作品名:[AD 10][2层] 控制板 (FT2232HQ+MSP430F5438+MAX3223)PCB源文件/ y& g# J3 Z) j7 Q* D7 t
m' ~+ V3 f3 }2 K5 J0 R/ O5 c% Q文件描述6 }- [+ q3 D$ w+ t0 [; ]
1. 作品用途:控制板
4 g7 M4 P) p3 x3 Q) a6 }1 W2 t# n2. 软件版本:AD 10
. B7 g' _7 u$ m3. 层数:4层板
$ t7 M+ |. E+ c4 T- G& t4. 用到的主要芯片:FT2232HQ+MSP430F5438+MAX32233 l0 h* ~# Y" F5 p; v1 U' l
5. PCB尺寸:167mm*151mm
* w0 e& K' `0 j! l9 ~1 v( Q( Y! I! M9 u P2 E7 ~
作品截图如下:
1 s& \* b! N, J6 m1 _) B9 m, i顶层截图:* `9 W) f7 l' x7 L, B9 A( v
0 x6 O* m; G; a
底层截图:
" x8 X! }! g, N( D( F7 l
- R. Y' S: V* U2 j0 C6 v
全层截图:/ d- G" |7 u1 W" ]! Q z7 R
' u5 k+ k7 g/ w- q0 n$ G5 a叠层信息截图如下:7 i2 q2 u1 W- |* V: E$ ^; Q
) W% j e& r3 p; Z7 y' kBOM:7 b. N2 w: I5 S* G$ t( p- Y
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 2.2uF | C1, C2 | SMD_0805 | 2 | 100uF | C3, C38 | SMD_1206 | 2 | 0.1uF | C4, C8, C28, C59, C62, C63, C64, C65, C66, C67, C68, C69, C70, C71, C72, C73, C74, C75, C76, C77, C78, C79, C80, C81, C82, C83, C84, C85, C86, C87, C88, C89, C90, C91, C92, C93, C94, C95, C96, C97, C98, C99, C100, C101, C102, C103, C104, C105, C106, C107, C108, C109, C110, C111, C112, C113, C114, C115, C116, C117, C118, C119, C120, C121, C122, C123, C124, C125, C126, C127, C128, C129, C130, C131, C132, C133, C134, C135, C136, C137, C138, C139, C140, C141, C142, C143, C144, C145, C146, C147, C148, C149, C150, C151, C152, C153, C154, C155, C156, C157, C158, C159, C160 | SMD_0603 | 103 | 0.1uF | C5, C11, C12, C13, C14, C17, C22, C32, C33, C40, C43, C45, C46, C47, C48, C49, C50, C51, C52, C53, C54, C55, C58, C61 | SM/C_0603 | 24 | 100uF | C6, C19, C29 | SMD_7343 | 3 | 220uF | C7, C9 | SMD_1206 | 2 | 0.01uF | C10, C31 | SM/C_0603 | 2 | 18pF | C15, C16, C35, C36 | SM/C_0603 | 4 | 220uF | C18 | SMD_7343 | 1 | | C20 | SMT CAP 0603 | 1 | 10uF | C21, C37 | CAP 1206 | 2 | 10uF | C27, C30 | SMD_0805 | 2 | 4.7uF | C34, C41, C42, C44 | CAP 1206 | 4 | 100uF | C39 | SM/CT_6032 | 1 | 470uF | C56 | SM/CT_7343_REV1 | 1 | 3.3 Zener | D2, D4, D6, D7 | SMD Zener Diode - 0603 | 4 | 1N914 | D3, D8 | SMD_0805 | 2 | USB Act | D5 | LED RT | 1 | 600R/0.5A | FB1, FB2, FB3 | SM/C_0603 | 3 | JTAG | J1 | 2X7 2.54mm SMD Header | 1 | MMCX | J2, J8 | MMCX | 2 | MMCX | J3, J4, J11, J15 | RF/MMCX/V | 4 | Hygrometer | J5 | HFW8S-2STE1LF | 1 | Header 20X2 | J6 | 3M5330-ND | 1 | MODULE A | J7 | 3M5330-ND | 1 | Digital I/O | J9 | DF1B-8DP-2.5DSA | 1 | Header 4X2 | J10 | 3M5305-ND | 1 | CONN DSUB 15-P | J12 | DSUB 15 RIGHT ANGLE MALE | 1 | MODULE B | J13 | 3M5330-ND | 1 | FAN | J14, J37 | DF1B-2P-2.5DSA | 2 | USB | J18 | USB B (ED90064-ND) | 1 | Balanced Detector | J20 | CONN FPC/FFC 12POS 1MM R/A | 1 | PPLN | J21 | DF1B-2P-2.5DSA | 1 | STAGE1 ENC | J23 | DF1B-6DP-2.5DSA | 1 | STAGE2 ENC | J24 | DF1B-6DP-2.5DSA | 1 | STAGE3 ENC | J25 | DF1B-6DP-2.5DSA | 1 | STAGE4 ENC | J26 | DF1B-6DP-2.5DSA | 1 | STAGE1 CTL | J27 | DF1B-8DP-2.5DSA | 1 | STAGE2 CTL | J28 | DF1B-8DP-2.5DSA | 1 | STAGE3 CTL | J29 | DF1B-8DP-2.5DSA | 1 | STAGE4 CTL | J30 | DF1B-8DP-2.5DSA | 1 | HYGROMETER | J31 | BLKCON.100/VH/TM1SQS/W.100/4 | 1 | DETECTOR MODULE | J32 | DF1B-10DP-2.5DSA_REV1 | 1 | RGB LED | J33 | DF1B-4P-2.5DSA | 1 | STAGE5 CTL | J34 | DF1B-8DP-2.5DSA | 1 | STAGE5 ENC | J35 | DF1B-6DP-2.5DSA | 1 | 490-PD-40S | J36 | 490-PD-40S | 1 | 常闭触点 | J38 | DF1B-2P-2.5DSA | 1 | 常开触点 | J39 | DF1B-2P-2.5DSA | 1 | 二次开发I/O | J40 | 4x1 2.54mm DIP Header | 1 | Enc1A | JP1 | SOLDER JUMPER | 1 | Enc1B | JP2 | SOLDER JUMPER | 1 | Enc2A | JP3 | SOLDER JUMPER | 1 | Enc2B | JP4 | SOLDER JUMPER | 1 | Enc3A | JP5 | SOLDER JUMPER | 1 | Enc3B | JP6 | SOLDER JUMPER | 1 | Enc4A | JP7 | SOLDER JUMPER | 1 | Enc4B | JP8 | SOLDER JUMPER | 1 | | JP9 | SOLDER JUMPER | 1 | Enc5A | JP10 | SOLDER JUMPER | 1 | Enc5B | JP11 | SOLDER JUMPER | 1 | TRG SEL 1 | JP12 | SOLDER JUMPER | 1 | TRG SEL 2 | JP13 | SOLDER JUMPER | 1 | TTL_O SEL 1 | JP15 | SOLDER JUMPER | 1 | TTL_O SEL 2 | JP16, JP18 | SOLDER JUMPER | 2 | TTL_I SEL 1 | JP17 | SOLDER JUMPER | 1 | SLF7045T-100M1R3 | L1, L3, L5 | L-SMD-7 | 3 | BEAD FERRITE | L4 | SM/R_0805_REV3 | 1 | Signal Relay | LS1, LS2 | SMD RELAY | 2 | M HOLE1 | MH1, MH2, MH3, MH4, MH6 | MT HOLE 4-40 | 5 | M HOLE1 | MH7 | HOLE-M3 | 1 | BC817-40L | Q3, Q4 | SOT-23 | 2 | 2K adj | R1, R3 | VRES16 | 2 | 220 | R4 | SMD_0603 | 1 | 470 | R5, R6, R7, R13, R14, R15, R24 | SM/R_0805 | 7 | 470 | R8, R11, R41 | SMD_0603 | 3 | 10K | R9, R10, R16, R18, R20, R26, R28, R29, R55, R58, R59 | SM/R_0805 | 11 | 0 | R12, R27 | SM/R_0805 | 2 | 47K | R17 | SMT RES 0805 | 1 | 1K | R19 | SM/R_0805 | 1 | 470 | R21, R22 | SMT RES 0805 | 2 | 1k 1/2w | R40 | 1210 | 1 | 10 | R52, R53 | SM/R_0805 | 2 | 16.9K | R54 | SM/R_0805 | 1 | 12K | R56 | SM/R_0805 | 1 | 2K | R57 | SM/R_0805 | 1 | POWER SWITCH | SW1 | DF1B-2P-2.5DSA | 1 | HVM TEST | TP1 | SMD_TESTPOINT | 1 | +5VA | TP2 | DIP testpoint | 1 | -5VA | TP3 | DIP testpoint | 1 | AGND | TP4 | DIP testpoint | 1 | TLV272CDR | U1 | SOP8 | 1 | 4N29 | U2 | DIP.100B/6/W.300/L.450 | 1 | LM317AEMP | U3 | SOT-223 | 1 | EMCO C02 | U4 | EMCO C02 | 1 | MAX3223/SO | U5 | SOG.65M/20/WG8.20/L6.98 | 1 | 6N137 | U6, U9 | 6N137 | 2 | SN65HVD11D | U7 | SOG.050/8/WG.244/L.175 | 1 | MSP430F5438 | U8 | QUAD.50M/100/WG16.00 | 1 | TLV272CDR | U10 | SOG.050/8/WG.244/L.175 | 1 | L7805CD | U12 | DPAK | 1 | SN74LVC1G125DRLR/SOT-5 | U23, U24 | SM/SOT25_12345 | 2 | FT2232HQ | U28 | QUAD.50M/64/WG12.00 | 1 | 93LC56B | U29 | SOT-23-6 | 1 | SN74LVC1G14DRLR/SOT-5 | U31 | SM/SOT25_12345 | 1 | L7805/DPAK | U32 | SM/_DPAK_REV1 | 1 | AMS1117-3.3 | U33 | SOT-223 | 1 | DL-6PC | U34, U38 | 直插式电源滤波器 | 2 | WRA1209S-3WR2 | U35 | WRA1209S-3WR2 | 1 | L7805CD2T-TR | U36 | D2PAK | 1 | L7905CD2T-TR | U37 | D2PAK | 1 | 7.3728MHz | Y1 | SMD CRYSTAL_REV2 | 1 | 12MHz | Y2 | SMD CRYSTAL | 1 | 附件:
/ G8 r' K! n" Y+ e5 mPCB源文件如下:- B- W2 P1 k2 ^! m9 t" M
/ r& `$ `& E' A4 ^) L8 a( e- R& m( |
