作品名:[AD 10][2层]便携式充电桩核心板(FM24CL04B+SD2405ALPI+XC2267)原理图和PCB源文件
/ s$ e1 U* `* k! T9 v" I/ ^: v# W. w4 }: }3 D4 L9 V# e6 D9 d
文件描述+ @ w2 m: G+ x" A& o4 a
6 ~3 ~; e& {: |$ Y% Z% X y1. 作品用途:便携式充电桩核心板0 Y. R+ X3 L% V' C }/ O3 Q0 ~
+ c/ d J" g' m- g0 u
2. 软件版本:AD 10+ _2 A0 f* e, u# e) b& t: V
! b0 t% ~' d) o3. 层数:2层板# e+ z( c/ U R o
* u4 M& W0 {; P4 M9 s; z/ o
4. 用到的主要芯片:FM24CL04B+SD2405ALPI+XC2267
# d: d; ~0 N e2 V4 w
+ |" D. V c/ l5. PCB尺寸:75mm*50mm
- W8 r# l. \ i( P' {: G
7 B4 M( q1 p" J0 r/ ~
: q2 F( ^1 S$ G$ Q. S O作品截图如下:+ I3 ?; q& p4 _. D2 I
6 s- {6 c5 i3 A/ q, f7 f3 {
顶层截图:
9 g: R% S& `" L" M. u1 x. u
) g. F5 K7 {6 L& {! ]
+ L+ v; i* M, T- L1 O- E: @底层截图:) y* x. Z3 S; r. y$ [
, w4 m/ G% N$ H1 ^
2 G7 e$ i% F8 B$ }# c% x; R: H全层截图:, q7 v" Q% q1 S: V, L
/ b8 s/ v% `' c+ u4 ?8 A6 ]* o; s+ e5 K8 q/ U: S1 h1 Y: f- C0 n2 A& t1 Q0 w6 O
叠层信息截图如下:+ f: U7 O4 { G3 n3 p" R
- z; M3 V4 X1 I
: ^. L1 a B, q) x/ g& t; T
BOM:
- {, [$ v. H& \% b L- H# }Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 104 | C1, C2, C3, C4, C5, C6, C7, C8, C9, C10, C11, C12, C13, C14, C15, C16, C19, C20, C26, C27, C28, C30, C32, C34, C36, C39, C41, C42 | C0805 | 28 | 20p | C17, C18 | c0805 | 2 | 47uF | C21, C22, C23 | 钽电容 | 3 | 22pF | C24, C25 | c0805 | 2 | 0.22 | C29, C31, C33 | c0805 | 3 | 1u | C35 | c0805 | 1 | 1uF | C37 | c0805 | 1 | 100pF | C38 | c0805 | 1 | 10uF | C40 | 小钽电容 | 1 | LED2 | D1 | LED | 1 | D Zener | D2 | 稳压管 | 1 | 4148 | D3 | 二极管 | 1 | Header 8 | J1 | HDR1X8 | 1 | HEADER 17X2 | J2 | IDC34-1 | 1 | speaker | J3 | SIP2 | 1 | LCD | J4 | SIP10 | 1 | RES2 | J30 | SIP4-A | 1 | | JP1 | SIP2 | 1 | SW-PB | K1 | sw | 1 | LED0 | LED1 | LED | 1 | Comment | M1 | MARK-D | 1 | 2N3904 | Q1 | NPN | 1 | 5.1K | R1, R2, R3, R4, R8, R17 | R0805 | 6 | 1k | R5, R7, R11, R13, R14 | R0805 | 5 | 10k | R6, R9, R15, R18, R19, R20, R21, R23, R25, R26, R29, R30, R31, R34, R35, R36, R37, R38, R39, R40, R41, R42 | R0805 | 22 | 100k | R10 | R0805 | 1 | 100 | R12, R28 | R0805 | 2 | 0 | R22, R24 | R0805 | 2 | 9013 | T1 | NPN | 1 | XC2267 | U1 | LQFP100 | 1 | SYN6288 | U2 | SSOP28 | 1 | 温湿度传感器 | U3 | 温湿度传感器 | 1 | OCDS | U4 | OCDS-1 | 1 | 45DB161 | U5 | TSOP28 | 1 | SP706TEN | U6 | SO-8 | 1 | SD2405ALPI | U7 | DIP-16 | 1 | FM24CL04B | U8 | SO-8 | 1 | XTAL | X1 | XTAL | 1 | 16M | Y1 | XTAL | 1 |
" \! E7 V: h7 R1 G! o附件:# [4 \! m" @. E( n3 t
原理图和PCB源文件如下:
& g1 X9 G+ s' h6 G. b6 N$ e( m. s- _2 D( W
' F+ L$ t% z6 F& D
3 r( O" _0 x5 ~$ F0 S7 |! U8 U1 E! ~2 r+ O5 @
9 y! Z3 M7 r1 v- K2 d
0 N- l* n$ q c& @1 O/ }& T |
