查看: 417|回复: 1
[AD 10][6层] i.max6底板开发板(TPS74801DRCR+TSC2007IPWR+MAX9867ETJ+)PCB源文件
发表于 2020-1-2 13:48 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名:[AD 10][6层] i.max6底板开发板(TPS74801DRCR+TSC2007IPWR+MAX9867ETJ+)PCB源文件
3 D  G4 v5 e; \* @6 ?6 x
' G( q4 P2 b" o& u文件描述
# X' B- G# Q0 l) q1. 作品用途:i.max6底板开发板
- p; K8 A3 |4 [9 C2. 软件版本:AD 10
7 l* @& c/ r5 v8 w+ Q3. 层数:6层板- B" O" P0 \' ^
4. 用到的主要芯片:TPS74801DRCR+TSC2007IPWR+MAX9867ETJ+
4 H  O8 U  p! S+ z3 D/ b5. PCB尺寸:136mm*111mm% ^3 T- V2 f: F3 w4 V
6 e) k1 y! N" v1 S- `
作品截图如下:
" {0 V! H& ?: o) i. S顶层截图:6 @$ L* Q) U- Q. U( C
: z! t( f) V/ y9 [% ^
底层截图:
( \7 u* k! T. O' g) v/ X/ g , y1 t- w& R$ s# L% c, t6 B
全层截图:/ M0 L5 \2 [% r( j5 V
' A3 W9 y2 W5 b
叠层信息截图如下:
2 S5 K- f, j4 v) @" z' k" U, J: f
0 d" i) Z5 X2 K2 {BOM:7 E  M' B) b  D9 }' }
Comment(属性)Designator(位号)Footprint(封装)Quantity(数量)
100nC1, C3, C6, C8, C9, C10, C14, C17, C22, C23, C27, C28, C29, C30, C31, C57, C69, C71, C72, C73, C74, C75, C77, C78, C80, C83, C84, C86, C88, C89, C90, C93, C94, C97, C98, C101, C103, C106, C108, C109, C110, C111, C112, C114, C115, C116, C117, C118, C120, C121, C127, C128, C129, C140, C148, C151, C152, C153, C154, C155, C156, C157, C158, C163, C166, C167, C170, C171, C173, C175, C176, C178, C180, C186, C187, C195, C198, C199, C200, C201, C202, C203, C204, C205, C206, C207, C213, C214, C216, C218C0402
90
10uFC2, C7, C82, C184, C185, C196, C197, C208C1206
8
1uC4, C18, C33, C37, C38, C39, C41, C42, C44, C45, C46, C48, C50, C51, C53, C58, C59, C60, C61, C63, C64, C65, C66, C68, C81, C95, C105, C107, C113, C130, C131, C136, C138, C147, C159, C161, C162, C168, C169, C181, C182, C209, C211C0402
43
22uC5, C11, C79, C177C0805
330uC12, C13, C24, C25, C40, C70, C85, C87, C91, C92, C96C2917
11
4u7C15, C16, C19, C26, C32, C34, C102, C104, C141, C142, C210, C212, C215, C217C0402
14
10uC20, C35, C43, C76, C126, C150, C172, C174, C179C0603
9
2700pFC21, C36, C132, C133, C143, C144C0402
470nFC47, C52, C55, C56, C67C0402
10nC49, C194C0402
270pFC54, C122, C123, C134, C135, C145, C146, C149C0402
8
2u2C62C0402
18pC99, C100C0402
1000pF, 2kVC119C1206
100pFC124, C125C0402
220u, 4VC137, C139C1206 -  TLN S Case Tantal
220nC160C0402
4x 220pFC164, C1654X_CAP_CC0805_CKCL44
1uFC183C0805
100μFC188, C189, C190, C191, C192, C193C1206
7E50-C016-00CFAST1CFAST_LOCKER
GreenD1, D2, D3, D6LED_0603
BZA956A,115D4, D5SOT665
BAT54HT1GD7, D21, D22SOD323
BGX50AE6327D8, D9, D10, D11, D13SOT143
RedD12, D14LED_0603
BAT54C-7-FD15SOT-23-3-123
B560C-13-FD16, D17, D20SMC
553-0121FD18553-0121F
PGB1010603MRD19C0603
220R, 2.5AFB1, FB2, FB3, FB4, FB22C0603
BLM15AX601SN1DFB5, FB8, FB9, FB14, FB15, FB16, FB17, FB18, FB24C0402
9
MPZ1608S601A 600OHM/1AFB6, FB7, FB10, FB11, FB12, FB13, FB19, FB23, FB25, FB26C0603
10
4x 220RFB20, FB214X0402_BLA2A_MURATA
QTH-030-01-L-D-AJ1, J2QTH-030-01-L-D-A
10018783-10010TLFJ3MINI_PCIE_36PIN
MM60-52B1-E1-R650J4, J9MINI_PCIE_52PIN_CARD_CON
0475531001J5, J7SIM_CARD_PUSH
MM60-EZH059-B5-R650J6, J8MINI_PCIE_52PIN_CARD_LATCH
76384-302LFJ10, J11, J12HDR_1X2_2.54MM_SHDR
76384-303LFJ13HDR_1X3_2.54MM_SHDR_V2
0471554001J14SATA_VERTICAL
N7G24-A0B2RB-10-0HTJ15CFAST10
47151-0001J16HDMI
HDR 1x3J17, J18HDR_1X3_2.54MM
HDR 2X3, BOXEDJ19HDR_2X3_2.54MM_BOXED
76384-304LFJ20, J23HDR_1X4_2.54MM_SHDR
USB MICRO ABJ21USB_MICRO_AB
5787617-1J22USB-2A
2-406549-1J24RJ45LED
SJ1-3535NGJ25SJ1-3535NG
SJ1-3535NG-BEJ26SJ1-3535NG
SJ1-3535NG-GRJ27SJ1-3535NG
SJ1-3535NG-PIJ28SJ1-3535NG
DM3AT-SF-PEJM5J29USD_DM3AT
1734351-1J30DBA9_M_RA
HDR 2x5, BOXEDJ31, J34HDR_2X5_2.54MM_BOXED
BA2032J32BA2032
HDR 2x7, BOXEDJ33HDR_2X7_2.54MM_BOXED
Hdr 4x2mm BOXEDJ35HDR_1X4_2MM_SHDR
5103308-5J36HDR_2x10_2.54mm_BOXED
PJ-002AHJ37POWER_JACK_5.5_2.1MM_NS
0015244449J38015244449
DM3C-SFJ39USD_DM3CS
0532610471J400532610471
FI-SE20P-HFEJ41FI-SE20P-HFE
HDR 1x2JP1, JP2, JP3HDR_1X2_2.54MM
ACM2012-900-2P-T002L1, L2, L3, L4, L5, L6, L7ACM2012
4μ7L8, L9IHLP_255MILX270MIL
2N7002BKW,115Q1, Q4, Q5, Q6, Q7, Q8, Q9SC70_SOT323
SI4816BDY-T1-GE3Q2, Q38_SOIC_3.9MM
0RR1, R2, R3, R4, R5, R6, R7, R8, R9, R10, R11, R12, R13, R14, R16, R24, R32, R34, R36, R37, R38, R39, R40, R41, R42, R43, R46, R56, R62, R63, R64, R65, R66, R67, R68, R69, R88, R89, R104, R105, R106, R112, R113, R120, R123, R124, R128, R129, R130, R133, R137, R138, R143, R153, R155, R156, R159, R162, R163, R164, R169, R170, R173, R174, R184R0402
65
10kR15, R31, R33, R35, R51, R52, R53, R54, R55, R70, R71, R72, R73, R108, R109, R111, R114, R115, R116, R117, R118, R121, R122, R134, R135, R136, R139, R140, R147, R150, R151, R152, R154, R157, R158, R165, R166, R167, R168, R172, R183, R187R0402
42
200kR17, R131, R132, R175, R176, R177, R178, R179, R180, R181, R182R0402
11
2k1R18R0402
330RR19, R21, R22, R25, R107R0402
2k4R20, R27R0402
1MR23R0402
3kR26R0402
2k2R28, R29, R30, R102R0402
100kR44, R74, R75, R76, R77, R79, R80, R82, R83, R96, R97, R171, R185, R186R0402
14
1kR45, R59, R78, R110R0402
15kR47, R90, R91R0402
4k99R48, R49, R57, R160, R161R0402
27kR50R0402
365RR58R0402
1k8R60R0402
3k3R61R0402
12kR81R0402
75RR84, R85, R86, R87R0402
33RR92, R93, R141, R142, R149R0402
100RR94, R95, R119R0402
562R98, R99R0402
47k5R100, R101R0402
10RR125R0402
1RR126, R127R0402
240RR144, R145, R146, R148R0402
FSMRA2JHSW1FSMRA2JH
FSMRA3JHSW2, SW3FSMRA3JH
H5007NLT1H5007NL
TPS74801DRCRU1, U3DRC (S-PVSON-N10)
TSC2007IPWRU2PW (R-PDGO-G16)
TPA6041A4RHBRU4VQFN32 5X5X0.85
MAX9867ETJ+U5QFN32 5X5X0.85
PCA9306DCTRU6DCT_8
CM2020-00TRU7TSSOP_38
SN74AHC1G09DBVRU8, U23DBV_SOT_23_5
TPS2034DU98_SOIC_3.9MM
LM358AMXU108_SOIC_3.9MM
MIC2026-1YM TRU11, U128_SOIC_3.9MM
USB2514BI-AEZGU13QFN36_6MMX6MM
SGTL5000XNAA3R2U14QFN32 5X5X0.85
TLV803SDBZRU15DBZ
ISL4245EIRZU16QFN32 5X5X0.85
PCF8563TU178_SOIC_3.9MM
BR24L02FVM-WTRU18MSOP8 _SMALLER
PCA9535BSU19HVQFN24_4X4MM
SN74LVC1G08DCKRU20, U21, U24SC70_5
ISL6236AIRZU2232_VFQFN_EXPOSED_PAD
12.288MHzY1ASFLMB
24MHzY2ABM7_V1_1
32.768kHzY3ABS06
附件:! |9 G# E3 b" l7 n
PCB源文件如下:1 Y! B% }& B3 F' [+ ?. O
游客,如果您要查看本帖隐藏内容请回复
0 i# X4 B% I1 D4 o
0 Y) J1 G9 F) D
发表于 2021-7-22 23:25 | 只看该作者
学习一下
“来自电巢APP”
GMT+8, 2025-7-31 15:01 , Processed in 0.156250 second(s), 29 queries , Gzip On.
