Bill of Material Report (Condensed) | | | | | |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
ANT-GPS | ANTENNA_GPS_ANT-GPS_GPS1003 | GPS1003 | IC | 1 | E1 |
ANT-PF | ANTENNA_WIFI_ANT-PF_PF1004 | PF1004 | IC | 1 | E2 |
AXK824145 | CONN24_AXK824145_AXK724147G | axk724147g | IC | 1 | J15 |
BEAD0402 | INDUCTOR_BEAD0402_BLM15AG221SN1 | BLM15AG221SN1D | IC | 3 | L20; L22; L25 |
BMA250 | BMA250_BMA250_BMA250 | BMA250 | IC | 1 | U43 |
C0402 | CAP NP_C0402_18PF | 18pF | IC | 7 | C1; C2; C258; C271; C272; C275; C276 |
C0402 | CAP NP_C0402_100NF | 100NF | IC | 105 | C3; C4; C8; C9; C12; C13; C14; C19; C20; C21; C26; C27; C28; C33; C34; C37; C39; C41; C43; C45; C46; C49; C54; C57; C59; C62; C63; C65; C67; C70; C71; C74; C75; C77; C80; C82; C84; C87; C89; C92; C94; C96; C98; C100; C103; C105; C108; C110; C112; C174; C175; C177; C180; C186; C187; C188; C189; C190; C191; C192; C193; C223; C224; C225; C226; C228; C230; C232; C233; C236; C241; C243; C244; C255; C266; C269; C270; C274; C277; C281; C282; C283; C286; C290; C292; C297; C298; C300; C302; C303; C304; C305; C306; C308; C309; C311; C312; C330; C331; C333; C334; C337; C338; C339; C340 |
C0402 | CAP NP_C0402_3.2NF | 3.2NF | IC | 2 | C5; C6 |
C0402 | CAP NP_C0402_2NF | 2NF | IC | 1 | C7 |
C0402 | CAP NP_C0402_10NF | 10NF | IC | 11 | C15; C16; C22; C23; C29; C30; C35; C185; C234; C307; C335 |
C0402 | CAP NP_C0402_2.2UF | 2.2UF | IC | 27 | C36; C52; C56; C58; C73; C76; C79; C251; C263; C264; C265; C278; C279; C284; C285; C288; C289; C291; C313; C314; C315; C317; C318; C319; C322; C323; C332 |
C0402 | CAP NP_C0402_1NF | 1NF | IC | 23 | C38; C40; C42; C47; C48; C50; C53; C55; C69; C72; C78; C83; C85; C88; C90; C93; C97; C99; C101; C104; C106; C109; C111 |
C0402 | CAP NP_C0402_1UF | 1UF | IC | 29 | C60; C61; C64; C66; C181; C184; C195; C202; C203; C204; C205; C206; C218; C220; C222; C242; C248; C250; C256; C259; C260; C261; C262; C320; C324; C325; C326; C327; C336 |
C0402 | CAP NP_C0402_10UF | 10UF | IC | 1 | C68 |
C0402 | CAP NP_C0402_220PF | 220PF | IC | 1 | C118 |
C0402 | CAP NP_C0402_22PF | 22PF | IC | 4 | C121; C122; C267; C268 |
C0402 | CAP NP_C0402_0.1UF | 0.1UF | IC | 4 | C194; C212; C213; C215 |
C0402 | CAP NP_C0402_2.2UF/10V | 2.2uF/10V | IC | 2 | C196; C198 |
C0402 | CAP NP_C0402_680PF | 680PF | IC | 1 | C197 |
C0402 | CAP NP_C0402_N.M. | N.M. | IC | 4 | C199; C209; C221; C273 |
C0402 | CAP NP_C0402_1UF/25V | 1uF/25V | IC | 1 | C200 |
C0402 | CAP NP_C0402_0.47UF | 0.47UF | IC | 4 | C201; C208; C217; C321 |
C0402 | CAP NP_C0402_82NF | 82NF | IC | 1 | C216 |
C0402 | CAP NP_C0402_100PF | 100PF | IC | 2 | C257; C280 |
C0402 | CAP NP_C0402_3.9PF | 3.9PF | IC | 1 | C287 |
C0402 | CAP NP_C0402_15PF | 15PF | IC | 2 | C293; C294 |
C0402 | CAP NP_C0402_1PF | 1PF | IC | 1 | C295 |
C0402 | CAP NP_C0402_4PF | 4PF | IC | 1 | C296 |
C0402 | CAP NP_C0402_220NF | 220NF | IC | 1 | C299 |
C0402 | CAP NP_C0402_2.2NF | 2.2NF | IC | 1 | C310 |
C0402 | CAP NP_C0402_47PF | 47PF | IC | 1 | C328 |
C0402 | CAP NP_C0402_CAP NP | CAP NP | IC | 1 | C341 |
C0402 | CAP NP_C0402_0R | 0R | IC | 1 | FC1 |
C0402 | R_C0402_4.7K | 4.7K | IC | 1 | R225 |
C0402 | R_C0402_33R | 33R | IC | 2 | R226; R227 |
C0402 | R_C0402_N.M. | N.M. | IC | 1 | R228 |
C0402 | CAP NP_C0402_33NH | 33nH | IC | 2 | X_FC1; X_FC2 |
C0603 | CAP NP_C0603_10UF | 10UF | IC | 46 | C10; C11; C17; C18; C24; C25; C31; C32; C44; C51; C81; C86; C91; C95; C102; C107; C114; C115; C116; C120; C123; C125; C126; C127; C133; C134; C140; C141; C142; C143; C144; C145; C155; C178; C182; C183; C207; C210; C211; C214; C219; C227; C229; C231; C235; C329 |
C0603 | CAP NP_C0603_4.7UF | 4.7UF | IC | 19 | C113; C119; C124; C128; C129; C130; C131; C132; C176; C179; C245; C246; C247; C249; C252; C253; C254; C301; C342 |
C0603 | CAP NP_C0603_100NF | 100NF | IC | 1 | C117 |
C0603 | CAP NP_C0603_1UF | 1UF | IC | 32 | C135; C136; C137; C138; C139; C146; C147; C148; C149; C150; C151; C152; C153; C154; C156; C157; C158; C159; C160; C161; C162; C163; C164; C165; C166; C167; C168; C169; C170; C171; C172; C173 |
CIG21L | INDUCTOR_CIG21L_CIG21L4R7MNE | CIG21L4R7MNE | IC | 1 | L1 |
CIG22L | INDUCTOR_CIG22L_CIG22H1R0MNE | CIG22H1R0MNE | IC | 6 | L3; L4; L5; L6; L7; L8 |
DCJ-065D | DC_0_DCJ-065D_DCJ-065D | DCJ-065D | IC | 1 | J2 |
DFN-10 | SP6685_DFN-10_SP6686ER-L | SP6686ER-L | IC | 1 | U46 |
FH19C-07S-05SH | CON9_0_FH19C-07S-05SH_FPC0515-0 | FPC0515-07-RL-XXX | IC | 1 | J17 |
FH19C-09S-05SH | CON9_FH19C-09S-05SH_FPC0515-09- | FPC0515-09-RL-XXX | IC | 1 | J6 |
FH19SC-40S-05SH | GB5RF40*-1151-7H_FH19SC-40S-05S | FP09-04403-XXX | IC | 1 | J5 |
FPC0515-24-RL-XXX | CON24_FPC0515-24-RL-XXX_FPC0515 | FPC0515-24-RL-XXX | IC | 1 | J12 |
FXMA2102 | FXLA102_FXMA2102_FXLA102 | FXLA102 | IC | 5 | U7; U9; U10; U11; U22 |
FXMA2102 | FXMA2102_FXMA2102_FXMA2102 | FXMA2102 | IC | 1 | U40 |
GNS7560 | GNS7560_GNS7560_GNS7560 | GNS7560 | IC | 1 | U36 |
GSM2804 | ANTENNA_GSM_GSM2804_GSM2804 | GSM2804 | IC | 1 | E3 |
HDMI-19P | CONN_MHDMI_19P_HDMI-19P_IO_0091 | 0091BAAG19Q | IO | 1 | J7 |
HMC5883L | HMC5883L_HMC5883L_HMC5883L | HMC5883L | IC | 1 | U39 |
J135 | PHONEJACK STEREO SW_J135_J135-1 | J135-140206-09G | IC | 1 | J9 |
KMCMG000M-B9980 | KMCMG000M-B9980_0_KMCMG000M-B99 | KMCMG000M-B9980 | IC | 1 | U26 |
LGA104_30_39X17_56MM | UNA MODULE-OPEN FRAME_LGA104_30 | UNA Module-open frame | IC | 1 | U8 |
LQH44PN | INDUCTOR_LQH44PN_LQH44PN1R0NPO | LQH44PN1R0NPO | IC | 1 | L13 |
LQH44PN | INDUCTOR_LQH44PN_LQH44PN4R7MP0 | LQH44PN4R7MP0 | IC | 1 | L14 |
LQH44PN | INDUCTOR_LQH44PN_LQH44PN100MP0 | LQH44PN100MP0 | IC | 1 | L15 |
LQM2MPN | INDUCTOR_LQM2MPN_LQM2MPN1R0NG0 | LQM2MPN1R0NG0 | IC | 5 | L2; L9; L10; L11; L12 |
LTPL-C064WD | LED_3_LTPL-C064WD_LTPL-C064WD | LTPL-C064WD | IC | 1 | D16 |
LTR-558ALS-01 | LTR-558ALS-01_LTR-558ALS-01_LTR | LTR-558ALS-01 | IC | 1 | U51 |
MAX2659 | BGU7005_MAX2659_BGU7005 | BGU7005 | IC | 1 | U35 |
MAX17040 | MAX17040_MAX17040_MAX17040 | MAX17040 | IC | 1 | U6 |
MIC-BGA4 | SM0401L-MF422-M02_MIC-BGA4_SM04 | SM0401L-MF422-M02 | IC | 1 | U33 |
MPU30X0 | MPU_3050_MPU30X0_MPU_3050 | MPU_3050 | IC | 1 | U44 |
MS412FE | BATTERY_MS412FE_MS412FE-FL26E | MS412FE-FL26E | IC | 1 | BT1 |
PAD-2 | CON2_PAD-2_CON2 | CON2 | IC | 3 | J10; J11; J14 |
PAD-3 | CON3_PAD-3_CON3 | CON3 | IC | 1 | J1 |
QFN10_1_8X1_4 | ST2329AQTR_QFN10_1_8X1_4_ST2329 | ST2329AQTR | IC | 2 | U2; U25 |
QFN10_1_8X1_4 | ST2129QTR_QFN10_1_8X1_4_ST2129Q | ST2129QTR | IC | 1 | U19 |
QFN28_4X4 | MAX8903AETI_QFN28_4X4_MAX8903AE | MAX8903AETI | IC | 1 | U5 |
R0402 | LED_R0402_LED | LED | IC | 2 | D3; D4 |
R0402 | INDUCTOR_R0402_BLM15AG221SN1D | BLM15AG221SN1D | IC | 1 | L16 |
R0402 | INDUCTOR_R0402_100UH | 100UH | IC | 3 | L17; L18; L19 |
R0402 | INDUCTOR_R0402_5.6NH | 5.6NH | IC | 1 | L21 |
R0402 | INDUCTOR_R0402_3.3NH | 3.3NH | IC | 1 | L23 |
R0402 | INDUCTOR_R0402_100NH | 100NH | IC | 1 | L24 |
R0402 | R_R0402_1M | 1M | IC | 2 | R1; R134 |
R0402 | R_R0402_100K | 100K | IC | 25 | R2; R23; R38; R52; R54; R56; R57; R98; R99; R105; R106; R111; R112; R126; R129; R136; R137; R139; R173; R203; R215; R232; R245; R257; R281 |
R0402 | R_R0402_100R | 100R | IC | 1 | R3 |
R0402 | R_R0402_0R | 0R | IC | 65 | R4; R5; R22; R28; R31; R40; R41; R42; R43; R44; R45; R48; R50; R60; R61; R62; R84; R91; R92; R93; R94; R113; R123; R124; R135; R151; R153; R192; R194; R199; R205; R206; R207; R208; R209; R210; R211; R212; R214; R216; R217; R219; R220; R222; R229; R230; R234; R235; R236; R242; R246; R247; R248; R249; R254; R255; R261; R263; R266; R268; R269; R270; R277; R289; R301 |
R0402 | R_R0402_N.M. | N.M. | IC | 34 | R6; R36; R39; R46; R47; R49; R51; R53; R55; R58; R59; R64; R65; R87; R102; R107; R108; R109; R141; R142; R144; R213; R224; R231; R233; R243; R244; R258; R259; R260; R262; R264; R290; R300 |
R0402 | R_R0402_44.2R | 44.2R | IC | 1 | R7 |
R0402 | R_R0402_10K | 10K | IC | 17 | R8; R9; R110; R143; R146; R162; R169; R182; R195; R240; R256; R265; R278; R282; R283; R298; R299 |
R0402 | R_R0402_1K | 1K | IC | 31 | R10; R11; R12; R13; R14; R15; R16; R17; R18; R19; R24; R114; R125; R127; R131; R133; R147; R163; R164; R170; R171; R174; R175; R176; R177; R204; R218; R223; R250; R251; R293 |
R0402 | R_R0402_4.7K | 4.7K | IC | 8 | R20; R21; R25; R37; R145; R252; R253; R295 |
R0402 | R_R0402_20K | 20K | IC | 5 | R26; R29; R30; R34; R138 |
R0402 | R_R0402_240R | 240R | IC | 6 | R27; R32; R33; R35; R95; R96 |
R0402 | R_R0402_200K | 200K | IC | 7 | R77; R79; R86; R159; R165; R166; R292 |
R0402 | R_R0402_15K | 15K | IC | 2 | R78; R156 |
R0402 | R_R0402_800K | 800K | IC | 2 | R89; R100 |
R0402 | R_R0402_220K | 220K | IC | 1 | R97 |
R0402 | R_R0402_124K | 124K | IC | 1 | R101 |
R0402 | R_R0402_750R | 750R | IC | 1 | R103 |
R0402 | R_R0402_3K | 3K | IC | 1 | R104 |
R0402 | R_R0402_150R | 150R | IC | 1 | R118 |
R0402 | R_R0402_R | R | IC | 5 | R119; R128; R273; R274; R286 |
R0402 | R_R0402_150K | 150K | IC | 1 | R130 |
R0402 | R_R0402_7.5K | 7.5K | IC | 1 | R132 |
R0402 | R_R0402_0.57R | 0.57R | IC | 1 | R140 |
R0402 | R_R0402_5.1K | 5.1K | IC | 3 | R148; R150; R152 |
R0402 | R_R0402_470K | 470K | IC | 1 | R149 |
R0402 | R_R0402_36K | 36K | IC | 2 | R154; R155 |
R0402 | R_R0402_2K | 2K | IC | 1 | R158 |
R0402 | R_R0402_6.8K | 6.8K | IC | 1 | R160 |
R0402 | R_R0402_698R | 698R | IC | 1 | R161 |
R0402 | R_R0402_1.38K | 1.38K | IC | 1 | R167 |
R0402 | R_R0402_330R | 330R | IC | 1 | R168 |
R0402 | R_R0402_47K | 47K | IC | 21 | R172; R179; R180; R181; R183; R184; R185; R186; R187; R188; R189; R190; R191; R193; R237; R238; R239; R241; R291; R296; R297 |
R0402 | R_R0402_33R | 33R | IC | 3 | R178; R287; R294 |
R0402 | R_R0402_680R | 680R | IC | 1 | R221 |
R0402 | R_R0402_106K | 106K | IC | 1 | R275 |
R0402 | R_R0402_12K | 12K | IC | 1 | R288 |
R0603 | R_R0603_0.33R | 0.33R | IC | 1 | R276 |
RCLAMP0506T | RCLAMP0506T_RCLAMP0506T_RCLAMP0 | RCLAMP0506T | IC | 1 | U27 |
RCLAMP0544T | RCLAMP0544T_RCLAMP0544T_RCLAMP0 | RCLAMP0544T | IC | 2 | U23; U24 |
RCLAMP2431T | DIODE TVS_RCLAMP2431T_UCLAMP050 | UCLAMP0501T | IC | 4 | D15; D17; D18; D19 |
RCLAMP3304P | RCLAMP3304P_RCLAMP3304P_RCLAMP3 | rclamp3304p | IC | 2 | U13; U29 |
RCLAMP3624T | RCLAMP3624T_RCLAMP3624T_RCLAMP3 | RCLAMP3624T | IC | 1 | U31 |
S5M8767 | S5M8767A_S5M8767_S5M8767 | S5M8767 | IC | 1 | U4 |
S5PC220 | S5PC220_S5PC220_S5PC220 | S5PC220 | IC | 1 | U1 |
SAFEB1G57K0F00 | SAFEB1G57KB0F00_SAFEB1G57K0F00_ | SAFEB1G57KB0F00 | IC | 1 | U34 |
SB07-03C | DIODE SCHOTTKY_0_SB07-03C_SB07- | SB07-03C | IC | 3 | D6; D10; D20 |
SC-59 | NPN_SC-59_IC_MMST3906 | MMST3906 | IC | 2 | Q7; Q9 |
SC-59 | NPN EBC_SC-59_MMST3904 | MMST3904 | IC | 2 | Q24; Q25 |
SC-75 | PNP_SC-75_IC_2PA1774 | 2PA1774 | IC | 1 | Q2 |
SC-75 | DTC114EET1_SC-75_DTC114EET1G | DTC114EET1G | IC | 1 | Q3 |
SC-75 | NPN_0_SC-75_IC_PBSS2515E | PBSS2515E | IC | 1 | Q12 |
SC-75 | MOSFET P_0_SC-75_NTA4151P | NTA4151P | IC | 1 | Q14 |
SC-75 | MOSFET P_1_SC-75_NTA4151P | NTA4151P | IC | 1 | Q16 |
SIMCARD | SIM CARD_SIMCARD_SIM CARD | SIM CARD | IC | 1 | J16 |
SLP2010P4T | RCLAMP0522T_SLP2010P4T_RCLAMP05 | RCLAMP0522T | IC | 1 | U18 |
SLP2010P8T | RCLAMP0544T_SLP2010P8T_RCLAMP05 | RCLAMP0544T | IC | 2 | U15; U17 |
SN75LVDS83BZQLR | SN75LVDS83BZQLR_SN75LVDS83BZQLR | SN75LVDS83BZQLR | IC | 1 | U14 |
SOD-323 | DIODE SCHOTTKY_SOD-323_UDZ5.6B | UDZ5.6B | IC | 2 | D9; D13 |
SOD-523 | DIODE TVS_SOD-523_UCLAMP1201H | uClamp1201H | IC | 3 | D1; D2; D5 |
SOT23 | MOSFET N_0_SOT23_MOSFET N | MOSFET N | IC | 1 | Q8 |
SOT23-6_0_95MM | SGM6600_SOT23-6_0_95MM_SGM6603- | SGM6603-5.0YN6G/TR | IC | 1 | U3 |
SOT23-6_0_95MM | FP6745_SOT23-6_0_95MM_FP6745S8G | FP6745S8G | IC | 1 | U16 |
SOT23-6_0_95MM | ALPU-MR_SOT23-6_0_95MM_ALPU-MR | ALPU-MR | IC | 1 | U41 |
SOT23_5 | RP100N121D_SOT23_5_RP100N121D | RP100N121D | IC | 1 | U37 |
SOT23_5 | MAX6412_SOT23_5_MAX6412 | MAX6412 | IC | 1 | U50 |
SOT323 | ZC2812E/SOT_0_SOT323_DAN217U | DAN217U | IC | 1 | D7 |
SOT323 | ZC2812E/SOT_1_SOT323_DAN217U | DAN217U | IC | 1 | D8 |
SOT323 | ZC2812E/SOT_2_SOT323_DAN217U | DAN217U | IC | 1 | D11 |
SOT323 | ZC2812E/SOT_3_SOT323_DAN217U | DAN217U | IC | 1 | D12 |
SOT323 | BAV99W_SOT323_BAV99W | BAV99W | IC | 1 | U49 |
SOT416 | PDTC114YE_SOT416_PDTC114YE | PDTC114YE | IC | 5 | Q1; Q10; Q11; Q13; Q15 |
SOT-363 | DUAL MOSFET_SOT-363_NTJD4105CT1 | NTJD4105CT1G | IC | 1 | Q4 |
SWB-A31 | SWB-A31_SWB-A31_SWB-A31 | SWB-A31 | IC | 1 | U38 |
TCM1210 | TCM1210_TCM1210_TCM1210 | TCM1210 | IC | 7 | FB1; FB2; FB3; FB4; FB5; FB6; FB7 |
TCXO_16M368_2520 | TCXO_TCXO_16M368_2520_NT2520SA1 | NT2520SA16.368MHZ | IC | 1 | Y3 |
TFCARD | CONN_TF_TFCARD_TOPP-150108-05G | TOPP-150108-05G | IC | 1 | J8 |
TP | TEST PAD_TP_IC_TEST POINT | TEST POINT | IC | 15 | TP1; TP2; TP3; TP4; TP5; TP8; TP9; TP10; TP27; TP28; TP29; TP30; TP31; TP32; TP33 |
TP | TEST PAD_TP_IC_TEST PAD | Test pad | IC | 17 | TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP34 |
TSSOP-8 | FP6791_TSSOP-8_FP6791 | FP6791 | IC | 1 | U20 |
USB3503A | USB3503A_USB3503A_USB3503A | USB3503A | IC | 1 | U47 |
USB-MICRO | CONN-MICROUSB_USB-MICRO_MR0F-17 | MR0F-170205-04G | IC | 1 | J13 |
WM8994 | WM8994_WM8994_WM8994 | WM8994 | IC | 1 | U32 |
XTAL_2012 | XM/SM_XTAL_2012_XTAL_32K736_201 | XTAL_32K736_2012 | IC | 1 | Y2 |
XTAL_2520 | NZ2520SD12MHZ_XTAL_2520_NZ2520S | NZ2520SD12MHZ | IC | 1 | X1 |
XTAL_3225 | XTAL_XTAL_3225_7V26000012 | 7V26000012 | IC | 1 | X2 |
XTAL_3225 | XTAL_XTAL_3225_DSX321G26MHZ | DSX321G26MHZ | IC | 1 | X3 |
XTAL_3225 | CRYSTAL4/SM_0_XTAL_3225_XTAL_24 | XTAL_24M | IC | 1 | Y1 |
