Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
BGA6X13-P8-12P75 | EDJ1108DBSE_0_BGA6X13-P8-12P75_ | MT41J128M8JP-125:G | IC | 4 | U2; U3; U4; U5 |
C0402 | CAP NP_0_C0402_0.1UF | 0.1uF | IC | 64 | C1; C2; C3; C4; C5; C6; C7; C8; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C99; C100; C101; C102; C103; C104; C105; C106; C108; C109; C110; C111; C112; C113; C114; C115; C116; C117; C118; C119; C121; C122; C123; C124; C125; C126; C127; C128; C151; C157; C158 |
C0402 | C_2_C0402_0.1UF | 0.1uF | IC | 60 | C22; C23; C24; C25; C26; C27; C28; C29; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C64; C65; C66; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C81 |
C0402 | CAP NP_C0402_0.1UF/16V_YC10-000 | 0.1uF/16V | IC | 6 | C130; C135; C138; C144; C145; C147 |
C0402 | CAP NP_C0402_390PF/50V_YC10-001 | 390pF/50V | IC | 1 | C142 |
C0402 | CAP NP_C0402_1.5PF/50V_YC10-001 | 1.5pF/50V | IC | 1 | C146 |
C0402 | CAP NP_0_C0402_0.001UF | 0.001uF | IC | 1 | C149 |
C0402 | CAP NP_0_C0402_1000PF | 1000pF | IC | 1 | C152 |
C0402 | CAP NP_0_C0402_10PF | 10pF | IC | 1 | C159 |
C0603 | CAP NP_C0603_1UF/25V_YC10-00032 | 1uF/25V | IC | 2 | C136; C137 |
C0603 | CAP NP_C0603_3300PF/50V_YC10-00 | 3300pF/50V | IC | 2 | C139; C148 |
C1206 | CAP POL_C1206_10UF/25V_YC10-001 | 10uF/25V | IC | 3 | C131; C132; C143 |
DRC-10 | TPS51200_DRC-10_TPS51200DRCT | TPS51200DRCT | IC | 1 | U7 |
L4040 | INDUCTOR_L4040_1UH/5A_YL10-0003 | 1uH/5A | IC | 1 | L1 |
NSIP4 | CONN RCPT 4/SM_NSIP4_POWER CON | POWER CON | IC | 1 | J1 |
QFN16 | ISL6535CRZ_QFN16_12V PWM_YU00-0 | 12V PWM | IC | 1 | U6 |
R0402 | R_R0402_49.9R | 49.9R | IC | 27 | R1; R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27 |
R0402 | R0201_0_R0402_240R | 240R | IC | 4 | R28; R29; R30; R31 |
R0402 | RES_V_R0402_510 OHM_YR10-00318- | 510 ohm | IC | 1 | R33 |
R0402 | RES_V_R0402_10K_YR10-00066-100 | 10K | IC | 4 | R34; R35; R38; R42 |
R0402 | RES_V_R0402_11K8_YR10-00311-000 | 11K8 | IC | 1 | R37 |
R0402 | RES_V_R0402_4K7_YR10-00091-100 | 4K7 | IC | 1 | R40 |
R0402 | RES_V_R0402_120K_YR10-00154-100 | 120K | IC | 1 | R41 |
R0402 | R_R0402_10K | 10K | IC | 3 | R45; R47; R49 |
R0402 | R_R0402_100K | 100K | IC | 1 | R46 |
R0402 | R_R0402_10R | 10R | IC | 1 | R48 |
R0603 | RES_V_R0603_2.2 OHM_YR10-00131- | 2.2 ohm | IC | 2 | R32; R36 |
R0603 | RES_V_R0603_31K6_YR10-00241-100 | 31K6 | IC | 1 | R39 |
R0603 | RES_V_R0603_2K2_YR10-00202-100 | 2K2 | IC | 2 | R43; R44 |
SKTBGA-1031-37X37_C9212_P65MM | 816X_0_SKTBGA-1031-37X37_C9212_ | Controller IC | IC | 1 | U1 |
SO8-MOSFET | SI468DP-T1-GE3_6_SO8-MOSFET_30V | 30V/40A NCh | IC | 1 | Q1 |
SO8-MOSFET | SI468DP-T1-GE3_6_SO8-MOSFET_3_1 | 30V/60A NCh | IC | 1 | Q2 |
SOD123 | MBR05030T1G_8_SOD123_30V/0A5_YD | 30V/0A5 | IC | 1 | D1 |
TC3216 | CAP_0_TC3216_33UF | 33uF | IC | 8 | C82; C83; C84; C85; C98; C107; C120; C129 |
TC3216 | CAP_0_TC3216_10UF | 10uF | IC | 1 | C150 |
TC3216 | CAP_0_TC3216_10UF/16V 10% | 10uF/16V 10% | IC | 2 | C155; C156 |
TC3528 | CAP_0_TC3528_100UF/6.3V 10% | 100uF/6.3V 10% | IC | 2 | C153; C154 |
TC7343 | CAP POL_TC7343_270UF/16V_YC20-0 | 270uF/16V | IC | 2 | C133; C134 |
TC7343 | CAP POL_TC7343_470UF/6.3V_YC20- | 470uF/6.3V | IC | 2 | C140; C141 |
