR1_19 |
KIC-6508-015STP_3 | HOLE_0_KIC-6508-015STP_SHIELD_3 | | IC | 2 | DESIGNATOR1_18; DESIGNATOR1_20 |
LQM2HPN1ROMG0_2 | LQH32C_0_LQM2HPN1ROMG0_LQM2MPN1_2 | 0.1 | DISCRETE | 1 | L25 |
LQM2HPN1ROMG0_3 | LQH32C_0_LQM2HPN1ROMG0_LQM2MPN1_3 | 0.1 | DISCRETE | 3 | L8; L26; L28 |
LQM2HPN1ROMG0_4 | LQH32C_0_LQM2HPN1ROMG0_LQM2MPN1_4 | 0.1 | DISCRETE | 1 | L27 |
LQM2HPN1ROMG0 | LQH32C_0_LQM2HPN1ROMG0_LQM2MPN1 | 0.1 | DISCRETE | 1 | L29 |
MICROSD_16P | EZ_SDB-8LFYGA_10_MICROSD_16P_EZ | | IC | 1 | CON11 |
R0402 | R1005_0_R0402_0 | 0.1 | DISCRETE | 6 | R18; R28; R30; R187; R314; R580 |
R0402_2 | R1005_0_R0402_100K | 0.1 | DISCRETE | 3 | R6; R8; R309 |
R0402_2 | R_R0402_100K | 0.1 | DISCRETE | 1 | R16 |
R0402_3 | R1005_0_R0402_10K | 0.1 | DISCRETE | 5 | R10; R56; R75; R310; R311 |
R0402_4 | R1005_0_R0402_0_2 | 0.1 | DISCRETE | 3 | R131; R132; R581 |
R0402_5 | R1005_0_R0402_200K | 0.1 | DISCRETE | 2 | R85; R99 |
R0402_5 | R_R0402_200K | 0.1 | DISCRETE | 1 | R106 |
R0402_6 | R_R0402_51K | 0.1 | DISCRETE | 6 | R176; R177; R179; R181; R184; R0402 |
R0402_7 | R1005_0_R0402_10K_2 | 0.1 | DISCRETE | 3 | R55; R191; R312 |
R0402_8 | R_R0402_10K | 0.1 | DISCRETE | 1 | R185 |
R0402_9 | R_R0402_51K_2 | 0.1 | DISCRETE | 2 | R178; R183 |
R0402_10 | R1005_0_R0402_44_2_1_ | 0.1 | DISCRETE | 1 | R9 |
R0402_11 | R1005_0_R0402_100K_2 | 0.1 | DISCRETE | 2 | R2; R5 |
R0402_12 | R1005_0_R0402_10K_3 | 0.1 | DISCRETE | 2 | R315; R317 |
R0402_13 | R1005_0_R0402_12K_1_ | 0.1 | DISCRETE | 1 | R316 |
R0402_14 | R1005_0_R0402_0_3 | 0.1 | DISCRETE | 4 | R204; R205; R206; R318 |
R0402_15 | R1005_0_R0402_100K_3 | 0.1 | DISCRETE | 1 | R313 |
R0402_16 | R1005_0_R0402_510K | 0.1 | DISCRETE | 2 | R101; R122 |
R0402_17 | R1005_0_R0402_0_4 | 0.1 | DISCRETE | 1 | R133 |
R0402_18 | R1005_0_R0402_51K | 0.1 | DISCRETE | 1 | R100 |
R0402_19 | R_R0402_240 | 0.1 | DISCRETE | 1 | R24 |
R0402_20 | R1005_0_R0402_51K_2 | 0.1 | DISCRETE | 4 | R189; R190; R197; R198 |
R0402_21 | R1005_0_R0402_10K_4 | 0.1 | DISCRETE | 2 | R188; R192 |
R0402_22 | R_R0402_240_2 | 0.1 | DISCRETE | 2 | R20; R22 |
R0402_23 | R1005_0_R0402_1K | 0.1 | DISCRETE | 4 | R11; R12; R13; R14 |
R0402_24 | C1005_R0402_3_3NF | 0.1 | DISCRETE | 1 | C2 |
R0402_25 | C1005_R0402_3_3NF_2 | 0.1 | DISCRETE | 1 | C1 |
R0402_26 | R1005_0_R0402_5M | 0.1 | DISCRETE | 1 | R510 |
R0402_27 | R1005_0_R0402_100 | 0.1 | DISCRETE | 1 | R509 |
R0402_28 | R1005_0_R0402_4_7K_1_ | 0.1 | DISCRETE | 1 | R27 |
R0402_29 | R_R0402_240_3 | 0.1 | DISCRETE | 1 | R23 |
R0402_30 | R1005_0_R0402_0_5 | 0.1 | DISCRETE | 6 | R582; R583; R584; R585; R586; R587 |
R0402_31 | R_R0402_20K_1_ | 0.1 | DISCRETE | 2 | R19; R26 |
R0402_32 | R_R0402_20K_1__2 | 0.1 | DISCRETE | 2 | R21; R25 |
R0603 | R1005_0_R0603_0 | 0.1 | DISCRETE | 1 | R308 |
R0603_2 | R1005_0_R0603_0_2 | 0.1 | DISCRETE | 1 | R573 |
S5PC220_080-0804B0400-99 | S5PC220_40_S5PC220_080-0804B040 | | IC | 1 | U1 |
SOD323 | SOD323 | 0.1 | DISCRETE | 1 | DESIGNATOR1 |
TP0_8-SMD | TP_P0_0_8_D0_TP0_8-SMD_TP | | IC | 4 | TP10; TP11; TP12; TP13 |
TP0_8-SMD_2 | TP_P0_0_8_D0_TP0_8-SMD_TP_2 | | IC | 8 | TP1; TP3; TP4; TP5; TP6; TP7; TP8; TP14 |
TP0_8-SMD_3 | TP_P0_0_8_D0_TP0_8-SMD_TP_3 | | IC | 1 | DESIGNATOR1_5 |
TP0_8-SMD_4 | TP_P0_0_8_D0_TP0_8-SMD_TP_4 | | IC | 1 | TP9 |
WLCS25 | SN74AVCA164245DGG_1_WLCS25_USB3 | | IC | 1 | U29 |
XS4_3225_0D8 | 32_768_SMT_XS4_3225_0D8_24MHZ | | IC | 1 | DESIGNATOR1_2 |
XS4_3225_0D8_2 | TCXO_0_XS4_3225_0D8_12MHZ | | IC | 1 | DESIGNATOR1_3 |
