作品名:[AD 9][4层] 集电源、 DSP、FLASH、USB等为一体的设计(TMS320F28335+TPS75701KTT+IS61LV51216-10TI)原理图和PCB源文件 & b D' g7 i! f% j: K9 b7 m
文件描述 2. 软件版本:AD 9 3. 层数:4层板 4. 用到的主要芯片:TMS320F28335+TPS75701KTT+IS61LV51216-10TI 5. PCB尺寸:76.5mm*63.5mm
5 E* D* u3 m3 B作品截图如下: 顶层截图:
N- L D% Z' y5 |6 l* C底层截图: 全层截图: 2 p: y" a2 O( z2 w/ p
叠层信息截图如下: . S. B/ S' }& U6 x4 A7 r
BOM: Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | Cap | C1, C28, C36 | 6-0805_L | 3 | 0.1uF | C2, C17, C18, C19, C20, C21, C22, C23, C24, C25, C26, C27, C29, C30, C31, C32, C33, C34, C35, C37, C38, C39, C40, C41, C42, C43, C44, C48, C49 | 1608[0603] | 29 | Cap | C3, C15, C16 | 1608[0603] | 3 | 10uF | C4, C6 | 1206 | 2 | 0.1uF | C5, C7 | 0603 | 2 | 330pF | C47 | 1608[0603] | 1 | Cap | CY1, CY2 | 0603 | 2 | LED3 | D1, D2 | SMD _LED | 2 | Comment | Designator34, Designator35 | PLACEHOLE | 2 | Inductor | FB1, FB2, FB3, FB4, FB5 | C1206 | 5 | HEADER 7X2 | J11 | IDC-14 | 1 | Header 14 | JP1 | HDR1X14 | 1 | Header 18 | JP2 | HDR1X18 | 1 | 100 | R1 | 0805 | 1 | 30K | R2 | 0805 | 1 | Res1 | R5, R6, R7, R12, R17, R18, R19, R20 | 1608[0603] | 8 | 2.2K | R14, R15, R16 | 1608[0603] | 3 | Res1 | RY1 | 0603 | 1 | SW-PB | S1 | 3*6*2.5 | 1 | TMS320F28335 | U1 | PQFP-176 | 1 | TPS75701KTT | U2 | TPS301 | 1 | IS61LV51216-10TI | U3 | TSOP-44 | 1 | XTAL | Y1 | SMD-CRYSTAL-2POLE | 1 |
/ d; Z7 A' x5 \8 W' n( V附件: 原理图和PCB源文件如下:
- U& \' p: p3 Y! s9 S9 P
. t: `/ x: B+ t! }1 Z, n0 y% G |
